[二次开发源码] UG二次开发源码-链轮齿轮标准件创建VB源码
2014-4-25 20:51:15 4808 0
发表于 2014-4-25 20:51:15 | 显示全部楼层 |阅读模式
UG二次开发源码-链轮齿轮标准件创建VB源码 ! C* L: g; o3 z
感觉还不错,VB写的分享下,只是这里没有使用渐开线的方式画齿轮!
5 _6 |' N. T1 E, v; ?3 _1 N  M) g4 Q5 p( }! V
[code] Private Function CreateChainGear(ByVal ChainType As String, ByVal Z As Integer) As Integer
# g# K4 H5 M7 ?4 [        Dim errorCode As Integer = 0- e& }  U# l" A# J5 G: n
        Dim p, dr, d, r1, r2, r3, da, d_cut As Double
8 f* Z$ `! S/ \. h8 j' K        Dim alf, Beta, Gama As Double
1 k8 ~# G. @, B1 D- i0 p( ]        Dim M, T, V, W As Double
" ]( _% f" o, D/ n' e        Dim DtoR As Double = PI / 180
# q+ E7 h; l& S8 n9 s        Try% l' h( j) ]# p& t0 r5 j8 a4 [
            Select Case ChainType4 x0 k% F# G% f# o; n7 s) ?3 s* `: d2 e
                Case "06B"
9 E' r) K. c" g# \3 b( x/ |                    p = 9.525
- G  s! G1 A- h- T4 ^                    dr = 6.35
; a' R- g+ t' z( k$ S+ a                Case "08A"# s, A7 D6 J# A- D( r/ [7 O
                    p = 12.7
5 s) m- B! b& a  H$ i                    dr = 7.95
' `5 z. A! ^6 A( q                Case "08B"
  z' f0 s" i2 W" j9 `4 @0 v                    p = 12.7
, q* J9 Q/ z" t% ]5 J- ]                    dr = 8.51# O3 }" V& j2 w  X) [3 P% m
                Case "10A"  f. ?* X( ?6 }! O
                    p = 15.8751 x/ i0 Y# F* ~& z* `
                    dr = 10.16- g- ]) o, H3 ]. ?% b) W
            End Select$ k. G6 o6 Z' S! B5 F
: @) A& W) Q; L
            alf = (55 - 60 / Z) * DtoR
  R- S0 r  s! Q( s! s! x. }" N            Beta = (18 - 56 / Z) * DtoR$ t* B. Y$ W# G  x/ y, c
            Gama = (17 - 64 / Z) * DtoR9 ]. ~3 b$ b! D+ ?
            r1 = 0.5025 * dr + 0.05
* r8 t) V0 B, h* D, e5 l            r2 = 1.3025 * dr + 0.05
, o/ i" W$ w4 V& B5 i& G            r3 = dr * (1.3 * Cos(Gama) + 0.8 * Cos(Beta) - 1.3025) - 0.05( t$ W. I7 |  g% O
            M = 0.8 * dr * Sin(alf)" }1 A' _* @' ~! x: |
            T = 0.8 * dr * Cos(alf)
1 B4 L7 h$ p( @% l, h            W = 1.3 * dr * Cos(180 / Z * DtoR)
5 C! {) g( P2 i5 B+ U; g            V = 1.3 * dr * Sin(180 / Z * DtoR)
8 a- C& a) q# H. y1 I. g            d = p / Sin(180 / Z * DtoR)
& V/ k3 u+ @) O" z& |            da = p * (0.54 + 1 / Tan(180 / Z * DtoR))  }5 b8 u. W( u% @) T2 z* e% u) E
            d_cut = p * (1 + 1 / Tan(180 / Z * DtoR))9 Z1 J8 Z/ @# l. F* B
7 I7 Q/ t  j! c# Y
            Dim Point_O, Point_O2, Point_O3, Point_A, Point_B, Point_C, Point_D, Point_E, Point_cut As Point3d
0 M3 V% W0 C. O% Z% r7 L% l            Dim Y_o As Double = d / 2
$ P; c$ i- E: K3 g+ e+ z& I2 W
* m1 y5 t; e, k2 s6 R' l            Point_O = New Point3d(0, Y_o, 0)
) Q) [( y1 R0 _5 D            Point_O2 = New Point3d(-M, Y_o + T, 0)% g9 g9 \4 }- D5 _' q
            Dim point_O2_neg As Point3d = New Point3d(M, Y_o + T, 0)
