NX二次开发源码:使用NX Open C++选取注释; d* a- w# o b$ ]. X
- #include <uf.h>
2 k6 Y2 y8 w C8 n0 {1 l - #include <uf_object_types.h>
: q, I: n. p( ~+ @! }: [8 [ - 3 N: T5 a! H% v1 g+ M' i& d7 o
- #include <NXOpen/Annotations.hxx>
( N" ~9 u% L' M. O - #include <NXOpen/Annotations_Note.hxx>
) _9 y1 N- e9 Y2 u1 W6 w - #include <NXOpen/NXException.hxx>, j9 Z' [( N l. ]7 n; Y
- #include <NXOpen/NXMessageBox.hxx> // as of NX5
) J5 @) @& T* {8 v' w - #include <NXOpen/NXObject.hxx>' A+ F; ?$ L1 }3 A& r! r h" _
- #include <NXOpen/Selection.hxx>8 R0 [- D/ R: Y! N
- #include <NXOpen/Session.hxx>
c1 {1 T* G% Y. n - #include <NXOpen/UI.hxx>) \) {& u% ]/ o- [/ t7 Y
- 3 y& q/ Y1 J' Y
- using namespace NXOpen;
- V: ]8 f) {0 ~ - using namespace std;" P& c- ?* n5 ~7 o- K* x
- ; P0 n6 w- E% r/ J8 Q S% {% \
- /*****************************************************************************. _0 V2 C% ^5 D. b- p& V
- ** Activation Methods8 C" L" y% q" F) O3 f3 Z* m
- *****************************************************************************// D3 U) B$ R( q2 O) e2 Y
- /* Explicit Activation
5 Z* L9 w' Y) G) H# `# o - ** This entry point is used to activate the application explicitly, as in. B8 q0 u7 G6 R5 ?% `2 h
- ** "File->Execute UG/Open->User Function..." */
8 s1 V# q" U: t* l - extern DllExport void ufusr( char *parm, int *returnCode, int rlen )
1 h& B3 H" ^1 f. n - {* d2 k+ W% e8 U- U0 @7 _3 m
- /* Initialize the API environment */
) N- S$ N2 i) Z/ ~+ y7 ^$ Y3 s O
3 ?3 M8 G# C+ V9 D* U! S- Session* theSession = NXOpen::Session::GetSession();2 b0 B& V( V3 J6 |+ b# P
- : H' |% {' _8 W8 B
- try
7 D3 L' U7 g e) m - {7 {0 Q n' G5 R1 g' {
- 6 e$ b% I. L" z% U% I; ]
- // ask user to select text) L$ p) g2 | y* d8 Q
- UI *ui = UI::GetUI();4 J% Q0 g+ e+ P. X
- Selection *sm = ui->SelectionManager();
: g5 P; U7 C' S- f' b( r - NXMessageBox *mb = ui->NXMessageBox(); // as of NX5
Y, [9 t3 |! W: q, i. v - 9 \8 w1 [" e9 T: L9 b3 _$ }7 L
- NXString message("Select Notes:");) @1 U$ l) d5 ]: m# h
- NXString title("Select Notes");" W' f$ X* ^" R: i4 z2 L- ?
- Selection::SelectionScope scope = Selection::SelectionScopeUseDefault;7 P3 W. r0 S1 d& O$ ^" t# |
- Selection::SelectionAction action = Selection::SelectionActionClearAndEnableSpecific;# r; x' | S% m/ [
- bool include_features = 0;
- g5 i0 x) Q: Q9 _2 z2 T - bool keep_highlighted = 0;. x0 R# o1 f- M
- * Z1 J5 v! P" K, D4 A7 [( K. d8 A
- // Define the mask triple(s)/ D4 ~# m U7 z3 J7 {
- std::vector<Selection::MaskTriple> mask(1);
& s3 D* r1 E# O5 T - mask[0] = Selection::MaskTriple( UF_drafting_entity_type, UF_draft_note_subtype, 0 );; a' |' a; ^% S# S- D8 i) _/ O# {
- 2 ]# T) @+ M c# O
- std::vector<NXObject *> objects;
. x0 _, K+ Z( M1 v3 U, B
, x. w* s; F6 y- // Select objects using filter defined by mask triples' y5 b8 o$ T! a+ o+ U4 v. ~
- Selection::Response res = sm->SelectObjects(
$ \* l, e) J- N+ w9 ~; t1 s$ R. s - message,
+ |1 i2 @) l% ?8 E# K9 P - title,
6 H1 [% @& S. B8 r9 L% n4 y. [/ M - scope,
