[二次开发源码] UG二次开发源码:计算曲线信息评估非常好用的方法分享
2014-5-3 12:58:05 4041 0
发表于 2014-5-3 12:58:05 | 显示全部楼层 |阅读模式
4 H% T) |1 S8 r: [+ U! {# N, F/ t3 B+ o7 c; t  h9 c
/ k; m- E" i; K) ?3 _( E+ F+ x# O
6 [" u( o' E' `" F/ f: u) Q
  1. /******************************************************************************
    # ?# y+ s9 k( t/ {8 K  k
  2.              Copyright (c) 1999 Unigraphics Solutions, Inc.
    - T- @3 v+ J8 [* `( }$ l  b
  3.                        Unpublished - All Rights Reserved8 S- w# f. _8 @4 j. V
  4. ( z; X0 }+ P& y! ~/ a: A
  5. *******************************************************************************/
    6 J- s, l3 ]) E
  6. /* This example demonstrates the UF_EVAL api for lines and arcs.
    . o7 O0 @, o* g; [/ n6 d# I
  7. Some of the UF_EVAL routines operate on an evaluator5 ?, S! ]8 ~/ \; K
  8. independent of type while others are type dependent.  No longer use: a8 u0 Z: |" z: Q) g8 q! m
  9. UF_CURVE_ask_curve_struct ( ),
    8 u6 ?+ u3 o8 O9 H" B, A; q1 B' f3 y5 E
  10. UF_CURVE_ask_curve_struct_data ( ) and
    4 Q' E' F8 L# L/ X' ?, W- F7 E
  11. UF_CURVE_free_curve_struct ( )4 _" `5 i/ C8 a9 m1 v! J. e) _- i
  12. */
    ' N7 C3 C$ t8 ^( B
  13. 7 s, e4 v% P$ s; h6 [+ i
  14. #include <stdio.h>/ M* {2 U) K$ B9 V1 W
  15. #include <uf_object_types.h>
    0 P7 j1 O* O. C1 }7 A/ C0 A/ `3 h
  16. #include <uf_curve.h>' W! ]  Z  J! z" a% @4 e
  17. #include <uf_eval.h>7 D# {9 j$ E7 h$ Z8 P2 U
  18. #include <uf_modl.h>
    0 b9 L% n, o) z
  19. #include <uf_part.h>& Z2 l" L' s8 C$ s9 l: b
  20. #include <uf_so.h>
    0 L: E" W( E- F% D
  21. #include <uf.h>
    ; b7 u& M. X( X
  22. #define UF_CALL( X ) ( report ( __FILE__, __LINE__, #X, ( X ) ) ). b. K. p2 y4 p! X% |
  23. static void show_edge_points(UF_EVAL_p_t eval, int n_pts);6 |) v, @$ I4 K3 }' W) b# G" B
  24. /*---------------------------------------------------------------*/
    * {# O4 }$ A3 q& q) c; w0 a) Z7 U" i
  25. static int report ( char *file, int line, char *call, int irc )
    # M5 E. R' J$ O, |) X- H3 `
  26. {
    - ~& `2 [7 G' j1 E3 q3 q
  27.     if ( irc )
    * D9 M1 U/ |$ j. {
  28.     {' t/ c+ B$ \9 n+ H; D
  29.         char message [ 132 + 1 ];
    # J% X# n+ D: v0 y3 _+ U
  30.         printf ( "%s, line %d:  %s\n", file, line, call );# r8 r2 [* V% `' _4 ~4 y
