6 Q3 w0 R6 C+ C5 _% c; g
) ^2 E+ _0 X* M. b- f. n开发语言:VB.NET
, U+ c$ ~8 H5 A( LNX版本:NX8.02 ]3 K+ Q+ w2 x2 Z
开发目的:快速调入library中的指定刀具
- T" G+ @6 ^. T# j; n' J( O3 y: ?# G- [1 a6 }
定义变量
; \6 q% X7 J7 k4 b: T8 V. ~- G5 q Public NXToolName As New ArrayList9 h: h! d" y6 i% l
Public PreName As New ArrayList4 U/ l( ]9 c2 c5 [9 ]1 q8 k) d
Public BckName As New ArrayList
/ g' _) \ L, j U2 X Structure ToolObj
6 N D/ u0 `; s! g3 L( u Dim ToolName As String
( l/ b( o, V, y" e$ l) o Dim ToolDima As Double
& e( S: [( T& t; N7 B( W* ] Dim ToolLength As Double+ G [5 O2 t* `7 r- p
Dim PreName As String$ \3 L9 l6 _3 L' S7 W
Dim BackName As String
7 b6 k- b5 X4 e0 S+ s! `3 h& z H End Structure% Z( g: v# t5 _' J
Public NXToolName_Library As New ArrayList: l0 ^5 z$ h. d9 k1 c2 H$ T
5 ?4 G; ~# @' L! R( T& b
# x7 j& @0 E L& i7 B程序入口
7 g9 `. B+ P' P6 t8 X0 L Sub Main()- z4 F n& E. y1 u: K
Dim NewForm As New Frmmain( q; f- A3 B- S6 @) W7 x$ Q& L
% r3 |7 ^9 g5 Q: M8 z* Y2 } Dim DllPath As String = System.Reflection.Assembly.GetExecutingAssembly().Location.ToString()
: o0 r; h: r. n! S Dim Posi As Integer = InStrRev(DllPath, "\")$ t+ r6 ? t9 m2 U6 F+ I! H) m
DllPath = Mid(DllPath, 1, Posi - 1); ^- `5 i6 E3 I& I# L+ O$ y
Posi = InStrRev(DllPath, "\")) K) i: `+ ?' X* L- {( t7 g0 L
APPPath = Mid(DllPath, 1, Posi)
g" K. }- K$ B
2 [8 U0 [& I3 I) ^ NXToolName.Clear()
3 p+ |. \# i; W0 c5 o GetToolList("GENERIC_MACHINE")
8 R) ^/ V' v: m3 ] GetToolListFromLibrary()
+ r% p0 \* m5 Q7 v1 R* q6 }0 q Try3 H- f/ g3 Q( _" q$ l' h( j+ y
If GetRight() = True Then
' o" }, |2 n1 o- ? NewForm.ShowDialog()1 P$ X! m% i7 `
Else3 B( @: T2 v4 m ^3 u9 P
MessageBox.Show("服务器没有开启或当前机器没有权限!", Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Information)
" U/ m% W7 @) i3 D End If) s6 ?9 \7 S) g5 H
CaTCh ex As Exception
! g# `3 I2 e" f) e* D9 W3 x
& t1 o: G- d" Y5 v( } End Try- x# }; ?& e) z- f& o
1 i5 @+ ?% `$ U; p
End Sub
* i) b# ]+ u2 T1 D' [3 Z
7 j' ~# L% t5 H3 W5 t! }4 F" ? Sub GetToolList(ByRef String_Pass As String)
+ w8 M0 \3 \$ K2 r; d# b' z4 g Dim TheSession As Session = Session.GetSession()
0 \- i# J& ^. c- X Dim ThePart As NXOpen.Part = TheSession.Parts.Work& j8 S% L% M' R% H
Dim NCGroup_Cycle As CAM.NCGroup% i" J! ^% I% s' L
NCGroup_Cycle = ThePart.CAMSetup.CAMGroupCollection.FindObject(String_Pass)
7 s/ j ~' p7 \! o$ |, P- f# k Dim NCGroup_Cycle_Members() As CAM.CAMObject = NCGroup_Cycle.GetMembers()0 k9 @+ C# L( t" }5 k
For i = 0 To NCGroup_Cycle_Members.Length - 10 n: R9 e- {0 f8 ?
