[二次开发源码] UG NX二次开发源码分享:创建自定义引用集
2014-9-27 21:06:44 4132 0
发表于 2014-9-27 21:06:44 | 显示全部楼层 |阅读模式
( |# J! |, I+ E1 l1 E6 h4 I% ?  D7 Y1 ?) y, G; }# h4 w
! `. {$ S$ f% p1 V
2 s6 ]& Y0 }9 m9 V8 G//create_specified_reference_set( o1 J! @6 ]: L  {8 Y
3 p- b# \3 N( w1 p1 I
// Mandatory UF Includes# f- Q2 A* @+ i
// UF_initialize, UF_terminate, uc1600- G& I) }. x& y, N2 i
#include <uf.h>
  i; l2 T- T: R+ {, \8 |! W, H0 f#include <uf_object_types.h>1 ~6 G9 Q$ N9 x
#include <uf_ui.h>) X- J+ \+ |' G6 R  O: ~
' P' B- i3 r' W! }5 |& ~// Internal Includes) d) a* Y8 P. y* ~
#include <NXOpen/ListingWindow.hxx>
% ~% m3 z8 M  L8 g#include <NXOpen/NXMessageBox.hxx>8 f  n3 c7 p8 p
#include <NXOpen/UI.hxx>
! g9 |( r# r7 b' Q( M
; t7 q/ C# u4 b5 [// Internal+External Includes/ D4 K4 R# g  ~' \
#include <uf_defs.h>
: S4 W# \3 A# W9 c#include <NXOpen/NXException.hxx>: O4 U2 n7 [, ~$ B  v
#include <NXOpen/Session.hxx>
* z! l( {' v) D2 ?6 T( Y* j( W#include <NXOpen/BasePart.hxx>6 L) Q$ j$ {4 n) H
#include <NXOpen/Part.hxx>
& B# _+ f# J" u$ L  d#include <NXOpen/ParTCollection.hxx>1 ~' n, T. j# C# a( C
#include <NXOpen/ReferenceSet.hxx>" u, F6 V& z: E% n2 `
+ ~  e6 c5 G6 f6 I* k$ n( h8 O#include <NXOpen/Update.hxx>
, W( I& B( o( r% u) \) s  a: J; v" |; K  N5 W4 ~/ a: `1 h. Q  S9 P
% x2 \+ o: ?, ]! r  v4 f// Std C++ Includes5 ]: D' T3 v; u# w% c9 F
#include <iostream>  X2 g  A2 u2 W/ b5 ~% a
#include <sstream>! C9 ?) v6 Y2 w$ {+ T
+ X$ H1 r. a( T5 v
using namespace NXOpen;0 d5 L/ G: Y: Y
using namespace std;
5 T* F: d) c# Q, M) Y. o3 F
' a' q8 ^( e2 w) I; }0 P//------------------------------------------------------------------------------( K, ]" b: Y) Q# `8 v
// Open C error handling
* _/ [% e% `; R//------------------------------------------------------------------------------
. S( c% u) M, W#define UF_CALL(X) (report_error( __FILE__, __LINE__, #X, (X)))
6 O5 `* u' J! S# Xint report_error( char *file, int line, char *call, int code)
7 [" j( O! _6 b: m. r{' s0 c, s5 R/ \1 R* f7 y+ Q
    if (code)
9 v% K' M% u7 `    {  |+ h( k, x1 @/ v1 \& l
) M) E( s! a$ n/ [: A  I        stringstream errmsg;
  W& x! K/ U# ^0 n: g* n3 T8 I2 t        errmsg << "Error " << code << " in " << file << " at line " << line << endl;) K0 t) w* J; }: E5 j7 g/ ^
        errmsg << call << endl;( W: J4 ^" @& U+ q4 ]& t  w3 p- z
        UI::GetUI()->NXMessageBox()->Show("Open C Error", NXOpen::NXMessageBox::DialogTypeError, errmsg.str().c_str());
1 c+ B# i( L, ]( q6 D        throw NXOpen::NXException::Create(code);
2 A3 Q1 q$ D' t& ~" F    }
0 a: `8 Q0 I/ x! _3 M# x    return(code);
$ p4 [/ _( t9 @+ O9 B}
- w) e0 k7 o1 D3 f5 m; h0 \: H+ V; n7 R: u# k
//------------------------------------------------------------------------------, x3 Q! y) b2 e3 q9 S
// NXOpen c++ test class
1 ]6 X1 l: x, ^& W$ S; V//------------------------------------------------------------------------------
" E9 i+ H4 ~  \, uclass MyClass
& Y1 U( {* V/ a. a1 e$ o{
9 C: l4 W+ k; [3 R1 G' h. r    // class members
6 W3 v  E- X+ xpublic:9 l9 W7 g# y; C
    static Session *theSession;
* B3 e" z7 z2 M2 J* T    static UI *theUI;
3 z) E  K3 e  @3 Q9 q- \3 Y5 e
& O( s# ~3 y! d- g9 w) ?    MyClass();
) _5 u+ |3 K. ?3 h2 v  b    ~MyClass();
! Y5 x6 C" T7 h7 }0 f- D4 F