  31.         UF_get_fail_message ( irc, message ) ?
    ) I8 E6 a4 }# I: H7 S) D8 j# w
  32.             printf ( "    error %d\n", irc ) :
    ' R- k4 T5 C# W; ~3 k7 h
  33.             printf ( "    error %d:  %s\n", irc, message );
    0 F# J+ N  S( e
  34.     }
    ! g6 ^1 H* H' ], V/ Z5 `
  35.     return irc;
    ; ^) d6 y2 D- [2 P& ?; @6 ~! k' U
  36. }: n8 Z) E; F" y
  37. /*---------------------------------------------------------------*/; l+ N/ l2 N1 q3 ]
  38. int ufusr_ask_unload ( void ): W; [# k- x& j
  39. {
    / E( l  g+ w5 n/ S: R
  40.     return UF_UNLOAD_IMMEDIATELY;( a& ]0 u2 N! u1 R9 C- l2 I: w" h( @+ _
  41. }
    . h, C2 v$ o; t3 C. d$ m! U. c
  42. /*---------------------------------------------------------------*/
    7 g8 X7 {! O8 L, o' U
  43. /* ARGSUSED */
    ) d6 J! `* }) z" L( O
  44. extern void ufusr ( char *param, int *reTCod, int param_len )4 |, G3 R( ^: P7 \* l4 b
  45. {
      E  @  u# ?; n2 v( C% ], Y
  46.     tag_t line;
    # w9 Z. y, [# x  ]
  47.     tag_t arc;  n0 N8 g0 Q- L  q! a9 T) @
  48.     tag_t edge;8 R! r( ]; K' x# u  Y4 f% ]
  49.     tag_t edges [ 3 ];
    " A/ P! H! A3 j' v) k9 u
  50.     UF_EVAL_p_t line_evaluator;3 R! d3 `+ T1 x3 T1 c3 V0 T2 {
  51.     UF_EVAL_p_t arc_evaluator;7 p5 s% w; K8 i" d
  52.     UF_EVAL_p_t edge_evaluator;
    * |0 t7 i& v0 z, t/ i  \! G
  53.     UF_CALL ( UF_initialize ( ) );) w7 d3 _5 B) d7 L) U
  54.     /*  : D: A) M8 {# o" L1 M) ?
  55.         Create new part "ufd_eval.prt"., j. V; h- C% t: ?$ E; U2 B! X
  56.
    * M' y8 e7 }- E  x: H% v! t# }
  57.         Close part if it already exists.
    0 R- c8 {1 u1 z
  58.     */+ ]+ E( g3 t. d% ?1 ~0 i
  59.     {) b5 x$ i6 i* x1 g1 D) S  p& f
  60.         tag_t part = UF_PART_ask_part_tag ( "ufd_eval.prt" );- U' x/ I7 R* Y# ]0 ^1 T* B
  61.         if ( part != NULL_TAG )9 P" F( U; M8 W5 w
  62.         {  u( O+ u4 o: {0 w) a( D- o9 H
  63.             UF_CALL ( UF_PART_close ( part, 0, 1 ) );0 v+ g. ^6 a( h
  64.         }
    ' G1 K& D/ e$ ?) V2 `7 g
  65.         UF_CALL ( UF_PART_new ( "UGd_eval.prt", 1 _) E8 a5 ~* g2 R
  66.                                 UF_PART_ENGLISH, . l) J" H# k& q: @$ H/ Y/ }* K0 ?
  67.                                 &part ) );
    2 F: B/ r8 ~; K7 `
  68.     }
    7 Z3 ~. y& P4 P" o: W" x
  69.     /*
    ( N- `, H: \0 Z  J$ i8 J
  70.         Create block and get edges.
    4 e$ X1 O) V+ g' h* g
  71.     */$ o! K+ ^5 a% m
  72.     {, X  }4 ]* y" h
  73.         double  origin [ ] = { 0.0, 0.0, 0.0 };
    4 b: B  u0 K% ~. J. A( G+ f; U
  74.         char   *sizes  [ ] = { "1", "1", "1" };. {' w3 e8 X% r. j$ a
  75.         tag_t block_feature;. R/ C# p+ Z- _
  76.             ; I6 c$ z9 T9 [4 R3 T' n
  77.         UF_CALL ( UF_MODL_create_block1 ( UF_NULLSIGN, ; ^6 J7 Y2 P$ q2 S: h
  78.                                           origin,
    . q+ `$ R4 \! l* k; W8 x% R" L
  79.                                           sizes,
    0 H) U! o% `7 A- ]2 Y- T. [
  80.                                           &block_feature ) );
    : Q0 q3 h# t9 p/ B. d, ]- f
  81.         {3 J# `9 i5 B/ E8 {9 ?
