发现了,执行的都是些常用的utility,拿出来看看!
7 J2 {6 B% D: T+ c# D- n- n3 ^$ x3 x) g, G% K
首先是设置环境0 y9 k1 ^/ q: t! e. B
8 D; A) B$ t% v g+ y- b% i( G
# v- |+ w3 l# y) aSetting up Teamcenter shell
0 u* K5 v$ v6 v
) s6 c1 w' F8 x, N6 p: D. C( \1 i* V! E7 x+ D+ k
Executing [set IMAN_ROOT=C:\Siemens\Teamcenter10]3 E, f" A- b+ A7 C( ]* s/ R
' I% z4 Z \$ h- J3 ~
$ L( B6 w+ ^% n J" _Executing [set IMAN_DATA=C:\Siemens\TCdata]$ M, V& x) Y5 o5 U5 n% i
$ `$ @/ O- O4 J% p! y
! j+ q. M# z" }9 HExecuting [set TC_ROOT=C:\Siemens\Teamcenter10]
% l; o0 f8 a6 p- L8 l" ] j( t# c# l' H
$ ?( p: A' T. P, ~6 q$ Z9 [Executing [set TC_DATA=C:\Siemens\tcdata]/ a# u) c/ }3 t& |! f- g
6 J/ |0 e% T: |7 R2 A2 M t) V+ k, `# {; J% r
Executing ["C:\Siemens\tcdata\tc_profilevars"]
/ X+ H6 Y* I4 }; g4 I% t1 h8 uOutput from command: "C:\Siemens\tcdata\tc_profilevars"0 H; y0 [4 O$ O# k i9 g
command_exit=0; Z' y+ T- i& v+ T% B
Exit Status 0, elapsed time 0:00:00! i/ `0 T. N) _' |+ O6 |2 P c; y
x( {( ]. q6 }4 `( P0 N
1 c! E0 Z2 o6 N k- {3 ~Executing [set TNS_ADMIN=C:\Siemens\tcdata]/ p3 {, _. b Q2 U9 u* j
3 t! e+ J9 o3 V. P! S( t, r; F
& T# B% R0 u9 ]. X! A! t. E) }1 r$ A
Executing [set IMAN_BYPASS_CANNED_METHODS=ALL] D! f( u6 T. Z, ] {& C
5 B( V. P) h! s# Y8 F) b' M+ `" A9 Z
Executing [set BYPASS_RULES=ON]; } w6 Q8 K3 [5 U
0 ~" l% |8 B- @/ t& ?( C! J$ e
8 U) ]5 _# [- a2 h1 N+ E8 W+ x3 r
Executing [set NR_BYPASS=ON]
; b% z7 d! R0 |; w$ P7 p, a( t; g' J2 _7 U+ W* |
% b( j( P4 s( o3 t" s& P
Executing [set BMF_BYPASS_ALL_EXTENSION_RULES=ON]0 C2 }& K/ A! _' C! z
+ D' K8 ^9 L4 M g: @' q: c
8 E. u; k! \% k( G5 YExecuting [set TC_USE_METADATA_SHARED_MEMORY=FALSE]. d M- L5 f3 A& Q8 O+ a0 t# G
& b5 J; K- c. p1 Z, G; m4 @
& H J5 O$ b( o4 ~Executing [set TC_KEEP_SYSTEM_LOG=true]) f9 Y. ]; |. S3 o' Y$ i8 W7 v# l
6 w9 u' ?0 o. l! w" e! d0 k
% h6 }* c/ C/ n; o- H I7 JExecuting [set IMAN_KEEP_SYSTEM_LOG=true]& \/ j7 b* A9 W9 W) X
2 k, P) D% j/ T0 G; [
9 U% o/ c1 O5 ?! h' n6 x+ h; m1 W$ Q, a
Executing [set IMAN_TMP_DIR=C:\Siemens\Teamcenter10\logs\1311250352]7 Q. G6 E2 K9 v( N
2 H9 X: b3 k/ F2 [# j
$ y3 o" E6 C" \' S# }3 {0 nExecuting [set TC_TMP_DIR=C:\Siemens\Teamcenter10\logs\1311250352]
7 l8 _ F7 i6 N$ P A! V9 v2 I) U4 T1 U
. K! n- P" n! x8 t& u
Executing [set LANGID=EN]1 W; B" t/ j: k, G1 ^8 t* i
; Z& N$ v- H& \( d
% c( v. y% t$ L( `7 q- B9 WExecuting [cd /D "C:\Siemens\Teamcenter10\logs"]2 Y Z& L8 w; B0 B) t& t
Output from command: cd /D "C:\Siemens\Teamcenter10\logs"
2 ]1 w. A1 c$ K& z( k" r' `6 f8 Wcommand_exit=0- A. z/ U, O. f5 R3 o4 W& u
