Catia二次开发源码分享: 对面进行颜色修改和添加属性
2018-1-10 16:50:30 3719 1
发表于 2018-1-10 16:48:55 | 显示全部楼层 |阅读模式
; A6 \/ @: A$ n' G$ x 4 S3 t+ a5 R7 G" h; u" C7 B% p: ^ C3 p w& y / z$ S" n _ f3 y9 J x( I + J! d) f; Y9 i$ ?2 z/ \: Z[mw_shl_code=c,true]// 3 X9 @( i7 ?. {; P f! i% L // 3- Loads the input document ! W( l2 l# m& I* _5 ?/ e- L // 7 @9 p2 ]' G) L* l- p( @# V CATDocument *pDoc = NULL; ; R+ g/ l g+ U& j2 {6 W8 Y rc= CATDocumentServices::OpenDocument(iArgv[1], pDoc) ;* T" r2 F/ h9 }' B. _ ) G% o& x6 e$ s7 ? if( FAILED(rc) ) 0 y6 B0 B9 L; E% f# D {+ o+ e+ r" U! D7 `# O; ^ cout <<"Error in opening the document: " << iArgv[1] << endl ; ! |( N9 Q r8 s0 L5 h return 1; % E; }& `6 u: I6 P! L: y# _ }* s- v* s1 _) ]& [( ~$ m cout <<" " << iArgv[1] << " is opened" << endl;; V) u z/ Y% R6 l$ { - R" R" w I$ [% d3 G CATInit *pDocAsInit = NULL; 2 ?% ]8 i$ y9 E* z rc= pDoc->QueryInterface(IID_CATInit, (void**)&pDocAsInit) ;3 T' k: E& u8 X7 Y' @ if( FAILED(rc) ) & z: [9 A" E# l# K# c4 ? { 0 }5 h; ]' \# D0 V& R2 d cout << "Error, the document does not implement CATInit"<< endl;+ Z2 o' |# ?3 A return 1;, a" N/ k" V! p0 i. `8 n/ Z8 t } 0 y o1 ]6 C$ S1 D0 [# }! c h) a! j0 U$ f2 d* G //1 L5 }0 I% U2 m: X // 4- Gets root container of the document ! |2 R# K' h/ J0 P( q( D // 2 j" R9 N- C2 l CATIPrTContainer *pSpecContainer = NULL ;# {% }& l) H' o) h4 E1 J; ]% c% z6 b pSpecContainer = (CATIPrtContainer*)pDocAsInit->GetRootContainer("CATIPrtContainer");; A5 G# \& u4 o8 g/ u3 r ; L% _+ q+ X. }: A0 e pDocAsInit->Release();: B! a4 L$ `6 n& `6 \& u pDocAsInit = NULL ; " C% e/ O# K4 L$ r' n3 D- Q) Y' G& ^$ I, D4 s if( NULL == pSpecContainer )0 T: o" A" g8 k4 _8 y {1 A! s q1 k" k) Y4 n0 w cout <<"Error, the root container is NULL" << endl;7 C8 h: a& _1 M- w* u return 1;# X) B1 S8 _6 @2 s) y! ^9 l7 H }/ v# M8 R* \$ s' g0 r# C 1 N+ t5 \4 A" f* X //* y" p& b; y O% m1 F7 S // 5- Retrieves the MechanicalPart of the document7 a6 Y% M4 `6 h5 L6 h8 X0 j5 K //: g% |) f( q' A- D+ {3 z) z0 Z' X CATIPrtPart_var spPart ( pSpecContainer->GetPart() );" B4 g3 Z0 j% Z s9 E3 [ if ( NULL_var == spPart )5 v0 m" f: Z" w' W% c {1 G% M) I# w7 \4 l5 D* Y cout <<"Error, the MechanicalPart is NULL" << endl; % S) z( N9 G* B5 u! { return 1;: G% E" i: s, ]9 ^2 P3 m; @ } 3 o; R, a# ^9 T+ s 5 U- ?# r7 n4 H* l' e7 L pSpecContainer->Release();- u2 x) U- R x( V: E pSpecContainer = NULL ;& O6 Q$ \& j7 t1 k0 x ; V7 h3 r5 f7 Q# }/ q2 F% ]4 ] //, s6 i7 k2 d$ C8 r //6 - Retrieves BRepAccess of all faces& w/ T; M1 C& ^% q7 l) u( z# b! D /// m' N8 v. O- f" ^5 ? ! C& @. S" t3 B: m W //6 - 1 Retrieving the feature holding the result of the main body % F3 [6 Q" L( e7 C3 `- O //+ g- R7 Z+ Z" o( K, a2 M' _( ^4 d) j //get the part) N( f. g" f9 M m8 l CATBaseUnknown_var spMainPartBody ;% Y4 {, f c6 ]7 u% {& f+ i; }; b8 ? CATLISTV(CATBaseUnknown_var) ListResult ; 9 n( H$ h/ s6 G$ j 9 ?6 y# u, W5 k; y4 K CATIPartRequest_var spPartRequest = spPart ;. V' _; ]1 S; ]+ C' @ if ( NULL_var == spPartRequest ) 2 m8 b) O8 @+ X; ` J {2 `5 p) n* o8 A, x# \ cout <<"Error on CATIPartRequest" << endl; 1 U2 v8 p, }4 x' y, K8 I# f9 a m return 1;; S! Q5 ^+ z' j+ x5 b5 N } 6 o( Q2 z" C: X, k7 G7 N / z( m# _0 {9 y' {, D5 J //get the main tool 4 h' n1 ?