& I+ F* h5 R( e- Z: Y E& oNX二次开发源码: 使用NX OpenC++查询装配组件并判断加载状态( U0 E$ E4 M) v" U
* X* T1 }& t& t2 y( V9 m! y* k
/ t: G. {* k: s# C# N! C2 \, J
- <p>static void geTChildren(Assemblies::Component *rootcomponent,unsigned int indent)
) r) K, K( [- ~3 N* s% T8 ^% E - {
# t3 p) ]1 e# {4 Q -
6 _6 O- r9 ]9 a4 Y/ m' q - unsigned int ii;
& [$ ? j l5 @0 G" k - char space[MAX_LINE_SIZE+1] = { " " };
. W. C# U) u. x5 F - for (ii = 0; ii < indent; ii++) strcat(space, " ");
. }! W* J; I% h/ ~ - std::vector<Assemblies::Component *>components;, B4 v0 e# ]0 U6 r- V
- Session *theSession = Session::GetSession();( E; ~1 w! V; B
- ListingWindow *lw = theSession->ListingWindow();
& \! e( K9 g; b/ W1 ~# Y) y3 L - lw->Open();
( k7 c9 E# \ z$ ?9 X - components = rootcomponent->GetChildren();2 N& ?( b# R) u: g+ }
- for (int i = 0 ; i <components.size();i++)
8 s$ Y* [: _5 Y9 F- C2 i1 H - {3 ?/ l. x( N0 b0 ]
- Part *childpart = dynamic_cast<Part*>(components[i]->Prototype());$ _% ^$ V7 k. x& K
- - \0 g) f4 ^/ g( i0 o+ H4 s1 V' d
- if(childpart==NULL)
1 N- g/ M0 u4 ~, b, ^: p - {
* h8 n( L- K$ a. S - lw->WriteLine(space+components[i]->DisplayName()+"\t"+"Status: not loaded!"); m, K. y+ _9 ~9 [4 k; _% ?% @$ t
1 z$ e+ e* W( T% N, ` k - else 7 J2 O% Y; p; N& a* O& z9 j
" G+ w- j" o1 u: r, g. O5 @ - if (childpart->IsFullyLoaded())
& h( O& m% Q" p" y8 I. L2 \" R3 t - {/ e$ }" h" D' o' l! a
- lw->WriteLine(space+components[i]->DisplayName()+"\t"+"Status: IsFullyLoaded!");
' h& \1 t( r$ R - }
& s* Z- f/ C1 ^- V, I; V - else
$ H0 f3 X/ A* { i5 |2 S' f - {. H* { d! q- G- v& `
- lw->WriteLine(space+components[i]->DisplayName()+"\t"+"Status: IsPartiallyLoaded!");4 c: {8 l i7 K& _$ \
- }* g m4 N* L( n* x) B( S9 U7 l# i
- + h, ^$ _+ T" r5 C- Y/ Z
9 ?) K% t. f9 Z( X n - getchildren(components[i],indent+5);
* m2 `3 r1 Q4 r1 Z3 k! b1 l - }5 x( W# \* Z; g. J9 b
- }" \1 X3 k% K1 R' X/ k
- }</p><p>static void do_api()
$ n8 l: R4 W" `. p - {. m) F% g/ u) l& q
- //list the components1 E" K- z6 Y1 H* h4 R
- Session *theSession = Session::GetSession();+ r6 O3 R" H" b
4 t- @# |* h+ F2 f - lw->Open();
3 t7 B; t: M% I1 f) P5 t- W9 m" M - Assemblies::Component * rootcomponent;
, v9 \' I9 z* n5 ^4 i3 @/ k - Part *workpart;$ N8 k% {% f c+ |; b
- rootcomponent = theSession->Parts()->Display()->ComponentAssembly()->RootComponent();
! ]+ G0 s) R3 T) ^& _; l - workpart = theSession->Parts()->Work();
8 \' {1 c# Q" ]( K5 g - lw->WriteLine("The workpart is : "+workpart->FullPath()+ "\n" );: f9 t a7 M9 m- S# C% g
- if(rootcomponent==NULL)
. v2 i% a) }" Q$ V7 Y' n# H% B - { % I5 M. E* K* q) h; E8 P, }3 _5 O) @
- lw->WriteLine("The part is not an assembly ! \n " );7 {1 L2 ~# i. U- ^( ^9 S: F, o1 D7 ^
/ y/ P% l2 T; L6 A - else
2 L, z+ A5 Z6 g0 f - {; V1 a5 ]+ \6 s7 ^9 ^
- lw->WriteLine("The rootcomponent is : " + rootcomponent->DisplayName()+"\n");& u5 P8 U7 D9 v6 s4 t' [' K
- lw->WriteLine("The children components are : \n");
0 D+ t" Z% A4 D) ?2 u - getchildren(rootcomponent,4);
' R: Y& w. T+ c; T Z - }</p><p>}
; g7 Y7 A$ y7 F' x, B - </p><p> </p>
n$ f4 n! N3 i |