' h/ l) }# W8 n
: p, e0 e+ X; p/ g5 n% {            Point_O3 = New Point3d(W, Y_o - V, 0)
$ @  g+ q/ }1 Z. B- I$ Z            Dim point_O3_neg As Point3d = New Point3d(-W, Y_o - V, 0)) S, U1 b8 B) \6 L5 H
! p: \' K: }( N' R: ^4 c            Point_A = New Point3d(r1 * Sin(alf), Y_o - r1 * Cos(alf), 0): a! e7 y, A4 f
            Dim Point_A_neg As Point3d = New Point3d(-r1 * Sin(alf), Y_o - r1 * Cos(alf), 0)) u& a3 y, L  a1 _$ D& f
2 E* x2 Y  h& ?! ^0 }, [$ S( W            Point_B = New Point3d(-M + r2 * Sin(alf + Beta), Y_o + T - r2 * Cos(alf + Beta), 0)
+ a3 `  U& H+ ~: N: D# K            Dim Point_B_neg As Point3d = New Point3d(M - r2 * Sin(alf + Beta), Y_o + T - r2 * Cos(alf + Beta), 0)
" i1 o. p' T4 ]1 m
: F4 Z9 ]! L: p            Point_C = New Point3d(W - r3 * Sin(alf + Beta), Y_o - V + r3 * Cos(alf + Beta), 0)6 L  i; r3 Q6 m
            Dim Point_C_neg As Point3d = New Point3d(-W + r3 * Sin(alf + Beta), Y_o - V + r3 * Cos(alf + Beta), 0)! M7 A! L" M- Q1 S# j' r
7 L& a$ Z+ O, C! J- W& ^
            Dim X_d As Double = W - r3 * Cos(90 * DtoR - alf - Beta + Gama)3 D$ i7 m4 w9 s
            Dim Y_d As Double = Y_o - V + r3 * Sin(90 * DtoR - alf - Beta + Gama)2 T: \; ^: d! x2 v" ~( ?
            Point_D = New Point3d(X_d, Y_d, 0)
) W) ^4 u8 t$ ^, F2 P/ G            Dim Point_D_neg As Point3d = New Point3d(-X_d, Y_d, 0)& c2 L3 a' i- p# L" E
" ~" v7 n9 w# s1 C
            Dim Ld As Double = Y_d - X_d / Tan(180 / Z * DtoR)1 Q5 }) l7 a; p4 x- F( v) m: a
            Dim Le As Double = Ld * Cos(180 / Z * DtoR)
* o9 s2 g) E# L+ p2 C/ T
. b" I% c' D8 k6 b+ N/ j( R+ Y            Point_E = New Point3d(X_d + Le * Sin(180 / Z * DtoR), Y_d - Ld + Le * Cos(180 / Z * DtoR), 0)( [& i0 p9 `  |
            Dim Point_E_neg As Point3d = New Point3d(-X_d - Le * Sin(180 / Z * DtoR), Y_d - Ld + Le * Cos(180 / Z * DtoR), 0)
: o* z$ ^4 y# D( _: N" t3 @0 x  w% h0 d5 x
            Point_cut = New Point3d(d_cut / 2 * Sin(180 / Z * DtoR), d_cut / 2 * Cos(180 / Z * DtoR), 0)
, K; G: I. p6 s, b" w            Dim Point_cut_neg As Point3d = New Point3d(-d_cut / 2 * Sin(180 / Z * DtoR), d_cut / 2 * Cos(180 / Z * DtoR), 0)
' D% w$ l3 E* Q5 t0 v
  M  Q; r! @# ~
2 C, K8 l* _. u9 b8 K            theSession.Preferences.SkeTCh.CreateInferredConstraints = False
/ C# E: K4 Y0 [! G! n$ G/ z% v            theSession.Preferences.Sketch.ContinuousAutoDimensioning = False
3 i5 W/ w# a  u+ i1 d, p            Dim workPart As Part = theSession.Parts.Work
% k3 v5 |# }/ U% g" K            Dim nullSketch As Sketch = Nothing
7 l) l, ?8 z5 E9 D            Dim sketchInPlaceBuilder1 As SketchInPlaceBuilder
+ n- `6 d  Y, a% [& K5 y, J            sketchInPlaceBuilder1 = workPart.Sketches.CreateNewSketchInPlaceBuilder(nullSketch)) u5 W2 q# G( I& P
