[VIP求助] 库缺少需要的入口点,功能名:ufusr
2017-2-14 11:29:07 6772 0
发表于 2017-2-14 11:29:07 | 显示全部楼层 |阅读模式
1 {9 ?' f0 ]- I! v0 v% }
! x7 b1 w& g& q& k: N4 w请问出现如下问题,是什么原因:库缺少需要的入口点,功能名:ufusr! l9 |7 R6 p$ t* I" T- D: p- t
代码如下:
, g$ Q7 s2 |/ `8 r- f#include "Shrinkage.hpp"5 t# ^; h  G3 d4 |/ L
using namespace NXOpen;
: m; X' G  T4 i; ausing namespace NXOpen::BlockStyler;
, k7 N( N  k! g6 X. \, W" v( L& s3 X+ D" J! n+ E. ?
Session *(Shrinkage::theSession) = NULL;/ E$ y& }# G0 L5 u
UI *(Shrinkage::theUI) = NULL;
/ [- L, Z3 F. I; s4 B" a3 J( Z
$ W- a, N# S. a% _7 a! c+ jShrinkage *theShrinkage;
  c' r3 K6 p8 Q3 C6 i+ T. J" e# j$ J" ?  Z4 i; k7 M2 Z
Shrinkage::Shrinkage()
  u0 v; U$ z7 ^' {9 S7 y' _; s{& V2 H4 w9 |; D& R: P- _1 k; V8 d) ]
    try
% T5 J. J1 K: ^+ ~- I( S9 ~3 j+ x    {% V( S+ ]' p' R$ e3 {1 R, `
        // Initialize the NX Open C++ API environment
* N2 y' K3 K9 t2 w; ]        Shrinkage::theSession = NXOpen::Session::GetSession();( c* Q% @9 F0 m8 c3 H' ]; \3 C
        Shrinkage::theUI = UI::GetUI();* T5 e) P+ ~. F! x5 e& p* U
        theDialogName = "Shrinkage.dlx";; P) }% h+ O, }; k# |
        theDialog = Shrinkage::theUI->CreateDialog(theDialogName.c_str());
7 g! G) [, V8 t" F6 W  ?; J        // Registration of callback functions
) Y2 ~" \  y% `8 |: J7 W! w+ q3 E        theDialog->AddApplyHandler(make_callback(this, &Shrinkage::apply_cb));
4 L: @& o( `! o' k2 @" P        theDialog->AddOkHandler(make_callback(this, &Shrinkage:k_cb));. T" v; z" y; }6 H5 _1 }4 Q
        theDialog->AddUpdateHandler(make_callback(this, &Shrinkage::update_cb));3 y( J- e% \6 U! F6 m
        theDialog->AddFilterHandler(make_callback(this, &Shrinkage::filter_cb));
% }* J) s4 W4 n& j        theDialog->AddInitializeHandler(make_callback(this, &Shrinkage::initialize_cb));
) T7 Q( }6 ]- a8 P8 A        theDialog->AddFocusNotifyHandler(make_callback(this, &Shrinkage::focusNotify_cb));, X% u+ x& q) E5 ?8 L0 s* f
        theDialog->AddKeyboardFocusNotifyHandler(make_callback(this, &Shrinkage::keyboardFocusNotify_cb));
$ K5 ^& k+ ~( C; c( P$ F( ~0 u        theDialog->AddDialogShownHandler(make_callback(this, &Shrinkage::dialogShown_cb));8 U1 R7 U) V# {* S8 p
& L/ b. D( _6 {1 C    caTCh(exception& ex)
! Q9 \* D7 s0 p/ J) M- R    {
' `8 a) k# o) z) ^3 I2 m
' J# [; s) T, n, `0 ~* F0 z/ C        throw;
9 L# v8 ~3 [/ `* R    }
& r4 r5 C, Y' j+ m7 C" D}
& ~. Q0 p! P" g0 n0 F8 H% R# t) w7 g9 ^; }9 @2 N( F$ Y
Shrinkage::~Shrinkage()5 Y! C2 E* l4 I* ?