% P4 Z b' c. i) P - action," g$ n1 d: Y. X& B, B! F( n$ C5 a5 C& S
- include_features,) A5 r5 z$ x- V$ @
- keep_highlighted,: h* \4 @' h" g' T2 ~
- mask,
- L' t8 t1 Z- f3 y, T) o0 T - objects& V0 b+ s7 g( B+ c0 Q/ `6 b
- );9 w/ s' S/ p! Z7 i z# ^$ S' r5 [3 j: U
- 4 a% e+ m8 ]$ \& u* E- p
- if (objects.size())
: n& ?' S! b1 g2 W) } - {8 } s+ k' u* j9 g
- Annotations::Note *note;# S$ u/ S. s/ I+ c" _
- std::vector<NXString> messages;2 ?) I+ _' G, A: z# E
- std::vector<NXString> texts;3 g! e* m# z9 d9 V' y" I& q$ i& G U
- for (unsigned int ii = 0; ii < objects.size(); ii++)" r2 M/ O% E0 O1 P
& ?, A! L& K. p - note = dynamic_cast<Annotations::Note *>(objects[ii]);
1 i ?0 b$ @& M$ q3 m( n - texts = note->GetText();; N4 J( Q$ e4 k
- for(unsigned int jj=0; jj<texts.size(); jj++)
# C0 C+ r/ H2 E& m# ?' v c - {0 ?/ R9 X2 M5 N3 O" I: o
- messages.push_back(texts[jj]);, I3 v8 A5 A5 r
- }" z3 d8 s; ~) G' G
- }! S4 {( ]1 f1 W9 D# o
- // NXMessageBox works as of NX5
3 N( C5 q: ?1 f8 `* U - mb->Show("Selected Notes", NXMessageBox::DialogTypeInformation, messages);& G! Y# B, O$ ^# Z# @+ F
- // otherwise simply write to the listing window8 A6 H, j# b0 y* e
- // ListingWindow *lw = theSession->GetListingWindow();
. n4 F0 d5 W# R5 Z2 X- Q - // lw->Open();
- F1 k" x# g+ t2 n" U/ T - // for (unsigned int kk = 0; kk < messages.size(); kk++)6 k, J0 R5 j5 z4 j1 i2 ]
+ `) b% l8 G, z9 M% D, z6 s - // lw->WriteLine(messages[kk].getText());+ X* S) b5 a/ F, o' I% P
9 a! O' Z; c+ \+ m& M7 ?& G* P0 e
2 G* G3 t7 U$ H3 L- }' V) H5 A |) A( v# F
; i; s: D; \1 K4 r \- s$ U
: @$ @" r, c% {. N+ b- /* Handle errors */- G$ ?: T: O3 D6 E. M
- caTCh ( const NXOpen::NXException& ex )
/ _7 _/ Y" ]" i- E9 g - {
5 i3 m& O: n f5 o `7 l' L! I- \ - // NXMessageBox works as of NX5
4 e# x. _ `/ ^/ P( z - UI::GetUI()->NXMessageBox()->Show("Error", NXMessageBox::DialogTypeInformation, ex.Message());0 p! V& n+ E/ h& X$ ^
- // Until NX4 simply write to the listing window
8 [0 i3 `" t1 e& ~; ` - // theSession->GetListingWindow()->WriteLine(ex.GetMessage());
& V* Z, v1 ^6 T5 D3 i1 h4 B5 S - }
* |" m) v1 ^; X3 \" N6 } - }
) X, q$ ~5 z2 I - . ]8 e# K- A" W# i) D7 [
/ ~* L. q8 `- W - ** Utilities
1 J: N. G- z1 \: X" ~) S - *****************************************************************************/
1 V: Z. j% ^, g' u, u d
6 E* _1 b! N' f5 i: x- /* Unload Handler* R* K9 G$ j3 @# m% c
- ** This function specifies when to unload your application from Unigraphics.; |4 T1 B. H2 G! f; k# |
- ** If your application registers a callback (from a MenuScript item or a9 |& E- X2 _3 r2 }( ?
- ** User Defined Object for example), this function MUST return4 M V- m4 b2 Y6 C4 e* {& L2 @$ a' Y$ d
- ** "UF_UNLOAD_UG_TERMINATE". */0 n# W9 c* s( v) Z# g# o; T
- extern "C" DllExport int ufusr_ask_unload()
" l' v$ y4 `$ V" R' X% D1 g# y - {, o4 `1 C# @* K3 @7 ^( z6 A4 k
- return (int)NXOpen::Session::LibraryUnloadOptionImmediately;# J+ w8 D; X& s* l" R5 j9 _
- }2 a! o: T8 P% {' }6 k3 q V
- ) D4 D- P8 q. u+ o
; \! `8 Y {' b4 K6 e$ Z! p' O* F; W