  82.             uf_list_p_t edge_list;; Y; }, m4 ^6 ?1 k* A! `  ]
  83.             UF_CALL ( UF_MODL_ask_feat_edges ( block_feature,
    1 l! z; ?$ U% ?1 z4 a
  84.                                                &edge_list ) );
    ; M9 Z6 l- U1 q% C" q8 F
  85.
    ( h! Q, Z* u! U
  86.             UF_CALL ( UF_MODL_ask_list_item ( edge_list,
    : }" t' g; W- M4 j$ g& ?
  87.                                               1,
    + `  [& {/ o2 w* H/ i6 B
  88.                                               &edge ) );6 g  x( j; a' F/ P
  89.             edges [ 0 ] = edge;) ~& T: C* T$ {  r& U, M
  90.             edges [ 1 ] = edge;
    : R" N9 z, a" s# T5 K( O+ Z( `
  91.             UF_CALL ( UF_MODL_ask_list_item ( edge_list, 0 D" P) m0 U) Y( w0 a
  92.                                               0, " \0 T0 }9 V9 R$ ?' l2 Z( O# Z
  93.                                               &edges [ 2 ] ) );# L' q; ^4 e; u- w8 E
  94.             UF_CALL ( UF_MODL_delete_list ( &edge_list ) );
    , _. _3 D3 P, B, D6 t
  95.         }7 j- q/ j& ~2 y3 y) p4 e0 ~" ?
  96. }
    % O" v, B' q; J& K7 B
  97.     /*  " }6 ?; O3 g$ B& y+ X! X* O
  98.         Create smart line.
    ! p5 l8 g4 s  G4 I# C2 w
  99.     */4 ^. Q0 ~% y5 Q0 i2 g0 d+ R  K: C
  100.     UF_CALL ( UF_SO_create_curve_extract
    4 ?8 x" R% u5 I# @; J. l9 m; d1 q
  101.               ( 2 a; M! y- V  q& @
  102.                   edge, 4 ~5 X, I- ?6 \5 ^5 n9 f
  103.                   UF_SO_update_after_modeling, - s: u$ T2 D  ]( O5 B' ^# o
  104.                   edge,- `4 A3 l! j- J, M, [
  105.                   UF_line_type, /* enforce line type */
    : r& D. W0 C) H8 U9 \% a4 n
  106.                   0,            /* no subtype to enforce */
    ) Q; U" q' V4 o; W) c2 e6 G6 |9 _' e
  107.                   NULL_TAG,# k4 A4 {$ z$ e: Z  s
  108.                   &line ( d, X  G9 {3 c! H; ?
  109.               ) );
    : }& q+ k- |1 r9 E# d
  110.
