Teamcenter SOA开发中关于变量声明,转换等代码的新处理方式
2015-2-3 09:18:14 3840 0
发表于 2015-2-3 09:18:14 | 显示全部楼层 |阅读模式
, W1 c' x5 i/ _2 e8 s- u% F$ n% c, n- ^5 B5 Y
" {- h* R0 W- p* A$ V. `) I* ~1 变量声明
6 f" S) n8 R" ?0 J* {; `6 Q! ]+ a1 e; x% P, [
# ~5 U) V2 g7 Y& F; N( p: vo Old way* Q9 O1 o& L* ]" g+ C! b5 O0 }
// Declare pointers for an Item, Form and vector of ModelObjects" p+ C9 n  C" y
// initialize to NULL
7 |0 i' l( R# z# B4 l8 jItem *theItem = NULL;
0 t# c$ L3 v( E5 s3 \Form *theForm = NULL;
- r4 H, k- c- A9 S7 Y/ fvector< ModelObject *> objects;; w# m! P( w* C; n+ T
...$ W- x2 j) L; I. E: f9 n; t
// Use the Item% D9 U/ `+ \3 x! w0 X7 P) z
theForm = theItem->get_item_master_tag();" @1 j/ O" c+ c/ R( u$ g1 w% X% q
objects = theItem->get_revision_list();
2 ]$ B- O) S' W1 E0 B/ X% fo New way
' V2 s! _4 Y6 F; ]" _9 j' G& p0 R( Z// Declare AutoPtr for an Item, Form and vector of ModelObjects
; o- N. e* z! x, r2 I9 [1 V+ V// all AutoPtrs are instantiated as NULL
' B. g) x- F9 W% z5 XTeamcenter::Soa::Common::AutoPtr<Item> theItem;
* a& J, M3 f& n1 x0 eTeamcenter::Soa::Common::AutoPtr<Form> theForm;
2 N2 y$ y3 ~* t3 v; uvector< Teamcenter::Soa::Common::AutoPtr <ModelObject> > objects;
$ B5 A; {% t) @* l$ w, F6 W7 ]+ ~6 K// Use of the ModelObject variables remains unchanged
) v- e& C1 Q' Z+ |8 mtheForm = theItem->get_item_master_tag();
9 K- t; R% o4 J: }, P1 Fobjects = theItem->get_revision_list();
' ?& [) Z- h8 D9 h) _4 J+ S! I) s5 U7 |' G" k4 [
4 {) U: u( j# l# r0 o+ b
2 类型转换
( X1 e: k- t4 j- Y5 `; ~
' p$ J' S" ?) A) Wo Old way9 H: v" ^4 g& Y% r* F# E6 x
// Declare the variables
+ M' [3 K- M. ?6 ^" k& [User *user;5 ~1 S% }% z2 P" `
ModelObject *anObj;) S' `' p6 `6 |
Folder *folder;
8 P' G$ c/ u! Juser = sessionService->login(name,pass, “”,””, descrim ).user;
" w: w" H5 E; j// Cast to the base ModelObject class* H( l% S9 v3 R9 M1 X4 _
anObj = (ModelObject*)user;0 J6 V2 J4 ?+ x* [4 y- n
// Cast to a speicfic sub-type, if not NULL
) Q# ^$ B( R5 j7 i, |3 C' v5 k// do something with the new pointer
( Z! w! r7 g$ W/ v* z0 `* H8 @user = dynamic_cast<User*>(anObj);$ H1 y& j0 Z8 a
if(user != NULL)* O9 [; U$ \8 f# O8 B
{# L4 R2 T! Z+ z' V
folder = user->get_home_folder();
% J% b; U# P& S# r" ?: c& a# G}
5 L) q. r6 V( Io New way/ X( m, j; c7 S( @
8 O, p0 ]5 G+ p% F% W: |+ p. XTeamcenter::Soa::Common::AutoPtr<User> user;5 ]7 d5 X4 d* f. ^+ L# J
Teamcenter::Soa::Common::AutoPtr<ModelObject> anObj;
+ y" P( c7 N& ]8 Q# t! U9 u, D2 aTeamcenter::Soa::Common::AutoPtr<Folder> folder;" [3 k0 A+ a* P, F/ t* Z3 K
