[求助] 克隆装配问题
2014-10-6 19:44:21 3775 2
19
发表于 2014-10-2 10:53:21 来自手机 | 显示全部楼层 |阅读模式
如何将克隆过来的零件只装入当前会话中;并未在当前目录生成文件;只保存的时候才生成;就像moldwizard调零件那样;请问怎么实现?
发表于 2014-10-5 09:15:34 | 显示全部楼层
这个是加载零件到内存
. v) {% i. k% {* E; G8 K8 U" T2 H9 L- a) }
UF_PART_open_quiet (view source)
0 K7 x) J; A2 _' d# _; s0 T: M
8 h7 S1 c& L- c  r+ f) U. e, o1 d5 B
3 f5 n( P7 c+ z  sDefined in: uf_part.h
& L' g' `/ T' E
: v5 E7 E! C4 B! w" l
4 V& P4 M6 I# g
/ o3 n- ^3 H  ?2 e" L! T  [4 HOverview
" n1 e& _. `5 ]3 j0 X5 U. z/ D2 u+ v7 `  d! c& v( ~* G0 e0 ^
) g+ Z/ j9 n* c; ^) YRetrieves an existing NX part or Solid Edge part into the session ( F, t  ~! A# B# B0 d  S
without making it the work and display part. Solid Edge parts (.par or ! |9 d: T8 K, `2 m
.psm file extension) are opened by extracting the Parasolids data from
1 N" a! p6 V1 S& b1 H- o0 ithe Solid Edge part and then importing this data into a new 3 F8 _+ q% e; @& |# W
NX part with a .prt extension. The file name of the new NX 2 t9 ^7 _2 O: b$ S. O
part has the Solid Edge part name and a ".prt" file extension.
1 T- i+ s. s' C  gIf there is an existing NX part with the same name as the Solid Edge part, ' L0 P8 @1 q: I: B
then this function returns an error.
. C3 }/ L/ _  Z
6 Q, B! M3 S- \5 u: g1 N
9 g/ l- u( M& w9 f/ K. W" i! P* ^+ X5 b- D* Z* `: b: S
Environment
" s  {4 E! `4 k+ }5 a
1 U. @- l' o9 E; O9 C  W) b1 ~. K5 i8 V4 Y
Internal and External : y. z, i" ?, m! H9 S! x
8 K) g) C. N3 a7 v4 F$ B4 }6 {% H, f" e( U
5 n  Q9 N6 p* @
History' a/ F+ e9 U' @" O
6 @& F: V! H; Y* j9 H
* }" n6 i, T: a' s6 p, e9 xIn V15.0, this function was enhanced so that it could open Solid Edge
* |) D3 S; m6 h7 L; e+ n( o+ q3 ~ parts. + q& o3 V  Z% }& D; q+ s( F3 l+ \
0 J' V" h$ m6 q3 y1 x
- G, l' P" g" z# X8 p- G+ P% P. u; b  Q& j" Z! n* O0 r
Required License(s)
3 ~& Y" \4 k& p9 d$ [! u3 V: u$ I# ~/ @
- W! X  Y/ V8 w/ ?7 `  X" X4 j: P! n' m; {2 j# ]0 E  \
gateway" U7 Q$ V5 ?$ r# C2 Q
$ y) B9 Z! Z/ j5 A7 W& Y
8 J. g. C5 l* S ( b; s3 [% d* @, C" X
. W" T3 P7 m+ |! T
int UF_PART_open_quiet' r& `1 l0 }  O6 |
(; {$ u% w( {6 j" w& j' u( [
/ J, ?! _% A& q4 [) e4 V# d: G6 G
const char * part_name,
* j1 t% Q0 T) ctag_t * part, + w( N: k0 N& ]% A* b
UF_PART_load_status_t * error_status
! e7 B7 G- z# h) y7 n
3 w2 K' |5 @$ X# P  H, Y)# n9 s) ]- T' ~
2 P4 e: k  q+ hconst char * part_name Input Name of part to retrieve. 3 T2 \. V! s' X1 X* @
tag_t * part Output The tag of the retrieved part or NULL_TAG if part 2 E9 [7 k0 H$ o, v
retrieval fails.
" J+ _$ T+ a  }# h" U# o" ^ UF_PART_load_status_t * error_status Output to UF_*free* The user allocated structure
4 f* o1 A; \) o% i# z <error_status> is filled with the names
3 t3 t# Z- K  h6 D" m( E and associated error codes of any parts ! U0 ?  I0 V4 }/ d, F) C( z
that did not load correctly. The
  X& h5 W, _( S8 K structure must be freed with UF_PART_free_load_status.
3 y+ o5 i. R1 N For details see the definition & v5 K- r% y4 G: J
of UF_PART_load_status_t. , d8 |4 }3 D; P! j
 楼主| 发表于 2014-10-6 19:44:21 来自手机 | 显示全部楼层
1,用这个函数后;点保存;会不会保存到工作目录?2,怎样更改文件名加载到内存里?
