[二次开发源码] NX 二次开发源码分享: 直接获取CAM对象类型 C#直接播放Jornal
2018-6-1 09:27:40 2456 0
发表于 2018-6-1 09:27:40 | 显示全部楼层 |阅读模式
NX 二次开发源码分享: 直接获取CAM对象类型 C#直接播放Jornal 就可以使用了
' u+ J! [- W$ N7 x5 _# G
" A  g' M% h1 }" v4 J[mw_shl_code=csharp,true]using System;
( t( {1 [! A; _8 t/ C  Tusing NXOpen;, r; x& T% j& W, m9 B" c/ T% N
using NXOpen.UF;$ M$ a, J8 U" s" E: H
using NXOpen.Utilities;  W! k. R6 N2 x. H' H: t
using NXOpen.CAM;& j  `( b- Q8 h* M
using NXOpen.Assemblies;
$ C% a- u4 b! U  l, w
/ O# H8 ]% G+ h- J3 estatic class GetSubTypeToOperation4 X/ H. G$ M1 o- _
" q: ^8 `! A' {" O    static Session theSession;* c! P% ]& t& K9 H0 t* H
    static UFSession theUfSession;8 i) v) Q% F2 @& I% N3 o# _
    private static UI theUI;2 s" B# V, x7 A, p! X! |
" f$ ^0 ]" ^5 h4 j6 m( R
    public static void Main()8 U0 f( g# k1 y7 Y: R
) i2 S  Y9 E/ f) x9 e" I        theSession = Session.GetSession();
, u9 Q0 _' Z3 P        theUfSession = UFSession.GetUFSession();" l4 s' W" `3 q/ ?) {& E4 }
        Part workPart = theSession.Parts.Work;0 B/ U; w& S! R. X
        theUI = UI.GetUI();
& O" p5 K! U0 K
9 p: b! g" e. z        if (workPart == null)/ i- V  g7 t$ q
        {$ g- f- |# E0 Y+ Q" r4 W1 z5 x
            UI.GetUI().NXMessageBox.Show("Message", NXMessageBox.DialogType.Error, "A Part must be Opened.");
2 G( c) H8 G( f: I9 p            return;" j, p& b  L" {
        }. K- c( j# G/ p( h
: X$ m, h* E/ ?# N/ ?; J
        theSession.EnableRedo(false);
9 _& h8 q& C' G
9 [  ^; @( o3 n2 h& j8 z$ A" M7 q: n        if (!theSession.ListingWindow.IsOpen) theSession.ListingWindow.Open();
" }. U/ D& {+ b5 ]" T
2 ^: c/ C- w# l* [3 [        SystemInfo(theUfSession.Part, workPart);
- {0 y, u* m7 Q# X9 u' q" U2 |' I9 J7 n% i/ F0 l
        try- e5 |; h) {# y* J5 Y4 ?- h
7 _2 e: C6 C' ^) B4 a/ q) V& j6 o            Tag[] operTag;
- s6 t! I  M1 H+ V; R            Tag setupTag = Tag.Null;$ j! y. x/ \/ K5 L
0 k4 }( r+ u5 Y' S4 ^* R            int countObject = 0;2 V1 x6 ^. Y" |1 d3 z  L
0 }- s$ h, a5 F6 ^0 S
            theUfSession.Cam.InitSession();
2 v: R1 s+ O; R            theUfSession.Setup.AskSetup(out setupTag);
8 K( Q% h, ?' h% _$ H. @' Q& v4 T/ e* A" z! |) r  x
            if (setupTag == Tag.Null)
3 U/ Z1 v3 F( Y) I' _            {' b6 b  `& o, O" L3 E4 h0 O" [: X1 W/ t
                UI.GetUI().NXMessageBox.Show("Message", NXMessageBox.DialogType.Error, "No Cam Setup in this Part.");: Y- [+ t* n0 `; I, _1 ^- w
                return;