user = sessionService->login(name,pass, “”,””, descrim ).user;# f  f1 U' L. D7 M& \, F! @, {
// Cast to the base ModelObject class' M7 u& Q1 d+ u- p! p
anObj = user.cast<ModelObject>();
( T1 _* m( D: Y. s1 w5 @7 {// Put the cast to a speicfic sub-type, in a try/caTCh block
; {" ]/ V% Y' T! h! L5 G: ^// if std::bad_cast not thrown, then cast was successful
* \5 v6 N  D% C. Wtry
, Q, E9 z. W, C. w, z7 E{
' }( b/ I# {! Z/ x! V3 e; y) u5 Auser = anObj.dyn_cast< User >();& B' r) M# a: J3 A, `
folder = user->get_home_folder();9 F8 S1 i7 O9 F/ v( b- J
( @. ^3 L* i$ xcatch(std::bad_cast&){}
! E; ~# e3 W8 S6 w. ]; L2 V
3 X8 n5 I. o) D2 D1 d: m- r4 @7 S% q
3 关于NULL 赋值% d( \/ P5 a2 d
$ ^, ~0 F6 T# v. x# B; W" _o Old way% L& y' [: Q( R8 L# P6 p5 H
// Declare the variables) T; U: I2 `5 H9 @* |0 d5 l+ H
LoginResponse response;% T6 ?" {# M. O1 m
User * user;
/ I; Y6 g: m; x7 k' z// Call a service that returns a ModelObject (User)  K7 I2 G5 O+ p8 m1 I5 x
1-28 Services Guide PLM00076 Jresponse = sessionService->login(name,pass, “”,””, descrim );
# W/ N0 [# l  @1 fuser = response.user;
, \" g+ c3 V' u- F) T% m4 B// Test that instnace against NULL8 ]/ G& B: t5 j( b' C6 }! w9 a
if( user == NULL)
' p0 G8 m4 a( a. Y) \8 B{
. i. c$ @# p. s6 P+ ]( b6 s/ a...
6 V8 n! v% |/ _$ U2 u}0 l2 O) K7 J" ]3 X; h% c7 t9 E, X* d
else
/ M2 t. i. T0 V! Y{  ]+ c1 o1 P) Y4 e7 x. P8 F$ t
// Assign NULL to the pointer3 w* W( p: [; e& A  k. y
user = NULL;, K2 j: b$ C) C/ ^# C% z- ^- a
  _  ?! d7 }  }% u( j3 co New way! i1 h/ u* T- u  g9 i# D
. z& Z' p1 H% O$ A: G& ~// The service data structures do not change, only
3 Z; _$ b+ m6 x) k, `6 W6 |// references to ModelObjects
6 H/ P- s, r( v) i* }% f: B" JLoginResponse response;
, j) [% c$ R' Y9 f# HTeamcenter::Soa::Common::AutoPtr<User> user;* P4 w% g* t' v8 Q) @2 f
8 d. O2 f0 {7 ?9 Z* [# p+ gresponse = sessionService->login(name,pass, “”,””, descrim );
/ D+ l! Z/ n: P5 n' W3 @user = response.user;
/ Z0 k& ]$ n' o( L: D3 l; f// Since we are not dealing directly with pointers,3 O6 ?' {3 @) m9 _3 Q% {
// NULL does not make sense here, use the isNull method from the
4 \: S2 E7 A8 o2 N9 f// AutoPtr template class.
4 w2 m& O6 g7 E" K) Bif( user.isNull())
7 ~' D6 {0 S  t6 A{% t' w5 S. `' e3 d* x
9 W/ z- H, Y- r; @}
: H+ e8 y, H9 D! jelse4 v2 f0 G7 J- b1 g
% t$ {& f6 E% a' w3 s- R// Release the instance and
+ W  z! m5 s) O: a" u- ^$ V1 G7 luser.release();
1 F1 j7 ?$ U* Z4 x: k3 D# _  x}, k( c5 b  g& i' @
! h& \# e7 @' d' X3 C9 F" w. g
# x8 @. B: y& Q' C  H0 R% G/ \9 A