% @* X: I$ x rc = spPartRequest->GetMainBody("",spMainPartBody);! U8 I: l _+ y/ i: b5 j) q6 K3 n if ( FAILED(rc) || ( NULL_var == spMainPartBody) ) ) Z( f U8 l5 P8 B {% A% j& I7 {8 F- u# D7 M cout <<"Error with GetMainBody" << endl; 3 Y+ y" X/ [+ r* {: S, K+ [ return 1; , f$ n; X$ B3 j4 h9 A0 M0 D9 G }7 _ Z# T+ B. a0 }" W $ z9 V6 A; M q' B$ k* J //get its associated body) f/ d2 ], F( I; s* j CATIBodyRequest_var spMainPartBodyRequest = spMainPartBody; % Z: ?! S7 p4 t( ^ if ( NULL_var == spMainPartBodyRequest )' E/ a% w' W0 a& P. u( j7 P& n {8 ]- a, `. z- h cout <<"Error, spMainPartBodyRequest is NULL" << endl; 7 ]6 t; l7 i& A return 1; 9 F w& Z3 V5 k } " c! z" V, W' K z% x5 ~& R9 H* G2 n1 i& y- C j" M y //Retrieves the feature holding the result of the main body ) a+ w2 \* {8 p( x //It's the first element of the list returned by GetResults (CAA documentation) ' i. b7 d& P5 l7 ~ rc = spMainPartBodyRequest->GetResults( "", ListResult) ; : D, L/ s- ?- m) e if (!SUCCEEDED(rc) || 0>= ListResult.Size())9 J* X, _) y. m6 _6 S% z { L8 z3 C' t5 n: B cout <<"Error with GetResults" << endl;9 h8 j! j% A* v3 f( i return 1; " B/ V2 {8 N: i( e3 @9 @ } + N Q/ [! }- V5 f% D 7 s: }" c; L: H8 a1 _ CATIGeometricalElement_var spFeatureResultGeomElem = ListResult[1];, f0 [. i# K: @, q" m if ( NULL_var == spFeatureResultGeomElem ) % @7 @& S' w8 t% P% u { 2 B# x6 g9 {& z: i1 y) c- C5 E, ~ cout <<"Error, spFeatureResultGeomElem is NULL" << endl; C! B4 I5 {1 @* q& T0 ] return 1; 7 V8 X4 g- J/ B2 ` } : @5 ?$ v [5 J* L0 _7 y- m9 _5 g( i- U! h //retrieves its shape2 L+ H/ E% a5 i P CATIShapeFeatureBody_var shapefeat = spFeatureResultGeomElem; $ l! J) s; D; Z- i$ G. e, E8 r- D* f if ( NULL_var == shapefeat )# E8 x _1 g' k$ p% ] {) E+ X9 B* v' e) Q* \ cout <<"Error, the Shape Feature is NULL" << endl; 5 r4 p+ v4 q6 u ~ return 1;5 o* y( Y% e& i' j/ z% O# ?( \ }; ]8 m# O5 v5 z( K ( L) V6 X6 V' W4 R: Y& a //retrieves the feature associated to the BodyOUT 9 h( H& e; e' y6 m CATISpecObject_var FeatureSolid = shapefeat->GetResultOUT(); # l" A8 x8 n4 W2 W+ Q if ( NULL_var == FeatureSolid ) 8 Q# [) ?