+ n: k" q) Z9 V$ @9 x4 l+ |6 H            }
: f1 r3 j1 V0 p% F7 b, p# k4 h1 d4 y$ |$ R5 E! x
            theUfSession.UiOnt.AskSelectedNodes(out countObject, out operTag);& R9 _4 i, K- k
: O3 s; {% C" E3 p6 c
            if (countObject == 0)
5 O: `. O# L2 u, j. D& s5 \: H. M9 n9 A            {
: O! u- e& K& ^' v8 S                UI.GetUI().NXMessageBox.Show("Message", NXMessageBox.DialogType.Error, "An Operation must be Selected.");3 T! n2 t( }: R0 _
                return;
; _% h8 M' m+ V& s0 Y            }, ]7 A, `1 ^" v0 L! F- |9 _
1 d3 {- d1 f( m6 o- y; ^
            for (int i = 0; i < countObject; i++)3 P3 b" K* u3 \; E
            {/ U, u! @: C3 [/ @; q) t
                int type, subType;
; l0 k0 H% H' ~& p: L5 T) K5 X* Z( o# z  G0 m( a2 s
                theUfSession.Obj.AskTypeAndSubtype(operTag, out type, out subType);* L3 P: D0 |! ]* S! I6 R4 H
# [$ `. E. n( G. W                NXObject camObject = (NXObject)(NXObjectManager.Get(operTag));" o3 v" L4 P, ^2 y# x
4 a8 Y( h% d2 Q/ ~7 S                if (type == UFConstants.UF_machining_operation_type)# P+ a7 I1 R( E3 R! k
                {+ l6 M! M; U! a5 ^+ I% I# H5 B
                    NXOpen.CAM.Operation operation = (NXOpen.CAM.Operation)(NXObjectManager.Get(operTag));/ V& L% y- x* c% ~9 }) \6 f+ N( G) b7 A
$ c8 D' m( M5 r/ j
                    GetOperationSubType(operation);6 Y4 Z! n1 s& o; @0 s+ h7 l
2 n$ V9 T0 O( b/ s
                } /* if type */1 ~5 O" Y4 B8 U. V8 W& p
            } /* for int i = 0 */
9 n  M4 d  w0 L; p. c- L* g* p& R/ _- T        }
$ c' V. U- [4 }4 ~: k7 F        caTCh (NXOpen.NXException ex)
6 J7 j  y9 L0 n9 Z4 Y        {3 [8 @/ V* Y) o
            UI.GetUI().NXMessageBox.Show("Message", NXMessageBox.DialogType.Error, ex.Message);
. f' f& s6 e6 z6 I4 m        }
- s0 W6 ?' J  N+ [  O    }
. T1 K  _) O) h+ [" A" Z) d& x. r6 `& u) i
) B3 J/ o6 m. p8 r: u) @2 H. w, |    /// <summary>
  \$ \+ I- z. s/ \0 p. w    /// Retrieve the Operation Subtype
- K& Y! `& r2 l# K5 U    /// </summary>
: i4 [& L6 R7 H7 e' ^( @/ _2 I8 U    /// <param name="operation">The Operation to Query</param>. k0 j7 o  a& Z/ z* T# W
    /// <returns>Return the Subtype Operation</returns>
3 P+ H$ q* x& E/ u3 L) k7 X. y    public static int GetOperationSubType(NXOpen.CAM.Operation operation)
+ J1 ^. p" s; x" m4 R& O    {
. ~, G# A3 P# _' K) \3 w/ l        if (operation == null) return -1;
  h* f* P6 x! L! A/ B7 a5 P; y1 m! L- ?