    + e! ?/ ]  D* ]" H" f5 `
  111.     /*
    ! [$ L  R  q7 q: [2 }7 t  g
  112.         Create smart arc.4 i$ C5 M& g) ?# t
  113.     */
    , c1 C6 z# c' w7 U4 A1 M+ b) Z
  114.     {" `1 X) n8 H) J5 x2 n
  115.         int i;" }; Q% b& S2 z) H9 ^- c) e9 ^
  116.         tag_t points [ 3 ];
    6 L6 W7 v# ?& E0 P! S8 ^
  117.         for ( i = 0; i < 3; i++ )
    5 G* j% Y# Y' f( S/ \/ i
  118.         {
    & F# S- w" ?0 G! t
  119.             char *strings [  ] = { "center=1.0", # ~% B$ S1 i# R0 V, V3 }
  120.                                    "start=0.0",
    5 N2 w0 Z6 b! {5 S
  121.                                    "end=1.0" };
    % q! W/ m2 W+ `0 F# w: X3 P3 n+ S
  122.             tag_t exps    [ 3 ];# V1 v: f; |1 D+ {
  123.             tag_t scalars [ 3 ];
    ( H2 W+ W2 d* n( P& a
  124.             UF_CALL ( UF_MODL_create_exp_tag ( strings [ i ], * k- r. y+ m. V$ @3 c: ~
  125.                                                &exps [ i ] ) );4 G$ p# f* Q% M+ U( b- d7 a
  126.             UF_CALL ( UF_SO_create_scalar_exp
    4 }# d8 Q/ g5 V5 ^: Y6 Q
  127.                       ( ( n# m3 e% S1 _, G4 J$ S& D- ]
  128.                           exps [ i ],
    1 |, f8 Z; `( P' K; F! t  G
  129.                           UF_SO_update_after_modeling, - {& h4 U* `" t# e+ v
  130.                           exps [ i ], 7 p2 a, [0 b$ ^7 Z  ]3 X6 X  ^$ b
  131.                           &scalars [ i ]$ Y, O, i4 _4 ^
  132.                     ) );. D" |( B5 `) u4 \' [$ q$ A+ L
  133.             UF_CALL ( UF_SO_create_point_on_curve
    9 h4 @8 H9 i! U* l
  134.                       (5 u& }4 ?+ M  X1 @
  135.                           edges [ i ],
    9 h9 L! f( T* Z
  136.                           UF_SO_update_after_modeling,
    ! m' e0 w( Z6 J# a2 Q& |
  137.                           edges [ i ],
      x" x- ?) h: y& `
  138.                           scalars [ i ],
    6 S( u2 g% \( L& t. Z/ Q
  139.                           &points [ i ]- w  Q8 c1 l4 y% k" |
  140.                     ) );
    : q$ F( p+ c: K; V
  141.         }' o; a& B+ w" ?
  142.         UF_CALL ( UF_SO_create_arc_center_2_pnts ( o$ C. _2 }, m" B. p
  143.                  (
    % x1 D; P% Q5 `/ m
  144.                       points [ 0 ], 9 D6 y, j8 e4 A. C
  145.                       UF_SO_update_after_modeling,
    1 R2 Y0 E" `) y5 X; a# _
  146.                       points, ! j6 M5 q: O9 G1 R1 o; \
  147.                       &arc / x) u6 \9 }: p7 c& z4 I
  148.                   ) );
    ' Q& \8 v; V2 @0 u: Q* D/ ~
  149.     }" a! `' q/ {1 r. Z, U6 ^1 T
  150.         2 l8 n$ W; e! d/ V% C# d) I) h# m4 \
  151.     /*
    & J' \) m1 i8 t% `
  152.        Smart objects are created as invisible objects by 6 Q5 i' \1 L0 r( j5 F# Y& T2 E
  153.        default.  UF_SO_set_visibility_option ( ) can be
    ) [/ b% N' B) g7 s  U/ k, b
  154.        used to make them visible in the graphics window.) z5 \" V( u' y& Y2 A' ^) a