            Dim Cut_sketch As Sketch5 V! L, w" G' C9 E
            Cut_sketch = sketchInPlaceBuilder1.Commit()3 E" u/ O# ]- i. g: H
            Cut_sketch.SetName("Sketch_ChainGear")
# M3 U2 E  X2 w6 B            Cut_sketch.Activate(Sketch.ViewReorient.False)  _8 V( w# J. h
9 r% c# a. {4 ]( A
            Dim NXMatrix1 As NXMatrix
3 P4 D$ _( M( I2 A# d1 M5 S            nXMatrix1 = theSession.ActiveSketch.Orientation2 |, \5 j, c+ z5 P" V
            Dim arc As Arc
/ _- @+ q. I( C& |8 U$ |9 i            arc = workPart.Curves.CreateArc(Point_O, nXMatrix1, r1, -90 * DtoR - alf, -90 * DtoR + alf)
7 @. S6 ?; ?2 T% `            theSession.ActiveSketch.AddGeometry(arc, Sketch.InferConstraintsOption.InferNoConstraints)
7 W+ E8 Q% ^2 `) _8 x0 R+ i( B$ b: P3 ~2 \7 C6 p
            arc = workPart.Curves.CreateArc(Point_O2, nXMatrix1, r2, -90 * DtoR + alf, -90 * DtoR + alf + Beta)/ J6 |/ `4 m1 K/ _
3 t( V5 j+ c+ j% [: y) `$ g: X* W. V
- ?* ?+ O" ?" _2 W            arc = workPart.Curves.CreateArc(point_O2_neg, nXMatrix1, r2, -90 * DtoR - alf - Beta, -90 * DtoR - alf)8 M! i  b9 w" ~' ^5 }
: t+ c1 X9 T) j" j: i2 x8 @5 M  i8 z' Y# R* ?! W
            arc = workPart.Curves.CreateArc(Point_O3, nXMatrix1, r3, 90 * DtoR + alf + Beta - Gama, 90 * DtoR + alf + Beta)
: x. c& U6 G% h, v+ V' h. z            theSession.ActiveSketch.AddGeometry(arc, Sketch.InferConstraintsOption.InferNoConstraints)
* Q+ _, G3 m6 l6 c7 g0 e: _' H- ~, j9 A- h" l) }$ e/ p
            arc = workPart.Curves.CreateArc(point_O3_neg, nXMatrix1, r3, 90 * DtoR - alf - Beta, 90 * DtoR - alf - Beta + Gama)$ r4 ]( d) ?$ x$ [7 L) F
; l" n  b" L1 y8 c
9 z  G" r, v$ F$ U% y            Dim line1 As Line
& X: N7 y% o' P# ~
0 l- I0 I+ U' U; v) }2 l            line1 = workPart.Curves.CreateLine(Point_B, Point_C)
( c1 E0 I! c3 Z, B0 [            theSession.ActiveSketch.AddGeometry(line1, Sketch.InferConstraintsOption.InferNoConstraints)) l* F+ ?  n+ ^5 M# d
            line1 = workPart.Curves.CreateLine(Point_B_neg, Point_C_neg)
& p0 N2 [* i9 G0 A& p            theSession.ActiveSketch.AddGeometry(line1, Sketch.InferConstraintsOption.InferNoConstraints)# i* Z1 b- k* b
9 e0 p) w, a/ n6 `9 ~/ u0 m            line1 = workPart.Curves.CreateLine(Point_D, Point_E)
! ]+ y) C3 A* u) t% i. i            theSession.ActiveSketch.AddGeometry(line1, Sketch.InferConstraintsOption.InferNoConstraints)
- w/ |' s* Y9 g" @            line1 = workPart.Curves.CreateLine(Point_D_neg, Point_E_neg)
% A. u9 D8 @6 g; X5 i            theSession.ActiveSketch.AddGeometry(line1, Sketch.InferConstraintsOption.InferNoConstraints)
4 ?8 H; R" s$ v& v1 |3 F. [+ i5 ]
            line1 = workPart.Curves.CreateLine(Point_E, Point_cut)5 s' n1 j  i! `- l- L+ W( J3 x
8 G6 w# N$ E' @: M6 Q2 |            line1 = workPart.Curves.CreateLine(Point_E_neg, Point_cut_neg)