( R a) l' q0 _ {0 Q. x- A8 W9 i" V9 l% T* o cout <<"Error, the Feature Solid is NULL" << endl; 2 {, v, h6 ~( t+ p return 1;' y8 O5 K& P7 ] }4 J) C- N+ Z8 k* }- B- G3 \4 k 9 x1 ^& T' W/ J# [! v; S+ P ( U: X K, q9 S5 ~+ ~2 Y6 Z //6 - 2 retrieving its associated geometry ( R5 W) |; K3 k* M2 r$ E' O // * C, q! ]3 n" D2 Y; U d% S2 i/ r' }1 B# m0 U CATIMfGeometryAccess_var geoAccess = FeatureSolid;" l. A* r* t( b x. f+ c if (NULL_var == geoAccess) 8 I: z- {4 N9 I6 ^0 L/ }; y$ @ { 0 E7 A5 Z1 c7 O cout <<"Error, the geometry access is NULL" << endl; 8 S8 Z( _4 `4 M, } return 1; # J" ^9 r6 F% e! z }+ {" x4 D `) m- i5 N 0 L5 A" m( W- N* v3 d- v- C" y/ e //6 - 3 retrieving BRepAccess from geometry ' p1 L7 J, D; D // - ^: M' }+ `% I( U6 ~ CATLISTV(CATBaseUnknown_var) breps;4 t6 O3 i- [4 B* J6 I; g Z int nbfaces = geoAccess -> GetBReps(breps);$ S9 B2 Q, d h+ ? if (0 == nbfaces) / C' P6 q4 G- h- J% t" y { 0 [1 B5 H* K" H" S- [" \" ]2 Q cout<<"Error, there is no face associated to the geometry"<9 K$ ^! C& s& }8 v( r$ T' T x" a return 1;1 l8 T+ \0 Y* V }* n4 m5 o- G( O4 ?( N( C$ X * f( V9 J5 z. e) I; S; N$ d' t H. f CATLISTP(CATIBRepAccess) ListBreps;1 P* n( S: o" d! u1 l% w E3 @ CATIBRepAccess * Brep = NULL; * e" a7 O j& t CATBaseUnknown * Unk = NULL; & f' f1 p9 i* w, ]: I/ J: S 4 Q0 L! G' m" m# ] int compt = 1; 7 w$ }( B- t1 k4 e! t/ |for(; compt <= nbfaces; compt++) ( H2 @% @2 w, Q: `9 y ] {: J/ G$ a. |. \! ?& ~( q Unk = breps[compt]; 2 k; i3 H: p+ n) p# l. {9 \ Brep = (CATIBRepAccess * )Unk; 1 n7 L" S+ ?" \, _, w/ { if (NULL != Brep)! G5 ^. A0 G, l w x5 H {- N2 O6 ?$ W/ h1 j4 Y& o. Q Brep->AddRef(); g* C7 u9 A5 e" j y) _: d ListBreps.Append(Brep);* |: {0 d0 ^9 E/ P1 X, g }+ I: {# F1 z T$ `' y } [& K* o$ `& u: J0 c/ S breps.RemoveAll(); + g) m) Z; e1 ?, R nbfaces = ListBreps.Size(); " S: H; }: b: w G7 b: h if (0 == nbfaces)) c5 X7 N2 ^9 U) q( k {1 g! U& p+ r6 m6 Y; i cout<<"Error, there is no face in the BRepAccess List"<8 }7 @* \8 Z/ s; r% V return 1;1 N ^& f7 ? | } E6 n. z/ X( h# g else" f% u/ r+ }. d/ H$ m- Q, b9 F. W { 2 N! i9 n: ^- ~ cout<<"There is(are) "<+ o" _% F9 L( [! F; C" m# z } 2 z6 ^! E5 H; q# @7 p[/mw_shl_code]
 楼主| 发表于 2018-1-10 16:50:30 | 显示全部楼层
[mw_shl_code=c,true]4 \* Q% r5 M8 C! j. Z' ~0 X4 _
+ p2 O% b% V! {! H8 E$ q7 {! x  //7 - retrieving and displaying current faces colors
' X+ j) G. r. F: A- u  //
% q& H# v4 M7 C+ M- T0 h3 {  cout<<"--------------------------"<<endl;  I. q9 B, m- S& Q" i
  cout<<"Retrieving current colors"<<endl;4 K8 L) x1 ^1 M2 \7 o8 J0 Z6 f" P
  CATListOfInt retrieveRed,retrieveGreen,retrieveBlue;- ~! R- y; t4 [! ?, `
4 R  k. Y% z/ p4 L5 }( c  rc = CATMmrApplicativeAttributes::GetColorsOnFaces( ListBreps, retrieveRed,retrieveGreen,retrieveBlue);# l2 z5 H6 x/ n. ]$ T/ P
  if (E_FAIL == rc )) h) ]/ N& \5 }5 m- Z5 ^
# v* K# |7 T8 `4 v# U    cout<<"Error, an error occured while retrieving current part colors"<<endl;
* T7 y& o1 a7 y' |* H0 U! n+ E7 Q& @    return 1;
2 s+ M4 R  X1 ]' h8 g  }; L; Z8 b5 ^- [( Y
% i. W6 M- D0 I+ @
  for (compt =1;compt<=nbfaces;compt++)
& o" z: {. m6 N. @. \  {! o5 _9 v1 _- Y/ Z3 s7 L9 s$ X- X0 l
    cout<<"for the "<<compt<<" face, associated color components are : R "<<retrieveRed[compt]<<" G "<<retrieveGreen[compt]<<" B "<<retrieveBlue[compt]<<endl;9 Y$ ^6 d5 A. R4 y
