3 g/ {/ l* F h' e
4 q7 w6 b8 \/ I% `
Action handlers ! N( w3 [# b9 h8 @•EPM-create-status and EPM-set-status! l: C# ?3 O& J/ n" H( b# }
◦The EPM-create-status handler creates a status object and attaches it to the root task. ! `" s0 ]/ z ~# X3 z◦The EPM-set-status handler applies the appropriate status objects to the target objects. 8 X2 m( k1 T* B( L
•EPM-fill-in-reviewers) [. y& @ S) h( q$ ]1 q
Automatically assigns signoff reviewers that meet specified user, group, or role criteria for the specified Review task. This criteria populates the signoff profiles. + y# g& Y/ M0 x
•EPM-require-authentication ' t2 r* x* S; s- v' l% Y0 HDisplays a password box in the perform dialog box or pane of the task within which it has been placed.- i! b% L( r( ^5 Q
•EPM-demote and EPM-demote-on-reject * S& V5 n, n, y rThe EPM-demote handler clears all signoff decisions from the current and previous Review tasks. An optional argument allows the user to specify the task name that the process is demoted to. + ^- B" c, A% y5 g0 IThe EPM-demote-on-reject handler demotes the current task to the previous task or to the task specified on the -level argument of the demote handler placed on the Undo action of the current task. " m( v& t4 G% b7 L- p7 a•EPM-attach-related-objects 8 W% M, s; P- yAttaches the specified related objects of the target objects as target/reference attachments to the process. This handler searches all target objects, finds the secondary objects with the specified relation and type (if specified), then adds them as target/reference attachments. h% N5 m. H( @2 V; ]3 \& k( N1 S8 s! _
Rule handlers) f2 T; ^- y3 S& B( y* }7 V
•EPM-assert-targets-checked-in" I: S9 k3 X! k
Verifies that all target objects in this process are checked in.$ N. ^+ y* B" w% L/ r3 m. W
•EPM-disallow-adding-targets and EPM-disallow-removing-targets) y+ _5 M7 a. o1 `7 u: @9 Y: O
The first handler disallows adding targets after a process is initiated. A swiTCh can be used to specify the types of objects to be excluded. The EPM-disallow-removing-targets handler prevents targets from being removed from a process after the process is started ( U# l& _0 S0 T - O {6 S/ |. y5 O: G
