Aras 安装完毕后, IE的一些常规设置
2018-7-13 08:28:23 2355 0
发表于 2018-7-13 08:28:23 | 显示全部楼层 |阅读模式
Aras 安装完毕后, IE的一些常规设置: @$ t$ `6 L4 D- s$ `- S" V2 b/ E
. L6 y  h/ q, E% }  f& g$ T 111.PNG 2222.PNG + `5 K( s; i& j, k0 Y4 y' k% k
Once you have logged into the client PC machine as an administrator, configure Internet Explorer 11
( V: R, J" D+ E' |0 x! ^8 i5 [# Dusing the following steps:
+ {' O( J+ c! t5 t: ~1.  Open an Internet Explorer window. & R% ]" T( _9 m1 J' `' d9 \' t
2.  Navigate to Tools --> Internet Options --> Security.
# k' X( ~; @/ n0 h: i4 v5 n3.  Select the Trusted sites zone and click Sites.
" U! E; j$ ]" w7 I& uThe Trusted sites window is displayed.
, e- _6 A: ~/ r4.  Type the URL for the Innovator in Add this website to the zone: and click Add. * y" p$ M. D$ r+ C
5.  Clear the Require the server verification (https for all sites in this zone checkbox.
6 E& |/ `5 |4 S' ]6 p6.  Click Close to exit from the Trusted sites window.
" B0 E9 t) T) D7.  In the Security tab, clear the Enable Protected Mode checkbox.
4 N1 H3 C# L3 f+ p# N; Z8.  Click Custom level…. # H) R; q4 x* H- _
The Security Settings - Trusted Sites Zone window is displayed. 8 O4 J/ W2 ?# a: e% K% F) ^
9.  Configure the following settings (scroll down to find an appropriate option).
0 G" Y/ Q) p6 T' h; ]# y, co  Downloads
5 N8 x0 B/ X4 I- e  Select Enable for File download.
& v5 m3 Q) G6 H2 N+ z0 ?o  Miscellaneous
, [. ]( x: V: f' E! `  Select Enable for Allow script-initiated windows without size or position constraints + q8 d+ X2 F3 I$ m
  Select Enable for Allow websites to open windows without address bar or status
% o( {, v, Z0 m6 g- d0 I7 ?bar. * `4 R' z4 m  {* V
o  Scripting ' s$ }6 ^7 ~: x+ i/ \" {
  Select Enable for Active scripting.
. N' \6 ?6 E; m1 ~5 k10. Click OK.
& w! @9 P* {) u4 n# M11. Click General tab. 3 B" M2 X  ], _% f! z- U3 b% u# `3 N
12. In the Browser History section, click Settings; I* l4 \& Q% F5 C" e6 L
- i% B8 B: N+ x+ m
The Temporary Internet Files and History Settings window is displayed. ' H1 a. x2 I' x; g
13. Select Automatically for Check for newer versions of stored pages. ( H* I5 }+ A. v: ]
14. Click OK. , T, B0 Q+ }$ t0 E! h, A
15. In the Tabs section, click Settings. + }  J5 q+ d1 L: I- T
The Tabbed Browser Settings window is displayed.
/ }  u4 ~8 D/ m" ^; U! D# `16. Select Always open Pop-ups in a new window for the When a pop-up is encountered: ) k0 S6 u; c; Z: e. w' Y
section. , l- w3 [* W$ t
17. Click OK. % c5 l) n9 ?" ~5 i4 [
18. Click Advanced tab and configure the following settings: 0 e! p# \# t' c0 E! A
o  Select the Disable script debUGging (Internet Explorer) checkbox.  , a6 p+ W8 N& m, h' A
Aras recommends disabling script debugging for any user not actively debugging their client 5 T- E! V4 x: I; W- N6 l
machine.  This is only recommendation and not a requirement.  For more information, refer to
, j8 ^. n: w' Y9 Jsection 2.5. 4 }2 D2 c; j$ @. g0 d  S1 q/ M
o  Select the Disable script debugging (Other) checkbox. 2 ^7 F7 F+ O* V5 h) C7 z& |8 D
Aras recommends disabling script debugging for any user not actively debugging their client ) b$ \1 \+ E4 @6 u, C% U" X
; X  d' D6 d) X' u7 W) c2 v' vsection 2.5. ' A( R1 k# S( B% R
o  Clear the Display a notification about every script error checkbox.
# N5 j' H+ G4 a; l$ [19. Click OK. : {. @% k! S% S  K/ ~( d$ r
20. In the Internet Explorer menu, Navigate to Tools --> Compatibility View Settings. 8 {2 o  L5 J, z! v5 V6 C* m: V
21. If the URL for the Aras Innovator instance exists in the Websites you’ve added to Compatibility
7 u2 Q( y5 A" ~+ i1 GView: list, click Remove.
: S% s3 k5 ^# G0 w3 t22. Click Close to commit the changes to Compatibility View Settings
! [- R# l* T, U+ N! B: m5 U0 [: x7 S- e9 L$ K" @, n8 y
按照浏览器设置即可!!* N. S& `0 H0 _
, V0 U/ [. l! B# X& |: c# f. x
