[二次开发源码] NX二次开发中treelist 树控件创建的逻辑过程
2014-2-12 19:13:34 7768 0
发表于 2014-2-12 19:13:34 | 显示全部楼层 |阅读模式
  1. void tree::dialogShown_cb()
    . h! W4 B: X4 Q) Y4 l
  2. {( ]) c4 q, \- q+ R8 x
  3.     try
    3 `4 K4 p0 ?; b7 r7 l
  4.     {. [6 @0 l9 C7 b/ M* d
  5.         //---- Enter your callback code here -----
    ! J4 L: n/ i. O! o, F# Z4 c
  6. 3 D. p1 Y3 y( a/ H
  7.
    4 d) a% C4 j9 }% O# B- l( C# ?
  8.                 tree_control0->InserTColumn(0,"Name",140);, W5 ]2 {4 C1 G
  9.                 tree_control0->InsertColumn(1,"Feature Type",90);
    : s6 j$ @* s' Z+ N2 Q
  10.             tree_control0->InsertColumn(2," Up to Date",70);
    # D' A0 o$ o6 a9 w6 P8 f2 l# N& V1 U
  11. # [0 w: \! M% c0 h+ ~
  12.                 tree_control0->SetColumnResizePolicy(0,Tree::ColumnResizePolicyConstantWidth);6 x; O- Z0 ^& l% d( y8 m. t
  13.                 tree_control0->SetColumnResizePolicy(1,Tree::ColumnResizePolicyConstantWidth);8 v+ F' C. S9 V* y
  14.                 tree_control0->SetColumnResizePolicy(2,Tree::ColumnResizePolicyConstantWidth);' O8 N6 n! v" |7 X' d! u& T
  15. - p7 c( _' `( C8 j) l$ ?0 @( B
  16.                 tree_control0->SetColumnDisplayType(2,Tree::ColumnDisplayIcon);
    3 P: W3 K9 w7 `& Q5 F5 L# p
  17. 6 q" w& V& P; g9 a
  18.                 // create historymode
    2 {+ V, d' j/ C0 `3 X
  19.                 historyModeNode = createInsertParentNode(this->tree_control0,"History Mode" ,NULL,nodeIcons[0],nodeIcons[0],Tree::NodeInsertOptionAlwaysFirst);- i" n' Q# V: W' E" r
  20.                 viewNode = createInsertParentNode(this->tree_control0,"Model Views" ,historyModeNode,nodeIcons[1],nodeIcons[1],Tree::NodeInsertOptionLast);9 {( q4 }9 T+ u# _" I+ T# K! R
  21.                 camerasNode = createInsertParentNode(this->tree_control0,"Cameras" ,viewNode,nodeIcons[2],nodeIcons[2],Tree::NodeInsertOptionLast);; M+ ?+ F" ^9 R# [  \# \
  22.                 modelhistoryNode = createInsertParentNode(this->tree_control0,"Model History" ,camerasNode,nodeIcons[3],nodeIcons[3],Tree::NodeInsertOptionAlwaysLast);& w* \* O3 ?9 n( w4 v$ Y  M
  23.                 tree_control0->SetSortRootNodes(false);
    8 I# |" p. ^0 q1 q% F
  24.                 modelhistoryNode->Expand(Node::ExpandOptionExpand);$ ^: q+ H  U% r, r! M' i
  25.                 // get all the features with values
    ' r( J% Q1 w5 w. J
  26. 1 R+ J: g- |( E, ^$ Z! _5 h1 P
  27.                 std::vector <Features::Feature *> nodeFeatures = getfeatures();
    2 c( h% B* F  X  L" b
  28.                 // insert the features( T" @- k% B* m/ B
  29.                 for(int i = 0 ; i < nodeFeatures.size();++i)
    + _' V' o; \9 |8 U! R& o; Q$ o9 h
  30.                 {
    + B* |6 ]( h) z6 h3 x
  31.                         Node *featureNode = tree_control0->CreateNode(nodeFeatures[i]->GetFeatureName());, m4 ]5 n3 V0 \% l5 _5 q, J
  32.                         tree_control0->InsertNode(featureNode,modelhistoryNode,NULL,Tree::NodeInsertOptionLast);) ?# g# w! s( e" j
  33.
    6 s; _7 N9 c+ r* l. `1 `0 h
  34.                         featureNode->SetColumnDisplayText(1,        nodeFeatures[i]->FeatureType());
    ; h3 a+ t7 q, l4 I5 F
  35.                         featureNode->SetColumnDisplayText(2,"check");
    / j1 O$ |$ S  G* F4 Y
  36.   G' p) G5 y0 C+ Y2 Z
  37.                 }
    % K( ^2 ^) ]4 k
  38.         : p* `: T" w# E) }: y
  39. 4 A0 @. [+ k0 z( t. |+ Y
  40.     }
    / s6 |0 f6 n2 C/ U
  41.     catch(exception& ex)$ M) I6 X$ R0 x, X- u7 g
  42.     {
    % Z+ y; E9 E! T* M, z5 C0 T
  43.         //---- Enter your exception handling code here -----1 j) Z, G9 R4 |* C+ r/ [- [+ M+ Z2 ~
  44.         tree::theUI->NXMessageBox()->Show("Block Styler", NXOpen::NXMessageBox::DialogTypeError, ex.what());
    5 u# s: n7 _5 a6 Z3 a
  45.     }
    ! [: A, V' ]- @, W6 U; p
  46. }
    % j% s; `7 o  _9 _% r' U
6 C: \5 B; S+ q" Z& e
! Y9 d- d2 a, ]* n. C0 m/ s
treelist的创建,需要在dialogShown_cb()里面定义treelist的内容
. o$ [- G; \+ ]9 i3 v: @5 p
' P# E+ h- D( [5 [  r& K* Y首先通过InsertColumn 定义列,有了列才能创建节点Node
+ D. S& b9 e" K+ H! Y" m: `9 Q3 _6 M" h0 d4 c6 d  ]
这个顺序非常重要!+ s8 v$ g0 E! ]- _, `
: r( D3 T- ]( A2 ^% V
treelist 树控件创建
treelist 树控件创建
& X9 c2 d: j! H4 E/ f4 W0 h
; @9 w- q+ a; B/ J: G
