在UG的二次开发中,通常需要使用向量来进行判断,此处给出常用的向量使用教程。以二维向量为例,三维以此类推。
0 G% `- a/ T4 z8 J, W9 Y0 y t' J5 t- k源代码如下!6 y' k4 X+ A4 J0 T& Y( K9 L4 b
0 @& Z* G1 s" | e% r, W8 w
' g9 e( Z8 g- g2 j' r- ( _) y( }: C2 D1 Z, ~ a( D
" D+ q. k4 `* D3 K! q
1 L+ c! g1 { A4 t& P" Uchar msg[256];# w" U$ ]: B$ r5 F6 V' n5 X- z& {
const double vec1[2]={0.2,3.4};( L5 ~9 J2 Z1 `5 l% z
const double vec2[2]={1.5,4.5};6 h3 V, }* g3 I
double scale = 1.5;
& d5 k. G( ?3 q% sdouble scale1 = 1.3;9 Y9 P9 }: ~8 n9 O5 v! V
double scale2 = -1.1;
( w6 o$ [# V0 c) a: t$ odouble sumVec[2],vec_comb[2],vec_perp[2];
+ Q) z9 P0 Z3 ?: g3 a; _% B' v% `double oscale1,oscale2;
Z5 S/ y8 o/ L9 c6 Cdouble tol = 0.0254;9 {) ~+ a2 }) _+ y$ D- P% ~% {9 ^2 X
const double vec_src[2]={1,2};# q$ f( ^( k$ u8 b5 O% o8 ]7 Q
double vec_dst[2],cross_product,distance,magnitude,mid_pnt[2];! u1 D8 x1 _4 c% F( i
double unit_vec[2],scale_vec[2],sub_vec[2],neg_vec[2];
. |. ?- J/ t5 k) `int isEqual,isParallel,isPerpen,isZero;
; Q* Z6 |& n& m- m+ {" W& b: ?
# r. c2 K% h7 ?- S$ M& `% Y: Adouble parameter = 0.5 ;
" C, f l+ i# q) O# r$ Wdouble pnt1[2] = {0,0};0 U c8 T7 r; M3 F; _2 \: {- @
double pnt2[2] = {2,5};
' g. o3 t( H2 {9 kdouble pnt_on_seg;& e: I4 H$ ~- {" M
! c2 R% U6 t K% m/ t- Y
+ N' I$ b) `) b) l8 X
9 n: P5 p& x1 I- F3 [$ e// Do something
3 [. L2 n+ z& B0 P//------------------------------------------------------------------------------
- G- Y1 _/ y9 `" ]: v, k8 X% x6 I Q1 |! t3 i) ?4 V, Z
/ K5 x; `2 b/ S m: j4 }void ufvecTest::do_it()
, F0 z9 T) @9 A& W{! ~8 d2 O# L3 U! r
. S* |: U! ]$ W. n1 E
// TODO: add your code here* k$ w' o" L8 L) M& _- F
% t& e. q( c+ R2 b6 y$ s |
8 [+ N7 p2 C5 k, \- R7 t' m$ |: e6 ~
/* & o8 z1 ` v% U! Y }
& h0 ?3 V0 a5 e q4 a% h3 Q2 R 1 UF_VEC2_add : 两个向量相加
; V }8 Z! q2 g( c9 l+ |6 f$ C vec1 + vec2 = sumVec
4 p) C6 p/ K0 |; I ======================
t& a! P3 w7 L4 C *// N& o1 f( l( O
lw->Open();
- f' N1 o! d5 H' c* L UF_VEC2_add(vec1,vec2,sumVec);
) W9 O% ^$ t: z/ `; N+ b sprintf_s(msg,sizeof(msg),"vec1{%f,%f}+vec2{%f,%f}={%f,%f}",vec1[0],vec1[1],vec2[0],vec2[1],sumVec[0],sumVec[1]); X6 C' l% \( t
lw->WriteLine(msg);: v' h6 j9 o% ]5 f" ^
3 w" n* r. A: A /*
9 |* r7 j, L/ E5 X3 i ======================