{1 r6 t0 E! v% S& Q8 m, [
    if (theDialog != NULL)- \/ B/ f! R4 j: _8 b
    {6 `5 m0 _8 s2 S2 o
        delete theDialog;
$ J8 y0 o: ?& x6 m: l        theDialog = NULL;. C+ _! M4 |+ R9 t" r9 |/ @3 x
    }* \9 Z, T, |9 e5 k$ v
/ R3 d: @& m( b/ }) R* N4 U! s
8 ^" P" w2 [: W7 t. l. x' q2 ]#if USER_EXIT_OR_MENU' V- `/ E, e0 S1 Q
    extern "C" DllExport void  ufusr(char *param, int *retcod, int param_len)
* V/ \' W3 f6 S; i! E/ l  l1 T% j    {, U0 t1 j0 d. x1 n) I# x
        try8 o2 |& y+ j7 p$ B
6 E' I6 r5 N3 U4 M, g2 }2 E            theShrinkage = new Shrinkage();
6 A: B4 ^% j0 d. X# ?& K/ u            // The following method shows the dialog immediately
  \; y+ h. \/ ~  _            theShrinkage->Show();
! ]8 C0 t& l9 a/ }- i( d" B% r        }$ \0 K# v/ g, T. `
        catch(exception& ex)8 r! {& C9 W2 `& w) _2 `
4 S/ S) `% @" [            //---- Enter your exception handling code here ------ D8 I$ }) O7 {1 S
            Shrinkage::theUI->NXMessageBox()->Show("Block Styler", NXOpen::NXMessageBox:ialogTypeError, ex.what());
: b5 u  B# b# w, v* s8 c6 n8 L9 S( \* [        }5 E# f: @: `8 N* s1 E
        delete theShrinkage;
- E* ]5 W) X  A5 ~+ s    }
* x. i+ \2 o+ x#endif//USER_EXIT_OR_MENU2 ?& `, |7 q9 ?: K# {8 d' i. r
#if USER_EXIT
) a! b6 [0 U: y* |9 u; A; z
% h) v% R* B0 a, k6 f    //------------------------------------------------------------------------------- P; B: Y! b( _( b
6 A. {2 P+ _, M, M3 d3 D    // MUST NOT use this option since it will UNLOAD your NX Open application image  @) w' H% w$ k" w# x
    // from the menubar.5 w1 u' s8 K& x7 L3 c
7 J$ O" t+ T) a- r3 W( Z  w    extern "C" DllExport int ufusr_ask_unload()* S6 [) X% Y1 |- r* d/ a- S3 `
    {, k% W6 \* c9 M9 P& B# {, J
        //return (int)Session:ibraryUnloadOptionExplicitly;, \+ \1 G" D3 r% s2 @
        return (int)Session:ibraryUnloadOptionImmediately;9 C& a! K; D7 t( ^+ A# d# c
        //return (int)Session:ibraryUnloadOptionAtTermination;/ |( P! \, U& K4 x; `) [7 ~3 q
2 X8 t, W2 Q  |! U5 N$ Z+ W9 ]1 @
5 _9 N6 A3 a3 U$ A- v: y  g4 U    //------------------------------------------------------------------------------6 w1 m* ^; s1 p0 o3 `& E  f0 C
    // This method is automatically called by NX.( _6 l* Y) S3 ]; E2 Z: W. l
    //------------------------------------------------------------------------------% Y5 }3 q/ J3 M/ u: m  L1 I
    extern "C" DllExport void ufusr_cleanup(void)
. s% R0 k' i9 V8 G% z6 X$ K7 C; y    {
0 d- m1 ~7 l) [% r% a) t" f4 ^( X        try7 y; u2 G  J$ N/ j
        {2 `! P4 e' l7 {4 Z" b
            //---- Enter your callback code here -----+ @8 R* e* L7 V9 [. p& X