2 K3 p% F5 o- c3 k            theSession.ActiveSketch.AddGeometry(line1, Sketch.InferConstraintsOption.InferNoConstraints)" x# V8 i  A, K+ ]
/ S" R+ _3 n2 o% |
            Dim Point_center As Point3d = New Point3d(0, 0, 0)
) P2 C# {. w; O$ V            arc = workPart.Curves.CreateArc(Point_center, nXMatrix1, d_cut / 2, (90 - 180 / Z) * DtoR, (90 + 180 / Z) * DtoR)
) `& ]+ A" B. i* ?# Z& J            theSession.ActiveSketch.AddGeometry(arc, Sketch.InferConstraintsOption.InferNoConstraints)
  u  ]2 g1 C) w$ S2 r% K& j
$ T  M9 |6 ]6 f  o            theSession.ActiveSketch.Update()
# I) S6 c9 n$ n/ U0 z            theSession.ActiveSketch.Deactivate(Sketch.ViewReorient.False, Sketch.UpdateLevel.Model)  a( L1 P( F  n. Z; M$ w3 O
) y9 i. h$ ?9 r! {9 s$ z2 x            sketchInPlaceBuilder1 = workPart.Sketches.CreateNewSketchInPlaceBuilder(nullSketch)
. [7 |2 J/ l, h5 k            Dim Circle_sketch As Sketch
* Z- q+ ]. t' p, `            Circle_sketch = sketchInPlaceBuilder1.Commit(); `# O- {: Q$ I3 E+ W
            Circle_sketch.SetName("Sketch_Circle")
4 D" q# T+ h$ q2 C' ?6 r( q; L8 x% M            Circle_sketch.Activate(Sketch.ViewReorient.False)) w8 `1 ?6 C4 d6 t: b& ?2 y
            arc = workPart.Curves.CreateArc(Point_center, nXMatrix1, da / 2, 0, 360 * DtoR)
$ V$ ^$ N1 E( ?* [& p            theSession.ActiveSketch.AddGeometry(arc, Sketch.InferConstraintsOption.InferNoConstraints)
8 t; s( b! \% n2 W9 \3 G            theSession.ActiveSketch.Update()+ q! ]/ o6 {6 U# j% N
4 b4 |& L+ C+ N/ Y
' q* ^# h. v2 e0 C! R9 Q            sketchInPlaceBuilder1.Destroy()1 o8 ?- O* d$ i3 ~2 y: u9 Z
/ a, A& O: S2 U( a* \            Dim nullFeatures_Feature As Features.Feature = Nothing
5 O& @3 [9 t" S8 Y2 V( N            Dim nullNXObject As NXObject = Nothing
, l/ i' h0 Z% w6 D            Dim nullPoint As Point = Nothing; j1 I0 G( c+ ^3 h
) m7 Z4 y5 O8 ], f4 i
            Dim extrudeBuilder1 As Features.ExtrudeBuilder
& Q: ~" x2 X( |/ b            extrudeBuilder1 = workPart.Features.CreateExtrudeBuilder(nullFeatures_Feature)
" _1 b. t, b* S  A; z            extrudeBuilder1.Limits.StartExtend.Value.RightHandSide = "0"  z0 |' ]* D& z. l" _# t, I$ r: @
            extrudeBuilder1.Limits.EndExtend.Value.RightHandSide = "5"5 I: H- N* L" Z
4 @2 F3 \2 e2 i+ t* @& t' Y6 J" o
            Dim targetBodies1(0) As Body' X( ^! O. L) A5 U9 y! g
            Dim nullBody As Body = Nothing
& c5 M2 K! \' n! z            targetBodies1(0) = nullBody5 s. G; i! z- b9 s2 E2 K" C+ o; g9 _
            extrudeBuilder1.BooleanOperation.SetTargetBodies(targetBodies1)6 V' C. c% j' d! l- Q# `
            extrudeBuilder1.BooleanOperation.Type = GeometricUtilities.BooleanOperation.BooleanType.Create
( l  ?5 C, z5 s. j. X
