查看: 4387|回复: 1
[二次开发源码] NX二次开发源码分享:报告当前工作部件的所有属性
发表于 2014-11-4 20:48:40 | 显示全部楼层 |阅读模式
$ I' U7 W/ B+ X0 O) Y5 j
NX二次开发源码分享:报告当前工作部件的所有属性' A: y- k( c! V8 f. ^! Y) I
主要是用过workPart->GetUserAttributes()获取属性信息;
% S6 g. j. u& a) v; ^
  1. void MyClass::do_it()
    3 C  i, ]6 p3 g' h4 r# r
  2. {8 g4 z& {6 w3 ^: C+ G. y) K: q
  3.     stringstream out;- J. Q) V5 c: L: S" J  D& V+ W1 s- ^
  4.     std::vector<NXOpen::NXObject::AttributeInformation> infos = workPart->GetUserAttributes();  U5 d1 y, l/ d+ P+ b# A/ O
  5.     out.str(""); out.clear();& e. C& C. }- {  l2 c5 v5 ^
  6.     out << "\nAttributes found: " << infos.size() << endl;
    ) j  G5 C& I* z! B0 W
  7.     print(out.str().c_str());
    - W9 D4 j6 f- V. U. L
  8. ) x% g* h2 M0 W! D2 D
  9.     for (unsigned int ii=0; ii<infos.size(); ii++)1 E1 R, J/ @* {, [) q
  10.     {- ~  k" ]0 u/ ^5 c3 `
  11.         out.str(""); out.clear();  m9 v- v0 n# \- a
  12.         out << "\nAttribute: " << infos[ii].Title.GetText() << endl;
      L* c, t& F4 A. M, k! X6 T' ^
  13. 8 g) b# |9 l' K! {3 R
  14.         out << " Array: " << infos[ii].Array << endl;  y$ u4 g, Q4 r8 E" Y) [3 i
  15.         if( infos[ii].Category.GetText() )
    " Q( _# q8 k# d7 ~. w
  16.             out << " Category: " << infos[ii].Category.GetText() << endl;
    & N8 m+ I3 k  b% X: X& c/ k1 F
  17.         else2 F( i* ^4 J9 H2 T0 {
  18.             out << " Category: NULL"  << endl;
    6 n; H9 J" b" L; @5 Z$ f4 t' o
  19.         out << " Inherited: " << infos[ii].Inherited << endl;4 z; Z9 j0 U0 z8 e" E) A
  20.         out << " Locked: " << infos[ii].Locked << endl;# }+ f! n  f/ ^9 r4 ~7 E" `9 I
  21.         out << " OwnedBySystem: " << infos[ii].OwnedBySystem << endl;
    7 a6 Y1 B, p; R7 q9 n# j1 d9 Y' S
  22.         out << " PdmBased: " << infos[ii].PdmBased << endl;4 D7 B' a. x( J% `) r* w/ y, \, M: D
  23.         out << " Required: " << infos[ii].Required << endl;
      l% o  {: v- C/ h( N
  24.         out << " Type: " << infos[ii].Type << endl;
    5 y5 N; i# V3 `5 N
  25.         out << " Unset: " << infos[ii].Unset << endl;
    * v0 o( S6 D- n$ O1 O; P" s
  26. * Z0 c3 z+ Q1 x
  27.         swiTCh ( infos[ii].Type )" E9 t3 u2 |. S/ {0 l
  28.         {
      h7 k* `7 K* W, x, B( J2 C8 P
  29.         case NXObject::AttributeTypeInvalid:% v. {5 Z% |: B3 o
  30.             out << " Type is invalid." << endl;# @9 ]) Q5 X  q* \: {
  31.             break;7 _4 r/ G, ?9 J
  32.         case NXObject::AttributeTypeBoolean:: M2 \9 `% Z$ y5 v& m. L! J9 |7 e
  33.             out << " BooleanValue: " << infos[ii].BooleanValue << endl;' e! d  g* F, b6 ^% u% D# l
  34.             break;
    ' i$ h6 i  w: k0 k9 d+ S
  35.         case NXObject::AttributeTypeInteger:( o& ?8 ]- D5 K2 R
  36.             out << " IntegerValue: " << infos[ii].IntegerValue << endl;, S# p- q! f& e2 A% I7 a; s7 M
  37.             break;
    . D% Y! Z+ Q3 F
  38.         case NXObject::AttributeTypeReal:
    5 b/ K) t7 l$ q+ r. [* g
  39.             out << "RealValue: " << infos[ii].RealValue << endl;
    0 Y; e) S; r  Q% ?1 I$ y- b; }
  40.             break;( k- l* ]( r7 U7 Q. L5 V3 U
  41.         case NXObject::AttributeTypeString:2 N; \: H' R1 F3 s2 I( R8 ]& Z
  42.             out << " StringValue: " << infos[ii].StringValue.GetText() << endl;3 Y. a! X& t  q0 d
  43.             break;) B. T  f( X, t4 F5 U! N
  44.         case NXObject::AttributeTypeTime:" B& f. b5 y8 ^* K
  45.             out << " TimeValue: " << infos[ii].TimeValue.GetText() << endl;8 J4 o+ ~/ r" p/ S' Q& A5 g. c
  46.             break;
    # r# L4 l$ ^" b/ e6 z2 M
  47.         }
    # W! _; }% _6 K6 a7 n  w
  48. ! |' }- c' P  _9 X
  49.         print(out.str().c_str());8 Y& ~% N- {1 |5 _# Y
  50.     }9 R7 \' i, n6 u- g  I* G
  51. 4 r" L. Q9 ~- E& Q+ z& F
  52. }1 S* U5 w9 g; H. |
/ U! ?9 ^0 r2 ]6 `4 O1 o; A9 u% n/ r. g2 }$ m
' [2 B8 T8 ^' }/ s# W
发表于 2019-4-25 18:49:57 | 显示全部楼层
有用的,解决