# i, A0 l6 z: `        catch(exception& ex)* r4 ?/ _8 S3 q0 {
        {# s% p. a+ a. o0 ^! e% W( s
            //---- Enter your exception handling code here -----5 _* m' ?( \1 q/ }5 C
            Shrinkage::theUI->NXMessageBox()->Show("Block Styler", NXOpen::NXMessageBox:ialogTypeError, ex.what());1 h" A1 e* U. \' w
        }  v. p( ]9 C+ B* P  S
$ O. l( T: }0 A#endif//USER_EXIT
9 G1 i' K- n2 R; d
5 T. H$ z7 S6 d# s2 G) d    int Shrinkage::Show()
$ I* Z  D8 H: R- ~    {9 S! w! ?. [3 C2 E0 ~0 A. a
        try0 O$ Y& C/ ?; b) u, y9 u/ W
3 e- d, z7 ?0 W8 j' d            theDialog->Show();& H0 F) Q) h$ l% q! V0 ^" w2 W
        }# x1 K  _6 u2 x/ h  U( V9 |7 o
        catch(exception& ex)) x$ P% d" z$ a4 t& |5 J5 N
, ?0 h! z  K0 s8 H            //---- Enter your exception handling code here -----
2 g/ ^- E0 J; d4 l2 E: }' V            Shrinkage::theUI->NXMessageBox()->Show("Block Styler", NXOpen::NXMessageBox:ialogTypeError, ex.what());! G3 D+ G1 N! K( v" j
" i! \; I% V7 Y' ~6 O9 ~        return 0;% [9 R. h' A. K6 C, U; J* D
% }0 \8 _: V0 C! Q) U    : p( W5 c6 g. W$ H- g
#if CALLBACK
! p( o0 z. ?/ N2 V* ^
- d: U  E2 A" ^& `- l    void Shrinkage::Show_Shrinkage()
# J4 ~# L3 D- H    {" Y; `& ^7 e: Y& O
        try, ^# G( d. F; v1 `( T+ v
        {! T+ V3 x! I3 |  o0 }9 ^
& n, ~( ~* X6 y3 x7 B1 R+ Z  i) H2 F9 G4 g  Z
1 F, g1 U+ R) [! s        }9 n" ]' e1 E' ?, b" o
$ v# u4 z3 H# Y        {
! d2 j: f9 S, d8 }% a) [. a5 r# U5 z3 i& Q& f2 ~
: x/ n( R! t7 {* ~2 N        }
% `1 f" z5 b+ c0 O" E0 i0 E4 Y        delete theShrinkage;
7 O  U" ]# y( l+ ?6 c    }5 I4 W% ?2 p* j$ T, b3 A- Q; W# k* |
#endif//CALLBACK
/ p$ _: K" Z0 i# f+ o+ a! j    ' i2 Q+ L" X+ D% o8 N9 g3 o8 }
    void Shrinkage::initialize_cb()
, S0 K# {+ h# w7 \  o" D0 V0 x- X    {
  @% \  y7 d+ E+ C! K% Z& x" x        try5 M8 S5 d/ W9 w' o$ p1 e
        {% T7 k3 s' _7 l+ _: G% |2 v
            group0 = dynamic_cast<NXOpen::BlockStyler::UIBlock* >(theDialog->TopBlock()->FindBlock("group0"));, F- c7 l; n* F0 ~  P3 E
            face_select0 = dynamic_cast<NXOpen::BlockStyler::UIBlock* >(theDialog->TopBlock()->FindBlock("face_select0"));( _) h0 X2 X8 _& T3 f8 X) b
            face_select01 = dynamic_cast<NXOpen::BlockStyler::UIBlock* >(theDialog->TopBlock()->FindBlock("face_select01"));
4 E7 f/ f9 v8 }0 W- J2 d3 a! b            group01 = dynamic_cast<NXOpen::BlockStyler::UIBlock* >(theDialog->TopBlock()->FindBlock("group01"));8 A& D. a: o1 d: |* {$ A* O
            bodySelect0 = dynamic_cast<NXOpen::BlockStyler::UIBlock* >(theDialog->TopBlock()->FindBlock("bodySelect0"));# E$ w6 ?9 V% g, c0 G8 \6 W! t