  }! Y8 G' ^" L/ W
$ d$ {2 c4 W( L# o6 C6 R7 b
  //0 `4 X  K0 g5 H/ p9 H6 L1 k
  //8 - Setting a new Color on all faces
' J( ~2 M# U- q+ I% ?  //; h+ Q- ?- w! c) l0 [
4 x9 D" E/ a; S( d3 h% n7 n8 X2 T
  //we are to color the faces with different color according their position : three by three will have the same color6 u8 J, `/ J0 c! Y& v
  cout<<"--------------------------"<<endl;& S5 }) f6 H- z7 s
  cout<<"Setting new colors"<<endl;
7 G, R! d! G2 G; S1 b& ^+ d, _
/ n7 U! u+ v& Q9 K  CATListOfInt newRed,newGreen,newBlue,FailedIndex;- J% e! N+ @  i* _. R
  int x=0;
1 z3 O$ z% p1 y  for (compt = 1;compt<= nbfaces;compt++)
  p  L( W% w) v* a7 `0 R  {: m4 d* P! j- J0 g0 S
    x = compt%3;
# \" K4 s3 e+ K  ]* N+ E: i  h5 n    int red(0),green(0),blue(0);
. {6 j, k3 u2 @+ a! k    if (1 == x)( f7 `3 ^3 L9 G& s1 D7 b/ ?; g
      red = 255;
8 U. B6 b/ v' V; h9 c5 p, s    if (2 == x)
) R) c% Q. F' H% v' D2 c      green = 255;
5 x2 ~* Y6 M2 U. `1 t. W    if (0 == x)' R8 m# y- {3 v0 Z  p+ Q# l
      blue = 255;8 p# J5 G6 c5 q3 K6 ^( N
    newRed.Append(red);
# f. |- V: w6 T    newGreen.Append(green);
( e7 k9 _% F. z9 k    newBlue.Append (blue);1 X$ q5 L( N0 k% t" s& ~# e
    cout<<"Setting R "<<red<<" G "<<green<<" B "<<blue<<" on the "<<compt<<" face"<<endl;
! j2 ~; o, q2 P5 C9 H) x6 ^, w  }2 e. Z3 v: Z; `, A. t6 ^1 h
( y6 E. Z$ f- o; M8 M! B  rc = CATMmrApplicativeAttributes::SetColorsOnFaces(ListBreps,newRed,newGreen,newBlue,FailedIndex);" [/ d0 y( b% r- z( {8 n
  if (E_FAIL == rc)9 ~( W* b/ m/ q3 l7 Z! G& H; \1 Q3 Y
  {# Q3 X. B: k  w6 ]  c: F
    cout<<"Error, setting new color on faces failed for all faces"<<endl;" s6 e$ w8 o' O% ^
    return 1;( c% ]. x4 B$ |0 ^- M( o
  }* c. e/ S2 o- ?0 M5 g
  else if (S_FALSE == rc )
  v, b( s; i5 p! y  {4 U! c" \3 Y5 C$ p
    int nberrors = FailedIndex.Size();
6 L) G) Q3 I4 x: q# a    cout<<"Error, setting new color on faces fails for faces :";
' U9 N# }1 x! J! V1 A1 X) L! e% S8 ^5 B    for (compt = 1;compt<= FailedIndex.Size(); compt++)6 V& N% ]" X& U! d( z
( z7 [# w" q% z( _& N2 ^      cout<<" "<<FailedIndex[compt];3 Y& `0 g5 z/ e3 d
2 b9 @9 i( _2 b: E4 ?5 ?    cout<<endl;3 m% @8 c/ N; Z
  }) s8 h$ U7 _! W8 z( X# S
  else
+ y" f( L! P% f6 q( ~    cout<<"Colors successfully set on every faces"<<endl;% r; ^% p  |* @' v0 ~9 I9 v
  //" Q. r. o3 E, |
  //9 - retrieving colors we have just set2 b( p: P. L& ]$ `& w7 y
: n$ c) `8 G3 o1 O' d7 V  cout<<"--------------------------"<<endl;, ~$ N5 K# l4 P/ g7 f5 `- U
  cout<<"Retrieving new colors"<<endl;3 n6 b6 H; M) h5 i% K
+ u( ^; ~( D0 R: H2 t1 l  if (E_FAIL == rc )
  q7 x( E1 Z8 C. T" ]  {
$ P2 R( n( ~1 ^/ T; @% b- C    cout<<"Error, an error occured while retrieving current part colors"<<endl;% w0 V5 o4 T$ W/ d
    return 1;
* N& A: Y1 V+ h  }
* L% g0 \* K6 o- ]' ?
