楼主 |
发表于 2013-12-18 19:22:24
显示全部楼层
这是子函数中的代码,是在录制“调整面大小”操作代码的基础上修改得到的。完整代码如下:
+ y! B3 {# @8 n' rusing System;( S/ y. H; D0 X$ J. B; o' b* x) I1 B
using System.IO;
+ h2 W- ] r- e& dusing NXOpen;
# i9 A; C& q1 B8 Fusing NXOpen.UF;
/ n2 j$ I2 g- i8 o- s7 I, z+ |/ h2 P7 I+ z# E; |* L Y
namespace InstanceFeature
3 D$ A H ^& d* {) [; }{7 |0 d( b1 \1 W' [
public class InstanceFeatureEdit# E; Z" `. _ W
{) ~( {9 |$ `2 {1 \
private static UFSession theUfSession;% F" [2 y3 S; T! r
private static Session theSession;
8 u$ z! x9 z# o$ ?% x" n
j: L5 t' I5 S public static void Main(string[] args)
" y5 T, G# c" @ {0 ]8 {8 n* O; B2 h
theSession = Session.GetSession();
6 e- K" V. `; a8 B# M) g theUfSession = UFSession.GetUFSession();
- L! Q6 b1 g+ G1 ?4 T theUfSession.Ui.OpenListingWindow();
4 s6 |5 |1 a1 [ Part theWorkPart = theSession.Parts.Work;
7 L: S5 S: I! R- O NXOpen.Features.FeatureCollection theFeatureCollection = theWorkPart.Features;
! T! Q& Z* R5 ?# ~2 a& |* u5 i NXOpen.Features.Feature[] theFeatures = theFeatureCollection.GetFeatures();
4 c4 D% `% w& G3 {' J for (int i = 0; i < theFeatures.Length; i++): B) O/ G) _! M8 d
{9 s, c g% }6 K3 U' m. b% S% y
theUfSession.Ui.WriteListingWindow("特征类型名:"+theFeatures[i].FeatureType+"\n");3 ]2 p5 k! t z9 }0 o
if (theFeatures[i].FeatureType == "BREP")5 p4 Y! X- @) b
{5 A. S0 B1 n: s
NXOpen.Features.Brep theBrep=(NXOpen.Features.Brep)theFeatures[i];
. D1 q/ J! R; n* B$ z. ~4 x Face[] faces_of_brep = theBrep.GetFaces();( ~! a+ ?+ B0 {/ o& ^
theUfSession.Ui.WriteListingWindow("面的个数:" + faces_of_brep.Length + "\n");
4 ?' ?+ f! H, P for (int j = 0; j < faces_of_brep.Length; j++), R) Q# M8 L& D$ ]0 t( ~1 o+ Z! e, m
{& }# @+ t( v( K& R7 l4 N2 g+ O, ?
string facetype = faces_of_brep[j].SolidFaceType.ToString();- ?. }2 t$ o, V; N6 A
theUfSession.Ui.WriteListingWindow("面的类型:" + facetype +"\n");% X& O6 G1 f0 G1 z( e
if (facetype == "Cylindrical") C4 v/ z9 g+ t( {, [+ T0 [
{& g. r5 T- j- X1 S
int type;
0 N' p \1 v1 [& u) |+ n/ [+ D double[] center=new double[3];
0 ?( i. |: t- v& r( p double[] dir=new double[3];
) r; P; q* E- A. b; g4 t0 n double[] box=new double[3];
* @; k/ O2 ]# h- B( F7 U N( r double radius;- K3 |! ]6 k! Y# J9 i+ K+ K& }9 T
double rad_data;" [& v! |& y. W! N2 p7 A4 @5 O
int norm_dir;. O a, P8 S, i( R4 b% G: M+ S
theUfSession.Modl.AskFaceData(faces_of_brep[j].Tag, out type, center, dir, box, out radius, out rad_data, out norm_dir);: ~! j) H- ]) k: ^/ h2 y4 f
theUfSession.Ui.WriteListingWindow("center: (" + center[0] + "," + center[1] + "," + center[2] + ")\n" + "radius = " + radius + "\n" + "direction: (" + dir[0] + "," + dir[1] + "," + dir[2] + ")\n");% c, r& I4 d2 a' w, c* f$ x
//DeleteFace(theWorkPart,faces_of_brep[j]);
+ K; B T T8 X) w3 J$ I double NewDiamter = radius * 2-2;
2 T @; s5 D7 g( W/ s+ u2 b ResizeFace(theWorkPart, faces_of_brep[j], NewDiamter); G0 J' V6 A$ `% b
//theWorkPart.Save(BasePart.SaveComponents.True, BasePart.CloseAfterSave.False);( ] E" C w* }) S
