查看: 2605|回复: 0
Teamcenter二次开发源码分享: 创建Item Create Item方法
发表于 2020-2-8 09:26:33 | 显示全部楼层 |阅读模式
, n2 _# x8 j3 T3 Q
; J2 W3 n' G# j5 n; R, {# W2 @( n) d+ W- k
[mw_shl_code=cpp,true]#include <TC/emh.h>6 l  ?+ b. i7 _3 ~
#include <tc/tc.h>0 E1 n  l5 m% O1 \0 m
#include <tc/tc_startup.h>; d' ~& T( n4 V/ j+ h
#include <tccore/aom.h>3 s, q$ v6 d7 B: J6 R" }
% }% e* g, [5 c! f$ W
#include <iostream>) m/ E: X' n) V$ k( m6 K  s6 L) H
#include <base_utils/IFail.hxx>0 \6 }# j+ E7 s4 n
#include <base_utils/TcResultStatus.hxx>
' x1 z6 |0 U3 G! P2 z  `#include <metaframework/BusinessObjectRegistry.hxx>
$ W4 |2 L' y9 d1 M( f#include <metaframework/CreateInput.hxx>" s! _3 Q  b' M+ g" \
#include <mld/logging/TcMainLogger.hxx>
! n; N8 d% `  r! L' W8 g1 _#include <tccore/Item.hxx>
& V* x$ |% k8 C" X/ R
9 ~4 p3 O4 X. K. y1 r' ?, Tusing namespace std;& q8 u7 _: I  h# M. W
using namespace Teamcenter;
! \: }: p7 P0 Z$ T& Gusing Teamcenter::Main::logger;* Z4 b3 T5 E7 t  W0 |
  T: g/ v& j5 I3 v* G
int ITK_user_main(int argc, char* argv[])
. }& G- l! v# x' X6 ]{. Y5 G/ x5 `: D
    int ifail = ITK_ok;
( Q0 C. v, j4 T/ g+ }& f: X    ResultStatus stat;! T* Z, [% Q$ f# A. g
    try
- q9 d& R* t2 x# ]    {$ P6 h0 S" ]* F% a* l: _1 [5 r
        stat = ITK_initialize_text_services(ITK_BATCH_TEXT_MODE);
' F# n- ~1 d: Z+ X        stat = ITK_auto_login();
! ?- q, ~" Y, W$ B        stat = ITK_set_journalling(TRUE);9 A  u/ e  U- e/ e) ~3 G
* T4 F& j: o% B. F( @" [$ O
& r$ v. Y) W5 [  h) \2 D        BusinessObjectRegistry& boReg = BusinessObjectRegistry::instance();
1 _( W- }) ~+ W& l        CreateInput* pCreateInput =
% O8 N/ _+ |3 y+ f7 v            dynamic_cast<CreateInput*>(boReg.createInputObject("Item", "Create"));
! a1 C$ ^/ A- K/ ~- ?- B
; z3 L  i, r: A- h) c        Item *pItem = dynamic_cast<Item *>(boReg.createBusinessObject(pCreateInput));
: d; m" F+ ^1 h1 W7 [  u6 |4 p5 U# ]; O; P; V2 r
        tag_t tItem = pItem->getTag();) ~+ B7 S, r" E/ w3 k, {
# Z: O6 \& [# Z! x6 h        string sId;
: i7 e  S9 l1 A1 _( _0 }! s        bool isNull = false;
0 T5 y6 W- }& r  ~+ `        pItem->getItem_id(sId, isNull);
4 J% a4 {' V. x; U        7 @/ `3 ?, P( q5 T) p' X
        pItem->setObject_name(sId, isNull);
# l. Z# n# j2 b' ^4 b6 S+ N' U% g& _* Z
0 y% |" K+ }+ c$ b, W; ]        stat = AOM_save_with_extensions(pItem->getTag());
" |4 {: n0 {; i0 H; b- O* d& ^5 a# \- }  z' t. v7 e
        cout << endl << "    ID: " << sId << endl << endl;/ Q: @# _2 W0 a
: F6 }3 R, q+ [& Q/ {. h    catch( const IFail &ex )
7 ^3 }5 w2 e8 z# h% n. y    {
9 ]! h+ R5 Q. }4 _" p        logger()->error( ex.ifail(), ex.getMessage());, d  b/ J# [8 @
        cout << ex.getMessage()  << endl;
# V% H4 K& E9 X! O- E4 a        cout << "error " << ex.ifail() << endl;
2 f* U9 Z' w" Y# J    }
1 d  [: t- r% V$ g) ^# ]3 h    const char* syslog_path;3 m& b" K3 y+ D' o, z
    syslog_path = EMH_ask_system_log();
0 S) P4 ]0 ^. F    cout << endl << endl;8 g2 _  ]2 K. l: c& ?0 t
    cout << syslog_path << endl;
+ G! b; P9 |" n6 ~8 k* {4 {5 X" }5 H. e4 l+ ]+ U8 l" p5 _; R1 s% E; A
    stat = ITK_exit_module(FALSE);
( d7 ]% X2 ?5 r0 q    return ITK_ok;9 M6 c. w& T, Q. O
}[/mw_shl_code]
! V2 e* E1 n' ^; Z