  155.     */
    8 D% M. n. j( `6 E1 E1 H$ V5 K
  156.     UF_CALL ( UF_SO_set_visibility_option ( line,
    * J8 ]4 p2 a( _4 f* {. v
  157.                                             UF_SO_visible ) );
    1 Q3 _8 v* C& v& k
  158.     UF_CALL ( UF_SO_set_visibility_option ( arc,  & T1 \' s. M+ q8 N
  159.                                             UF_SO_visible ) );
    ' b( l. h9 ?: V
  160.     /*  : L5 a) m, a: u( f. X/ J
  161.         Get line/arc/edge evaluators.
    ; |0 `4 u( o6 q* K6 R
  162.     */9 D# K6 c4 g1 y8 o" h) T- b1 j
  163.     UF_CALL ( UF_EVAL_initialize ( line, &line_evaluator ) );" i$ P' b# u& X' I6 B% B; e
  164.     UF_CALL ( UF_EVAL_initialize ( arc,  &arc_evaluator ) );9 y  ?1 X9 W' J3 A/ f
  165.     UF_CALL ( UF_EVAL_initialize ( edge, &edge_evaluator ) );! P- v9 H0 {; b! A, G# x
  166.     show_edge_points(line_evaluator, 10);
    . P  ^2 C1 ^+ z( y# V
  167.     show_edge_points(arc_evaluator, 10);- r2 M" q' y9 u+ {% r5 i
  168.     show_edge_points(edge_evaluator, 10);. u* S( p  h( p3 C% ]
  169.     /*
    , Y$ W9 X5 _: v& c, ]3 ?8 e& f6 g
  170.         Get line/arc/edge data.1 N; `/ U" L. T" Y
  171.     */
    ( Z; r" I4 X+ v& V# x1 C' C9 W: F+ N
  172.     {4 h1 ]8 f- B% m, K! x
  173.         UF_EVAL_line_t line_data;
    . ?7 L. w0 T; E4 a( h
  174.         UF_EVAL_arc_t  arc_data;
    $ K6 ]9 p( K( }( E; R. g2 y# Q
  175.         UF_EVAL_line_t edge_data;, B, `+ H% P6 p3 d, b& L$ |
  176.         UF_CALL ( UF_EVAL_ask_line ( line_evaluator,
    * z1 l. q7 {1 C3 B5 I! Z" `# a
  177.                                      &line_data ) );5 b6 A! [4 Z& h* M) n) \4 m: {
  178.         UF_CALL ( UF_EVAL_ask_arc  ( arc_evaluator,  $ W) }, N& q  u9 Y- S- \
  179.                                      &arc_data ) );; H1 o# R$ ?% m" {1 k5 ~3 T  N
  180.         UF_CALL ( UF_EVAL_ask_line ( edge_evaluator,
    + u+ X1 W- e. X  d4 E7 |$ E8 @5 E1 y
  181.                                      &edge_data ) );% h' Y* r3 s. k
  182.     }8 d! b) f. h) P  o. ^' w/ R5 I
  183.     /*
      j3 I. @2 f! y" N2 U3 M5 I
  184.         Check line/arc/edge periodicity.8 s, l9 u4 u  M0 G+ n' j
  185.     */
    ! Z/ v2 p( @4 L# x1 J7 k9 m
  186.     {
    4 Q! ?% J. s$ c1 Z; g& i* `
  187.         logical is_periodic;+ M* `5 n/ {9 k( Y' @( ~
  188.
    + ]3 u9 L. K3 v2 c: `0 J6 y0 `
  189.         UF_CALL ( UF_EVAL_is_periodic ( line_evaluator, ' ~, |$ u& |2 `5 r5 B$ Q. X
  190.                                         &is_periodic ) );5 {3 l+ k  h) \* _- s/ Z
  191.         UF_CALL ( UF_EVAL_is_periodic ( arc_evaluator,
    , S0 }* ]2 V6 k8 G1 ]" Z
  192.                                         &is_periodic ) );
    - y& @; e; _% d; W6 Z3 i9 }
  193.         UF_CALL ( UF_EVAL_is_periodic ( edge_evaluator,  9 z+ _9 `9 \2 a! Z. i/ [* u
  194.                                         &is_periodic ) );" [9 ?7 t4 B% W1 j8 a2 f