/ w' e1 ^+ V  K# ^  for (compt =1;compt<=nbfaces;compt++): d9 X4 g% t- w+ O7 M
6 C  F. z6 G5 Q& L) W    cout<<"for the "<<compt<<" face, associated color components are : R "<<retrieveRed[compt]<<" G "<<retrieveGreen[compt]<<" B "<<retrieveBlue[compt]<<endl;) K! q4 ~' h" n/ ^
% b' v# J$ t4 q" s- I
5 M+ L; d7 v8 D5 h  //2 f$ q) d: M' p$ R
  //10 - Setting Applicative Attributes
; }: f+ K8 v+ b9 R5 S  //
3 S, o  [  K/ p
, G( Y+ a  \- U, q2 Y& x: o  //. B' j0 V/ V1 s+ t
  //10 - 1 creating new attributes
) B( \4 r5 G+ h$ b  a  cout<<"--------------------------"<<endl;
3 s8 a. K2 j" g2 v0 S  cout<<"Creating applicative attributes for different faces"<<endl;) C1 \5 X2 K" K" X& L1 c$ \! P2 m1 ?
  CATListOfCATUnicodeString **AttrNameListToSet = new CATListOfCATUnicodeString*[nbfaces];% e/ B1 B  Q$ k* @% O
        CATCkeListOfParm *AttrValueListToSet = new CATCkeListOfParm[nbfaces];
' M! b% r$ \; ]9 ?% D  CATICkeParmFactory_var factory = CATCkeGlobalFunctions::GetVolatileFactory();
* v4 v  Z1 T% O0 b2 n, h  for (compt = 1;compt<= nbfaces;compt++)
4 @6 W$ r4 L9 A9 I  F  {8 I$ n! `2 U% }1 [2 H/ T$ |$ W% ]
    cout<<"Creating ";3 ~" B: ?- o  L( j  G+ I
    x = compt%3;
6 a- {' L9 N2 ~, ^; q, ?3 l+ U    //for each face we create a new list of apllicative attributes
  I! P0 i- V/ B* r' F4 I    //an applicative attribute is made of a Name and a value
1 ?4 w  x+ T# y# u* v6 A* S    if (1 == x)/ n) G' e8 L, s3 f
    {4 d. f. i% S/ ?, p4 C. s& s$ R
      AttrNameListToSet [compt-1] = new CATListOfCATUnicodeString (3);6 q8 B8 ^2 v  ~1 U( U' `9 m
      AttrValueListToSet[compt-1]   = new CATLISTV(CATBaseUnknown_var)(3);7 g& G4 _+ c0 Z6 T( e, m. W
) Q: }( K; Y% x: R      //The first attribute will be the number of the face
4 J7 B2 q& O3 }5 X9 Q: a      AttrNameListToSet [compt-1]->Append("FACE_NUMBER");# n3 l7 o/ I% T8 z) J
      CATICkeParm_var tempcke1 = factory -> CreateInteger ("FACE_NUMBER",compt);, s& E! v9 E4 z6 T7 J
      AttrValueListToSet[compt-1]->Append(tempcke1);
% T% A8 m. i5 ~      " v3 B6 j2 F0 z) l" u
      cout<<" FACE_NUMBER with value "<<compt; 7 J5 \8 M2 Q* S5 t. |; J7 H" n
% |; ~" T9 e3 H; r9 I$ I; i5 d      //the second will be the color, s; C3 _. a0 A) F; q7 f3 D
      AttrNameListToSet [compt-1]->Append("COLOR");+ E9 |. u( U0 l
      CATICkeParm_var tempcke2 = factory -> CreateString ("COLOR","Red");; V* i+ ^1 l% K  B
      AttrValueListToSet[compt-1]->Append(tempcke2);
* e0 x+ h. @- b( v5 W3 f
% g: u. A  T1 S* \      cout<<" COLOR with value Red";3 M; @. |% Y8 @) }$ |8 m$ f
      ; |; Z+ ?" Z5 G) t
      //the third is x
' f6 H- Z! }6 u$ i% }: I      AttrNameListToSet [compt-1]->Append("X");