" c/ I. i' K( m) _  a) e( f    void do_it();- ^" `" x" H# q' x3 s! W
    void print(const NXString &);/ E2 f( O8 ?1 d, {
" k+ o) }- b  }+ S4 V, D+ Yprivate:
6 ]6 X" l) u, g( D$ ~    Part *workPart, *displayPart;3 ]# s7 v- c0 d) b! \3 L
    NXMessageBox *mb;, U9 w8 I  A2 t$ j+ ~/ R
    ListingWindow *lw;
5 h( V/ B2 z, {  F& u1 q};
' l  H. g- F3 r! j% N; E/ V( @# e% }4 Y
9 P; b' `$ Q% L- v" W//------------------------------------------------------------------------------) R6 K$ G6 q8 T
// Initialize static variables
" B. ?- N# D  `& K//------------------------------------------------------------------------------
8 Z/ L5 y2 n- n0 h+ \+ kSession *(MyClass::theSession) = NULL;( e- ^5 n; i, K" j) v, q; s
UI *(MyClass::theUI) = NULL;! O6 U# Z6 |5 V( G$ U4 h; S
* r, C% Y/ [4 {6 ^( B  s9 l//------------------------------------------------------------------------------( b6 k$ Y& H. Y5 k/ _
// Constructor & p# {/ M' G; X2 ~0 I' j' O
//------------------------------------------------------------------------------1 n+ }, o5 ^, [4 x, o1 V$ a
MyClass::MyClass(); D* n; p) R( c
{( u0 M7 b/ z+ o, c$ _2 c# Z# b
    // Initialize the Open C API environment */
8 T( k* j; F: O+ ~5 Y% w3 k    UF_CALL( UF_initialize() );
( r( W. e) M# i( H8 s1 j" F2 d
% K7 o( z& E/ ^0 s. g4 ^- a    // Initialize the NX Open C++ API environment
! F# M" Z$ R) j1 v4 y+ Y2 Y    MyClass::theSession = NXOpen::Session::GetSession();5 Y, U0 s* Z  |) P; U& t! E
    MyClass::theUI = UI::GetUI();2 D6 Y! F/ n: A
    mb = theUI->NXMessageBox();
6 E* |5 t: y4 L/ Q/ I+ t9 D+ v: s    lw = theSession->ListingWindow();0 ^+ M/ b/ p  \3 o' q
; l8 i) e2 N+ @
    workPart = theSession->Parts()->Work();$ `# V) Z. K& q2 k2 H6 }
    displayPart = theSession->Parts()->Display();
- w' r& K/ d0 |7 p, S1 p    7 F, m  m7 X  H2 ?
$ b. M& O( O2 D' {8 U9 j
$ S6 u+ F. d9 F* K5 x( |- z; Y//------------------------------------------------------------------------------
6 Z% r# [& I" T2 D$ f- h" ~// Destructor
, t( M7 w8 T' G6 v* v* [//------------------------------------------------------------------------------* F& C7 y+ g, ^# s7 s  _
MyClass::~MyClass()
$ O* z: L% s( z& S# _, [  L" m6 q{. x2 I) m( I, Y2 ?
    UF_CALL( UF_terminate() );' [7 f' J, u, r
& S2 H) V) A6 U; w; J1 A; _: N( \" H4 A! F, [1 z5 }! [
//------------------------------------------------------------------------------& V3 Y7 W+ R) r' r, j% Y
// Print string to listing window or stdout* ], \0 U7 |& B4 E" X
//------------------------------------------------------------------------------1 a! e  P; Q, g6 b, o2 a% Y4 I- C
void MyClass::print(const NXString &msg)" O. t% }- Q/ ^/ a+ a& c4 @& @$ w9 M) ^
{; z1 d3 A' O% e* a
    if(! lw->IsOpen() ) lw->Open();, B/ l; g: ]0 h. l- g$ e5 X- a
    lw->WriteLine(msg);
2 P" g& X" U1 t0 D- i  i  ]}3 X# W1 D9 Q' Q7 Q. l
3 A8 k0 {9 N3 Z( L2 k* A/ n
" d, r$ l+ c" J0 [3 Z
6 p9 Z7 b( m& ~
6 k; ^  W- f/ g7 _//------------------------------------------------------------------------------3 s- x# N! i6 l  S0 Z0 Y3 W
// Do something
% }0 J4 F  P- O: ~//------------------------------------------------------------------------------
9 E; ?! U+ Z+ _, v, ?: J% @; x3 G2 }void MyClass::do_it()
5 \7 F; g) X3 X{
6 e# c' o' c. N! ]* r& ~    // Prompt for Reference Set name7 m+ m6 k; q3 g& y6 N