If ThePart.CAMSetup.IsGroup(NCGroup_Cycle_Members(i)) Then& w5 Y& v! e; U+ i$ {
If NCGroup_Cycle_Members(i).Name <> "NONE" Then
Y' \" I2 O s9 l NXToolName.Add(NCGroup_Cycle_Members(i).Name)
8 V/ n/ l Z3 W$ w3 x: T End If8 h" L* ]! J& e; a7 c7 v2 }, B
GetToolList(NCGroup_Cycle_Members(i).Name)
8 k+ N. F3 k7 H M* L" h6 z End If: ~1 o* j- r W
Next& _/ Y( Z/ v: S7 Q4 s1 ~/ P
End Sub
: M8 U2 j9 e8 j1 `' H( D/ B Sub GetToolListFromLibrary()
* K2 J' W& }. f) r NXToolName_Library.Clear()
n! z5 ?; g& b5 N" Y Dim NX As String = Application.StartupPath
3 N2 r6 ?5 j& ~. N3 c Dim Num As Integer = InStrRev(NX, "\")2 d& V3 z/ H. g% l) }
NX = Mid(NX, 1, Num)
a$ P1 {! `4 e7 n6 p% ]$ O Dim ReadFile As StreamReader = New StreamReader(NX + "MACH\resource\library\tool\metric\tool_database.dat", System.Text.Encoding.Default)
2 w$ o$ f: W; K4 f5 V, r Dim StringLine As String = ""5 l1 P1 u+ q) s. w) E
Dim StringSplit() As String' B' a% r5 Q2 R
If ReadFile IsNot Nothing Then
4 U0 q% k& ]5 N% O Do Until ReadFile.EndOfStream
8 A4 d$ e5 I% Y M- p StringLine = ReadFile.ReadLine
+ F$ j' g# M% i7 J8 E If InStr(StringLine, "DATA ") = 1 Then ‘分析刀具名称9 w% I8 C0 ?2 q* A0 Q
Try
1 ]3 ?/ h0 h- E; G0 Q1 A StringSplit = StringLine.Trim.Split("|")) l( U/ s/ M- I, ?' Y0 b3 S
Dim ToolName As String = StringSplit(1)- ~" |8 f: L+ y. v0 O
Dim NewTool As New ToolObj5 l9 S+ l, {. _+ n+ n
NewTool.ToolName = ToolName- ~% {: E x: m& R1 x. q0 g
NewTool.ToolLength = 0; S9 n8 L: `# t0 L: y' @/ i f, g6 O
Dim ToolData() As String = ToolName.Trim.Split("_")" @1 k# \; H, }) n# A; G; U% \. X! `
If ToolData.Length > 3 Then; K' G1 h7 A) G
For j = 1 To ToolData.Length - 1
3 V, t% {, A4 R9 I& W Try) b+ E0 Q0 n- J' l
If InStr(ToolData(j), "L") > 0 Then, r v R# S) V* p" a$ _
If InStr(ToolData(j), "-") Then) k5 w" ?# i* ^$ {8 Y/ d2 E! W
NewTool.ToolLength = CDbl(Mid(ToolData(j), 2, InStr(ToolData(j), "-") - 2))# J R3 I( Y! y$ Q
Else
8 s8 Y7 c# E9 {/ ~* @" T NewTool.ToolLength = CDbl(Mid(ToolData(j), 2, ToolData(j).Length - 1))7 ~4 a( j9 o2 \! \
End If
1 k, S/ {/ _6 ^- l+ E9 p Exit For( B5 S- {* t0 \ Y T: j
End If
3 }+ I/ Q3 I* N' u- K- y" E, q Catch ex As Exceptionm* b! s5 |5 t& f) v6 Z
End Try
% |3 I$ v( k/ z9 d$ C0 t0 J Next
* O) w3 K% ^! y' C+ I6 ]
+ f% g1 f3 L( w" I NewTool.PreName = ToolData(0)0 u; ]0 P2 q# e$ _! h+ Y+ C
NewTool.BackName = ToolData(ToolData.Length - 1)6 m- d; z4 F6 f# h3 o' V% j
: e* f5 S T/ r# [" }4 Y" X Dim PreNameIn As Boolean = False) Z o- \6 s5 N* d7 S4 n+ v' C0 k
For i = 0 To PreName.Count - 1, j1 c% n& R7 A' t! y+ L
If NewTool.PreName = PreName(i) Then" N! @" E' p: D) @5 p% @7 e
PreNameIn = True" }/ _) ]" u* n8 V& h+ J
Exit For, j1 P+ b( k3 P- f/ L' Z% e
End If9 u, f; h0 I+ q9 s5 d0 P
Next
: m1 o5 i# G7 I' [/ c If PreNameIn = False Then C& U$ e' |8 ]# W' t' ?" Q
PreName.Add(NewTool.PreName)$ e; J( m7 V' Q6 Q
End If, r& Q d% Y% ?
3 ]7 ^* H. i7 x9 _2 }
Dim BckNameIn As Boolean = False4 y. u, n; K0 h% ^
For i = 0 To BckName.Count - 1
% O7 F5 B; A; b9 j/ h' ~9 \& Z) C7 c If NewTool.BackName = BckName(i) Then _+ B$ U1 f) v6 B# S) @3 N! ^
BckNameIn = True
) w1 N4 X7 c5 ]4 D$ X Exit For
! |+ z! A! s7 [( f End If# H2 l: r# w9 ]+ p& e$ D# {6 U
Next
' ]6 p+ I3 s# z If BckNameIn = False Then
A0 ~7 ?6 z3 a& v5 N. |. l$ i BckName.Add(NewTool.BackName)9 V. @% K [. @& @: L
End If
5 r- i& v, M, z2 }- z: {
, D9 d1 q4 V# y NewTool.ToolDima = Trim(StringSplit(10))
. t5 ]3 s' ^2 \. B6 y% t If NewTool.ToolDima = 0 Then
9 u2 p: L7 U/ U" }" s* M6 C4 j NewTool.ToolDima = Trim(StringSplit(14))
$ M$ z5 C* b- A& \2 Y: e End If! Q4 p# G. {- Y% e! n
NXToolName_Library.Add(NewTool)- y) A& a/ v( T5 g, h
End If. V" t& V, @4 ~0 x. T2 p) b4 s( \
Catch ex As Exception3 e) N$ Z$ a m& J
1 o: `# S5 e7 [, v1 [
End Try
0 T/ E) c l2 z& S! s End If8 x' T9 C! N5 ]7 N+ H1 }
Loop
- S2 m2 n7 P$ B) ~' K PreName.Sort()2 ?; G* q9 k& b" |" R9 C" S8 @4 h- @; X
BckName.Sort()
B0 V' t4 @* Z: v. b End If
; k& t5 e3 y! q End Sub
; h+ y: f8 W* v9 M/ H, v Public Function GetUnloadOption(ByVal dummy As String) As Integer1 j* `& X7 b! @" H5 P0 b
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
' Y. a: @, v+ ^0 w% V4 i End Function
7 L* d, U8 d7 D5 q. \' b3 ~5 M4 U7 @4 T; j- [- G* p, E0 Y
: z# ]9 U6 O7 [2 I
刀具导入工具界面