        int type = 0;7 B0 m% p, A  i# T6 W
        int subType = 0;
. Z7 A, h1 U" t3 y: Z- Y; c9 ~0 G  G+ d' u: I! F: c( s
        try
2 Q1 ~4 V4 [. L# y        {" \1 B( z0 c. G1 w& B( u
            theUfSession.Obj.AskTypeAndSubtype(operation.Tag, out type, out subType);
6 m+ {5 `0 n4 k  T" \, Z1 B            theSession.ListingWindow.WriteFullline("Operation : " + operation.Name.ToString() + " -> Type " + type + " SubType : " + subType + " -> Operation GetType : " + operation.GetType().Name.ToString());; f% o, Z; m# F: s% Y1 k7 j
+ U& `; w7 `, ~) v% z6 Q            /* If needed to Switch to Operation Subtype (uf_object_types.h)*/# S7 v# ]; @' l1 a3 P
            switch (subType)
0 Z+ n% b) Q, o7 b            {6 _/ Y4 N; F: Y% x2 h) M" \
                case UFConstants.UF_mach_pocket_subtype:                /* Planar Milling Operation */
$ k/ b* v" W6 H& ]! R2 P+ I                case UFConstants.UF_mach_cavity_milling_subtype:        /* Cavity Milling Operation */) Y" Q- _- x& Y& v6 \( a' }0 ~
                case UFConstants.UF_mach_face_milling_subtype:          /* Face Milling Operation */( K0 H4 i3 g7 Q. u% s$ T. y, R: Q
                case UFConstants.UF_mach_zlevel_milling_subtype:        /* Z-Level Milling Operation */- O! h% _+ b+ S2 ?. S
                case UFConstants.UF_mach_groove_milling_subtype:        /* Groove Milling Operation */
2 ?* u3 i, j' m8 y                case UFConstants.UF_mach_cylinder_milling_subtype:      /* Hole Milling Operation */9 R$ v4 E- K$ w+ u7 C) G
                case UFConstants.UF_mach_chamfer_milling_subtype:       /* Chamfer Milling Operation */  D7 m7 F% C( |8 i- O5 d% r9 o. X! L1 K
                case UFConstants.UF_mach_radial_groove_milling_subtype: /* Radial Groove Milling Operation */
6 q: O6 a7 d8 |8 w4 |* s& @                case UFConstants.UF_mach_surface_contour_subtype:       /* Fixed Contour Operation */! e/ p5 W8 R8 ]
                case UFConstants.UF_mach_plunge_milling_subtype:        /* Plunge Milling Operation */
8 @: Z* ?7 G. g5 m7 m7 {                case UFConstants.UF_mach_vasc_subtype:                  /* Variable Contour Operation */& L2 _" I4 \$ P4 N- g
                case UFConstants.UF_mach_vazl_milling_subtype:          /* Z-Level 5 Axis *// C- S# x; R+ F8 M
                case UFConstants.UF_mach_thread_milling_subtype:        /* Thread Milling Operation */6 G0 d$ }! n, {, ]( s) C: y3 ?2 M
                case UFConstants.UF_mach_fb_hole_milling_subtype:       /* Hole Making Operation (Legacy) */
4 F1 b) d) f0 O* k6 t3 I                case UFConstants.UF_mach_hole_drilling_subtype:         /* Drilling Cycle */6 N+ G/ c" K/ y
                case UFConstants.UF_mach_mill_ud_subtype:               /* User Mill Defined Operation */
* ~: B! k; m2 W/ s5 L3 g- x                case UFConstants.UF_mach_gmc_subtype:                   /* Generic Motion Operation */. C  q$ b) Q9 H+ j
                case UFConstants.UF_mach_mill_mc_subtype:               /* Mill Control */
5 w: n6 x4 B: v. U) u1 f# r                case UFConstants.UF_mach_gssm_main_op_subtype:          /* Sequential Milling */
- b4 u' R5 c2 D                case UFConstants.UF_mach_hole_making_subtype:           /* Hole Making (Legacy) */