  195.     }% g7 S: g6 [( T- _  g: ?; \+ O# w/ W
  196. /*
    - T5 N: ^% B* w2 X
  197.         Evaluate line/arc/edge.
    & n: B; ?9 s. G# z9 |  A
  198. */
    ( V. h- }7 M$ h# Q, c
  199.     {4 g' J9 G" U* A5 K- m2 _
  200.         double limits [ 2 ];
    / Q( i+ {! p! g. t- f# R  E8 `
  201.         double mid_t;
    3 k# A2 L* \- ?/ U% H4 d
  202.         double point [ 3 ];* N0 b- C- ]) @; T
  203.         double derivative [ 3 ];- Z% v4 i7 N( r
  204.         double tangent [ 3 ];# R6 x3 {8 @6 h/ w6 }4 a3 g
  205.         double normal [ 3 ];
    % p: X2 ?% ~0 }- x$ @: W' E5 k
  206.         double binormal [ 3 ];9 N3 f4 N/ l: A
  207.         UF_CALL ( UF_EVAL_ask_limits ( line_evaluator, limits ) );
    ' K$ Q0 C0 t% Q0 z1 f& F
  208.         mid_t = ( limits [ 1 ] + limits [ 0 ] ) / 2.0;; g! \% o! ^0 G1 \
  209.         UF_CALL ( UF_EVAL_evaluate ( line_evaluator,
    6 Z& m4 n# x: n" h5 v2 O3 c
  210.                                      1,
    , _6 o# ^3 @4 s6 f  }% O$ I
  211.                                      mid_t,
    3 {; i) F, P+ P- d! e( E
  212.                                      point, 8 ?7 [) F- D6 `9 N* d( D6 z4 z1 R
  213.                                      derivative ) );2 f" Z) I4 R- l, n1 ^0 r; b8 I' o( q
  214.                   & S- u3 X' Y9 T" t
  215.         UF_CALL ( UF_EVAL_evaluate_unit_vectors ( line_evaluator, 1 K- u" I! S$ @* h. C
  216.                                                   mid_t,
    4 r6 T) h' r. g
  217.                                                   point,
    : T# x0 O% R, G4 V+ s: ^
  218.                                                   tangent, - j' k$ s( W7 X' P  h
  219.                                                   normal,
    ; l, {. I* ^# a3 u
  220.                                                   binormal ) );
    " ?' B9 R4 @( T3 m& Z1 G
  221.         UF_CALL ( UF_EVAL_ask_limits ( arc_evaluator, limits ) );
    ! s) D7 w. ^! g- E8 f, ~$ n
  222.         mid_t = ( limits [ 1 ] + limits [ 0 ] ) / 2.0;$ K; ]& j. U. y' T- r; `- z
  223.         7 C2 f, ]+ U% F; {
  224.         UF_CALL ( UF_EVAL_evaluate ( arc_evaluator, + \' _0 [7 q3 L9 Z9 |5 d# c3 h+ {
  225.                                      1,
    8 _# B: O( |1 C5 ^; s
  226.                                      mid_t,
    . M$ ?8 `: {; E" R
  227.                                      point, # o; W; u4 a: v
  228.                                      derivative ) );
    " k* e, i3 n2 s: `+ [' f5 X
  229.         ' U$ D0 h) f! r# E
  230.         UF_CALL ( UF_EVAL_evaluate_unit_vectors ( arc_evaluator, , `5 T5 w$ G7 @4 D5 F- d# `
  231.                                                   mid_t,
    ( M& `" _* S& Q3 ]7 L$ y
  232.                                                   point,
      A1 c* z( E1 J6 I) ]
  233.                                                   tangent, 5 K' z$ q4 {2 d0 K5 e4 K+ r+ G7 x
  234.                                                   normal,
    + p1 h  i' b7 G0 U& C7 ]
  235.                                                   binormal ) );# e" J2 q$ g! n, Q6 w- t
  236.         UF_CALL ( UF_EVAL_ask_limits ( edge_evaluator, limits ) );& p" X( h9 d7 ^, ?: g8 j
  237.         mid_t = ( limits [ 1 ] + limits [ 0 ] ) / 2.0;
    + K$ H* A/ y2 b; Y+ m6 h
  238.         UF_CALL ( UF_EVAL_evaluate ( edge_evaluator, 8 h6 d3 ^# k# u/ p5 g3 W& i' A& z7 N
  239.                                      1, 9 w0 l3 U1 R) r; M6 p0 y0 A
  240.                                      mid_t,   |$ @& y7 {. f) t
  241.                                      point, - a( X3 T# x* X/ U; |9 L: X) A
  242.                                      derivative ) );
    4 O0 B/ E! \) G/ ]2 y
  243.         UF_CALL ( UF_EVAL_evaluate_unit_vectors ( edge_evaluator,
    8 w, j7 D% R9 Y- @7 L0 [! c7 h
  244.                                                   mid_t,
    6 }6 z% F" \- c2 Z+ }
  245.                                                   point, ) \* c! W# e6 A; W
  246.                                                   tangent,
    9 V  R4 I+ Z( I  H  Z
  247.                                                   normal,
    - J* X4 B# N* V5 H3 y! S
  248.                                                   binormal ) );% \+ }. _/ L# F' p
