这段代码可以参考看看哦,显然比ufun的代码长点,但是是新的也是最好的方法( _0 \+ F4 x( A- I7 {
2 L/ `% ^, I( s( q0 N) [1 ]1 H
; B$ ?5 V3 S( {: p2 W/ g& ~
/ H$ e/ j- G7 z0 O4 x Z! T$ q! c8 R /* Initialize the API environment */
- F+ g! o' Z; R if( UF_CALL(UF_initialize()) ) ) g: q0 M1 w$ ^& u, M
1 v g+ Q. U5 Y. K* k" k4 l K9 q* q0 ^ /* Failed to initialize */2 k, K: I2 Z5 Y3 F+ f7 F
return;
6 t& q! K7 h5 L }$ F- ?9 j3 W6 n1 I0 c" v v
/ C4 u" @$ N. f8 }. V$ ~
Session *theSession = Session::GetSession();
3 T$ X# h7 ]: p; `' B$ c, e Part *workPart = theSession->Parts()->Work();+ w; z3 X) F0 [# J% i3 c2 E
$ k1 E' u S+ {: X* U8 L+ m /*Get the existing group objects to create the operation under*/5 e5 p6 J6 [ B) z9 `
CAM::NCGroup *programGroup = workPart->CAMSetup()->CAMGroupCollection()->FindObject("PROGRAM");
E& i# n. W& {- r CAM::NCGroup *methodGroup = workPart->CAMSetup()->CAMGroupCollection()->FindObject("METHOD");
" ]( y: z" [+ u* T7 k7 N* X CAM::NCGroup *toolGroup = workPart->CAMSetup()->CAMGroupCollection()->FindObject("MILL");' }" |1 d+ C2 A/ N3 L+ s6 }; l
CAM::NCGroup *geometryGroup = workPart->CAMSetup()->CAMGroupCollection()->FindObject("WORKPIECE");" F8 A2 ?1 d; K( K6 } Q
) c2 ^1 T" ^+ ?
/*Create the Cavity Mill operation*/& `; _1 N; A, m& D: Q; N
CAM::Operation *operation = workPart->CAMSetup()->CAMOperationCollection()->Create(programGroup, methodGroup, toolGroup, geometryGroup, "mill_contour", "CAVITY_MILL", CAM::OperationCollection::UseDefaultNameTrue, "CAVITY_MILL");
8 K* l N" \4 w9 I. a# b3 Q
# W" ]' L/ A j" L( C /*Create the Cavity Milling builder*/* F! V' I! z6 g1 K8 n% j
CAM::CavityMillingBuilder *cavityMillingBuilder = workPart->CAMSetup()->CAMOperationCollection()->CreateCavityMillingBuilder(operation);
: c8 G/ N( X# g3 o' u' q# x7 q% h! b: E& _9 N8 n
/*Get the solid body named PART*/4 \) n. p# Y) @; u+ `9 Z5 s8 \9 o
tag_t partSolid = NULL_TAG;
/ u: Z, ?. H; C) h UF_OBJ_cycle_by_name_and_type(workPart->Tag(), "PART", UF_solid_type, false, &partSolid);' {6 h# Y+ O. Z* \, W
Body *partBody = dynamic_cast<Body *> (NXObjectManager::Get(partSolid));
( U$ H1 h9 z% X* W v1 @; Y8 y j std::vector<Body *> partBodies(1);
+ T9 j& @, J% a- {) F: q partBodies[0] = partBody;
# m l! a; ]6 ~! H% J; _3 Y, T$ f- @# f
/*Set the part geometry*/
+ J# n4 _4 i- O cavityMillingBuilder->PartGeometry()->InitializeData(false);
8 S5 Q6 k6 h/ t8 k$ [1 ?, I CAM::GeometrySet *partGeometrySet = cavityMillingBuilder->PartGeometry()->GeometryList()->FindItem(0);
/ g) A8 E1 s* a7 B/ p BodyDumbRule *partBodyDumbRule = workPart->ScRuleFactory()->CreateRuleBodyDumb(partBodies);
9 B& W; F; l" ~2 Y% @ std::vector<SelectionIntentRule *> partRules(1);7 x0 c( }2 i, k
partRules[0] = partBodyDumbRule;2 q( _" K3 m/ W- {1 L
partGeometrySet->ScCollector()->ReplaceRules(partRules, false);
% }. Z, w6 ^9 t, F1 h3 ?% r
/ a: Z3 |6 o( q" b( ~2 G7 C5 t* r /*Get the solid body named BLANK*/& w" z1 }) U8 b9 v& r/ X
tag_t blankSolid = NULL_TAG;" r; I1 ?2 k4 s' B) `4 s( i1 r
UF_OBJ_cycle_by_name_and_type(workPart->Tag(), "BLANK", UF_solid_type, false, &blankSolid);
# I2 _" c1 Y( h* ~$ c" R) { Body *blankBody = dynamic_cast<Body *> (NXObjectManager::Get(blankSolid));
% N- _ O! r- b5 G0 y std::vector<Body *> blankBodies(1);
; D9 t. V8 M$ H+ n blankBodies[0] = blankBody;
; k# e3 [( _& X. ^/ w3 i2 S1 T
" O+ @& ?. C0 b) C& Y ? /*Set the blank geometry*/
3 k: |0 ^. {9 u# k3 T cavityMillingBuilder->BlankGeometry()->InitializeData(false);. u7 B0 Z& N! I, M
CAM::GeometrySet *blankGeometrySet = cavityMillingBuilder->BlankGeometry()->GeometryList()->FindItem(0);
+ c0 o1 }, F' v9 R' H' Z4 C BodyDumbRule *blankBodyDumbRule = workPart->ScRuleFactory()->CreateRuleBodyDumb(blankBodies);' [' P: S, ^2 _7 V5 w; J6 ^$ `
std::vector<SelectionIntentRule *> blankRules(1);
& C7 o" a+ Y# c. u5 f blankRules[0] = blankBodyDumbRule;
) i; Q$ |9 F L8 y4 ?% x% G3 m blankGeometrySet->ScCollector()->ReplaceRules(blankRules, false);
8 S! } o6 W) B3 ^9 _ \- `. \
cavityMillingBuilder->Commit();
3 \2 G: X f! ? cavityMillingBuilder->Destroy();3 G. C: v4 _- A4 I
# e' c z3 N' s" F* t+ B /*Generate the tool path*/9 B; }* D. c a# z0 B% _& K: I
std::vector<CAM::CAMObject *> operations(1);4 x8 d) Y- [* `1 x, b/ J! t( @
operations[0] = operation;
" }8 _6 e( B' Q8 q' F$ y workPart->CAMSetup()->GenerateToolPath(operations);& _& w, R# B0 S6 c: m: f$ W
. f* d; F6 g" p, Y/ P
/* Terminate the API environment */
! C }' z2 \! V$ ?# Z" \$ q$ m UF_CALL(UF_terminate());
3 y8 j: q0 l2 A1 X3 d# k}$ F) f6 m' j" F( z
% E- N' }( t! S
