NX二次开发中有关表达式的操作代码分享
# t" d1 }7 w; _, E 2 O4 e* J- y; v$ V, k
' b& g# ?* g/ ?! n9 y+ D- <p>static void do_UGopen_api(void)
! @2 ]6 N, S9 \ q' s- \ - {' \0 |4 U) C+ J& W/ Q2 K
- // create block 1# @% D' F; T) o* P& |& N
- double coner[3] = {0,0,0};# v$ b9 E; R/ O% |6 \% X! H
- char *edges[3] = {"l=100","w=100","h=20"};
$ `3 ]4 l. _3 j [6 k - tag_t blk_tag;2 d0 |. A8 X2 z3 R, K) L7 p+ ]
- UF_MODL_create_block1(UF_NULLSIGN,coner,edges,&blk_tag); V0 L9 a! w; Q; Z4 K% h% B
- // create a hole! r. |/ H! Q9 @+ K. r$ B
- double dir[3] = {0,0,1};
" P+ i* Z" j( i - double coner1[3] = {50,50,0};" L+ h2 A( B. h/ C. ~2 y, h
- tag_t cyl_tag;& {! r x6 h! X
- UF_MODL_create_cyl1(UF_POSITIVE,coner1,"h+30","50",dir,&cyl_tag);</p><p> /*
3 k% i: N# P3 k" x4 s1 i* I5 W - create expression and delete it
4 Y; p* P4 n) V7 Q8 l% P; m; g - */5 C, e9 \ `$ g0 f( E6 Y+ {" U
- // create expression
+ H5 b5 X3 R: _: G4 K% K/ {: ? - char *exp_str,*str,*value;
5 z! O+ L7 ]2 M8 d$ w - exp_str = "new_exp= 100";
/ Q& u" |2 a$ F: m - tag_t new_exp,old_exp_tag;. n/ _$ v. |6 x# p2 A/ X3 d& y! U
- char *str_exp,*str_old_exp;* b1 u2 c3 F4 G0 |- ~5 S
- int nums;
- w& l4 B. f% b' H1 [4 w- F% b - tag_t *exps; d" V$ _+ q- w7 M" x" A8 M
- // before create the new expression, we need check if the expressions have been created or not 7 w1 S4 u/ Q5 m7 ?3 h6 a) _: d
- // if having, we delete it: c, ]% B9 z7 W& O
- tag_t part= UF_PART_ask_display_part();- W1 R: y9 i- r* N) u
- UF_MODL_ask_exps_of_part(part,&nums,&exps);
1 O- `' B* g) l: ~; t" O L - UF_UI_open_listing_window();" V8 e' i' d( f; ?, _
- if(nums != 0 ) V3 F: Q' j1 f, D9 o( O
- {2 B4 }$ j, s0 H* g6 i( ^4 N9 S
- for(int i = 0 ; i < nums; i++)0 t* J3 \; S$ b! |, x- u/ a
- {# ?4 m8 O( g) a% r
- UF_MODL_ask_exp_tag_string(exps[i],&str_old_exp);
+ _! O+ B- K/ q+ z - UF_MODL_dissect_exp_string(str_old_exp,&str,&value,&old_exp_tag);7 ~& T: L/ s6 x c6 p1 m
- if(!strcmp(str,"new_exp"))- l. E( v1 _7 o1 d# q
( w2 J: ?6 x. H3 J [ - //UF_UI_write_listing_window("we find the alreay expressions ==> new_exp and delete it \n");
' ~& t: k: o2 [5 G# M1 c6 |) z - //delete expression
' v8 s. j( d9 Y. _3 [0 e4 Z% o$ @# | - UF_MODL_delete_exp(str);
) I3 [5 j$ f/ O+ [' i - UF_MODL_update();6 c; C# E, V e% x6 }$ l+ P" l
- break;
* H( Q3 d/ } I6 p- C6 d - }3 k7 A L/ p% v6 r7 ?6 Q& D
- }6 j; u% H8 w# `
# Z* C' e, u: q7 K+ ^ - //UF_UI_write_listing_window("we can not find the expression ==> new_exp and create it \n");
8 F% p5 M1 y* s" h6 D - UF_MODL_create_exp_tag(exp_str,&new_exp);
) k8 `8 Y) N' {3 c3 e+ Z" j - UF_UI_write_listing_window("The new created expression is : \n");
" L( e4 G2 Y4 j1 Y! Y' f, D0 P1 K( | - UF_MODL_ask_exp_tag_string(new_exp,&str_exp);( o9 r" `7 d8 `- T! g, [7 B
- UF_UI_write_listing_window(str_exp);6 O+ ]0 E/ @; u/ } }2 \+ d
- UF_free(str_exp);
8 `$ s( _& E } - UF_free(str);
1 A+ e0 a5 y' `6 Y' I$ N* b - UF_free(value);
/ c$ s- g6 e& ~, N0 I" P - UF_UI_write_listing_window("\n");</p><p>}</p>
5 W# r+ o$ R2 B$ x" r/ K6 L5 `& ~ |