0 h) S  ^( M0 @# B- x! y; Z            Dim section2 As Section1 h+ r" J5 K$ q6 [1 H
            section2 = workPart.Sections.CreateSection(0.02413, 0.0254, 0.5)# a, D' v) N) w
            extrudeBuilder1.Section = section2
6 y7 p, X6 d7 [- a9 f7 J* Z/ v            Dim features2(0) As Features.Feature
' B& e7 i. h6 P, b" T            Dim sketchFeature2 As Features.SketchFeature = Circle_sketch.Feature& S, n9 [8 F! a5 f
            features2(0) = sketchFeature2. b8 |+ a5 Y8 N6 Y+ t8 |0 \8 D
            Dim curveFeatureRule2 As CurveFeatureRule5 Y7 r! i9 k/ P1 [2 B! F9 P
            curveFeatureRule2 = workPart.ScRuleFactory.CreateRuleCurveFeature(features2)
" f2 V/ j8 o  H/ h2 w/ }1 Z7 h            Dim rules2(0) As SelectionIntentRule. i& M7 G! y" D7 x! e
            rules2(0) = curveFeatureRule2
  h! O: O, Z5 ]( o' T            Dim sketch2 As Sketch = Circle_sketch6 V5 Z; O6 U0 W# b
            Dim helpPoint2 As Point3d = New Point3d(0, 0, 0)
# T; h( N, }; ?/ T1 m            section2.AddToSection(rules2, Circle_sketch.GetAllGeometry(0), nullNXObject, nullNXObject, helpPoint2, Section.Mode.Create, False)
5 X8 c1 H" ^9 I
- O6 a: Y1 {7 L+ n1 z& f7 v- k            Dim direction2 As Direction
2 d2 k: s  ]2 [4 Q            direction2 = workPart.Directions.CreateDirection(sketch2, Sense.Forward, SmartObject.UpdateOption.WithinModeling)
( _4 b7 F3 \9 y$ ~1 A            extrudeBuilder1.Direction = direction26 M2 Q9 A3 J5 ?; f0 o8 f1 j
8 X0 N+ k" _: l, l# a
            Dim ExtrudeFeature As Features.Feature
6 [) C; _0 {. A+ n2 g  q            ExtrudeFeature = extrudeBuilder1.CommitFeature()! o0 a" I+ [! n6 D7 J5 E
            ExtrudeFeature.SetName("Circle")/ o5 b+ @6 d( E! M
7 t3 u/ D; e3 {9 j% m6 a            extrudeBuilder1.Destroy()
; w" Q0 J( Z9 [: T7 a& S2 X  q1 l' l
  w2 u2 Q3 p& K6 C& e            extrudeBuilder1.Limits.StartExtend.Value.RightHandSide = "0"
5 @" I9 u3 Y& ~8 D, |            extrudeBuilder1.Limits.EndExtend.Value.RightHandSide = "5"
; |/ i4 d1 u. U6 q# \9 t# z: ]0 _; b3 r5 O
            Dim CircleBody As Features.BodyFeature = ExtrudeFeature
4 s8 h$ A: c* b4 s; S3 K2 W            Dim body1() As Body = CircleBody.GetBodies()( W! C  m& Y' Z; M
7 A+ I/ _5 t9 u! O$ j- m+ R; @
            targetBodies1(0) = body1(0)
5 e, z0 s3 J: ~: P6 V2 l; W+ `( T            extrudeBuilder1.BooleanOperation.SetTargetBodies(targetBodies1)
  E; X5 f% c( Q2 K3 }7 I! N            extrudeBuilder1.BooleanOperation.Type = GeometricUtilities.BooleanOperation.BooleanType.Create
( j) ?1 L% K# R. U6 M
9 D% \: Z7 p: D- U            section2 = workPart.Sections.CreateSection(0.02413, 0.0254, 0.5)
7 U$ p  O+ u# S* d: ?1 S8 O* [            extrudeBuilder1.Section = section2$ Q0 F# Z% [  l# f) g) W- N/ |, \& w5 Y
            sketchFeature2 = Cut_sketch.Feature
