Teamcenter11.2 升级到 Teamcenter 11.4 图文教程" [1 a5 W0 t" |5 a6 I/ C7 ~
视频教程请参考plmhome.ke.qq.com- L# Q2 |9 T5 F% r& k L
2 S# n/ Q8 j( w/ D! ?& P
===Clearlocks======, k7 q. y. \( ?/ k( J! w
clearlocks -assert_all_dead -u=infodba -p=infodba -g=dba
5 b8 b/ C Y# u* n! J+ w) Mclearlocks -verbose
9 i7 e' i9 y& D0 s; F7 }" R6 B( u5 n( h5 |3 ]9 B3 @
5 M- R9 L# B8 z8 I5 |/ c3 |
11.4 的升级比较特殊,特殊的两部如下:
: y _0 {* s1 V3 Z+ d7 d
}) |2 t$ ?9 ~1 A+ dREM === Migrate trace links =====
1 o0 a9 i+ C: s& C1 t( p' x
1 X7 G" j* X0 D. E( }req_migrate_bomview_tracelinks -u=infodba -p=infodba -g=dba, G+ o* H3 P8 d4 S2 a
+ S& [ r2 b" c3 @( O
6 l- ?) R( z' } m0 q====DB =======3 @* s2 \" |& P
=====backup====
5 S& l7 @" C) F) x; T# H, K3 M! V0 f! J ~0 t+ {2 j
! @8 |8 M* s' X( v* FREM ==Estimate tablespace requirements for update====7 M7 c+ ^; t6 E& I- e. l
Oracle databases:' a6 J4 O3 g7 q0 v2 O2 {
1. Back up existing Teamcenter data.
: K1 @ s Z, Q/ [2 ^2. Determine the tables affected by the update to Teamcenter 11.4.
, d8 I) O' `, K" K( K* ~a. Enter the following SQL command:
$ _3 {/ [8 d; {$ ^) t" {8 U
( i+ K: Z4 q3 u6 T1 `SELECT ptname FROM PPOM_CLASS WHERE BITAND(pproperties, 8192) <> 05 O' z' H: _0 Y9 \" }, R- B" a
UNION
2 x! E8 N& ~+ }" H; HSELECT ptname FROM PPOM_CLASS WHERE BITAND(pproperties, 32768) <> 0;
3 A/ k0 ]5 s& A; X1 m
0 m7 P0 y" C5 z# }1 Y& Pb. To the resulting list of tables, add the PIMANEXPORTRECORD and PPOM_STUB6 ]$ g! l1 m2 J# m: O
tables, which are also affected by the update process.
0 p3 o; T8 w% T, O1 r" p E a" q1 b' W" Z+ S" G7 o
Determine the amount of space consumed by each affected table.
4 F! R5 {: j0 z; E' DFor each table identified in step 2 (including PIMANEXPORTRECORD and PPOM_STUB),
: v. C3 l F g
) l) Q" \% k+ T& J. W( T* E ]enter the following SQL command:
% _6 Q6 a$ ^1 X: Z. a$ d( v4 ~WITH cte13 P' o' n& h+ h& x: F3 g0 O2 U
AS (SELECT table_name
, |0 {+ K$ d( j& v+ ?/ R5 g1 {2 VFROM user_tables) [% f9 K1 q; S- Z! t) @' z, g
WHERE table_name = 'TABLE-NAME'),' n& H7 a! d1 T0 t
cte2- g. w, e9 y P$ J
AS (SELECT SUM(blocks) * 8 / 1024 MB
! K; C/ N7 `: d" LFROM dba_extents,) \; e4 F% x5 e1 V
cte1
4 q K) a# O1 nWHERE owner = (SELECT SYS_CONTEXT('userenv', 'current_schema')7 Z1 M1 I# n+ U6 u3 a
FROM dual)9 M2 n' E. ?9 S+ k. f4 F
AND segment_name = cte1.table_name)
7 z& \4 P0 P/ g9 `; ]; v* l' d5 e/ lSELECT ROUND(SUM(mb), 0) || ' MB' AS ESTIMATED_SPACE
- x8 l2 R( j/ D! Y" u, C7 H* J6 j, qFROM cte2;
& T/ R% A1 Y" A4 A
8 ^- }6 V* i5 ^& w. q# vReplace TABLE-NAME with the name of the given table.
