有两种方式可以创建草图:! n. _: }3 z' X
1.通过参考平面创建
. c" ?4 i; N8 x& A3 U0 U7 Z$ ^ e% t//获得参考平面
# C- F+ E0 ]3 e' s/ ]/ {! h6 I+ ECATLISTV(CATISpecObject_var) spRefPlanes = spPart->GetReferencePlanes();
; N7 l2 r( D1 ^ `+ c//初始化草图工厂. T2 z8 N* u$ w8 u! M% F- l
CATISkeTChFactory_var spSketchFactory(spContainer);
- D( s$ T. S' N; W* }& I* ~ ~% j//在XY plane 上创建草图
0 m2 r! p a3 ]6 k S$ G2 PCATISketch_var spSketch = spSketchFactory->CreateSketch(spRefPlanes[1]));$ v! v* p) t- N
2.通过原点和两个矢量方向$ o! ]" ]* r" x& j5 J- ]
该方法通过定义一个原点和两个方向 pH、pV 进行创建。
- x% p) }1 ]: y定义原点和方向:
' r/ e6 {1 b7 a6 Zdouble pOrigin[3]={0,0,10};% e+ u0 x Z+ ?5 a. S
double pH[3]={1,0,0};
3 r! X3 r( W! U! ]' gdouble pV[3]={0,1,0};
" k# }- ]* o. [$ C: X5 r1 sCATISketchFactory_var spSketchFactory(spContainer);
% P. i+ K3 P# h1 \9 H8 R) ^+ R+ ?CATISketch_var spSketch = spSketchFactory->CreateSketch(pOrigin, pH, pV);
6 |: {) s1 U5 N. e$ ^6 j) f) I1 Q& N9 z6 @) }. v9 p
$ Q e1 _3 P! c( e" H% I# G0 V( msp2DFactory(spSketch);* |. k, x9 ^+ Q; W
//下面创建点2 t+ R9 B' ~: k" h. _
CATI2DPoint_var spPt_bottom_left, spPt_bottom_right, spPt_top_right, spPt_top_left;
! A: B! d7 }0 W. Z& v' V& cdouble pt_bottom_left[2] = {10, 10};
M" w: n) n" ndouble pt_bottom_right[2] = {50, 10};
& V8 @1 l _( ]6 Ddouble pt_top_right[2] = {50, 50};, A! h$ j2 s# T
double pt_top_left[2] = {10, 50};
% Q+ s5 }2 D0 P x/ ]) v. C# m" |spPt_bottom_left = sketch2DFactory->CreatePoint(pt_bottom_left);
0 G, `6 p/ D. b& o. F8 XspPt_bottom_right = sketch2DFactory->CreatePoint(pt_bottom_right);
( u4 r( F% i/ lspPt_top_right = sketch2DFactory->CreatePoint(pt_top_right);, k! B" K {0 v F/ u
spPt_top_left = sketch2DFactory->CreatePoint(pt_top_left);2 ]" [. b `% S! M0 z- l
//开始创建线
% i9 o4 |4 A. u7 f; lCATI2DLine_var spLine1, spLine2, spLine3, spLine4;
% `4 C# o9 z8 W: |spLine1 = sketch2DFactory->CreateLine(pt_bottom_left,pt_bottom_right);$ ?1 z# `3 p; o0 C4 p$ M) U
spLine2 = sketch2DFactory->CreateLine(pt_bottom_right,pt_top_right);
2 O0 W& i6 o$ `, c* `- W$ @spLine3 = sketch2DFactory->CreateLine(pt_top_right,pt_top_left);1 z- \1 _3 W& T1 D
spLine4 = sketch2DFactory->CreateLine(pt_top_left,pt_bottom_left);
0 l( R2 [) t5 g; r5 a! `//将线的首尾连接起来, M3 Q7 E1 c# V) {! R- |2 P" z
( P) \$ i: Q I. ?5 i8 K1 u
CATI2DCurve_var spCurve1 (spLine1);) x# f" p* E; O. r
CATI2DCurve_var spCurve2 (spLine2);
( n* f* y `4 H% z+ |: tCATI2DCurve_var spCurve3 (spLine3);+ t9 T g/ n0 n1 P: i" V
CATI2DCurve_var spCurve4 (spLine4);, V; Q5 w# ^# q3 \. p: M2 J
spCurve1->SetStartPoint(spPt_bottom_left);5 N2 T1 b" v; l3 `$ s
spCurve1->SetEndPoint(spPt_bottom_right);