    char refsetName[133] = "My Bodies";
/ J# \, S, q; ^3 N; ~    int length = 0, resp = 0;) O$ M( e. h' }3 a5 s* q) b* k# F
    resp = uc1600("Reference Set Name", refsetName, &length);0 M$ M0 F3 Z& n2 ]5 C3 j0 U& T
) e& d) t0 F' X0 U: E6 |    if( resp == 5 || resp == 3)
( `) u" ]1 i# q& V- f    {
* c( J" f( @2 j4 C        // Create Reference Set
: Y. w7 u5 Y, n4 V8 X! H        UI::GetUI()->NXMessageBox()->Show("Reference Set Name", NXOpen::NXMessageBox::DialogTypeInformation, refsetName);
4 s  P/ m8 I; X/ m; H8 j' ]4 J; S& r, {" q% y
        Session::UndoMarkId markId1;- t- I: A5 U3 n, f. s" j
        markId1 = theSession->SetUndoMark(Session::MarkVisibilityVisible, "Start");
( Y+ s, f2 y: k( [
: c7 m7 r! S2 H1 J6 A        ReferenceSet *referenceSet1;
1 Y% H( K4 a) B0 Z        referenceSet1 = workPart->CreateReferenceSet();  O6 a6 E9 M& D% p6 n" \; [
        referenceSet1->SetName(refsetName);
- ^* _8 h5 Q$ K1 P9 t    & U3 v4 w& l$ s: g0 d0 X
        int nErrs2;9 Z" v  {) ~/ i& L* A  D
        nErrs2 = theSession->UpdateManager()->DoUpdate(markId1);4 A( J$ l2 W; s
5 n+ |% Z$ n0 `# x& p& H}" k  t6 \% i/ F4 [  f: g6 W
" W7 ~6 c7 O' G4 K9 y4 l, _
//------------------------------------------------------------------------------- s0 |: K. o2 q& {& A1 q, K# ~9 C
// Entry point(s) for unmanaged internal NXOpen C/C++ programs
$ a  S8 \% a9 s//------------------------------------------------------------------------------9 g4 {1 L6 b! o: }7 k9 S
//  Explicit Execution
6 l6 I! u) O9 X6 s4 {7 o: uextern "C" DllExport void ufusr( char *parm, int *returnCode, int rlen )
2 }/ \4 u# W* E; z8 B% i{
2 M/ b+ T. o  i9 A! V+ v+ r    try- U6 i' I' Z5 ?, \. ^' t8 B8 o3 u
    {: I" ~. |! R# F( `0 q6 W
        // Create NXOpen C++ class instance
  r1 K+ b3 g& ~1 E        MyClass *theMyClass;
. X9 w6 U- x2 L0 d+ Y5 Z3 X/ d        theMyClass = new MyClass();9 p$ z: r4 y4 ^9 ~* \' U7 b
        theMyClass->do_it();8 F3 E5 ~# b& n$ o
        delete theMyClass;: H; v% @3 y' N& ~
8 z: H% T1 x% y2 k1 y* v    catch (const NXException& e1)
' _, I3 T: y6 @/ k; k    {
! @' k  j4 W. n7 S        UI::GetUI()->NXMessageBox()->Show("NXException", NXOpen::NXMessageBox::DialogTypeError, e1.Message());
* v' ]9 }/ b  O/ E& `1 p% L' Q    }
/ u0 ?0 Y3 }  W( I9 F    catch (const exception& e2)
# L1 k/ O  b3 D# ^3 h9 F    {( ^6 N( ~* F3 ?+ a' S
        UI::GetUI()->NXMessageBox()->Show("Exception", NXOpen::NXMessageBox::DialogTypeError, e2.what());& Z0 x0 `0 p: z+ l, N7 G
; Y7 }2 l4 l6 b' v    catch (...), i: V! \* d3 R, [% o
    {8 m# g4 l% v* g, X$ Y
        UI::GetUI()->NXMessageBox()->Show("Exception", NXOpen::NXMessageBox::DialogTypeError, "Unknown Exception.");: J! F5 \6 a5 b* V1 E( C
    }2 [% Z9 y% |1 L/ `/ i7 y
}2 u: f- C' A% C& R
! U+ b  ^4 T' }. F4 ~5 [
% H2 q, x0 O7 h' o; Y$ a# l! v: G( A5 S; g
//------------------------------------------------------------------------------. s& Z' v9 _$ \5 Z, `: X; p/ O
// Unload Handler% Z' |, s  L5 h. K; t
, `3 F" Z* J! O- _extern "C" DllExport int ufusr_ask_unload()$ Z- L+ |4 r0 r0 G$ A. |& a6 l
{4 E* `+ t& d* r; H" r
    return (int)NXOpen::Session::LibraryUnloadOptionImmediately;
/ O& K& ~4 J! d4 @}
8 o" P4 X+ [/ p5 B( h6 Z2 T
( W$ j# u5 q$ P+ S8 L
; p1 F$ R( R/ l1 k2 U8 u' V