* t s L6 P# ], V' T# [% d) v0 x" u( n. d8 b$ O
( u4 ]8 _) _. ~: F/ O" E
7 j$ v6 l# |2 k* U- d# oREM ==unzip install.zip ======# ~& e+ J4 G) ~
5 ^* j8 [- L) d. m0 `
TC_ROOT\install\install\unzip -o install.zip
: j' l/ \# T' K, D" U5 P5 L2 D0 o1 R
) b$ x3 a) G7 q5 R; O: J) _& K( b8 K) q* \# o1 `
REM ===Install patches on a Teamcenter server====
/ Z3 c+ W& B# V Z6 _, i' i& K# U. X# m1 l3 z
TEM--> updates manager
4 t P: D, A: ^' |2 O( W. j" l- w+ H+ [7 w8 G# e5 ^
REM === Update kit location : product-level_number_platform.zip // Tc11.4_wntx64.zip
3 O/ E& Z3 }% }6 V/ F- H, p1 y! H6 n" N) C
After the server is successfully patched, you must manually update your TC_DATA directories.1 C& C! k) j, e* p! S6 \
a. Create backups of your current TC_DATA directories.9 e) E. e6 s, r
b. Expand the platform\tc\data.zip file from the temporary location you created in step 1.
4 B0 u% R) k( c# a; A$ @0 {1 P. yc. Copy the expanded contents of the data.zip file to your TC_DATA directories, overwriting
8 B; c$ K, S ?! b4 }existing files.- d" q* C" y! Y: P' y, d
d. Copy the tc_profilevars.bat file from the backup to the TC_DATA directory.3 v: m4 s* Y3 D3 R7 G5 T
& h9 @. E* v* l0 ]) L/ ]
$ J# g e, H7 J1 m1 o6 }! `1 ^; ]
; r7 X' Q, A/ c* Q' F* C
& I, S2 v$ T9 k; t7 W! L" u
& I/ T6 f" Z: B' @========Patch the rich client using TEM
! W$ H8 x7 q! e# G: ?, J' K( S; c========Patch the rich client using the Over-the-Web Installer2 t" S. ~4 q; U$ {7 n) a$ B, I
1 ^3 ]4 p8 B) o! a# H
2 O/ ?4 C6 J" X. `a. Click Reinstall Solutions.
' K' ]9 Q' }1 M2 Q# B9 B) N' |' x' \b. In the Reinstall Solution dialog box, click
1 r0 Y/ b2 w; x' s, BOK.18 @: ] o- k* l9 L0 Q2 Q) W8 B
c. In the Confirm dialog box, click Yes.
. i9 {1 ~6 r' s: C; v2 Jd. In the Modify Required Context
* S( N! o/ C0 `- J: S/ `; bParameters dialog box, click OK to begin
9 k/ G& z+ y: z3 @& D% Opatching. u7 R c) c$ m5 N* \
e. After the patch is installed, click OK to
3 h7 N. K: T6 A9 I# rclose the Progress dialog box.1 g! U, e+ ?* l/ z4 b6 N C
9. In the Modify Web Application dialog box, click OK." P- l9 k) {0 n* N* v! g
10. Exit the Web Application Manager.
# ^) }2 V# p. Q) @% Z, B" j0 N11. Copy the otwweb directory from your WEB_ROOT\staging-location\webapp_root directory) ?& l r, h, a- D0 W/ w, U
to your web server.
2 s$ \; u! g1 |2 z- B, d' b12. Restart the distribution server.3 Y8 N/ N1 b0 {5 ^" F, v# e
4 @' u4 y- {, i# P( |+ t' n
+ X# F# D7 A) _2 r% N% ~& H=====Patch Lifecycle Visualization====
; R- V, L% a9 _; Q* r' N0 H6 P: V# c q( |8 Y" B8 N$ [- E0 b# t8 @
: W T+ e" B* }: c% U
& [( }7 D* W% z4 U8 }5 K
===Patch the web tier======
7 }. N. X1 L2 S; o" a
; U) N6 e9 m, h/ Y. [# E/ {! e! ^( l: ^5 S5 K& \( j
7 d$ w) M( X D4 C) [5 Q9 r
& P0 T# X0 X2 M0 H
8 K# I6 z* }* X* K( L C7 s |