}$ ~$ C2 y; g4 ?6 I5 J. F* ~% ~' g
}9 O" h8 c! J- E4 K) b& N+ `
}3 B* m* D3 ~4 P! H5 f- G: Z
if (theFeatures[i].FeatureType == "CYLINDER")5 {3 f; h4 m0 P T. e9 M
7 M8 d! }/ E. J: {& l0 Z: @ NXOpen.Features.CylinderBuilder theCyliderBuilder = theWorkPart.Features.CreateCylinderBuilder(theFeatures[i]);
1 m+ P* }. n: l) l Vector3d dir = new Vector3d(1, 1, 1);
$ E4 T2 h8 B- S$ T: O! J6 W theCyliderBuilder.Direction = dir;
1 |# A3 e r: ]' u. B5 N$ `* C9 N! g string str = theCyliderBuilder.GetFeature().FeatureType;! f2 ?; h* X# h. H9 W% E7 t
//theUfSession.Ui.WriteListingWindow(str + "\n");8 A" A" _, } z) I7 B
theCyliderBuilder.Commit();
% Z3 P" ]; ?! {' b% y1 z) e Point3d point1 = theFeatures[i].Location;
2 |3 G. V2 s0 I; c+ g theUfSession.Ui.WriteListingWindow("(" + point1.X + "," + point1.Y + "," + point1.Z + ")\n");
4 P+ Y0 K, { S$ A- L* s theCyliderBuilder.Destroy();6 I1 t8 k/ G1 O1 O
}5 A$ J }9 x% b- l' ]; h, l* l. h2 T* t
}' |1 h( x1 M0 {" k8 J! G
}2 E, c9 @- k4 H+ y+ f( @& I
4 d; r& h9 C5 d1 q9 j4 R public static void ResizeFace(Part workPart, Face face,double NewDiamter)9 b. k, S- g$ C" B5 {! u( j
! G, I/ S" a) N% S" C try1 q5 I i* A) R* s! y3 U
{; Q) Y: v* t% J+ o; h$ n
NXOpen.Features.AdmResizeFace nullAdmResizeFace = null;
( v* r( I* A. X x/ E& M. F0 C' p NXOpen.Features.AdmResizeFaceBuilder theAdmResizeFaceBuilder;6 e% G# {! z$ d4 o' g- h1 u/ z
theAdmResizeFaceBuilder = workPart.Features.CreateAdmResizeFaceBuilder(nullAdmResizeFace);, R6 O, j2 t8 x3 W( Q) [6 l) Z
: G7 l' ^: a* T! b3 U/ F8 M$ o' r Face[] faces = new Face[1];
" l' B+ `5 W/ b/ T3 `8 \# H5 N2 ]# c faces[0] = face;* E {% v; s, r9 ^' n8 v8 L
FaceDumbRule faceDumbRule1;: t/ o+ ?8 ?& ?' D
faceDumbRule1 = workPart.ScRuleFactory.CreateRuleFaceDumb(faces);
. K9 N! K" r) Q$ \6 `6 L5 U+ ~ SelectionIntentRule[] rules1 = new SelectionIntentRule[1];7 \& u3 c. k6 D! Z) J4 L$ _
rules1[0] = faceDumbRule1;
1 \9 E: W; V" I6 d8 i) ?1 S theAdmResizeFaceBuilder.FaceToResize.FaceCollector.ReplaceRules(rules1, false);5 `( a# ?5 l3 o5 Q0 q
1 b% t7 O% s7 Z* G) x# E theAdmResizeFaceBuilder.Diameter.RightHandSide = NewDiamter.ToString();
1 {" V% _- q, h1 D$ ~: A theAdmResizeFaceBuilder.Commit();+ j: |( S( i3 V- B
Expression expression1 = theAdmResizeFaceBuilder.Diameter;
$ v. p- L) n6 H5 W faceDumbRule1.Dispose();
' ~$ ^5 s5 K P- k theAdmResizeFaceBuilder.Destroy();
2 ^: N- s9 q9 q9 t. V8 q }3 m3 g: c3 s) l! _) v0 I/ T F* R
catch (Exception ex)
3 Q7 \ ?- E8 A! P1 G6 r {1 S' |* [, H) k
theUfSession.Ui.WriteListingWindow(ex.Message+"\n");1 T( \# c8 @1 H8 o, M! v7 ^
}0 U' @+ }4 |5 f2 x
$ H! R1 n2 I6 c- F8 m
$ }0 X( t- w" ^: `# f5 ? public static int GetUnloadOption(string dummy)4 J* x! { B9 d8 `# ^
; D+ S, u$ ]7 @- D' n/ G3 l9 b theUfSession.Ui.WriteListingWindow("GetUnload函数\n");8 j- a8 T! a( z5 X+ R) ?, s
return UFConstants.UF_UNLOAD_IMMEDIATELY;( e2 m1 X' H# e/ S' n# ?0 N1 |
* K% ^' o7 e t' o }$ ?) a1 i8 E; D: Y: C: `: B2 l
}% a2 ^* }" d" M$ |* m3 k3 g+ D
