[资料] Teamcenter制造管理TCM中MPP的工作流程
2015-8-4 13:36:59 5104 0
admin 发表于 2015-8-4 13:36:59 |阅读模式
2015-8-4 13:36:59
Basic tasks using Manufacturing Process Planner9 I# g, I8 ]' [5 o
5 Z' P# }1 W: L/ l% B* K) W, FThere are five main tasks that you perform when using Manufacturing
/ P, w. I, V# k4 B& b) x& EProcess Planner.
& Z# ]" W0 `7 o( B) Q( t; q
( j- u" S+ u; \7 o4 w) a. {1. Open the product in Manufacturing Process Planner.
& l; j6 P- b0 r% u( E- RBring the product into Manufacturing Process Planner before associating
/ q& b# i# g& }; H7 P+ f  Va process structure with a product. The product is typically designed
5 @& Q+ n, H  b) P2 I; Dwith an independent application and loaded into the database. Once in% X. G0 o7 s. l" Q
the database, it can be included in a product structure and opened in6 F& S4 [+ z7 O1 }% y6 C% }
Manufacturing Process Planner.$ M; r# |- Q' f! C$ P  E
% A) m) t) C! |6 t# ]: N
2. Define the work area.$ N6 p* Y3 z# C$ G
These are the locations in the plant where various operations are
! P) R/ z3 {, O: l' j# t/ dperformed. They are described by their location on the shop floor and
. O& l% {; }4 b) O- sthe process capabilities they provide. Any number of work areas can be! }6 b3 |! \# J  N# U" `8 P
defined.# \* c( P' q; x: y: H' y9 P) y
; H7 z! V6 q) T0 g0 t; J/ V/ d, F3. Create a process structure.
$ N1 S* i" @3 Z6 F% x5 D$ UThis specifies the sequence of operations and activities during the
& x# c+ _  u& ]3 \manufacturing process. You can specify the operations and activities that
! l4 X9 ^. O& Mcan be completed in a parallel process, and the preceding processes to
; \3 Q+ R" d8 |* scomplete before others can begin. As you build the process structure, you: K5 d; E9 C; }$ s8 |+ F. h$ C$ W
can specify items that are consumed by the process, and you can assign( S! G7 a( S. o, ?
the individual components of a target assembly as consumed items.3 L) @  X+ J- Q7 x% u- M3 [
' e4 ~( d) |: f, ?! p
4. Create a workflow by sequencing your operations.
  s& G1 z4 }# qThis defines the individual operations and activities used to manufacture4 H! _' M7 ^; `- B! C5 m6 W* }
a product. As you create the structure, attach the resources used in each* }) Z" s" O% G+ W9 V: I
operation and activity.. o2 y& H3 W2 V
3 V# R% W" S8 j' X) q5. Create product, process, and work area associations.
' A4 f: Q3 u9 \3 ]% z9 G& YAssign target items to the processes and operations to associate specific
! m4 @5 U- F6 W0 w" Q0 \processes with a particular product. This identifies the work area where7 |: c* Y1 S! m, m: f
the processes are performed.5 _" h5 \. ?9 D: q) L2 N
You can have more than one work area and process associated with a! i+ F9 \, a% P1 x' G6 P1 w3 F
given product.
& v0 Z* G  \) B8 L. n1 e
9 `$ Z% U3 x. _, z" K( R