$ G$ |: \  `7 G* w$ U                case UFConstants.UF_mach_planar_additive_subtype:       /* Additive */* z4 c3 s2 o' K) f! ^) s5 y
& k/ P+ L+ c8 l* `7 W1 A, r0 ?                case UFConstants.UF_insp_tolerance_subtype:
& B8 X* T, B) [) ^; k: A7 _                case UFConstants.UF_insp_path_subtype:9 ]2 b* z) a& s( T
                case UFConstants.UF_insp_output_subtype:, ]% N# ?6 |5 p! p
                case UFConstants.UF_insp_misc_subtype:
( B0 o; l$ C6 R4 M9 n4 @                case UFConstants.UF_insp_align_subtype:: L1 X) t9 R  A, p6 g( o( z
                case UFConstants.UF_insp_sensor_subtype:* Y' n* T0 H- D  w2 i9 ^, ^
                case UFConstants.UF_insp_construct_subtype:
! ?8 ]0 r" e. X, s8 S                case UFConstants.UF_insp_bounding_feature_subtype:1 @% B( k, O3 t2 Q% O' X  x+ `& q
                case UFConstants.UF_insp_feature_subtype:0 u7 y) ~/ o+ I; t; i1 V
8 G6 z& x- v+ n
                case UFConstants.UF_mach_canned_cycle_subtype:
  V' [! I5 c- K8 `* L
+ l  w* B; d+ _& D                case UFConstants.UF_mach_laser_teachmode_subtype:
! {. l4 ~( e& u. V! B+ Q
9 z8 k( R3 D2 E                case UFConstants.UF_mach_turn_roUGh_subtype:
1 [7 |* ?: d6 m; c# }                case UFConstants.UF_mach_turn_finish_subtype:
7 r# ~. {: n( i4 E$ P* W                case UFConstants.UF_mach_turn_teachmode_subtype:% C1 p# }4 o! ]+ [. D; L
                case UFConstants.UF_mach_turn_thread_subtype:: p/ B; y% T3 R7 G2 U
                case UFConstants.UF_mach_turn_cdrill_subtype:
( S4 ~" c; @( B0 n                case UFConstants.UF_mach_turn_auxiliary_subtype:
- L6 K4 o6 ^" A( R, g+ M) A                case UFConstants.UF_mach_turn_probing_subtype:
7 T$ Z% h2 _6 L: L3 h                case UFConstants.UF_mach_turn_tool_probing_subtype:7 i4 n' j3 m5 x( }5 i
                case UFConstants.UF_mach_lathe_mc_subtype:* e5 T7 L# g$ _' Z
                case UFConstants.UF_mach_lathe_ud_subtype:
' c- q: \; u. c+ _& _
; `4 n7 r* U  e4 O" F( P3 l+ m- H                case UFConstants.UF_mach_wedm_subtype:- d& Z( X( k& E" A1 ]+ t# }
                case UFConstants.UF_mach_wedm_mc_subtype:
& t5 C9 j/ P% i: c# D% m                case UFConstants.UF_mach_wedm_ud_subtype:6 O) O& z$ B/ ~3 w) o1 A3 F% X0 O
                case UFConstants.UF_mach_mass_edit_subtype:
+ {5 E+ o5 Q: k5 v3 o6 ^: t9 d" U                    break;
( I3 z  M$ p7 e: k) t+ F6 C
1 @* E& I1 E$ c8 `                default:  Z, j) C  Y' P  Q
                    theSession.ListingWindow.WriteFullline("Unknown Operation SubType.");% B$ q+ Q: G3 |' d* d
                    break;
# h$ G  P6 ^' V& `  {            }  _& M& C2 m0 `9 s/ a
' _% _' k/ G/ @3 k        catch (NXException nXException)1 g; m/ m* |- _8 R+ p4 |6 S
        {7 W: H$ r& u- _& G/ g# C% y) ]% J
            theUI.NXMessageBox.Show("Operation", NXMessageBox.DialogType.Error, "Unable to Query Operation. Error : " + nXException.Message.ToString());
8 v& a$ |% D$ Z  N            subType = -1;! i, Z; A4 G& n
, Y; I  u  g  u! s' M  q5 T8 A/ T. g3 R, ?8 e
        return subType;
9 l$ G4 f8 Q- t  r  X    }! Q8 C* A% W. d* t9 ^  F
$ X$ ~! A% y- G5 F
    /// <summary>
