6 V- [( I, O' O" }9 X, P1 m' l
【NX二次开发源码分享】关闭NX后,做点儿事
& h/ W7 L0 L2 c: B5 }- ]& q0 f k. y# d- Y- u( j4 n
[mw_shl_code=c,true]/*
4 d5 f3 R7 }9 J0 Y7 F! i% ^) E% J4 B9 W @
ufusr_ask_unload is invoked immediately following the completion of ufusr' Y2 G! H+ I& z( R& w/ r
(or ufsta when the dll is run from a startup folder) to find out when you' B' [0 W$ x* x/ T6 I9 X
want the dll to be unloaded. If ufusr_ask_unload returns6 A7 J6 _0 d- Z; V+ v, s( P* k
UF_UNLOAD_UG_TERMINATE, the ufusr_cleanup is called right before the dll is( g1 { \. _' ?) d" K
unload when NX is terminating. To prove to yourself that this works, set, s0 L5 ^5 Y6 }7 v1 {+ ^" b
the environment variable UGII_KEEP_SYSTEM_LOG=1 so that the syslog will not
/ w* }! ^1 }) Z h$ n automatically be cleaned up when NX terminates. Start NX. Use Help-> NX
o& M2 |7 Z/ X4 R( \ O# \ e Log File and make a note of the full path to the syslog which will be shown
+ ?) L" y3 V, N! ~# X) a as its own first line. Run the dll built from this code (nothing noticable, {* J* W% A: s2 R
will happen.) Exit NX. Find the syslog and open it in any text editor to
! ~. H* y E, J v see this line near the bottom:" {' p; W8 i: x$ ?. i+ f% B
- w7 L% q$ W5 C4 i/ w" B
NX is shutting down - running ufusr_cleanup
5 j8 Q4 y8 `9 k' [5 l! A9 c8 {2 x7 E! c6 ~0 u7 g
2 u. e6 V4 g8 Q: i' B#include <stdio.h>/ v& S4 V& q0 J/ s7 z' O- s
#include <string.h>
' R! z) \! I2 M7 n/ C: J- M7 o#include <uf.h>( |: _+ c9 q! m( I' T
#include <uf_ui.h>2 K6 B4 A2 G; z8 M
#include <uf_exit.h>- b* S/ P6 ^. {3 v6 b
" v, V+ W9 F2 o) \( k5 j7 Y#include <stdarg.h>4 r8 R# E. N B, Y j& N+ L) t
+ z7 B+ @" t; Vstatic void ECHO(char *format, ...)
8 J7 H" Z- ~( E2 q5 c{
. o* A% S1 X) p5 Y4 p: d char msg[UF_UI_MAX_STRING_LEN+1];
' L, E+ E( P' P0 C V2 E va_list args;8 K% P$ S# ^. d. e0 o) l/ r1 L: {( \
va_start(args, format);
- Z2 N+ E& \" @. ^" x vsprintf(msg, format, args);7 B! w4 Q* S& w
va_end(args);' m# {( h2 m- y* S3 v( w4 ^8 z
UF_UI_open_listing_window();+ x9 I6 N. n0 X, ?0 r$ B
UF_UI_write_listing_window(msg);' \% M5 s" g. ^- |) ?! v
UF_print_syslog(msg, FALSE);; J/ j. O$ t7 o
3 \1 F' q7 X3 R+ }
% P8 n1 W5 D5 ~ u; e6 p# W#define UF_CALL(X) (report_error( __FILE__, __LINE__, #X, (X)))
9 b4 z( O X: O1 a& I E& ?/ J0 }, j8 [4 u5 r
static int report_error( char *file, int line, char *call, int irc)/ r$ P6 V6 P. ~
+ o \, ~9 |9 d( A# F+ p if (irc)
2 U/ o. |; \. |, o+ v- V {
1 Z0 s2 f% S7 `, S9 g& i# q char err[133];
3 f6 n5 z4 |0 N+ m4 }6 w% M( y+ C5 w
7 d3 ]% f2 p0 H; u% Z UF_get_fail_message(irc, err);2 y3 j/ p0 \2 a: u# `
ECHO("*** ERROR code %d at line %d in %s:\n",
/ Z8 O9 z& H1 K& E5 e irc, line, file);0 y. n/ t7 O- a( _5 i3 z) X% }
ECHO("+++ %s\n", err);9 |# ] v# B- @. A& g
ECHO("%s;\n", call);! t% K# A& n' k. B! e/ T
}: o- ^! E# J3 ?/ X8 _) l& T. j
; W; n2 ^" H$ E+ t
return(irc);: E$ M' y7 V( F8 v5 {
4 G/ j) ]" T" {4 f6 d
. j5 Y9 Q; F3 e3 B) ], \. ^: f/*ARGSUSED*/
* Z; t9 ~8 d7 I2 pvoid ufusr(char *param, int *reTCode, int paramLen)9 Q0 M) S+ ^ i7 R+ h4 M% ?$ D1 C
{6 g5 r; M* ^% ?1 g! ~
, k5 N$ N; \- w4 X" K% u8 s" n# ~% K. X$ y8 I
/*ARGSUSED*// S# ? ]; Z5 K7 B3 y& \% p
void ufsta(char *param, int *retcode, int paramLen) t) ]# Q. t3 H. ^1 c4 j
$ n0 b: D5 s) m- w/ d}
4 j: F6 n( ?1 O5 \' C' f j* O- t
int ufusr_ask_unload(void)) i3 c. Y; v7 v+ u. |- S5 i
{0 y4 a' n8 R# A& f
return (UF_UNLOAD_UG_TERMINATE);
( \$ J T0 N$ c; {' u W x}( o' v- H2 m8 L7 Z9 p4 p/ }& l
7 `9 U2 m# Z8 gvoid ufusr_cleanup(void)& u# r% D8 J& F* f* h5 E2 T
' B, W& ]4 D8 q6 r ECHO("NX is shutting down - running ufusr_cleanup\n"); R/ p& S# H( a$ o; K1 Z
- n$ ^4 G) z% J3 f/ } /* put your code here */9 W' H7 {7 w, Y/ } h- x
}[/mw_shl_code]
" q* o" }5 F$ i1 j |
