查看: 4721|回复: 2
[求助] Move Object 中出现报错
 火 [复制链接]
发表于 2014-6-27 14:52:48 | 显示全部楼层 |阅读模式
                Session *theSession = Session::GetSession();; W5 b7 s5 S9 A, E5 B" i
                Part *workPart(theSession->arts()->Work());
' M  S7 S# O: i7 i* @/ @                Part *displayPart(theSession->arts()->Display());
, ^9 c3 n! _2 R) [# o! D
8 q' f( d% Q5 J! y' e- O6 ~                Features::MoveObject *nullFeatures_MoveObject(NULL);$ Y5 o& s# W" i5 W, R
                Features::MoveObjectBuilder *moveObjectBuilder1;& y2 X: ?" ?' g# \
                moveObjectBuilder1 = workPart->BaseFeatures()->CreateMoveObjectBuilder(nullFeatures_MoveObject);
0 P5 p9 B: L3 N' {9 d8 }; v. B* [
                NXString angleValueString;
  x" E. Y$ r7 J8 C& M8 e                std::stringstream ssang;
+ N) f& @, s' p0 r! a4 B* n                std::vector<NXOpen::Body*>bodies;
2 e# [& X  k( u# G9 M  \. N                NXOpen::Body *bodyList;
4 |+ d4 _9 }7 u; }& u2 w                std::vector<NXOpen::Curve*>curves;
% s9 ^4 z* l+ g7 m/ y9 \: Z                NXOpen::Curve *curveList;
! Z0 _! i, |% I# _; q                std::vector<NXOpen:oint*>points;& `: B- `5 W$ u
                NXOpen:oint *pointList;' T/ ^/ d% [5 R* C% ?! @
( s% J! i9 _* z
                //Get base point
; {& a/ m! o' U1 r$ {                BlockStyler:ropertyList *pointProperty = point0->GetProperties();
$ q- |: }1 q) y9 G                Point3d point= pointProperty->GetPoint("oint");
4 V+ s. E" L7 ?7 _/ m2 a2 z0 b                delete pointProperty;
# B% w# d; r$ F                pointProperty = NULL;
6 y9 h; n! a- C4 q- h7 x+ |; `& x+ w4 x5 b+ r/ A
                //Get revolve Lie value
0 ]* F" k% T( q+ T                BlockStyler:ropertyList *rValue = expression0->GetProperties();
/ j4 U/ P! V4 L% b: ?                double rangle = rValue->GetDouble("Value");3 ?" L  Z' n5 D5 O# A, L5 `; h
                delete rValue;0 `+ a9 E# N- p
                rValue = NULL;. `% F1 U0 y$ @( u, c% m
" g7 m& ?6 @- d6 h0 `                //Get Rod section Objects
% P1 v  \) T: I8 v+ D3 r2 z                BlockStyler:ropertyList *bodyObjects = selection0->GetProperties();
1 q1 H1 ]6 N) `/ Q/ X/ ?9 l* f                vector <NXOpen::TaggedObject*>taggedObjects = bodyObjects->GetTaggedObjectVector("SelectedObjects");
% a; X7 r' o/ H4 H; b                delete bodyObjects;# R; g5 `" i1 a. o, p' I; F
                bodyObjects = NULL;
; l5 R) l7 \7 ]& y! s  x1 V$ K5 t) _- B
                //convert TaggedObject to body & curve & point; o2 Y- R2 _: f" n' c" |! k6 J
                bodyList = dynamic_cast<NXOpen::Body*>(taggedObjects[0]);$ O/ b: S* f6 M, v& V0 I
                curveList = dynamic_cast<NXOpen::Curve*>(taggedObjects[0]);; X8 {0 w4 Q: d/ v* |/ x
                pointList = dynamic_cast<NXOpen:oint*>(taggedObjects[0]);2 ^" Q1 `% Z9 j8 l( P' T$ N; @
, O. Q$ D$ c4 C
+ @, `2 O/ `' Y3 _, p0 `! Z                //convert values to string7 y% Q0 Y  ^! k) i/ M
                ssang<<rangle;
7 \" r. }* f' u' l: x  O                angleValueString = ssang.str();: v1 p2 p8 T7 U7 Z/ K
. \7 H2 X; I; l- O8 A+ b
) }2 H3 Z2 ?6 V' n; r4 j+ f: [                //create motion feature
2 s8 c3 N8 I9 R0 ?' B( y4 ?9 g- T* j( p, s8 t6 H
                Point3d origin1(0.0, 0.0, 0.0);
& ~2 I& c+ {( K                Vector3d vector1(-0.0, -1.0, -0.0);  F, S9 g7 j+ b( |* P- Q7 j- B
                Direction *direction1;
/ g. v6 l' c; m# J                direction1 = workPart->Directions()->CreateDirection(origin1, vector1, SmartObject::UpdateOptionWithinModeling);
, F: ?3 A+ a4 ?4 T. V6 }& ~( C$ N6 A0 |1 U+ M; X7 ~6 _# c9 w7 `1 k6 r" s
                Point *nullPoint(NULL);0 g* W( h: L: z# Q
                Axis *axis1;
+ J0 @; e6 ?# ]! H" P$ x                axis1 = workPart->Axes()->CreateAxis(nullPoint, direction1, SmartObject::UpdateOptionWithinModeling);7 ~/ D" V" ~4 r+ T3 m" C/ i0 j
. s4 g# W( s9 E9 M/ f, T) X# {
                Point *point1;0 O; g# a% `0 H' k0 {, k0 g/ T
                point1 = workPart->oints()->CreatePoint(point);5 H- I" I" p4 g
5 m9 }: D; u* O  l: Q& w# c# O                axis1->SetPoint(point1);  ! a- J2 c- r0 X, h
                moveObjectBuilder1->TransformMotion()->SetAngularAxis(axis1);' o! R$ f2 n( {  f" Q& W
                moveObjectBuilder1->ObjectToMoveObject()->Add(bodyList);4 p& E; h1 B  F, t6 u( E
                moveObjectBuilder1->ObjectToMoveObject()->Add(curveList);
: `: l+ w. D  _0 z0 b! r                moveObjectBuilder1->ObjectToMoveObject()->Add(pointList);
8 H1 U) \7 i+ p% ^; E                moveObjectBuilder1->TransformMotion()->Angle()->SetRightHandSide(angleValueString);
6 }. C% @4 S7 w! a8 x8 |+ o                moveObjectBuilder1->Destroy();
9 r+ {0 @" N9 d1 f
4 N6 `$ d; [2 r" x; U& y# ~调试没有问题,执行的时候,总是后报错,还请指点一下:; [! k: o% Q; O2 i6 k" O, R/ l" Q
) o  \* G) }; b9 [. ^
登录/注册后可看大图
# O' r9 ]5 W& ]. Q4 _! U0 c- F" D; o/ y* q% w
2 ^( k/ g- P! l( C' y! ]* g
+ G& F+ C  U+ L! b$ U& X
 楼主| 发表于 2014-6-27 16:54:23 | 显示全部楼层
NX9中运行没问题,NX8.5中,可预视移动,仍会报错,按完报错确认,又回复原始状态
发表于 2014-6-30 09:59:52 | 显示全部楼层
eda 发表于 2014-6-27 08:54
9 I5 g: {2 V3 t0 C+ ANX9中运行没问题,NX8.5中,可预视移动,仍会报错,按完报错确认,又回复原始状态
2 S3 {3 G( H% _  T3 |) y+ e) X
没见你commit吧
6 D; L0 G# n& m4 T' dmoveObjectBuilder
