; Q2 J9 |; W* F" g: BCatia二次开发源码分享: 获取装配所有组件列表& ?7 f; ?# p3 s2 e/ }
k& ` N" V" z# Q1 {2 ~, l
& g, n) z0 x2 ]" t4 C3 Z& q
[mw_shl_code=c,true]/* ----------------------------*/
5 ?6 l. Q$ W6 |) L0 T& k /* 2. Retrieves Root Product */& }/ l4 Q9 J/ k% [
/* ----------------------------*/+ R& c' o M# e: U" {0 \: B- R
; ~3 W4 V% b3 t0 H& l6 L // Begin navigation throUGh the document => start with the RootProduct.
" ^. q( x8 Q# ^% Y CATIDocRoots* piDocRootsOnDoc = NULL;! S" y1 j% Z# l+ |1 Z! @( x5 U
rc = pDoc->QueryInterface(IID_CATIDocRoots,
8 i `8 K) H5 L4 i (void**) &piDocRootsOnDoc);! k7 t5 S# D' t7 {, k1 R ]
if ( FAILED(rc) ) return 3;+ p% W9 ]' i: R0 q5 U5 Y
. T, A) V, {) v2 i // get the root product which is the first element of root elements% Z8 a. l7 i7 c7 {
CATListValCATBaseUnknown_var* pRootProducts =
7 u9 E" B4 i8 W1 | piDocRootsOnDoc->GiveDocRoots();
6 }; ?& z& I+ O _6 N) R( G) H' w CATIProduct_var spRootProduct = NULL_var;2 M# s# _6 K# c) F) k
7 ~, Z1 Q d8 W& Y) ~
if (pRootProducts && pRootProducts->Size())* B3 D3 b; v0 p" v8 T. J F
! [2 s* G# P- k spRootProduct = (*pRootProducts)[1];- j1 ^$ b y, o2 u. Y% J( A
delete pRootProducts;7 N) y9 D5 Z7 Q
pRootProducts = NULL;. V% j+ c: Z0 Y& g, K
}9 _2 F3 F( o1 ~
/** @anchor err_1 piDocRootsOnDoc not set to NULL after release */
! g! J8 s1 N" K! O# m, G piDocRootsOnDoc->Release();. Y0 D+ j g; A; K: ?4 ~9 B7 M
piDocRootsOnDoc = NULL;& b& [* ]% s: P: P
4 }2 r6 f& `: ~- ? m4 Z
// Get CATIProduct handle on the root product.
2 ?9 b$ B$ w9 ?8 I" t CATIProduct *piProductOnRoot = NULL;
5 b& K2 I! q: a i& Q rc = spRootProduct->QueryInterface(IID_CATIProduct,5 i8 `0 x* |8 P- }1 W
(void**) &piProductOnRoot);
J9 ~5 r* D* C. t% r7 t if ( FAILED(rc) ) return 3;
" {/ a- y1 P) |$ y8 r$ |" h5 |9 P6 }; ]
/* ---------------------------------------*/1 n7 r% z8 V9 X
/* 3. Retrieves children under the root */
6 Q+ r3 ^" z- P s% @ /* ---------------------------------------*/ t# W( Z- g$ C% R6 N
% W, F+ c" B( r9 _
int nbOfDirecTChidren = piProductOnRoot -> GetChildrenCount() ;. R& @' [ F: E& Y5 f/ @
cout << " Number of direct children under the root = " << nbOfDirectChidren << endl << flush;
7 [# W* R) V# \" F/ @$ M! s / t0 }1 d. k3 S# X2 Y! d4 \5 g# J
// then on a root product, get all the children agregated to it.0 t7 m% k- J# i/ J" T5 Y
CATListValCATBaseUnknown_var* ListChildren =( ?5 ^: e) F% p. n3 V& J
piProductOnRoot->GetAllChildren();
/ w) v, ]3 M+ ?7 J: ~/** @anchor err_2 piProductOnRoot not set to NULL after release */ " h% X/ ]6 C2 J5 D- [) }2 G% S
piProductOnRoot -> Release();: L- e6 g8 Z- ?! Z) E
piProductOnRoot = NULL; {; d& o/ v6 }8 O M; y
if(NULL != ListChildren)
4 a0 [$ i+ d" o7 u s; t4 d. v {! q& \7 o4 L; t @: G. A6 F- F
$ |5 R- F4 d3 M/ k int numberOfChildren = ListChildren->Size();1 ]# @+ \ K. g! n7 q
cout << " Number of all children under the root = " << numberOfChildren << endl << flush;- O, R9 F5 U& V3 E% {% ^- m
j- G4 F' W$ ^( T: D2 F- j: ~
/* -----------------------------------------------------------*/: ]8 L2 |' M6 k4 `9 P. F* a
/* 4. For each child, get its partNumber, and InstanceName */
: J( E+ ^& P* M3 l! M7 i2 h. E /* -----------------------------------------------------------*/1 K4 {( u" ^. Z* l; w4 E$ M" h$ X9 @
CATIProduct_var spChild = NULL_var;/ ^9 {& C8 p, h( w: R i# d
for (int i=1;i<=numberOfChildren;i++)
7 O; S3 ?6 K. v: K- R+ h. o {- W5 I1 l6 [. z U4 ?2 d1 r' x5 N' @
spChild = (*ListChildren);% I Z( C% X+ z
/** @anchor err_3 spChild not tested before use ( if !! ) */ ; |/ M8 k% J$ b! S* Z% x4 `
if ( NULL_var == spChild ) return 4;
$ i* _6 o/ y' t& V CATUnicodeString partNumber = spChild -> GetPartNumber();
|( [- v8 F! r/ |. D+ V CATUnicodeString instanceName (" ");
# @* p2 ?9 W8 q2 `0 k: ?' K rc = spChild -> GetPrdInstanceName ( instanceName ) ;6 _6 G4 N/ B' j: v
if ( FAILED(rc) ) return 4;8 O) S9 p9 l6 Z- s- k( B0 _
" t" x: ^& @/ C* H0 r# g cout << " child number : " << i << endl << flush;
: f4 N( v! q2 V4 I& r- ]0 \" H! |+ Q cout << " has as part number : " << partNumber.CastToCharPtr() << endl << flush;" a3 u" c7 n% `# Y
cout << " and as instanceName : " << instanceName.CastToCharPtr() << endl << endl << flush;
1 w& Y8 o0 X5 f% g% r; W7 s }
" o, I {) p$ M% f1 f& N1 F, d delete ListChildren;
2 p: Y* v( e, t2 U% \. I ListChildren=NULL;
$ v" ^$ j! s r$ ]- G/ _ } + u! E" w9 Q% S5 d4 ~& p: \
& D3 `% @: B# u3 n5 a1 u9 T /* Ends the session */
6 t5 q. x) B' U1 o /* -------------------------------------------- */[/mw_shl_code]
( m3 U# L% x# i6 t( b& J" F. |5 g |