9 B6 c; r& n& Z5 H: Z            features2(0) = sketchFeature2
( K: a  N, e0 t# V            curveFeatureRule2 = workPart.ScRuleFactory.CreateRuleCurveFeature(features2)
, x; M9 ^! z0 J! j% E7 O            rules2(0) = curveFeatureRule2% e. u  ?- a% `( t- D: P4 b/ p; V
            sketch2 = Cut_sketch
, v  T+ X! w! z8 j6 o            section2.AddToSection(rules2, Circle_sketch.GetAllGeometry(0), nullNXObject, nullNXObject, helpPoint2, Section.Mode.Create, False)
1 i3 K( Q, X) E! J6 N
5 T: c% g) j9 @9 `$ t            direction2 = workPart.Directions.CreateDirection(sketch2, Sense.Forward, SmartObject.UpdateOption.WithinModeling)
* X: R3 Q2 L* K" C            extrudeBuilder1.Direction = direction2
" c7 R3 a% Y$ `2 {: B( f% }5 g5 o: U& I+ [7 C  F
            Dim CutFeature As Features.Feature
& S2 N  Z9 B5 ?* l, D            CutFeature = extrudeBuilder1.CommitFeature()
/ u  M0 @* K& P            CutFeature.SetName("Cut")5 a' h0 k* k2 H# H9 m6 Z+ ^' i
# n6 [1 K3 y. Y6 l8 O            extrudeBuilder1.Destroy()
# K" `: Z$ I' z' d* R5 }  M  m$ F9 C( Z% \/ r+ ^4 x9 q; f
            Dim geomcopyBuilder1 As Features.GeomcopyBuilder  ]' m8 o! o* @, i+ A9 q
            geomcopyBuilder1 = workPart.Features.CreateGeomcopyBuilder(nullFeatures_Feature)2 a' k% g6 X* L# c! G
            geomcopyBuilder1.Type = Features.GeomcopyBuilder.TransformTypes.Rotation
( u& y- `  N8 m6 j" v
0 y' M+ E: v8 m: J4 i            geomcopyBuilder1.RotateDistance.RightHandSide = 0! f% {# P7 x( I) ]+ X
            geomcopyBuilder1.RotateAngle.RightHandSide = 360 / Z. ?2 M8 }' T+ y- l4 I: p
            geomcopyBuilder1.NumberOfCopies.RightHandSide = Z* K+ `; S; B4 t( @% x, u. g% G
            Dim datumAxis1 As DatumAxis = CType(workPart.Datums.FindObject("DATUM_CSYS(0) Z axis"), DatumAxis)
+ h) S1 `9 m2 }7 Q6 }4 u6 F( d& d
            Dim direction1 As Direction
1 O9 C: M5 Z0 x% v. v: I            direction1 = workPart.Directions.CreateDirection(datumAxis1, Sense.Forward, SmartObject.UpdateOption.WithinModeling)" O; ^# q) q- @4 F/ T
            Dim axis1 As Axis
- i# ^+ ^$ U$ E7 d" G0 b5 ?            axis1 = workPart.Axes.CreateAxis(nullPoint, direction1, SmartObject.UpdateOption.WithinModeling)
# [9 n6 T6 c: o% e6 l. }2 _% G3 J$ T# s, H9 Q* n2 t  W/ v
            geomcopyBuilder1.RotationAxis = axis15 ]( c) h, i* r# C0 W
6 |0 x! U1 l0 d1 q# b6 u5 E1 R            Dim CutBody As Features.BodyFeature = CutFeature' u$ D: ]8 I9 w5 p) K% p
            body1 = CutBody.GetBodies()
. a+ g* T' L; ^6 i( h- \. a- b+ X1 Z8 @) f+ P, o/ T6 j
            Dim added1 As Boolean
; I7 P3 `, B; X% a            added1 = geomcopyBuilder1.GeometryToInstance.Add(body1(0))
( w$ M! Y7 K  l5 s+ L+ w# j( ?9 a            Dim GeomCopyFeature As Features.Feature/ S3 L1 Z: M# k, G