# T3 j5 v! {9 [% p0 e 2 UF_VEC2_affine_comb : 仿射变换. _5 r3 e# O, i$ [/ Z
vec_comb = vec1 + scale * vec2;* q* j; @; G9 }5 p
: ?4 s8 g' v, X3 a8 z, A */; }$ v) X8 O) K/ O
1 w8 h" n! }& S4 ?) }9 e
UF_VEC2_affine_comb(vec1,scale,vec2,vec_comb);- K, M% J `' W: _ S
sprintf_s(msg,sizeof(msg),"vec1{%f,%f}+%f * vec2{%f,%f}={%f,%f}",vec1[0],vec1[1],scale,vec2[0],vec2[1],vec_comb[0],vec_comb[1]);4 G) A- i, f' D: o) q
lw->WriteLine(msg);9 M& P+ h; M1 d T& `
8 `1 L! C9 ~! C: u
/* 0 a B8 h) C+ k+ G* c7 f
( x6 M a" M+ u% q4 \/ j1 D 3 UF_VEC2_ask_perpendicular : 求出垂直的向量
8 Q: l( _; S4 L' F% B" \ vec1.vec_perp = 0/ T7 F {: N3 v# N6 h0 y
+ R R" L: E% o d T */9 {2 j' x3 U8 `& J
6 q1 f- t, ]- F H' B4 ] UF_VEC2_ask_perpendicular(vec1,vec_perp);5 y8 m1 ~( L0 x4 C$ P
sprintf_s(msg,sizeof(msg),"vec1{%f,%f} . vec_perp{%f,%f}= 0",vec1[0],vec1[1],vec_perp[0],vec_perp[1]);
9 ?$ G1 i! U% d lw->WriteLine(msg);4 M( G/ d+ c$ ~) @; R4 p, Z1 \; m
V% k& W" p5 l+ P" ]& ~' ^4 |
. R. u& z" s5 ]+ b4 p# { ======================
$ g9 c3 v2 Q D3 S1 x5 \3 T; B$ R 4 UF_VEC2_components : 求出垂直的向量 1 |7 t0 d5 }5 D1 V
vec_comb = scale1 vec1 + scale2 vec2$ Z3 N g$ @9 \+ Z. B/ Z
返回: 0 可计算 1 平行
* r' a8 k8 \. p$ S( F% m ======================. y, o w" A3 Y) [6 L% N+ U
*/' `; M9 X+ P* ]2 Y7 {
x& _6 p# ]- n) ^0 D1 p
int result = UF_VEC2_components(vec1,vec2,vec_comb,tol,&oscale1,&oscale2);5 l( ^7 P: i+ N
sprintf_s(msg,sizeof(msg),"oscale1 = %f,oscale2 = %f, result = %d ",oscale1,oscale2,result);& F& \8 X, ~4 j; _; B6 I
lw->WriteLine(msg);/ W: t6 ?6 m2 N$ V a
$ f5 r% C4 m$ A( N. b /* 4 \3 X6 c! j6 q+ \7 y
" ^# `0 J1 X$ `' {7 v! P$ ? 5 UF_VEC2_convex_comb : 计算点在直线上的位置' c( e, M5 q k# [+ x+ a$ ~
pnt_on_seg = (parameter pnt1) + ((1.0 - parameter) pnt2). 3 U1 ?4 W: O0 g' M1 Q3 V* u+ m- a: g5 ~5 f
0 B! b# M, G' ?- c */
' J, D8 S( w! S' }+ R/ x4 K! W
) V* E% O3 Q% g" N+ u' A
& y" Z" C1 s D/ u, e8 R( B+ u1 h" C UF_VEC2_convex_comb(parameter,pnt1,pnt2,&pnt_on_seg);% ] a; y1 n; [* J. o
sprintf_s(msg,sizeof(msg),"pnt_on_seg = %f",pnt_on_seg);* V2 _. `/ c& n; Q: _9 E6 N
lw->WriteLine(msg);' E) `4 H/ C) I$ D, s6 D
# E0 f+ ~( i0 {% X) U1 k /* % I0 W, ~3 ~# D! s5 U, g
======================0 U# e' m- e. X' U6 y( x
6 UF_VEC2_copy : 向量拷贝
! n m, P! B, k' P- q! m9 U vector (vec_dst = vec_src).
