查看: 3867|回复: 1
[原创] NX二次开发linux平台下需要安装的rpm包
 火 [复制链接]
2477
发表于 2016-10-4 09:12:54 | 显示全部楼层 |阅读模式
国内应该用的少,感兴趣的看看
6 x" v2 }5 ~8 o/ n* S0 w' H8 W5 h& a, l. n& L
NX needs the correct rpm kits installed in order to properly build an NXOpen program.
7 \9 T1 ^1 |7 ]* m: J( y! \7 o7 JOtherwise compiling and linking may fails by missing dependencies, e.g. "Cannot find -lelf -lXm".6 S; K& x; c: I7 Q3 P! k1 U+ F& v
" i; R  H: l  a0 H9 C- C# l! w* [
For NX 11 and SUSE 12 the following packages are required:
& c+ U3 Q; ?2 z; \/ e# y----------------------------
% Y% t/ ~9 I: z4 I2 ^4 zlibXm4-2.3.4-4.15.x86_64.rpm. o9 Z% m  x+ L5 f; f" g# I, q5 F
motif-devel-2.3.4-4.15.x86_64.rpm% @, u' Y* X5 n. m
elfutils-0.158-3.200.x86_64.rpm2 m1 V" J5 l# E( C' q" M9 [
libelf1-0.158-3.200.x86_64.rpm9 y4 T; o9 [" a7 M/ m
libelf-devel-0.158-3.200.x86_64.rpm# X  R4 e! _0 G9 `, k8 w
5 E: `( l$ _, R& {/ `. t
For NX 11 and RedHat 7 the following packages are required:2 a* R( R5 C; L( X2 K; G  {
----------------------------$ D  G2 w! c. s& ]
motif-2.3.4-7.el7.x86_64.rpm
- T+ K# P* d4 @, {motif-devel-2.3.4-7.el7.x86_64.rpm7 U) [, N/ H* _& j
elfutils-libelf-0.158-3.el7.x86_64.rpm; Z4 a2 E4 G) Y( x" a! e# J2 e4 ~! i- F
elfutils-libelf-devel-0.158-3.el7.x86_64.rpm
( o" c9 I7 x' s- |7 Welfutils-devel-0.158-3.el7.x86_64.rpm7 p* n- `$ }% P! ]5 {
elfutils-libelf-0.158-3.el7.x86_64.rpm7 q% g6 Y1 f# ]! I9 E" a
elfutils-libs-0.158-3.el7.x86_64.rpm
1 Z9 R) p' g* Z5 [2 l6 }5 c. D- Z9 Z7 B6 [1 m; S
For NX 10 on SUSE 11 SP1 the following packages are required:
( G( o8 _3 S% K  `% x  W----------------------------) @8 X0 e3 _9 y" P6 b" Z+ o: ^" v2 V
elfutils-0.137-8.22.58.x86_64.rpm
9 Z  k$ z; b6 a* x% flibelf0-0.8.12-1.1.52.x86_64.rpm
6 i- s8 `9 B; @- M' B) L, z; M, c% jlibelf-devel-0.137-8.22.58.x86_64.rpm$ u5 C" w9 f- W3 Y2 a
libelf1-0.137-8.22.58.x86_64.rpm# c0 ~- o/ [6 ], _
openmotif-libs-2.3.1-3.13.x86_64.rpm1 @4 |1 l: Y5 k9 L( r' U  \2 u
openmotif-devel-2.3.1-3.13.x86_64.rpm
4 R" h. v" h" K& C3 Z3 `4 s
( R) v' r) U* @" ~7 q; eFor NX 10 on Red Hat 6.0 the following packages are required:+ ^  m7 I! h( v8 J
----------------------------: c$ c: h& Y6 }7 l
elfutils-libelf-0.148-1.el6.x86_64.rpm
# v" Q/ U2 g) C1 N4 t4 L- nelfutils-devel-0.148-1.el6.x86_64.rpm
/ e' r( q) d- k9 z) Y! Z+ k) selfutils-libelf-devel-0.148-1.el6.x86_64.rpm
" T( G6 Z& x8 f$ Telfutils-0.148-1.el6.x86_64.rpm
1 V, \* t3 j7 U# _+ y( |elfutils-libs-0.148-1.el6.x86_64.rpm
7 i: c% B+ o& [. a( o# v9 A5 Hopenmotif22-2.2.3-19.el6.x86_64.rpm, y5 u" v+ M( Q8 K7 a) p$ t6 m
openmotif-2.3.3-1.el6.x86_64.rpm
6 q8 w3 A; E, m0 g" f9 ?
" s' X* o) w0 Q+ X9 Z3 aNotes: & M2 @( z- m: _3 P! m7 t# E+ V
----------------------------: Q+ n% S9 k  _% K; _" D2 K+ t
For SuSE, the "devel" packages are available from the optional SLE 11/12 SDK DVD/ISO! p* @, Q* B' p2 x; _
发表于 2016-12-9 10:13:37 | 显示全部楼层
老师辛苦了
