Component details
+ K8 r, v3 ^' nThere are several components to the Active Workspace Client.) n; u/ |2 N% Z& N( b
• Active Workspace Client data model
$ }( l B0 {) }* {The data model is the client-specifi c model required for the Active Workspace
/ @+ d" M. y) J, F; p( UClient feature. It is installed as the Active Workspace extension to the/ D9 V w+ [- G" v
Corporate Server using Teamcenter Environment Manager (TEM).1 S: K8 d9 h8 q; I7 D1 e- m
• awc.war file
3 N$ {0 G& O' r. v- g5 h! GThe awc.war file is an additional deployment. This fil e is generated and
* k. j& C. a3 e4 H9 i5 tconfigured by selecting the Active Workspace Client solution in TEM, with all# w3 X$ Z% x& S: g0 h
features that contribute to the Active Workspace Client.$ p/ p. s" o, t+ o' g
This .war file can be deployed on the same application server that hosts the
8 y( Y4 r& H# @; O0 ?" CTC.ear file and the Teamcenter J2EE middle tier. This is the user facing web
" r( w& V6 G5 r& C4 Q4 V2 `8 X# ^# _application and serves as the host to web proxies that connect to the existing
& I( x' ]$ D- ?- \( UTeamcenter SOA and File Services. You must deploy the awc.war fil e on an
0 Y8 E: @6 j& I) Y' cexisting server, much like the traditional Teamcenter web client (J2EE middle
+ ^, @) D! n" i, l7 u' Qtier).& K6 u% T; h: S) H* g& U0 {
• Visualization Server Manager5 r* X) C6 A* ^& z. m* i6 l
The Active Workspace Client delivers 3D visualization throUGh a pool of) b" P) ]) D1 I$ x- K
rendering servers. Each server runs a single Visualization Server Manager
' L) m' l( k5 qcomponent, which manages as many VisServer rendering processes as required.
~: ~3 R6 T/ Y0 \: Q8 ]: OFor Active Workspace Client 2.0, only a single rendering server is supported.# u% f3 i( q0 ~
Note You cannot run the Visualization Server Manager on a virtual machine3 L1 S+ E+ ?3 O$ f& ]) s, m
as it requires hardware graphics support.: A( Q' c6 i8 [$ O+ V; N
1 Z( Y( `( w$ ?1 T" l1 k2 Q• TcFTSIndexer client1 x) p2 i# o" e
This is a 4-tier client used to export Teamcenter data for importing into the
z$ g- A# S f3 Z, q# NSolr database. It uses Dispatcher to execute Query, TieExport, Transform0 C2 y5 t* q, |8 S$ ^2 N
and load operations. This is installed and configured by selecting the Full% X9 l/ h( Q n7 H. X
Text Search Indexer feature in TEM, and by installing Dispatcher with
5 l; F n1 U0 y, W5 H7 I$ ztcftsindexer_queryuids, tcftsindexer_tieexport, tcftsindexer_transform,
2 H% a! Z% Q! ?' Kand tcftsindexer_load services. The TcFTSIndexer is run directly for the
" ^: J, d" |6 Minitial indexing and run periodically (scheduled) for subsequent updates.
6 @; k) w$ B3 @/ j+ v- ^5 t• Solr database5 Q- w r( y5 ]. A% w4 A; z
A Solr database is required for storing Teamcenter data for full-text search. This
% O: R! M' A4 @/ v* _9 H7 f* A/ F2 ?* wcan be an existing deployment or installed specifically for use by the Active
@! Q# y$ t9 ]2 P. p1 V2 @& h$ x3 |Workspace Client. If an existing installation is used, there are configuratio n and
3 l! n" A1 y! A3 I' R" c! [+ V4 pschema changes required to accommodate the Teamcenter data.; V4 P: _! P- U0 O5 Z5 V
2 Q( @, M# r! I: w3 m. U2 Z! z9 l2 r3 Z# G0 t0 [4 x X8 s n* r