  249.     }
    0 c% p  B% C8 r$ B% M6 A8 j+ K
  250.     /*
    7 Z5 N% K9 T$ O- r  H* a/ [* D
  251.         Check line/arc/edge equality of evaluators.
    + T7 }3 g: D: Y* A& B7 R
  252.     */
    / B; `0 ~2 S, y8 Z
  253.     {, r: z) I1 D+ i6 B4 |; Y
  254.         logical is_equal;
    $ v* X' D; Q9 h3 F/ N
  255.         UF_EVAL_p_t line_evaluator_copy;
    . ?& i1 s" ]$ t5 [
  256.         UF_CALL ( UF_EVAL_copy ( line_evaluator,
    ( e3 e+ N5 M0 c" h/ J4 c$ [; s
  257.                                  &line_evaluator_copy ) );! s6 E- x: Q" m* y$ p# A4 I
  258.         UF_CALL ( UF_EVAL_is_equal ( line_evaluator,+ @) }5 b; U' b5 ?0 d1 {7 e
  259.                                      line_evaluator_copy,1 P) t( I! {" _/ P5 x1 U: X. M
  260.                                      &is_equal ) );
    0 u1 d- E; G8 w2 k3 P- J! R
  261.         UF_CALL ( UF_EVAL_free ( line_evaluator_copy ) );+ m/ Z) w$ `6 e- b
  262.         UF_CALL ( UF_EVAL_is_equal ( line_evaluator,
    5 G: T) t# q2 A& {0 {* b
  263.                                      arc_evaluator, 9 @3 l1 W2 I0 G- w
  264.                                      &is_equal ) );) h. G  o+ R, ~) f0 K
  265.         UF_CALL ( UF_EVAL_is_equal ( line_evaluator, ; r4 Y* a! R" Y
  266.                                      edge_evaluator,
    - J2 Q& S. _$ V( @. l! X3 K5 \3 b+ N( I
  267.                                      &is_equal ) );$ t/ m4 f8 k/ |# t+ D: C" Y/ l4 k
  268.     }
    ( P: T  [$ w0 z! a
  269.     /*  * q5 B% x8 ?1 U+ g( F: \+ }/ ~8 o
  270.         Check line/arc/edge type.
    " C; [  v: B* k
  271.     */+ R9 W7 S7 r0 v
  272.     {
    5 y0 j6 ]. {& ?, o- x
  273.         logical is_line;
