[二次开发源码] NX二次开发源码分享:动态画圆,指定屏幕点和向量相关用法
2016-9-17 10:11:08 6621 2
发表于 2015-2-9 13:45:19 | 显示全部楼层 |阅读模式
6 q+ M# M8 `/ {$ T: H
NX二次开发源码分享:动态画圆,指定屏幕点和向量相关用法! ?( V3 u* C2 z, r6 X1 T. r4 ~
0 J2 h. K3 g6 N+ u3 m' ~
6 l; W+ t6 V' ~0 V+ y
这个案例很不错的,分享下,程序运行的结果是指定屏幕,拖拉即可动态绘制圆圈!
; O/ R# ^- w1 C  i
, w! r1 u$ Y0 A3 m9 S#include <stdio.h>
, z; x  y; m9 u3 V#include <uf_defs.h>
' o/ S- p2 P8 e& i3 @#include <uf.h>1 M% W, F" _% ~
#include <uf_ui.h>
+ Y: F6 Q- |( M7 q: ]2 }, F6 I#include <uf_csys.h>: \5 k: \, q, ?4 y. K: X
#include <uf_vec.h>
$ c. i6 U6 A- k# r. |#include <uf_disp.h>3 B/ |- V! C" _: b9 W! u4 \
#include <uf_curve.h>
/ r( z$ l6 N; f9 U, X' |#include <uf_mtx.h>; x' g3 G/ u% N" W& e! Y2 C  s
#include <uf_obj.h>
& n' R( }4 R# K) W1 otypedef struct# E( |! _, Y$ w- a: f
        { UF_CURVE_arc_t  *arc;* F) n0 ~, l, g
          double          abs_ctr[3];% k- S2 p  Y) v7 `8 l" Z
          double          matrix[9];& s' o' @  v6 I/ G/ g0 J
          double          x_axis[3];3 ]  m7 Q/ y" I
          double          y_axis[3];5 \; O' I- ]) D  R7 G8 B2 G
        } my_motion_data_t;7 F/ M) I8 X; ]" F: A! R5 T/ N
/* Define a motion callback to render a visual representation of
% K) _' f$ n! V * the circle to be created, along with a bounding box around the- ~- O9 N# A& r9 F2 o; n8 l" j
* circle, an arc of radius 1.0, and a "rubberband" line from the
, f/ a/ m" |4 d * center to the cursor position.
: k6 ?5 c5 A" }2 ?- w */$ y. M% q3 |! i- [
static void motion_cb( double                   *screen_pos,
# Z6 T- G% r) k                       UF_UI_motion_cb_data_p_t  motion_cb_data,
( b) c+ J/ k+ R+ L; S" `4 q  F                       my_motion_data_t        *my_data )
5 v* f# q- l! e2 M0 ~% b7 D2 k{
- B/ Q! E" ~' n- R$ Z$ n: b" n    double radius, pos_array[5][3];6 z: f7 m1 n0 N0 D+ p5 Q
    double xrad[3], yrad[3], x_y_vec[3], x_ny_vec[3];: o' Q2 K) N5 U( p! y, t5 C
    /* Calculate the arc radius:  the distance from the arc center1 G" }* E; [5 u+ O7 H4 S
     * to the current screen position.
2 T: T( u+ `. f     */
! e% O- V  P+ d+ j" C5 Q    UF_VEC3_distance( my_data->abs_ctr, screen_pos, &radius );5 m: b0 t) A: ~3 G, z& Z# C
    /* Map the arc center to the "csys of the arc".
