/ o9 R3 W. Y K/ a" O% X3 S
一些关于使用ufun进行CAM加工设置参数的简单函数示例: ]4 ?: \( W+ B$ t g4 p
可以参考下,常用的方式!' t: F0 I$ _- f/ h2 r4 u
/ b% S1 a# B3 h% g; s+ O# R. }* w
static int set_tool_param( int jj, tag_t toolTag )
) S1 Q# E6 E$ w+ l{& |. a- V" c0 j9 r4 C* i/ F
double toolDia = 0, toolRad = 3;! i: E4 t7 h: \
, d& m1 V6 C4 |' L1 n6 j# J1 P/* Modify the default 5-Parameter Milling Tool */0 r! t7 l; ]3 E) F
" g6 Z# l- V5 y; d8 [& E i swiTCh( jj )
( d1 I7 y! {- {8 S$ I {* T+ K2 \ J& j/ w6 G- S
/* Tool No. 1 */
( ^3 I# O& p3 n; }* {9 h2 m3 Z4 F/* Add a 3.0 MM crad */- s# E* t( U7 b! e3 C* L
case 1:
, {' d( l+ j' |% A9 E3 @1 Q, r {
% S# ]' l- j9 g% p2 q w UF_PARAM_set_double_value( toolTag, UF_PARAM_TL_COR1_RAD, toolRad );
) H$ s& c7 d4 x3 b0 H/ p break;
( q! l, N. @7 E2 I; o/ s: N }
9 d/ b# O8 \! c& p3 \! r/* Tool No. 2 */
; I/ [* k' Z7 H/* Make this a Ball Nose */3 Y* E9 {3 B% M3 o7 d- g n# {
case 2:6 |, o5 m# s/ ] N0 t; C
- _+ x4 O1 ^7 ~! E: j$ y UF_PARAM_ask_double_value( toolTag, UF_PARAM_TL_DIAMETER, &toolDia );/ S0 V1 y7 X% z% Y, T
UF_PARAM_set_double_value( toolTag, UF_PARAM_TL_COR1_RAD, toolDia/2 );
! m5 I3 O" d( u6 J break;* o/ c- y, P6 U
* W! q |. A @/ W/* Tool No. 3 */
+ A5 i2 t# L5 D/ s& y/* Define a smaller Ball Nose */8 I, }( B! g! {' U H
case 3:. ~* |) k# m( h7 b
{6 y: g2 |* Y( G8 z, {
UF_PARAM_set_double_value( toolTag, UF_PARAM_TL_DIAMETER, 25.0 );
3 c6 S6 f" E% S9 o/ \8 o5 |! e UF_PARAM_set_double_value( toolTag, UF_PARAM_TL_COR1_RAD, (25.0/2) );3 ?& l6 n1 v1 n3 |# n" T! T
break;( g# H5 S( n! Q6 \, a( m& p! T1 Y
9 B# Y- t: g! V, Y5 D* ]" ~ X" C default:
8 v5 U2 P/ b: j( M' u! j- s {
3 Q# ]" i4 M; M4 v printf( "Default...\n" );
) \" X* u! u* g& { }
' X1 }& u. O$ _3 e9 v; N }0 u/ O, u, }0 H; ]
return 0;" B; w) Y* B; k! |1 Z
# H' ]0 M3 |' w
- Y7 @3 v y1 V6 f7 zstatic int cav_mill_param( int numop, tag_t *operTag )* P; F) ]8 {- [8 {9 Z, B
{1 B" u) o, b% d$ j* i& b; i
/* int numop;*/
2 E( B4 s9 q' g/ L* m, T0 u double depthPerCut; g1 e4 @/ J& v+ X+ N5 @
double stockPart;
+ h0 W8 I% I' K- [, ~
% Q' ~4 F8 @' C; G! G4 X' m7 @ UF_PARAM_ask_double_value( operTag[numop-1] , UF_PARAM_CUTLEV_GLOBAL_CUT_DEPTH, &depthPerCut);$ ~- ~4 Q/ C& @! w
printf(" Depth/Cut default is set to %f\n", depthPerCut );* m) z$ K3 L4 q/ ^
UF_PARAM_set_double_value( operTag[numop-1] , UF_PARAM_CUTLEV_GLOBAL_CUT_DEPTH, 12.000 );
0 T" h- i1 V# ~. Z# H1 E UF_PARAM_ask_double_value( operTag[numop-1] , UF_PARAM_CUTLEV_GLOBAL_CUT_DEPTH, &depthPerCut );( W( Y4 R$ l/ t: E( c' x6 \