Exit Status 0, elapsed time 0:00:00. ^7 h* g0 g6 E) {- C' S* k: F' c
...Done1 B$ K1 J$ z, {) b+ E. ]( [& j
K" j3 r# e1 v$ V ~: g. y# ^2 X1 X# v$ m
Executing [set TC_INSTALL_DIR=C:\Siemens\Teamcenter10\install]1 w) E" ~ \( t
, g& y& A0 `- F! Z9 v8 V& u
! ~ f- }* m' ^
Executing [set IMAN_USER_PASSWD=*****]
* V$ \; u+ W2 N3 p! g+ J0 O: H' Z x/ i- q5 [
' s+ N8 z" V3 _' H: ]Executing [set TC_USER_PASSWD=*****]
# T1 B( ?5 J* J" N- m* |
9 l1 Z! i7 y# z4 f9 \# [) b* r$ i2 L: y
Executing [set IMAN_VERSION_STRING="TEAMCENTER V10000.1.0.20130604"]
1 u. k& Z! O. x7 ], \ `
8 F. Z, w# r8 J. O! Z
2 C, d4 w% n7 I% q$ [9 HExecuting [set TC_VERSION_STRING="TEAMCENTER V10000.1.0.20130604"]
8 g4 G4 w$ S* b. S; n7 z: S. A& l. A1 D& O' u- v ^+ u* e& r
X( \/ `- z0 TExecuting [set LANGID=EN]
: j, h- V* ~- `
* a' J5 |4 ~5 m) \4 l6 d7 `! ]
5 M/ T& K. @ j; v, [5 vExecuting [set ORACLE_DBA_USER=system]
4 M9 a7 F( f0 }/ U: c. h
/ x3 D i5 N. m2 P5 J" M
3 `1 n" t" M. G- h4 h) ^Executing [set ORACLE_DBA_PASSWD=]
! |5 ~( F n; x+ C! u( k" |, T7 H0 j/ Y; s( q- t# `! v. L
) g) W! f2 O" K0 G5 W! h. v
Executing ["install_runner.bat" -u=infodba -p=***** -g=dba -templates=NX0tcin]
/ W0 Y) `4 D7 J" j* `* i( P+ u D' }0 q
- [; z% ]8 S1 O4 g5 [: f5 ?! I! |8 K
看看关键的utility吧+ T* R: U* T3 u$ ^: P" |% L
& `( f a- M/ B
' n5 L7 l5 P6 x: c! P" n; M% CExecuting command 1 of 13...$ n6 m4 [9 H6 [3 ?3 ?$ T
Section: bmide_pretemplateinstall* A2 t1 p& b) }" s
File: install_runner, P) K7 M/ { v ]/ G8 e" A
Command: bmide_pretemplateinstall -u=infodba -p=***** -g=dba -templates="nx0tcin"1 L3 Y& M1 V1 E; W4 t, H6 |
; q, a9 |; [, }( C+ Q: {+ D- F6 ]7 h
O5 g& m; E5 \1 {# \" S J" Y
, w7 r1 q1 k# @* HExecuting command 2 of 13...
# P0 x: \8 d1 f8 ]7 p. a8 @Section: database-preparation4 X z9 C8 B P+ _; s& L: `
File: install_runner, X" |4 ^* P, Z$ x
Command: install -regen_schema_file -u=infodba -p=***** -g=dba+ R' Q& H5 U- I8 q& M# [8 D7 ?
$ Z7 b0 F3 R1 U+ v5 \" }4 b
; W7 \8 b: j6 W8 a* o) L" w
9 O/ ~+ z' o4 l! L" |. C8 a7 I- qExecuting command 3 of 13...$ F/ H$ N2 n" k. \
, z) F8 p G/ H' P. U3 {, q4 p" ^File: install_runner
) Y/ E! N9 B9 BCommand: install -lock_db -u=infodba -p=***** -g=dba
- } I; X+ ]' [/ a! H4 [. h6 d4 K4 o, c! L9 x0 ]7 V
& \; J! Z& f0 Z3 J/ V- s& g' F: ~
f6 g% v5 S4 z! ZExecuting command 4 of 13...: Y# q: L5 B, j5 \% W' A! g
- e0 K2 }+ ^* V2 y/ x3 p4 CFile: install_runner' S3 @2 b2 X0 v: u3 _( e. F8 O
Command: clearlocks -assert_all_dead -u=infodba -p=***** -g=dba
& G: G' e, m5 t. L/ [* D+ p- M* q* U5 h# e
) ?3 G' Q6 u& V- y! P. _6 @* ]
9 h& U! J5 c6 U' o3 w
Executing command 5 of 13...