6 N4 B/ A$ u4 Y     */6 W1 s: I* L+ D& T6 W. J) U8 B
    UF_MTX3_vec_multiply( my_data->abs_ctr,$ @% D( Q; i6 }: c2 w* n! q
                       my_data->matrix,
6 h$ U/ b6 _4 t! X4 k2 U; h: V8 e8 L                       my_data->arc->arc_center );
0 L0 \% K4 _( i9 U7 f    /* Draw a circle and an arc in the view of the cursor.# ^5 o7 b8 W: n6 s
     */6 z+ M) w( r: c+ D2 r1 N8 S
    UF_DISP_display_ogp_circle( motion_cb_data->view_tag,% K( O) P+ l. Y, R
                            my_data->matrix,! T; I- B5 _3 X# c; P3 H4 y- a
                            my_data->arc->arc_center,
! H" A2 B% C, P* ]8 H. I* t                            radius );( T7 n# I9 k2 b: G! d- [
    UF_DISP_display_ogp_arc(    motion_cb_data->view_tag,3 S2 _: P! S# v2 Y* m3 a
                             my_data->matrix,, b/ ~) |- [# {+ I) j
                             15.0*DEGRA, 345.0*DEGRA,
$ i0 G1 {$ z( x3 p* O9 i) w/ P* c                             my_data->arc->arc_center,% z" C% P. ~9 U! |7 P
                             1.0 );% D+ r$ D9 b* q( r' @$ v; i1 L
    /* Draw a bounding box around the circle.
' l5 e. Y  ?" v     */- x: M6 F$ [* Y* T0 _  g1 m4 {6 i% s
    UF_VEC3_scale( radius, my_data->x_axis, xrad );' Z3 F4 h0 V- B
    UF_VEC3_scale( radius, my_data->y_axis, yrad );: g" q& S$ |0 T3 g
    UF_VEC3_add( xrad, yrad, x_y_vec  );+ q' S( M% ~1 C4 t& I: ?2 ~! A8 L
    UF_VEC3_sub( xrad, yrad, x_ny_vec );
9 E4 }$ G+ i- k1 N! w8 Q1 z0 g$ k    UF_VEC3_add( my_data->abs_ctr, x_y_vec,  pos_array[0] );
$ b( y1 z+ E% Q1 a: ]4 G    UF_VEC3_sub( my_data->abs_ctr, x_ny_vec, pos_array[1] );' ^+ Z7 h/ T8 v/ @
    UF_VEC3_sub( my_data->abs_ctr, x_y_vec,  pos_array[2] );
" ]* X/ G  w1 i3 F  \3 `" h    UF_VEC3_add( my_data->abs_ctr, x_ny_vec, pos_array[3] );7 Q# m1 q, a6 @6 j/ I; O! D  o! Q
    UF_VEC3_add( my_data->abs_ctr, x_y_vec,  pos_array[4] );
4 s+ _4 S" c4 [3 O0 a6 C    UF_DISP_display_ogp_polyline( motion_cb_data->view_tag,
9 F: G1 u2 T/ @: _9 x) [0 p6 Q                              pos_array, 5 );$ S+ R/ T! k2 |. O1 N8 ?/ I3 d* C
    /* Draw a "rubberband" line from the circle center to the6 g+ K2 z. {  ^9 w
     * cursor position.
0 W) P, ?9 C; m+ B8 E     */9 Z& ^( [4 z4 A$ i' b6 M3 M! }
    UF_DISP_display_ogp_line( motion_cb_data->view_tag,/ Q7 `# \! J& J( @3 J
                          my_data->abs_ctr,
6 x+ W: @$ K& V1 {* L( I                          screen_pos );
/ ?8 o" N$ r3 E! G2 d2 s}, v& q8 f) }; g$ Q/ u2 c+ @
#define UF_CALL(X) (report( __FILE__, __LINE__, #X, (X)))
9 H$ J* P5 f. Q% J3 istatic int report( char *file, int line, char *call, int irc)) c- w7 {  M# ^& q9 A5 U" n' f
, K$ n& H( e6 x8 ~7 @/ C  if (irc)- P# X; Z  P( k+ V* }# d2 V
  {% q8 F# O* G- `
     char    messg[133];
, G0 F# E' C' O/ v, D/ N     printf("%s, line %d:  %s\n", file, line, call);" v/ k: a. y/ ]* f$ G# v9 ?