            GeomCopyFeature = geomcopyBuilder1.CommitFeature()" J% y' T1 h' E
; p$ @, p: P0 u; H            Dim nullFeatures_BooleanFeature As Features.BooleanFeature = Nothing
. h3 ?7 x$ j! i& G! v+ G4 p( i! p5 {- N( q
            Dim booleanBuilder1 As Features.BooleanBuilder
1 b# i) r1 T' }: n9 L            booleanBuilder1 = workPart.Features.CreateBooleanBuilderUsingCollector(nullFeatures_BooleanFeature)! W1 ?. I: `6 Y% N3 n. p
) f! k* g2 J  M4 R8 c            booleanBuilder1.Operation = Features.Feature.BooleanType.Subtract: I8 k" C% e, |5 K" O% p
            body1 = CircleBody.GetBodies()2 c' ^$ ~7 R  n; y, ]) P
) [9 E$ o* [! }* |) ?1 S& i- t            Dim added2 As Boolean; A$ ^5 X; i: z$ `4 V7 }( w3 q
            added2 = booleanBuilder1.Targets.Add(body1(0))
! A6 P; O" y8 K; T/ O' n: p% L# ^- ?4 [3 b
            Dim features1(0) As Features.Feature- C8 W  W& ^' i; l$ C, ?
            Dim geomcopy1 As Features.Geomcopy = GeomCopyFeature3 ^/ |  c/ y  N2 Y
' ^" r  Z2 H" |" e" D  {0 J2 ]' M            features1(0) = geomcopy1
- U1 L: Z% f/ v4 g; T            Dim bodyFeatureRule1 As BodyFeatureRule* R1 ?6 @$ j0 ~: {  ?5 s1 b5 x3 W, t
            bodyFeatureRule1 = workPart.ScRuleFactory.CreateRuleBodyFeature(features1)
! }1 ]) T2 y' n9 l4 ~$ T& s2 B. C8 X- S. W
            Dim rules4(0) As SelectionIntentRule
8 l) ?+ |; n$ k2 H7 f            rules4(0) = bodyFeatureRule1
5 l$ i' k$ C2 t3 q2 H$ i            Dim scCollector2 As ScCollector
4 M5 V+ R4 F) x. k            scCollector2 = workPart.ScCollectors.CreateCollector()
( }. `% @. A; r- V# t9 e& l            scCollector2.ReplaceRules(rules4, False)6 q3 t: n; V3 C+ P
5 c7 p8 a3 g2 D. R  r1 U
            booleanBuilder1.ToolBodyCollector = scCollector2" ^/ G2 T) P9 M- ?5 s* q
            Dim nXObject1 As NXObject
: ?- @) P: m/ \. z9 [+ \            nXObject1 = booleanBuilder1.Commit()
+ F8 \  r9 Z) X7 N% n+ X0 @% \& S2 a% }% c1 h! D
            booleanBuilder1.Destroy()
2 S8 l5 B, h' H# u* z' }
! O6 L5 l) t# ?
+ w& l9 |" C! {$ O$ o, @% ~            Dim objects2(0) As DisplayableObject- \1 s. X+ p6 ?5 i* C
            objects2(0) = CutBody.GetBodies(0)
7 `9 ]& t+ h! W7 ]# x            theSession.DisplayManager.BlankObjects(objects2)
2 a# ?! s$ ^2 e2 y0 g        Catch ex As Exception
, o/ Q9 y( ]: F6 s0 ]# o" s4 o! c            errorCode = 1$ F& M! i+ G  q+ c: j9 R5 }
            theUI.NXMessageBox.Show("Block Styler", NXMessageBox.DialogType.Error, ex.ToString)
) P+ [. v6 T' y" K) A; T$ L
: h4 Q% [7 X+ z8 C; i8 }4 I        End Try
, s( ?- a/ R' d8 ]* h" k8 _        CreateChainGear = errorCode+ Z+ M& n. k$ F5 I
    End Function6 A; u) A6 t% g$ |% i/ }9 H; w/ a
7 C- b" P2 v9 s- Y* m) z& b* oEnd Class[/code]. _6 J2 J. a, @) G  q0 K
/ G* u$ O0 V+ ~- }
