[资料] Teamcenter制造管理TCM操作的基本任务和过程
2016-4-25 22:46:28 6197 1
admin 发表于 2015-8-4 11:00:14 |阅读模式
2015-8-4 11:00:14
Manufacturing Process Management basic tasks
/ g' p( }8 O6 j6 o7 t
1 E& I' L7 S' }6 _# s) JTo create a manufacturing process plan, you can perform the following basic
2 S* k$ _. \9 G$ n9 U+ A; wtasks in the Manufacturing Process Management environment.
# A. i) B) P+ |' s) x4 ?4 I2 G4 W* z' {# K! x
• Create a manufacturing process
* D/ P+ S" d2 C$ {% HThe manufacturing process plan includes a top-level structure of the
2 Z! O1 r: s9 z+ O, P# L5 kprocess needed to manufacture the product, as well as a detailed design" W( V1 N$ o4 a
of the individual processes and activities to be included in the plan. As9 L  D0 [+ Y4 @/ G' q
you build the process structure, you can assign resources to the various# D/ j# X6 j2 s/ a9 |8 L/ q" h/ d
processes, operations, and activities. You can also identify the specific! F- g1 Z/ d% Q" [- G* J
locations within the plant where each operation and activity is performed.3 Z' G7 r$ E' z& k
) K. z& J. T$ h* Fo Load the product and the work area.
; _% a/ h: h9 w8 z7 e3 G# Jo Create the process structure
9 a+ t9 K% e" K  f& `: f6 P. Bo Create operations
' c  u! ^2 X. q  k0 w' U1 ~; L; _3 Oo Establish relationships between process, product, and work areas
2 C% f. y3 e+ I. I0 Ro Assign work areas3 M7 d/ v/ b  b! Q
o Create activities under operations0 S- V7 P' @; }" r
o Add resources to operations5 d/ v: F; ?2 P* b
o Verify the manufacturing process1 |% e* Y7 J$ A! r3 \
o Create structures with Microsoft Excel™/ u: j: ~3 k1 `5 ~
) s3 R- D) R* {& B% U$ ?+ C
• Create a factory or plant structure1 |2 R5 @8 F$ q/ U  p. e
Plant Designer allows you to design, modify, import, and export the9 x) m$ t2 M& V$ t0 d
structure of the factory in which you build the product. You can provide( x  g( e% h- b, v  E
a view of the plant structure layout and organize the areas where the8 o5 `* W$ ~% v+ m# H$ Y
product is manufactured and assembled.
" e) e  |0 x/ o) {; B) }o Create and edit the plant structure5 _6 p0 ^: d5 a
o Define work areas
7 r4 }" f% {* T; T. {" V. f) {o Manage plant structures and layouts. `3 F# Z5 `+ s  a
o Store model files in DWG format or as JT files for visualization
: W" z3 Y* v6 }
  p. P- `% O" t- T• Create a preliminary data indicator (baseline)
8 Q  m+ W# f5 d3 v& @7 I# cYou can create a preliminary data indicator (PDI) or baseline of a
, e6 n% N/ h: c& ?% {manufacturing process that is in development. You can then release/ o  S: c' N* _4 F% Y
the PDI to other users and external suppliers, who can then complete
, k) V- x8 g$ W: Eassociated work on the basis of the data in the PDI. You would normally; R9 A: r7 Y* y2 k2 Y
release PDIs at defined intervals, so that users know the effectivity of
2 V* z) c9 Q, O1 x9 T: l: r. Ythe data provided.
2 E) W9 q/ o' |# Q
- s8 R  h7 S2 R. G/ y8 }* k; E" u• Create an intermediate data capture# |! m2 v. M  m) m0 d
You can capture the state of any structure or part of a structure for; ]: G8 q- h, E9 ~& }' e
subsequent retrieval and viewing. This capture data does not represent" h: Z$ w; z" I& C5 C; ?5 r3 z5 m
the final released state of the structure, so it is referred to as an' v& F- z6 n- `* Q* o
intermediate data capture (IDC). The configuration rules are saved
8 S7 z! d4 ?( Z; K- U" H8 k8 ~+ Qwith the structure allowing its exact state at the time of capture to be
4 t0 L4 n3 L& f1 U/ R* |6 x) {% h0 ~reproduced each time it is retrieved. Creating an IDC does not affect any$ `3 J2 C/ M0 ~8 o) m
subsequent changes to the structure or its release by a Workflow process.
" K7 W+ v1 Z% e9 _3 \' }8 k7 C7 x) S4 T7 ~
• Create reports$ }8 g# s9 [7 ]3 V# s, _! y7 i
You can create reports in the rich client or the thin client, and attach them% Q) U: t0 G" V/ D2 v" W+ b
to appropriate nodes in your process structures.. b6 N" U% r4 H5 |) g2 Z3 _: ]8 b
. G, p9 @$ U5 H1 \7 ?• Performing process simulations
' h# C: g& s. }( Y$ aThe Process Simulate application allows you to perform detailed& v8 m! z. r' E7 R( E
simulations of process structures that are maintained in Teamcenter.
% x% [3 e( G  q( F
4 V: c, X' g0 `: c• Design a fixture for manufacturing7 ]9 k* O' n2 T1 W9 f! |/ g
When you design a fixture to use in a manufacturing operation, you must
$ d7 F% {/ x9 X" N0 ~( Xknow the state of the product in the manufacturing process in which
) m. m! \4 e6 r: ]  t9 T5 cthe fixture is consumed. You also should know the factory components9 {. x0 \) [, \5 B  z5 z, j
in which the operation is performed, and the relative positions of the/ t8 v" E5 h; p) \$ D
in-process workpiece and the factory data.
9 l7 ^9 @( w4 q9 |, E2 P# [/ E" n6 r
# ?. l6 H- o9 x1 I: j6 F0 C, W
ericp 发表于 2016-4-25 22:46:28
ericp 沙发
2016-4-25 22:46:28
全英文啊,看一看