    0 P4 u6 S0 \; a! u7 `7 J
  274.         logical is_arc;7 v, W* v" `2 x- ~( [
  275.         UF_CALL ( UF_EVAL_is_line ( line_evaluator, &is_line ) );, v$ }! l$ d  s
  276.         UF_CALL ( UF_EVAL_is_arc  ( line_evaluator, &is_arc ) );
    3 v. }  H) B3 t2 H. }
  277.         UF_CALL ( UF_EVAL_is_arc  ( arc_evaluator,  &is_arc ) );5 I! g* P  ]( J7 C# ^, s+ V
  278.         UF_CALL ( UF_EVAL_is_line ( arc_evaluator,  &is_line ) );
    9 G( O5 ?$ [5 y: [- a' R- [
  279.         UF_CALL ( UF_EVAL_is_arc  ( edge_evaluator, &is_arc ) );
    - J# |% I# t* j- s7 W; I) z
  280.         UF_CALL ( UF_EVAL_is_line ( edge_evaluator, &is_line ) );2 d8 U& W$ T6 N1 s* U2 ?) |
  281.     }
    $ T( V$ c# L" n7 y: I2 |
  282.     UF_CALL ( UF_EVAL_free ( line_evaluator ) );' T2 q5 \- @' {
  283.     UF_CALL ( UF_EVAL_free ( arc_evaluator ) );
    ! [7 x( N, k. `5 Z) O) o2 U0 X
  284.     UF_CALL ( UF_EVAL_free ( edge_evaluator ) );7 R2 M& ~. l  S1 V
  285.     UF_CALL ( UF_terminate ( ) );6 d% ]( {5 P- N, i% Z! ?
  286. }9 y& g$ [, u  ?7 i
  287. . T  x2 \( R; `: `/ v8 m
  288. /* This function will disply n_pts equally spaced along the0 W5 |8 S! q" v
  289.    input curve.* W9 F! V( n( @; c; q: Q
  290. */
    9 o3 I' q9 E# K3 i; t0 V
  291. static void show_edge_points(UF_EVAL_p_t eval, int n_pts)
    4 y+ v6 I; C8 T, x( q( {4 R
  292. {
    ' y4 u) _* t, R: W, u) s
  293.     int ii;
    ' {. C' G: `- F( {! `
  294.     double limits[2], p, point[3], end_parameter, start_parameter;* b! N( ]; r1 o: _7 e( L
  295.     UF_OBJ_disp_props_t2 {) d: X5 d6 @$ }3 l
  296.         attrib = { 1, UF_OBJ_WHITE, UF_OBJ_NOT_BLANKED, UF_OBJ_WIDTH_NORMAL,! o- k2 F# N, y6 E6 ~- `0 T. S1 |: k
  297.             UF_OBJ_FONT_SOLID, FALSE};" H1 V0 Y, K. [- D* f7 M; W2 R  M
  298. ) l1 \1 s: b) C1 O
  299.     UF_CALL(UF_EVAL_ask_limits(eval, limits));
    4 |/ L* W$ A/ t* R: D: N
  300.     printf ( "limit0 = %f\n", limits[0] );
    ) [0 Q, p  f6 e8 B9 a# R5 U& I2 }3 u" V
  301.     printf ( "limit1 = %f\n", limits[1] );5 q; k1 u( m- B" V1 U
  302.     start_parameter = limits[0];
    + z, z7 l. V2 K5 S
  303.     end_parameter = limits[1];( b. f7 W7 ?& u: `/ ]) ?9 U! ?
  304. 7 U0 N( |0 t! \! H5 A4 Q% x7 R
  305.     for (ii = 0; ii < n_pts; ii++)
    0 Y+ F; t! |) J# `( q
  306.     {- S) u2 z& e9 e8 O
  307.         p =start_parameter + ii*((end_parameter - start_parameter)/(n_pts - 1));2 Z, }9 d1 c  \6 [* s0 z5 v5 |$ ^
  308.         printf ( "evaluate = %f\n", p );
    $ K* n/ Y3 `+ ]
  309.         UF_CALL(UF_EVAL_evaluate(eval, 0, p, point, NULL));, ?  ?. i# b- {; Q0 f6 V, S
  310.         UF_CALL(UF_DISP_display_temporary_point(NULL_TAG,
    $ h! l6 l1 Y3 j
  311.             UF_DISP_USE_ACTIVE_PLUS, point, &attrib, UF_DISP_POINT));
    . e% T2 L# T' i7 f. x% d) y
  312.     }5 w' x/ `& {8 K* V1 o" {, F
  313. 3 @' w7 K1 e5 r/ I. Z- [( a
  314. }( n) i, f. E, f5 J! Q- w
, _- [# f9 F) z# l  i7 S- R$ K3 z5 v2 R) \) p- [" @4 Q
# e1 K4 F0 ?) y( A% S! {# n9 G