& P2 h( P+ o! C# j7 o# I  L0 D      CATICkeParm_var tempcke3 = factory -> CreateReal ("X",x);
7 U( `1 a/ b; @% ?7 c- f' D) I' V      AttrValueListToSet[compt-1]->Append(tempcke3);7 E- z6 B+ d! v# b
5 y6 n+ H7 q& T6 c      cout<<" X with value "<<x;# d' _( K( h4 {1 U' B& R+ E
      cout<<" for face nb "<<compt<<endl;
* G& G3 V! o9 m6 T% q4 D. G    }
. l5 q. d* s3 X5 D# }    else
( h+ h! ^8 n# P- ~2 H    //just to show you you can have different size of list
0 R9 B7 Y. g+ ~* U* f7 j* B    {+ P# O; B: r5 Y. U2 u% ?' c
      AttrNameListToSet [compt-1] = new CATListOfCATUnicodeString (2);
) H& P* O) D# W$ s      AttrValueListToSet[compt-1]   = new CATLISTV(CATBaseUnknown_var)(2);/ x# h! D0 ^  K- i
2 r7 t. \) n4 H/ I6 Z- I  C+ F$ d
      //The first attribute will be the number of the face! _3 ?6 j7 W# M1 C% X
      AttrNameListToSet [compt-1]->Append("FACE_NUMBER");4 V9 D% }0 j1 K! Q. Y
      CATICkeParm_var tempcke1 = factory -> CreateInteger ("FACE_NUMBER",compt);3 B) M& i! j' V$ n/ L+ {8 x
      AttrValueListToSet[compt-1]->Append(tempcke1);) a( Z; K: }! U0 H4 a5 X' Q0 ]
* c3 @/ y6 A$ I- r      cout<<" FACE_NUMBER with value "<<compt; ; |. R$ a2 X% V# j% \0 [
  S* I* n: o& u7 r$ N7 e" N) }0 o
      //the second will be the color# w5 K9 ]$ h) V- i, G
      AttrNameListToSet [compt-1]->Append("COLOR");1 m4 ^- Z$ t" c; u1 e
      if (2 == x)
7 @8 Z4 \) |0 O% O8 o      {( D8 Y/ |+ Y) m; l3 G: \
        CATICkeParm_var tempcke2 = factory -> CreateString ("COLOR","Green");
8 b( _; p. P2 ^3 s1 \: q        AttrValueListToSet[compt-1]->Append(tempcke2);- o+ h1 ~9 ^5 |' K' {
# @( b1 U2 T8 A, E' W7 T        cout<<" COLOR with value Green";0 a. I' i0 h3 Y# r
      }. \2 E2 l! {" l& g# P
      if (0 == x)8 W0 H7 Q# U; U/ s( C6 w- U" V
( s4 `5 v4 K) {2 i' z        CATICkeParm_var tempcke2 = factory -> CreateString ("COLOR","Blue");
( F( Y7 {0 ^8 i8 H/ e% a8 v        AttrValueListToSet[compt-1]->Append(tempcke2);
5 U0 t( K  g( T- i  Z
% E8 A; d# d1 l+ h        cout<<" COLOR with value Blue";
* q( {% e( _1 |2 m6 ~; _( x      }
5 K% i3 W/ {, v5 V  u: j  l  h- f1 b( T4 @$ b: ]
      cout<<" on face nb "<<compt<<endl;
/ f5 i! u! v8 a1 ~6 j2 l; F) H* t! K) _. n' H7 O8 @1 i! x: i0 a: t
    }# Y! }0 C' c# \9 z
  }7 \- h0 H* p- t7 |! ~& r
) f/ C' g4 a. w, ^( ]$ J3 \! N  //10 - 2 Setting the applicative attributes2 c, i; D7 {7 l$ V- A
  cout<<endl<<"Setting applicative attributes on different faces"<<endl;
9 D6 }2 r! X8 C- W7 p, o  FailedIndex.RemoveAll();
  X9 Y9 Y# e/ i% B# h( ~6 n  rc=CATMmrApplicativeAttributes::SetAttributesOnFaces(ListBreps, AttrNameListToSet,AttrValueListToSet,FailedIndex);