            bodySelect01 = dynamic_cast<NXOpen::BlockStyler::UIBlock* >(theDialog->TopBlock()->FindBlock("bodySelect01"));
* @* {) j1 J2 O' K2 }            group = dynamic_cast<NXOpen::BlockStyler::UIBlock* >(theDialog->TopBlock()->FindBlock("group"));& U+ x! \; M1 I- x/ i
            string0 = dynamic_cast<NXOpen::BlockStyler::UIBlock* >(theDialog->TopBlock()->FindBlock("string0"));
/ B' i- I9 q& B, w  L6 G. S            label0 = dynamic_cast<NXOpen::BlockStyler::UIBlock* >(theDialog->TopBlock()->FindBlock("label0"));
1 S8 \+ e5 t! B            string01 = dynamic_cast<NXOpen::BlockStyler::UIBlock* >(theDialog->TopBlock()->FindBlock("string01"));
7 g8 A  c( a: C# Z; y$ j            label01 = dynamic_cast<NXOpen::BlockStyler::UIBlock* >(theDialog->TopBlock()->FindBlock("label01"));
1 J( V. L; t1 ]. i: l3 {) _            label02 = dynamic_cast<NXOpen::BlockStyler::UIBlock* >(theDialog->TopBlock()->FindBlock("label02"));3 w! g# ]. H" \6 n
1 @! G1 L0 m: c1 p' k2 n        catch(exception& ex)
- P+ x8 S, X. h/ C: G$ ^. U) ]0 U        {, W1 {* B! [- T1 ]; H5 n2 c
           ( q' U& d) d& u9 @1 K
            Shrinkage::theUI->NXMessageBox()->Show("Block Styler", NXOpen::NXMessageBox:ialogTypeError, ex.what());1 V4 e1 [# Z+ z/ g
        }( _! k4 x! m6 p/ w- N
    }# G2 B& l* f& t+ P: ?
8 c5 B- C* S( z; r" w4 X, j    void Shrinkage::dialogShown_cb(): K' `1 K. W, C
0 ^/ |* a) e7 E5 g. W        try/ D1 l( E5 T6 j( }" H/ L
        {3 U# r; e. q) [' Y$ v7 a
, \5 t5 K* D4 j5 f) z5 |        }. z6 S: {  T- y( z0 W. v! ^% {
        catch(exception& ex)/ c  E* G4 @0 H  A  g6 [/ r
. h" @% U! B% T/ ]8 N
" {  M& }% h  ]/ ]0 s0 y            Shrinkage::theUI->NXMessageBox()->Show("Block Styler", NXOpen::NXMessageBox:ialogTypeError, ex.what());$ d4 F# G8 }! _% P/ E8 Z
        }& Z7 \6 ]' I3 X5 ^$ z
% ^/ u3 G# p; Y9 v* G- ^    2 m4 O  N6 ?9 d6 P1 m1 _
    int Shrinkage::apply_cb(), x7 G- D; q  T6 S/ b1 V# N4 p
1 ~, B3 E  P+ @% g  f. L, t        int errorCode = 0;
4 d5 A$ ?0 N0 k+ W! _        try" e( L0 S4 m5 V, ]
5 U# C2 p% P0 d7 A% @            //---- Enter your callback code here -----
3 c% I! F7 i! o) ]& k" h        }! K& W* a0 l1 v" W2 a. w' Z+ N
! ]9 K  z8 D+ d( J* x; U/ Z: t        {
8 ~3 ~/ R0 `/ n2 h' |            //---- Enter your exception handling code here -----
5 K, h9 y* C9 }6 P" i  p0 ^            errorCode = 1;
+ X! ?4 j9 U+ N            Shrinkage::theUI->NXMessageBox()->Show("Block Styler", NXOpen::NXMessageBox:ialogTypeError, ex.what());7 r6 K1 H: n4 r! k2 |7 A, F% ^
        }2 R' s! G3 r! P' p. o
        return errorCode;