\7 d; q. F: |% U3 A ======================- Z% f( H. r3 f
*/3 N- {3 [$ U! Y+ e1 T& P
+ r* B: X+ H j( v
& q, [+ G( b: c; J# t- K UF_VEC2_copy(vec_src,vec_dst);
2 v: r) Q8 Q& t3 }1 b- Q" E/ z$ @ sprintf_s(msg,sizeof(msg),"vec_src = {%f,%f}\tvec_dst = {%f,%f}",vec_src[0],vec_src[1],vec_dst[0],vec_dst[1]);* s' y ]! N( z) A: S- A3 e
lw->WriteLine(msg);9 O6 f+ c1 f$ u# T
6 @8 E: O4 N# Y# m
% V& E( X4 O& B5 ?0 ^
/* 4 e4 }* M, x: j
======================- J. E+ K$ t+ Q8 H& P
7 UF_VEC2_cross : 向量向量积
- h* Z) k, ?& V" Y cross_product = vec1 x vec2+ X! ^3 l$ A' j3 T2 t
% e/ k4 p& m' i* Y1 _ */- P6 ^ `: G, ]: n
. W8 K7 d0 m7 i, L5 }3 D. f/ y& Q
; P$ T0 y/ G6 ~7 O% c
UF_VEC2_cross(vec1,vec2,&cross_product);8 i, m/ \" j) v% S
sprintf_s(msg,sizeof(msg),"vec1{%f,%f} X vec2{%f,%f}= %f",vec1[0],vec1[1],vec2[0],vec2[1],cross_product);
4 X4 p! N& ?2 B8 ]1 w lw->WriteLine(msg);5 W9 n* h1 B1 _
3 ]1 x, c7 U) O8 }/ e$ ]* ?6 J1 t' P$ o( ~
/* 1 H1 `# [8 z( P/ q. V5 d _& g5 N
+ B- V* V @% L: |* i3 }- P 8 UF_VEC2_dot : 向量数量积* v& Q# R! M+ p/ o
cross_product = vec1 . vec2
* {* k' X1 j8 m, }# }! C9 J ======================. k, Q6 D/ J% X- @& B9 w
*/1 Q" ]1 s) a' x! L
- d- m3 I5 Y U! Y D E, f& T7 B; O
UF_VEC2_dot(vec1,vec2,&cross_product);
6 J1 h$ W1 l- [: @ sprintf_s(msg,sizeof(msg),"vec1{%f,%f} . vec2{%f,%f}= %f",vec1[0],vec1[1],vec2[0],vec2[1],cross_product);
+ I! q' b* m& v% P: Z( h lw->WriteLine(msg);9 x! L5 e N4 {! Z
, A6 M- [( Q' ?0 d# d2 t2 P5 @1 G/ k1 [& V# _
9 w K; x9 t- {+ A0 d" V /*
$ [" Y& }$ J% s1 W4 |6 B9 t ======================
; Q+ M, Y5 s& J! S v 9 UF_VEC2_distance : 两点距离
7 Q) k0 @+ k ~4 }8 W (distance = ||pnt1 - pnt2||); r; n7 T6 i# n% q
======================8 F) N" k# ]$ [, S0 W1 @7 ~2 I6 I
*/& i% x6 L9 C( }+ o
: g- a3 Q5 ~; v7 A J- {1 R
/ u% q: M' ?. }8 U UF_VEC2_distance(vec1,vec2,&distance);) N1 G6 |& X. A/ @# V0 K7 d+ Y' o7 ?' B
sprintf_s(msg,sizeof(msg),"||vec1{%f,%f} - vec2{%f,%f}||= %f",vec1[0],vec1[1],vec2[0],vec2[1],distance);
! ?7 B/ u$ _! o3 S lw->WriteLine(msg);4 d' L0 g% D: N' s8 {
2 m3 \' A* z4 j
* r o6 U3 a- X; f$ p( I ======================+ Y" V2 N z1 b9 E; r2 _2 E
10 UF_VEC2_is_XX : 判断矢量关系
. h4 ]- P( Z. R* F5 u$ R$ [ 0 = false) b. M7 \& M' J, ]) H
1 = true$ y1 ^0 s& \$ b& S- l
* X- F3 X4 m K& q */+ q% Y7 u: K$ D! n; @
E, [0 V# d7 V6 G7 L# U6 B
, L; A4 {# a4 O s4 J6 \4 J UF_VEC2_is_equal(vec1,vec2,tol,&isEqual); //相等
1 n; b- ^$ U! A1 f% V; R* \ UF_VEC2_is_parallel(vec1,vec2,tol,&isParallel); //平行
f$ @$ P6 s3 X' m- e) x2 s' |' Z UF_VEC2_is_perpendicular(vec1,vec2,tol,&isPerpen);//垂直0 C' Q; D& {% X, q$ i
UF_VEC2_is_zero(vec1,tol,&isZero);//为0$ D1 j0 | C) v9 r4 o2 U
+ c$ t: V6 y4 r/ k0 ^
sprintf_s(msg,sizeof(msg),"vec1{%f,%f},ve2{%f,%f} is %d equal,%d parallel,%d perpendicular,%d zero",vec1[0],vec1[1],vec2[0],vec2[1],isEqual,isParallel,isPerpen,isZero);* T( R: q5 }( B7 J; [. k