4 Q, p5 _$ Z) _& c8 `    /// Display System Information1 B0 f: j; B* @+ K
    /// </summary>4 D+ m- {% E0 k2 U2 D/ c
    /// <param name="uFPart">The UFPart to Query</param>
9 N' o+ y/ X4 k" j! h    /// <param name="workPart">The Work Part to Query</param>5 J/ t% K9 s& N7 U) j
    static void SystemInfo(UFPart uFPart, Part workPart)
( T2 i, w3 O; n- F    {
8 t) Z, w, f3 O3 L& w( l$ U        try8 Q( @) @. v0 K& S5 H1 N# h
; G' `( k7 F9 o5 e            SystemInfo sysInfo = default(SystemInfo);
: K$ A" f( F8 H0 K. H            theUfSession.UF.AskSystemInfo(out sysInfo);) a8 r6 V9 Z  ?  ~8 f0 ~
$ \& A0 v. `' v' D" o
            string partName = string.Empty;
, |! |  A: [& Y- x# e& c            if (workPart != null) uFPart.AskPartName(workPart.Tag, out partName);
# L& u, J4 d& p7 P* g' F
3 t( X% X7 e4 {            if (!theSession.ListingWindow.IsOpen) theSession.ListingWindow.Open();9 v" }% _, C$ G  ^6 u2 p/ @& b
            theSession.ListingWindow.WriteFullline("============================================================");$ M% r9 `) J3 q- r8 q4 W3 j
            theSession.ListingWindow.WriteFullline("Information Listing Created by : " + sysInfo.user_name.ToString());
  y' i8 ~6 n  v( s            theSession.ListingWindow.WriteFullline("Date                           : " + sysInfo.date_buf.ToString());
% y+ H( {9 ~" n6 j& G: O3 Y8 _            if (workPart != null) theSession.ListingWindow.WriteFullline("Current Work Part              : " + partName);8 \8 O/ g% r' D, F& k. \7 K
            theSession.ListingWindow.WriteFullline("Node Name                      : " + sysInfo.node_name.ToString());
. m/ {; U3 X9 G! Y' p. f5 c. G3 N            theSession.ListingWindow.WriteFullline("============================================================\n\n");1 a% L# P8 z+ S9 ]$ Q" `
        }4 Z' r  {2 u+ v# ~) z: C, j
5 c$ z8 v1 @  o+ @* h8 i* Z        {& j2 U2 q: K2 `! o& k! K0 k# V1 B! N' K
            theUI.NXMessageBox.Show("System Information", NXMessageBox.DialogType.Error, "Unable to Display System Information. Error : " + nXException.Message.ToString());
/ B  t3 @( C; b" g6 ^        }
3 T3 w0 M+ Q( F. b: Y; A    }: o; X# b* G* O4 D% |
% `4 A8 v- a+ j1 e* A6 r    /// <summary>
# t8 j. g' @( N% l) ]    /// Unload the Current Image$ V3 F7 P- o) ~
    /// </summary>4 x3 Z( v# G+ f3 S" _/ J
    /// <param name="arg">String Send by NX</param>
4 Y1 U* X* Q8 C( ]. `; e  X  I7 \    /// <returns>Unload Integer</returns>! V! S( F9 O* J& I, r' k% k
    public static int GetUnloadOption(string arg)
/ p$ {/ h. n9 Q1 T7 b    {3 S, [) A/ U9 Q- @" }6 {
        /* Unloads the Image Immediately */
  H& M, v5 \7 ]6 \        return System.Convert.ToInt32(Session.LibraryUnloadOption.Immediately);
' d2 ^2 ], `: U& h% k* u1 T# F4 o8 k& K! P$ i0 I
        /* Unloads the Image Explicitly, via an Unload Dialog */
1 ?: u! _9 ~: f5 c9 o        //return System.Convert.ToInt32(Session.LibraryUnloadOption.Explicitly);
* v: ?# \/ {- m! a. q# r
; D, ~0 \/ ~% L: ]6 G/ _        /* Unloads the Image when the NX Session Terminates */
4 |- B4 F0 k; |3 s, \" p        //return System.Convert.ToInt32(Session.LibraryUnloadOption.AtTermination);2 c, j" j6 Z* {+ ?1 ], O4 ?5 H
    }) D' ~/ @0 ^: I& e, W5 U0 L
}[/mw_shl_code]( }5 A4 `& _- P# A: A- s