# w# f5 v+ L% F) h    }- ~# G6 J8 P% Z7 E7 H. j
) [* S; M! y* _    int Shrinkage::update_cb(NXOpen::BlockStyler::UIBlock* block)0 M/ ?  k0 E0 q
1 H3 M  J8 K+ M        try
% ~0 `8 w  I" @% J0 d6 r* u: ?+ _, [        {
' n) A4 I! p$ o; K* o0 v( ^% I            if(block == face_select0)& u7 H8 c2 L1 x1 T' d1 M6 l5 H) |; q1 @" i
: _$ X- O7 [( W" t- F; ?            //---------Enter your code here-----------
  P3 H2 Z( B+ G            }
, Z/ L3 m3 B! _' z, l            else if(block == face_select01)
- L9 y) P2 a2 g  D  m( n            {
7 g7 R+ q2 T) x$ Q4 l            //---------Enter your code here-----------* V4 z2 ?, J- l
  {  B8 l- _( M% _# o. e            else if(block == bodySelect0)
6 |) T9 @; R$ W$ E1 `& q            {
- V5 c+ N! U8 T7 z            //---------Enter your code here-----------
4 `: f6 L4 G2 }. R  M4 w& K4 ]            }
+ \6 {6 o7 ~4 A! z" a" _$ R+ r7 s            else if(block == bodySelect01)
4 D8 \1 }9 e5 u! j            {5 Z& h5 l  d  u3 S3 ^" p
            //---------Enter your code here-----------) Y9 ?: f. _, P' i5 C. H$ y
$ B1 l1 E( }$ a. Z0 C* d            else if(block == string0)7 ^+ O  e# w/ T' _+ I9 m# t1 v
* H7 n' y0 n  J! d            //---------Enter your code here-----------
$ _6 u( d" x  E            }2 _4 {: l% {0 u. J. A9 t3 M! s4 x
            else if(block == label0)
7 Z4 u/ B' w2 m: w. R            {
6 T$ e7 l4 c8 W' q: |' ]            //---------Enter your code here-----------5 L7 |/ i1 F% h; e5 W) o8 h
" X8 j( W1 J8 r9 S. S            else if(block == string01)" X9 I/ T/ e( }& W! b
            {4 P7 R9 R$ M. T7 x' `
: k+ N' @, {2 V4 o, N; f$ V            }
4 c6 \/ ]3 }3 c, F            else if(block == label01)
& D1 [- t' C- z% N            {
0 g' p) H. Z7 b6 K% Y) u3 U9 f5 ?5 c8 P            //---------Enter your code here-----------
% K7 Q! Z" S5 d- B$ d( Z' W" G8 |, \            }
# E/ D# k0 k" r4 p            else if(block == label02)' Z' t& R/ `0 b* Z; s/ t
            {$ k4 f* g0 ]/ G' g
            //---------Enter your code here------------ H) G7 {# ^6 I3 s
            }) N* h2 H& h) G8 I5 w, T8 W; y+ t
3 c6 u, R9 a! U9 [9 ]0 z        catch(exception& ex)
; E- |( w4 z$ t3 l0 g2 r; z        {
" {' O) P* D3 @, b1 [            Shrinkage::theUI->NXMessageBox()->Show("Block Styler", NXOpen::NXMessageBox:ialogTypeError, ex.what());
4 [$ a% i% _% @, g% B9 t+ M        }' }5 m% r& J1 Y' a  J
        return 0;
- H, @: q" O  g. C3 ?* j    }
- ?2 R* o$ p$ S2 j! B% ?) Y    1 P) L2 U5 u, M9 g, P" Q' `$ e( {
    int Shrinkage:k_cb()
) n1 [2 W  H; E7 _, t+ b% ?$ w  M    {
+ K& q6 F! X9 e6 L0 T! j) Z) G6 c        int errorCode = 0;
; {$ J8 s- q4 I; d        try