     (UF_get_fail_message(irc, messg)) ?
, w9 u& K$ _. V       printf("    returned a %d\n", irc) :
. C8 H9 G) I8 J- k! C# u6 H       printf("    returned error %d:  %s\n", irc, messg);3 r) w9 z% {- U6 V8 [! B9 {
9 U4 U+ L6 D* U2 Q7 T  l9 H3 w  return(irc);
7 a3 L9 a/ \3 B+ K( E! C; N}
  P2 R* @- {/ S( {2 }7 mstatic void do_UGopen_api(void)6 P1 x+ V2 T4 E2 k9 O
8 f# `5 U; U7 g- m    int               default_plane;
- _2 _5 M. \5 I& _2 F0 G    int               plane_resp, ctr_resp, pos_resp;
8 i( M  [, {8 d9 x. P( D$ {6 |    tag_t             plane_tag, saved_wcs, mtx_id, csys_id,' ?: ]! y6 r6 W: X
                      arc_id, view_tag;
) R; K2 o. }& }- `0 }3 p. T    double            plane_matrix[9], plane_origin[3],
# b% [$ G/ s  F6 @1 ~                      x_vec[3], y_vec[3], arc_edge_pos[3];* q5 s2 l; I/ E& b/ y6 I8 o
    double           root_origin[3] = {0.0, 0.0, 0.0};3 X5 K) w4 T: k- D# z" i+ C
    double           work_origin[3];7 y7 \: \/ S& y. b
    UF_CURVE_arc_t    arc;# d# b* x* u% c
    my_motion_data_t  my_data;
4 I' g+ H6 {) I7 ^$ g% u* x! ^( p2 s* y5 F: E7 D# D
    my_data.arc    = &arc;
( u  Z, N; L- A- K1 ~    arc.start_angle =   0.0;
* J  ]) S5 w, b    arc.end_angle   = TWOPI;    /* Create a full circle. */
( N( X/ D( X! i: O, H: L    default_plane   = 5;       /* Default plane = WCS */
) v, A# A3 H# t3 v    do$ I' Q8 i3 C8 p4 f0 P; ^* j( v4 I
# y4 P: M" f) ~2 t0 `: f4 S$ W        /* Specify the plane on which the circle is to be created.9 @: {$ U) P* X! O$ o9 L
4 @  v, d( [, p7 P* C: `8 F        UF_CALL(UF_UI_specify_plane(. U% Y2 x4 C" g
                         "Specify plane for circle creation",. u/ p  @- b/ K! z  N( z$ @
                         &default_plane,9 t8 q' ]6 ^+ c
                         1,
) h7 q  }4 x. V) ]! C8 ?                         &plane_resp,& {2 b7 j3 a8 o! H& j0 p3 _
                         plane_matrix," G8 T# n# F5 m( D7 M) A; F" Z
                         plane_origin,
# L4 F  {6 z3 F  b: W% B                         &plane_tag ));7 }# L! Z9 n1 ^+ k
        if (plane_resp ==3)$ k+ T  Y. L# m+ _( v
        {* R7 T9 z; _7 Z5 A2 u+ G% m
            /* Save the current WCS for future restoration.