2 c: [6 |4 w9 A, ^( I5 ~  if (E_FAIL == rc)/ e1 j( V0 ~3 O7 A3 W
  {) k$ A9 F( n  m. X4 D+ n3 R. a% z1 W
    cout<<"Error, we failed to set applicative attributes on all faces"<<endl;, Y. M. X) q7 `' ?0 y) Y1 g$ `$ ^8 g8 s
  }; c" L% ~& K; \
  else if (S_FALSE == rc)
" R" O/ T2 G7 K) V8 T  {
' w) v) r% J- o/ k6 t    int nberrors = FailedIndex.Size();
! U- f1 v) u" B: Y3 b* D    cout<<"Error, setting applicative attriutes on faces fails for faces :";
  [9 B- V" R/ n6 j8 e1 ?9 ~    for (compt = 1;compt<= FailedIndex.Size(); compt++)
- a) p7 B4 \$ ~* L    {; g6 T+ B# j% t
      cout<<" "<<FailedIndex[compt];8 M) D" I' a8 ~  y/ R. o5 r
    }2 X7 P7 ?+ ]! R9 ~( J
    cout<<endl;
9 J: _7 ^6 A9 _6 v# }  }
( N: V& ~  s$ F7 W) u, m3 N  else
: J) y4 Y! ]+ _/ l- K* g/ a  {
+ e. O$ s" r# Q! ?# x* T    cout<<"Applicative attributes successfully set"<<endl;* g* H; w, f  Z
  }8 K' W9 Z% f" e( O1 b
5 M8 o$ `" d2 M) g( U$ x# d
  //10 - 3 cleaning1 u( t3 g, U! v8 a
  for  (compt=1; compt<=nbfaces;compt++)$ G" L) j, J! m
3 K( `# ]! W" G+ J8 h2 }) Q% t; _# ]                AttrNameListToSet[compt-1]->RemoveAll(); delete AttrNameListToSet[compt-1];  AttrNameListToSet[compt-1] = NULL;8 k- c) ?+ a5 f* j2 @  {: i
                AttrValueListToSet[compt-1]->RemoveAll();delete AttrValueListToSet[compt-1]; AttrValueListToSet[compt-1] = NULL;( k; y7 N; i6 c8 }
% ?$ ^: Z1 r& W. Q- Q4 Y/ A9 @% `1 \7 O, _8 a" N) P
        delete [] AttrNameListToSet; AttrNameListToSet = NULL;3 A2 S( i7 Y8 x
        delete [] AttrValueListToSet;AttrValueListToSet = NULL;
& O" x1 _4 d! Q5 m; E. _! J+ ?9 F/ U$ K9 w" {
, `; d. p7 T! S) K; L  //11 - Retrieving the applicative attributes we have just set
/ g- ^1 r) y  Y& {$ W9 b0 X( V  //* ~! q& @+ ~0 B1 g
( _: d' ?$ R6 R3 E! v% N  cout<<"Getting applicative attributes on faces"<<endl;
( S2 X1 T' S& J" p+ P  //
- [) d; g/ K2 t# x' E' x  //11 - 1 Getting attributes
5 g# z; m# b" F# s# Y  CATListOfCATUnicodeString * AttributNameList = new CATListOfCATUnicodeString[nbfaces];5 Q& r2 x" c; B; {  l1 m9 E
  CATCkeListOfParm  AttrValList = new CATListValCATBaseUnknown_var[nbfaces];+ n9 f' x$ A+ I4 f
  rc = CATMmrApplicativeAttributes::GetAttributesOnFaces(ListBreps, AttributNameList, AttrValList );
; D4 Z7 Y7 w9 |* d  if (SUCCEEDED(rc))6 y4 c! x, Z+ k6 p: \* H
" E& r; L9 p9 X1 i6 w  Q    CATListOfCATUnicodeString templiststring;$ L$ w" C. \) U7 G$ ^) E. l
    CATListValCATBaseUnknown_var tempCke;
* f. J. n7 k& Z; P  ?8 N$ K" t9 P    for (compt=1;compt<=nbfaces;compt++). i& e  u6 y8 M8 Z! d/ J
    {9 |3 l0 G8 o$ H1 b' J8 Y: Q
      //retrieve a list a position k (arrays start at position zero).5 z4 S3 j7 D, b  a: G# ?