6 @* ?& Q! H" W9 ?        {( z( s5 v1 u- K* ]  q0 \
            errorCode = apply_cb();' x/ K$ ~% {& q- J7 _
        }# {. i; C+ E9 g* u) E0 o
        catch(exception& ex); s1 g: |! z  n# P
, I, m" k9 v7 o$ q            //---- Enter your exception handling code here -----" K' O; L& q) q0 \) m2 @
            errorCode = 1;
( M$ e* x& d' {) c3 n            Shrinkage::theUI->NXMessageBox()->Show("Block Styler", NXOpen::NXMessageBox:ialogTypeError, ex.what());- I& Y! \4 p% F& z
9 }: i  p. o  W8 ?        return errorCode;8 |( n/ ^# _/ t: y; J0 ]
% e$ h7 {$ d7 J- j    ( W/ P+ s: u% k" w- v) K
    //------------------------------------------------------------------------------8 C6 J: [0 X1 U
    //Callback Name: filter_cb$ F: b8 W( v# j% b' \' E- I
    //------------------------------------------------------------------------------& R1 q; }6 {4 i( Y8 K
    int Shrinkage::filter_cb(NXOpen::BlockStyler::UIBlock*  block, NXOpen::TaggedObject* selectObject)( n" }- _5 H3 w" G+ k: z# W3 j4 g
    {9 ~% A5 `! I; \4 F9 Z& T" d  _
        return(UF_UI_SEL_ACCEPT);9 Y+ S/ o; ?6 \6 x$ O8 k$ n! N
    }' p; W$ U; q# [" X& E$ W5 p; K
9 A6 s" x/ E/ @0 K- @5 @, h    //------------------------------------------------------------------------------
  [5 [2 q% H/ E3 t; i    void Shrinkage::focusNotify_cb(NXOpen::BlockStyler::UIBlock* block, bool focus)  T+ }# ]9 J9 C) ]. B4 L
+ {) A. Y* N, J8 k$ @        try6 ~3 o4 u3 `' `1 V/ Y( {; F9 E
% g/ ^  N0 k) ^9 c$ Y: ^            //---- Enter your callback code here -----1 k; W9 S9 {* S8 I
        }* u1 n, W  p: j( ~" j
        catch(exception& ex)0 X8 X6 ^' }: K, R  [- N- c6 B% |
        {; }8 Z$ X; M  _) A
/ B2 N' i* d2 }% s$ Q  D; E) G* Z- o! R            Shrinkage::theUI->NXMessageBox()->Show("Block Styler", NXOpen::NXMessageBox:ialogTypeError, ex.what());+ s0 z' a6 |2 S/ E# S! O9 z
+ y6 \: ]6 C/ D" X) D( C; k    }" s: r$ c8 w) [: G* G) |
    8 O1 B1 r8 L5 q4 [
1 L! L4 V4 o. _7 R6 A    void Shrinkage::keyboardFocusNotify_cb(NXOpen::BlockStyler::UIBlock* block, bool focus)2 x7 j$ t. X4 W9 r
    {! {6 L. {1 d! `
        try0 E* G- k: f  d5 Z9 B; T$ M' f
        {' e7 D! |! j) j) V* d$ }% M: h
            //---- Enter your callback code here -----& G' I1 i: }! ?* a  \6 ]
        }8 y1 R* n; f; |
" q8 t3 _8 ~# L7 X+ {        {# ^1 f+ @- q/ N5 x  y
2 \; T. z" H' l. c0 ~2 `            Shrinkage::theUI->NXMessageBox()->Show("Block Styler", NXOpen::NXMessageBox::DialogTypeError, ex.what());
, B+ ]' t7 I& G8 Y% L/ r) h7 z9 M        }
/ u* n' m0 q# X* O4 k; U5 Z1 a    }3 E" k! A" H8 S; K0 p
* p4 [* B6 ?5 q
2 o/ @( Q9 ]$ j* L
application.rar
9.79 KB, 下载次数: 3