; d1 p) G. H# X* s0 ]0 d             */
5 ^  [& J0 F& Y& j7 t! F            UF_CSYS_ask_wcs( &saved_wcs );
* L  r! e: z- t1 K, S; E            /* Move the WCS to the specified plane. This is
2 K; W0 O! S5 A, U) e9 R+ r             * necessary because the position passed to the motion1 k2 }* m. t0 J% H2 P
             * callback, and the position returned by
  ?( v. T* I8 f! w' u0 Y" C; v             * UF_UI_specify_screen_position, is the screen) t0 ?# C! @% u8 q8 E
             * position projected onto the WCS XY plane.. I! i. `0 ]% X  |0 M+ I
% O& a# P+ L9 g: W9 h            if (default_plane != 5)" Q& a) d/ n6 I! Y4 g
            {5 j4 i0 {" g5 X$ @$ v
                UF_CSYS_create_matrix( plane_matrix, &mtx_id );- _* F9 Q! J+ R( n0 [0 r: k. a
                UF_CSYS_create_csys(  plane_origin, mtx_id,
& g! m3 p* B$ r* x$ E, a                                   &csys_id );
. q( `$ w' w0 ?2 C3 c4 ], j                UF_CSYS_set_wcs( csys_id );7 Z4 \+ @% U1 B) j
/ R# i2 ?' c7 X/ ?            /* Obtain unit vectors and the arc matrix relative to
( x/ h' t- K, v) \             * the Work Part coordinate system.
* _6 E$ Z% D1 j# W" D             */  o2 a' x/ ]/ c! j1 x1 F0 u3 `
            UF_MTX3_x_vec( plane_matrix, x_vec );
4 t, v5 l! |5 Y7 g) ^: V            UF_MTX3_y_vec( plane_matrix, y_vec );5 d! I9 d3 Y  i- `! Y' g$ S7 n
            UF_CSYS_map_point( UF_CSYS_ROOT_COORDS, x_vec,
0 c7 V( L" ?/ e, X2 k                            UF_CSYS_WORK_COORDS, x_vec );; ~/ `' `9 k: [8 H1 ?
            UF_CSYS_map_point( UF_CSYS_ROOT_COORDS, y_vec,
9 j7 f& ?1 L. b                            UF_CSYS_WORK_COORDS, y_vec );  f1 Z' j2 v8 Q1 w! G1 T, B
            UF_CSYS_map_point( UF_CSYS_ROOT_COORDS, root_origin,
9 K, j9 a5 s4 r4 G* P1 P                            UF_CSYS_WORK_COORDS, work_origin );
( x) t/ W* o' G& _' u5 Q5 u9 G            UF_VEC3_sub( x_vec, work_origin, my_data.x_axis );
4 `; h4 y8 z9 v9 D9 X! u            UF_VEC3_sub( y_vec, work_origin, my_data.y_axis );" Q4 r/ z: S9 Y# d
            UF_MTX3_initialize( my_data.x_axis, my_data.y_axis,
0 z( q$ C9 n/ T. L7 j# z                             my_data.matrix );; s* k4 k$ H' |
            UF_CSYS_create_matrix( my_data.matrix,! D, @, ?7 l  c2 n( T" J: g$ K9 r
                                &arc.matrix_tag );
( n9 Q. z$ L- o- ^            do: Y6 r* n) u9 M+ I# Y
            {% E* |  z- k2 L& b0 Q
                UF_CALL(UF_UI_specify_screen_position(/ l0 _$ G8 _$ t( C  s; \1 s
                                "Specify arc center",
! p! W- ?7 n$ g+ {! c, X                                NULL,  N$ N5 s4 v9 w7 Y/ a9 Q  N
                                NULL,/ s3 v5 r+ G% g/ R1 a
                                my_data.abs_ctr,3 v7 X! ]! e8 \$ i9 D
                                &view_tag,- G- v( E3 \' A$ N9 W
                                &ctr_resp ));
( d6 k' T5 d0 M& d. b8 M5 a                if (ctr_resp == UF_UI_PICK_RESPONSE)* x1 @) A, _) p: s& b
3 R) k$ S+ ]0 j, q+ T! m                    /* Map the arc center to the arc csys.! ^+ c- o0 h) ~6 u- a! y& q( R
/ k+ G2 f3 |$ Z+ r                    UF_MTX3_vec_multiply( my_data.abs_ctr,! g; T2 R1 Q3 S2 R- u, B" G$ ^/ k
                                          my_data.matrix,
! T# X  P2 U; {) w: m6 E                                          arc.arc_center );
. V$ T0 N/ l( \7 |* V  E3 T& `0 ?3 w                    UF_CALL(UF_UI_specify_screen_position(
: K0 f7 M0 ?7 Y1 ~) o- {) g  B/ `                                    "Indicate arc radius",
9 S$ R7 ^% T7 \4 E                                    (UF_UI_motion_fn_t)motion_cb,7 _( v$ `9 h4 E, w0 {# B* j$ z
                                    (void *)&my_data,
/ Y. m  X" s" }$ d/ [9 `) G+ H                                    arc_edge_pos,
' H  h: t9 U4 w5 \- v                                    &view_tag,5 W) R; v6 X4 H+ I
                                    &pos_resp ));
1 C5 c( m' P4 [$ V8 {; R- w                    /* If a position was obtained, create the0 Y/ p& A5 n% n' M# I
                     * circle.
