3 y+ P- s0 b$ d+ N4 @: lNX二次开发源码分享: 打印已经修改的零件信息
8 u( Z& v1 }4 a! }! C( \
+ R5 g1 R- m5 a; H[mw_shl_code=vb,true]Option Strict Off
: m( a1 K" m e& b8 M( w9 w, S' k1 [8 S2 } Q3 T! u+ n2 w2 D
Imports System
! I3 s! P0 q: ~/ ?; d1 k% P3 sImports NXOpen
/ q2 z* x y% v, ^. }1 lImports NXOpen.UF4 T* U6 k \' A
+ S$ E8 U: D1 w% y
Module report_only_modified_parts1 G9 ^* F$ |/ E5 S) Z
$ m5 B; l" b" E. Y/ a/ z! A
Dim theSession As Session = Session.GetSession()* v4 l0 ^4 Q' k X3 v8 ]
Dim theUFSession As UFSession = UFSession.GetUFSession()
+ L' c2 o. I/ b& \* G Dim lw As ListingWindow = theSession.ListingWindow
; F: n: `9 I* r4 x+ S! V1 _* {& E/ i, o0 U/ F4 f1 v/ W; r) z
Sub Main()
$ p! h' @# t+ F; |
5 p$ W- g5 h2 v2 V7 h$ H lw.Open()5 F+ o# w+ N3 k- v: L
/ ^4 H' ~1 ]3 H/ N$ Z
Dim pc As ParTCollection = theSession.Parts
- V$ O' p/ O& C; w5 ? Dim part_array As BasePart() = pc.ToArray()$ T9 P% ^ R E) S) u9 D* r
Dim num_modified As Integer = 0$ b9 h" e% w0 S: ]& }8 ~2 o
Dim num_parts_in_session As Integer = part_array.Length()
. Q" I, ?" W7 P4 ^4 p$ @( w2 s; m) R
lw.WriteLine("There are " & num_parts_in_session.ToString & _
9 {" k2 c& G8 H* ~3 g " parts open in this session.")0 ?* f. {3 k6 `! |8 b2 |8 _
lw.WriteLine(" ")1 v) B5 q6 H, _, f3 j% y$ F
& \6 F3 p9 c& Q+ p1 E( a
For Each p As Part In part_array% t2 Y; `7 \7 u& v5 i7 u
( e |3 U8 T [+ ?
Dim isModified As Boolean = theUFSession.Part.IsModified(p.Tag)9 e3 W6 J$ O. c, ~
! t: D( V" @ E, V- o3 g' U1 T If isModified = True Then
A* K8 U$ h% B) T8 {; S8 n3 j8 w lw.WriteLine("Modified Part: " & p.Leaf.ToString)
! O+ z5 |4 g; Z- L( A3 t num_modified = num_modified + 1
1 p7 ?) f) C! y0 G End If
0 A3 @9 i |4 X2 A" W& f' v+ u
+ s1 a' x; x: l, z. Y9 _) M Next: b4 I; n* ?; W. I" Y
* A1 M$ q3 F s2 [' {7 V( L6 @
lw.WriteLine(" ")
! W5 U+ O6 y% A I& w- j lw.WriteLine("Number of Modified Parts: " & num_modified.ToString)$ C; M" ^' t. l" ^. z( v$ L* b7 h# o
5 ^# y$ }2 b! b# j8 g/ f. E/ w
End Sub
# ~1 t- Q1 y& u, |- @0 |) u; G: m- f" P1 N! W
Public Function GetUnloadOption(ByVal dummy As String) As Integer; h) Q% O( R9 Y, w6 `% U
Return Session.LibraryUnloadOption.Immediately
5 ?7 b" z% l8 y W End Function$ R$ [. T+ `4 s6 `3 H
3 x4 g; H/ s" W- E) i
End Module[/mw_shl_code]
: Y5 z6 e; L ~& F8 h |