lw->WriteLine(msg);. S) D5 v, }: t! l- G1 L
% S3 O' G0 h( \ /* * l( z- e0 z* v- O* o4 |
" R! r6 q, y* ?) `- c! p8 M 11 UF_VEC2_linear_comb : 线形组合! K) }( `: R2 g# K/ G
vec_comb = (scale vec1) + (scale2 vec2)9 y) @* c! D0 u9 [( y
======================& E6 p# Q+ S1 f0 T. N M% }
4 b2 R1 U2 C2 V: T$ B; N+ ~
# E) V. Z. j6 X, Q1 H# d7 z UF_VEC2_linear_comb(scale1,vec1,scale2,vec2,vec_comb);0 [# A; S2 F7 y0 [2 Q# f7 _" y
* B1 Y. Z, H( Y
sprintf_s(msg,sizeof(msg),"vec_comb = (%f {%f,%f}) + (%f {%f,%f}) = {%f,%f}",scale1,vec1[0],vec1[1],scale2,vec2[0],vec2[1],vec_comb[0],vec_comb[1]);$ ]# U+ u+ |( ?+ S3 @4 W! `
lw->WriteLine(msg);: k! K1 k' L! L% g7 }
" k+ `# R: x/ b# _7 F- |: F
& }0 L' ?0 f- d8 k9 g. G( H& \ ======================
/ W: Z/ [" [& i2 W* s5 n0 }( y3 i$ } 12 UF_VEC2_mag : 向量模
e& a6 S; Q' k magnitude = ||vec||
& X( L0 t- g: p: A) X% } ======================
7 Y h. |: }; H7 a */! y% W5 O8 a% G& y! X
$ ^+ J( V( m! H Y) f% g UF_VEC2_mag(vec1,&magnitude);
6 {2 m6 k, I, p; ]7 [# j N6 O: h( ~* X; o% I
sprintf_s(msg,sizeof(msg),"UF_VEC2_mag = ||{%f,%f}|| = %f",vec1[0],vec1[1],magnitude);! D/ S8 N& P& x, I- c" M
lw->WriteLine(msg);
+ E: `2 J. h0 U/ X7 R! y0 Q* B) C. Z) X8 p+ U
/* ( G, W8 p( J6 m* Z3 Y- [/ \7 s6 f
======================+ j) z, T) L% \) Q
13 UF_VEC2_midpt : 求中点 8 T3 B; d0 t; Y. d6 p& Q
mid_pnt = (0.5 pnt1) + (0.5 pnt2)
! x5 E! ^5 C6 U8 f' V$ w1 q ======================0 {+ N) A& _ R) E& r
; }; t6 Y! X1 M7 i5 o% ], N% `) s% ?4 E8 M: j2 r5 `4 k
UF_VEC2_midpt(vec1,vec2,mid_pnt);7 g- {2 `/ N- r2 B: R
1 T) m2 D; d5 `3 Y/ \1 g
sprintf_s(msg,sizeof(msg),"UF_VEC2_midpt = point1 {%f,%f},point2 {%f,%f} = (%f,%f)",vec1[0],vec1[1],vec2[0],vec2[1],mid_pnt[0],mid_pnt[1]);
3 x; X2 @" _6 f3 p% N lw->WriteLine(msg);+ z1 v/ ?! m) a8 t( B2 \( v
$ v% c% {5 W) t( O& X
3 X8 D4 n$ _2 d9 N ======================
; H) m4 y k0 \, s 14 UF_VEC2_XXX : 向量的其他操作,反向,求差,单位划
5 @+ X* a) Z& b" S" h5 E " S7 ^. @4 w) @5 d7 O
======================3 l# d! `* l# E' f/ r: E
*/5 h# k* C1 a' E! [$ K$ v
O' h8 M m5 E( \
UF_VEC2_negate(vec1,neg_vec);
e$ P" P! Z5 V8 d6 a3 e1 ` UF_VEC2_rotate(vec1,2,vec_comb);
, o/ g) L9 ]+ X# Q- E& g UF_VEC2_scale(scale,vec1,scale_vec);
4 c& O/ A1 |5 O% F) @ UF_VEC2_sub(vec1,vec2,sub_vec);9 Y4 L: J4 X" N
UF_VEC2_unitize(vec1,tol,&magnitude,unit_vec);
) t& L" i' i; O3 b& k
; ^ P, Y9 n9 p3 u& ]* ~8 J sprintf_s(msg,sizeof(msg),"vec1{%f,%f},vec2{%f,%f}:negative(%f,%f),rotate(%f,%f),scale(%f,%f),sub(%f,%f),unitize(%f,{%f,%f})",vec1[0],vec1[1],vec2[0],vec2[1],neg_vec[0],neg_vec[1],4 i2 @4 O- o0 E8 i* t% v2 {# k
vec_comb[0],vec_comb[1],scale_vec[0],scale_vec[1],sub_vec[0],sub_vec[1],magnitude,unit_vec[0],unit_vec[1]);; ~3 x3 l5 J, r
lw->WriteLine(msg);7 o- j) Y; R0 E6 J/ X( {$ f/ _
6 V; Y2 i5 L, p$ {
# |$ @6 I* B( A+ V" Z7 d1 p}/ G; @ a3 `$ \, R: b4 O& [
X0 F1 Y8 V# y! z1 |
+ ^/ P- I G0 a5 f6 K |