1 o, J* D5 l. _8 X! Y0 K! ^spCurve2->SetStartPoint(spPt_bottom_right);. o# w" |$ Y/ S- V% K1 b! _
spCurve2->SetEndPoint(spPt_top_right);
: T$ y" F6 \, a! ]% C& B: i/ \spCurve3->SetStartPoint(spPt_top_right); m) T- {4 R* j4 \( ]0 Y
spCurve3->SetEndPoint(spPt_top_left);0 S7 n+ ?+ `# I5 |- _
spCurve4->SetStartPoint(spPt_top_left);
+ y# ]: D# `8 N# O) n1 g7 nspCurve4->SetEndPoint(spPt_bottom_left);. F/ \1 G- m, G: d& `
//然后退出草图:
- N. m4 |, j6 [) g% s% K: N3 XspSketch->CloseEdition();5 E" I4 J# h" W5 I
/ a$ ]( {% j$ `- b4 B0 ]) l& I' J v! ~9 [1 d' M
% P% k; E# w' S, M4 Q) J2 M
创建草图约束! i# ^- c \0 p+ ] P
CATI2DConstraintFactory_var spConstraint2DFactory(spSketch);" k; E3 g8 c3 G1 v- b
//定义spLine1 为水平约束; k' ]( [9 h0 x
spConstraint2DFactory->CreateConstraint( spLine1, NULL, NULL, NULL, NULL, NULL,/ v8 }7 c# |" C
NULL, Cst2DType_Horizontal, 0, 0 );
; R. G9 f- i& R- ~9 K' L' ~! c o//定义spLine2 为垂直约束2 ?. @8 o- w$ ?/ c( _" ], I6 Y7 k
spConstraint2DFactory->CreateConstraint( spLine2, NULL, NULL, NULL, NULL, NULL,$ M0 z3 |/ r9 a" Z o' t; a7 P
NULL, Cst2DType_Vertical, 0, 0 );% u w7 ?, m3 n0 `' _+ x# l, o! x9 s
//定义spLine3 为水平约束' q5 r8 }+ s: Q5 M6 O
spConstraint2DFactory->CreateConstraint( spLine3, NULL, NULL, NULL, NULL, NULL,& A3 s3 T' u. {6 }
; Y7 b" N3 w$ y( Y( M//定义spLine4 为垂直约束+ Y+ u; _4 I+ d
spConstraint2DFactory->CreateConstraint( spLine4, NULL, NULL, NULL, NULL, NULL,
! w6 @! Z/ H# z8 V: [2 h* LNULL, Cst2DType_Vertical, 0, 0 );5 n. `5 a/ F% ^0 k. p3 a
//定义spLine2 的长度约束
) G: r' V! z- q% s2 X! C, kspConstraint2DFactory->CreateConstraint( spLine2, NULL, NULL, NULL, NULL, NULL,
5 U( u/ P/ Q' f7 }NULL, Cst2DType_Length, 0, 0 );8 _! v& p0 K C5 i( a
6 d+ ^0 b- w6 j1 y. ]0 i/ B//定义spLine2 与spLine4 的距离约束
1 T( D2 v0 |( ]2 `) F9 espConstraint2DFactory->CreateConstraint( spLine2, NULL, spLine4, NULL, NULL, NULL,. y6 f. [2 @1 j+ f
NULL, Cst2DType_Distance, 0, 0 );
* S q M$ A0 x3 H2 n! ^//定义spPt_bottom_left 与X 轴的距离约束
* f5 i& M, X v% k3 V7 e0 yCATI2DAxis_var spSupport = NULL_var;5 E4 w' ? o# K4 g t& B
spSketch->GetAbsolute2DAxis(spSupport);
& ?* g% _) l% r" y. x. `+ wspConstraint2DFactory->CreateConstraint( spPt_bottom_left, NULL,
: |1 c; E" p( E# i* w" U3 n' l/ WspSupport->GetHDirection(), NULL, NULL, NULL, NULL,Cst2DType_Distance, 0, 0 );1 V1 S+ F N4 E7 `+ }8 r
//定义spPt_bottom_left 与Y 轴的距离约束
8 U% `) t: t9 U5 x9 L0 }9 p, Q# EspConstraint2DFactory->CreateConstraint( spPt_bottom_left, NULL,( _7 l1 @/ M. E4 U, y
spSupport->GetVDirection(), NULL, NULL, NULL, NULL,Cst2DType_Distance, 0, 0 );
# ]/ z" n' M! k* z& z
J2 b# n5 L* p% [* a+ {& y1 p( [1 x& D+ g- ]* S7 K