      templiststring =  (AttributNameList)[compt-1];
/ h& x$ s: _. G$ Z. i      tempCke = (AttrValList)[compt-1];: d8 |8 y$ I* V8 V5 R
& _5 A6 q1 h9 x6 D$ Z( Z      int nbAttributes = templiststring.Size();6 F; I3 k# s4 E# T1 B: a
      int nbValues     = tempCke.Size();
, K+ o3 @' O/ }
' S' z' O& m# h1 i! H% m; }8 i+ ~* y% A      //the list must have the same size! If not, we jump to the next face5 @% U; i+ ~% a- |
      if (nbAttributes != nbValues)
/ s6 {3 e2 w+ q6 s* |2 P7 W0 O      {
3 K6 x/ A7 Z% E. ~        cout<<"Error on face "<<compt<<" : nbAttributes and nbValues are different"<<endl;, ]$ m3 A8 B+ A" C0 \5 E. y
        continue;' K3 t' d8 L# B
$ ?( C5 z4 j1 c! c3 r6 {      else
" d! s* R% g- a5 g6 u      {
6 @* d' i. h! o5 p9 Y+ x& _        cout<<"For face "<<compt<<" there is(are) "<<nbAttributes<<" attribute(s) that is(are) : "<<endl;9 P( a" |6 c9 d* w  f" d* h; i# O
      }3 R" s. _- m" m) |- k1 O' q8 @# ?
      for (int i=1;i<=nbAttributes;i++)- m1 z. @: C6 Q, |6 r" ~
+ f$ @4 S  k1 Z4 ^2 u        cout<<"    - "<<templiststring.ConvertToChar()<<" = "<<((CATICkeParm_var)( tempCke ))->Content().ConvertToChar()<<endl;/ i) _% y7 s9 l" o! @& F
& P+ A& N! W& O. F0 E3 x9 u      templiststring.RemoveAll();. F+ L9 Y7 @: \' I0 ^1 z. e
      tempCke.RemoveAll();$ d1 ]6 w  P9 }' ?' P- |
* o; E* r, U5 ~  f4 w" b1 J0 W% v  g    }4 f  E  V7 R; x# g
! X& z6 Y7 K( p- r. p) F  else if (E_FAIL == rc)
7 _$ z6 H5 s+ R  g  {6 ~1 a; p( ?! s4 Y2 {. y) ]
    cout<<"Error, applicative attributes couldn't be retrieved"<<endl;/ c2 _5 q* j, Q( E9 q
    return 1;+ |- e' M* f+ g$ s1 N
" n8 Y% S7 [" E/ S  //, R1 o) E8 ~3 j
  //11 - 2 Cleaning List:
- E# _! c3 M5 @, J( ?  int i = 0;2 a8 ]4 A3 W- p' x( o$ |8 [
  for  (i=0; i < nbfaces;i++)
5 u/ c* [% b  Q) h3 Q- x  {
- N% o9 J( E; f  v    AttributNameList.RemoveAll();
) K" e& Q! l% X. a7 w! G7 R0 P    AttrValList.RemoveAll();; b/ r- W9 z! [! ^. U& P  S2 c) x
2 d/ o1 e) W, f" e% T/ {3 p: ?  delete [] AttributNameList;        AttributNameList = NULL;. U7 Q. ~; x5 v, ^( r3 j8 n
  delete [] AttrValList;            AttrValList = NULL;  g! e1 ~$ a% W  ]/ [0 p3 R# Y) Z: M
7 v; W) v: b- j% g+ @
  for (i = 1;i<= nbfaces;i++)% v/ F3 q! j5 Z5 q  I) T
2 `9 v% p  r3 P- Y9 L  s9 v    Brep = ListBreps ;
( ?2 G0 H5 y- ~0 P( H    if (NULL != Brep)
. H9 k4 |5 U6 r5 }1 q( v    {
' }7 ], `8 ^/ S, k- ~      Brep->Release();, I; P; c8 v5 o, _" I: s9 g9 L. n; G
# T" _/ ?5 l' M) Y  }
% b& c/ a" ^2 i3 z1 r  k  ListBreps.RemoveAll();[/mw_shl_code]
2 U) S/ ~/ ~. d5 B0 H