9 q& a+ Z3 g, Q, k                     */
5 B9 B/ m. f. h2 r, J0 r                    if (pos_resp == UF_UI_PICK_RESPONSE)- o$ Y+ L) K: B% d
9 [% D5 l2 [# F                        UF_VEC3_distance( my_data.abs_ctr,8 Y, s. K. Q0 k6 Q8 Q# P
                                        arc_edge_pos,
/ B" |2 m7 `& |                                        &arc.radius );. b5 O, b+ L+ |
                        UF_CURVE_create_arc( &arc, &arc_id );' f& B0 _1 d! F6 `; F
                    }, Y' W. K' r5 c3 I; C
                }, r) c9 l1 p" n0 F
            } while ( (ctr_resp == UF_UI_PICK_RESPONSE) &&
- J7 W- D7 `* x                     (pos_resp != UF_UI_CANCEL)           );
' h8 h* _8 g  ^! s) E  _            /* Restore the WCS if it was altered above.
* B( B7 f% c; y& O0 j' [8 n             */: X" Q* Z% R& c- T2 ^4 q9 w( r
            if (default_plane != 5). f; l: O. W2 X3 J0 C# X; r
3 a$ N6 ~7 r+ g8 Z2 N) N% f( r- m                UF_CSYS_set_wcs( saved_wcs );
) {/ l  `$ u2 s' l2 R/ E$ ?4 p                UF_OBJ_delete_object( csys_id );7 i" J$ A" ^: P
            }/ E$ J$ G& |5 i& p
3 b9 W2 u; t0 U$ V  l- M: s9 ^    } while (ctr_resp == UF_UI_BACK && plane_resp == 3);/ R  I' T2 |, A/ @8 {2 v
}) U6 t% F+ J, V- q
/*ARGSUSED*/" X  a1 B( }4 c9 I
void ufusr(char *param, int *reTCode, int param_len)
& W. z1 h0 j6 S* y7 U{
8 w7 J3 o( O2 X# L  O8 u) F3 v8 q) p& d0 S  if (!UF_CALL(UF_initialize()))
6 G  r* q6 x+ \  I) I" B# C7 M$ e  {% ]6 J  t- x1 l* J7 Y5 ^
    do_ugopen_api();4 B' ?: @$ D% h# N+ s; m( Z
    UF_CALL(UF_terminate());5 }' K" T: F* J; X  X
  }% F1 Z  o7 \( T8 T% y
}9 ~) J" }# y! }. D. i1 y
int ufusr_ask_unload(void)
4 j/ m  e: d1 O{# j, y8 j( f) L. j4 K
  return (UF_UNLOAD_IMMEDIATELY);
! e, R. r0 [- N% ^& A5 \  D5 B' S- i}8 x2 e1 p# i$ f* H2 T( [
8 M0 y6 l" B+ I! U
发表于 2016-1-8 22:21:57 | 显示全部楼层
老师来个NXOPEN的耍耍
发表于 2016-9-17 10:11:08 | 显示全部楼层
学习一下,顶( }
