Aras Innovator 12.0 发布,界面变化很大,也很现代化了
2019-6-16 20:05:10 3804 0
发表于 2019-6-16 20:05:10 | 显示全部楼层 |阅读模式
NOTES: Aras Innovator version 12.0 was released on May 31, 2019.
' ?$ W# m8 t8 H0 u3 T2 w9 O! c0 d( z+ T$ u2 s  P6 a
Enhancements in Aras Innovator 12.0
# ^' J& E3 H/ z" k' q
: A0 q- _+ N/ Q2 P! L: m! u1 ?Aras Web Client UX (User Experience) Enhancements" f2 E9 Z- l, r
The web client has been significantly updated to provide usability improvements that will help every Aras user to get their work done faster. The entire navigation approach has been rethoUGht and updated for maximum productivity, and styling has been updated to be clear andconsistent throughout. These changes represent an evolution of the existing web client, not acompletely new client, allowing existing client configuration mechanisms to be maintained. The 12.0 release introduces many specific new features listed below, and sets the foundation for further UX improvements to come.% g" }3 H& z* n3 h# b" q0 ~
 Run in browser tab: The client now operates directly in the current tab of the browser,without opening a separate window.
7 d6 w; R, _# O' L# u Support for Authentication Framework: The client has built-in support for the new Aras Authentication Framework, making it easier to define the authentication approach,6 ~; o+ Z% q, z" m; V. N
which is then directly available to users from the login screen. Enforcing OAuth is now available in Aras Innovator. In addition, implicit grants for web clients can be enabled.4 a3 U0 E4 Q  k
There is also improved infrastructure for authentication plugins.8 [$ _1 l, W/ D# z
 Navigation Panel: This new panel provides the main entry point for navigation in the system. It initially contains the Table of Contents (TOC), with more features to come.  o8 z! `$ p7 Z6 D5 R% w; ~. a
 Improved Table of Contents (TOC): Both the usability and styling of the TOC have been improved, to clarify how users access their available ItemTypes and HTML pages% p( m: K7 q1 h" C7 ^2 x. \& E( U6 p
(Dashboards)
: ^: u8 t2 m+ x4 ? Everything as separate tabs: Searches, Enterprise Searches, and HTML pages (Dashboards) are all now supported as independent tabs, which can all stay active. Q0 y+ T! M8 |, j: `: ]
simultaneously. Multiple simultaneous search tabs for the same ItemType are also supported.! u0 b  y1 Z1 v& W
 Updated toolbars: Access to commands has been consolidated to context-specific toolbars, where the most common commands are clearly highlighted and secondary
- W! e3 [" ]( |commands are grouped in convenient dropdown selectors. Each toolbar has a clear title to indicate the contents, and command names and icons have been updated as well. All
  h( i* |9 E9 {! G9 c( H1 R# |7 `toolbars can be configured using Configurable User Interface (CUI) modeling.8 n- [0 o4 C& m
 Simplified item editing (Edit not Lock): Users now click on the Edit button to edit an item, and on Save, Done, or Discard after editing. The concept of “locking” still exists at) n" W$ D* E) ?! B& y* w% y
the database level and remains unchanged. Users also have the option to set a Claim on an item (which locks the item) without going into edit mode.( t, |7 Z% E9 d( I/ Z+ G
 Item accordion view: The main view of items has been updated to use accordions, providing a more modern and convenient way to scroll through item information. Tabs, y' x# r( k5 f: @
can be selected within each accordion as a second level. Standard Aras forms have been simplified to remove the redundant “Item Info” section on the left.
1 \, t  u% b& s. n" r1 k New Favorites approach: A simple, consistent approach for Favorites is introduced in this release, starting with Search Favorites. Formerly known as Saved Searches, they
1 t; c3 h$ e# Y+ b  F( lcan be easily saved by clicking the star icon on the toolbar. The Favorites concept is planned to be extended to Items and other content in subsequent releases.$ ?5 `7 D2 D* }+ E# D
& W: |7 |  w6 }/ m& i
, C! J: ]: t6 T0 E4 g" }7 U/ z9 K
) z  {% I7 J% A0 I" G