printf(" Verify Depth/Cut reset to %f\n", depthPerCut );
$ `, R6 S, T- n0 [; y; I) ~+ [/ y' n- t- i! j
UF_PARAM_ask_double_value( operTag[numop-1] , UF_PARAM_STOCK_PART, &stockPart ); c4 ^& E. D9 v2 y: @# }
printf(" Part Stock default is set to %f\n", stockPart );# C1 ?6 G; p; d
UF_PARAM_set_double_value( operTag[numop-1] , UF_PARAM_STOCK_PART, 1.0 );8 X0 a$ E- I. I8 b8 w; [
UF_PARAM_ask_double_value( operTag[numop-1] , UF_PARAM_STOCK_PART, &stockPart );1 F6 O6 Z7 f& z& t( B
printf(" Verify Part Stock reset to %f\n", stockPart );9 Z8 z$ c& K$ P) O) Y) @) J$ Q
& i8 q; \% M; v3 e/ W9 S UF_PARAM_set_int_value( operTag[numop-1], 327, UF_PARAM_cut_trace_method_tolerant );. q. e' I! f& |9 [. H0 }7 V
UF_PARAM_set_int_value( operTag[numop-1], 328, UF_PARAM_cut_ctrl_trim_method_silhoutte );% j& P* R( B% O+ I- ]
- K$ U' `! J7 b return 0;
/ F! O* y& h( ?! ^% @0 d0 h}$ R' W; w9 l+ p: o$ h7 Q: J
2 c) h! Y: ~ l
static int flow_cut_param( int numop, tag_t *operTag )
' }+ C1 N' H" Y9 H9 H" L{
. m: N) k- h' m1 Z UF_PARAM_disp_tool_t display_data;
' F5 x9 }. e T7 `* n# z display_data.type = 2; /* Type = 2 produces 3D tool display in tool path. */7 P6 B l! X2 A
display_data.frequency = 10;
0 d Y4 L% B$ Q7 y3 A( M7 \8 o6 O+ o& r/ N
UF_PARAM_set_subobj_ptr_value( operTag[numop-1], UF_PARAM_DISP_TOOL , &display_data );
9 K3 e& G& T/ H UF_PARAM_ask_subobj_ptr_value( operTag[numop-1], UF_PARAM_DISP_TOOL , &display_data );$ R' w4 X& L+ q% f2 n( j5 i
printf("Display data for tool type returns %d\n", display_data.type );
. h; w ^; q: g3 S0 Z% b$ w9 A! g printf("Display data for tool frequency returns %d\n", display_data.frequency );
4 L; W0 d% H2 Y2 d: c
: {! t0 }+ R( ^& m return 0;
4 H6 {7 T, n1 C7 o1 R}
' J0 p- Z3 F. f7 H
: x1 i6 j. x7 x8 R2 \static int area_mill_param( int numop, tag_t *operTag )
5 G. t# v, }1 r8 \' H @{3 L7 M# p& w4 G; y
% r4 {- f& c0 w
UF_PARAM_set_int_value( operTag[numop-1],UF_PARAM_CUT_EDGE_TRACE_REMOVAL,UF_PARAM_edge_trace_removal_on );; L8 k! o L8 T
# y1 O2 F' u- Z* B
/* 1 = Warning, 2 = Skip, 3 = Retract */ ' @1 E" D$ l# U6 ~$ z% J
& L2 n9 ]" f* N* h" x: e- V UF_PARAM_set_int_value( operTag[numop-1],UF_PARAM_AVOIDANCE,UF_PARAM_avoid_stepover ); ! r1 b' K6 I) I! y C- r" f
UF_PARAM_set_int_value( operTag[numop-1],UF_PARAM_CUT_FOLLOW_CHECK_STATUS,UF_PARAM_cut_follow_check_on );
8 I- L6 S/ b. n
9 n# v5 {8 ~7 ^6 h% f" z" j return 0;6 y, m9 k# y6 @- |- Y8 o
}4 \/ L% c& P& A& c; R* }. y
' w X1 e( ?( C* }/ X" P0 P |