' Z# c6 k4 N4 N8 C8 O! _, U- gSection: schema1 d9 Q. r. f; Q. E
$ W. U; u) l" G3 K: E7 `% qCommand: business_model_updater -u=infodba -p=***** -g=dba -mode=upgrade -update=schema -process=all -file=C:\Siemens\tcdata\model\delta.xml
; o, k v' H; S+ W
) @- y# B) k& R& E4 F: ?* P2 a0 m. |
/ }. }4 t( u. z0 F/ S; XExecuting command 6 of 13...5 C% h7 E. C9 v; Z
Section: schema
1 D. H- v7 W7 z" V/ l+ @# o1 WFile: install_runner: k3 I7 R6 {+ A
3 |# ?' q& [" m R1 {1 l# k( u1 H+ p) N
. Z1 x" Z# S6 B' f& E2 a& ^
1 Y# G+ P: |: N" _0 R, J7 F( WExecuting command 7 of 13...3 p0 s) ?8 I3 t6 u" P+ }% s0 d8 D6 J7 x
Section: non-schema
9 Q- ?( M0 |' r# }* tFile: install_runner
8 V/ x; q4 U; E* c( ICommand: business_model_updater -u=infodba -p=***** -g=dba -mode=upgrade -update=non_schema -process=all -file=C:\Siemens\tcdata\model\delta.xml5 J& s6 }8 ]2 u) b) G4 B' S
# _& d" E9 Z; g% Z$ V4 d; F- b
1 p6 G. u+ L8 p3 j' S5 a' ]2 h, @
Executing command 8 of 13...) U) x. k7 ^7 M" ?0 B+ O1 B
Section: post-non-schema-add, T- }3 @! }0 U& A
File: C:\Siemens\Teamcenter10\install\nx0tcin\install_nx0tcin.default' m6 {/ @5 }8 `2 \6 A4 C! V
Command: preferences_manager -u=infodba -p=%TC_USER_PASSWD% -g=dba -mode=import -action=MERGE -scope=SITE -context=Teamcenter -file=%TC_INSTALL_DIR%/nx0tcin/nx0tcin_preferences_merge.xml
$ H, C& }. F1 X1 B& Y: |% c7 x6 g8 _# f$ k: R9 t
* @) s1 ?# o9 {( m E: t1 v4 e
5 c: N3 K. P5 t9 C
Executing command 9 of 13...
7 J( S/ d; P8 t# lSection: database-finalization
8 I6 Y" Q( c# Z5 ]3 i0 }" |" v1 y1 `% LFile: install_runner4 A9 }" T2 u; V1 |
Command: bmide_manage_templates -u=infodba -p=%TC_USER_PASSWD% -g=dba -option=add -templates="nx0tcin"
- ^" f) ^ }# T3 D) }5 J# y( ^, b
8 @( u3 f3 Y+ s' ?$ V( T& Y
( e8 _9 j% ]7 X5 oExecuting command 10 of 13...
9 w- a& ^3 {5 [0 l, zSection: database-finalization$ a; O$ U) K3 R+ \2 `: ?
6 F0 Y7 B+ s. B: YCommand: install -regen_schema_file -u=infodba -p=***** -g=dba0 k+ w( c- T/ j- g
. Q) R# S" t: w* @8 G
0 T5 s- E3 v. }% t# I% |
1 g9 y% y1 b: p0 uExecuting command 11 of 13...
; f* B; D" }! T9 y+ a! K7 L4 i& R8 sSection: database-finalization
: t$ z6 L) q @& {$ B W1 XFile: install_runner
s8 k7 `4 n Z9 }, r1 [& a* [Command: clearlocks -assert_all_dead -u=infodba -p=***** -g=dba
' X* x7 L' B A, P7 K# i
, o8 o/ [/ c8 k4 }. G7 \8 |
8 G6 d* b& [+ I7 _/ Q# E
, h: h3 g6 f2 z6 t8 n( k+ U7 CExecuting command 12 of 13...
2 J' h: @1 w/ a0 T" P- @3 Q9 r- t iSection: database-finalization
3 _; F6 y; Z4 ^/ |9 v8 ?! qFile: install_runner {+ a+ i" \& r! h' e) R8 E
Command: install -gen_xmit_file -u=infodba -p=***** -g=dba
+ Y3 j1 @* f( J7 P3 l# Y/ F9 U3 _4 l6 `) E+ y- Z
5 S( ] u, a1 t' K' l0 B% u3 n8 h( r9 `( b, P/ |& ^" |
Executing command 13 of 13...
, f: |6 M$ j7 E5 R9 \0 [1 ZSection: database-finalization8 O, `! q2 [" L
File: install_runner9 A2 l* _! z" z5 C
Command: install -unlock_db -u=infodba -p=***** -g=dba
- @1 T. L# u) X( v; l0 T" X& P
6 G* l4 ?- _( `3 ^- |7 z. s |
