记录自己学习过程。
2 k% w4 G& r: f V+ H Y! Lextern DllExport void ufcre( char *param, int *returnCode, int rlen )
9 C% j* J3 x' N4 U% p* Z! C{
2 i1 U8 ]3 a$ B5 x/ x0 ]" } /* Initialize the API environment */
' @9 n1 H* E' K$ ]0 b5 O" T& `- e! c if( UF_CALL(UF_initialize()) ) 8 @; V; ^4 K7 a' Z
{1 S9 N- O8 `5 O# @ P' ]' P
/* Failed to initialize */6 n$ g6 u, _' f' a8 _$ D k
return;
6 X- s$ M) k7 h }
/ E4 v- M. |( B; P
7 b5 t& Z) H8 u% ] /* TODO: Add your application code here */
' S n& t. }0 b( k- g uc1601("This is new !",1);2 w. e( m( @& a0 z
/* Terminate the API environment */0 N$ x7 m1 L7 Q: q' o
UF_CALL(UF_terminate());4 _3 X% ?$ E8 e7 M. i2 G
}, g/ }* R6 V- ~; J! X$ J
8 N7 [+ \/ }5 k% m
0 T3 Z( `$ L N& F' {** Utilities
6 P( r+ j @8 G6 \: t& x*****************************************************************************/
8 a" m4 [4 {" U, o9 w. Y$ @" `6 w
8 b. B& x. A7 }# S7 {# r( `/* Unload Handler
0 K+ `% g, z0 R6 v$ r8 \1 ?* k: h- f** This function specifies when to unload your application from Unigraphics.. g! Y4 g" o. C' Q- w j
** If your application registers a callback (from a MenuScript item or a
% A7 }, r' f, q** User Defined Object for example), this function MUST return) j. o8 P) W9 A' L# g9 E7 c" w* [
** "UF_UNLOAD_UG_TERMINATE". */' f# u/ L7 S, A- Q5 k
extern int ufusr_ask_unload( void )
) P: P! Y6 N( b3 V1 D" L6 e) m{
9 [# y& y1 y( L9 C) I* ^ return( UF_UNLOAD_IMMEDIATELY );
; i7 H" V- p6 G}: m3 U: _3 {* N& E: N
: x" Z& t0 K( R. u$ w3 t, a/ K |
