using System;
; [: q, v5 k: Z E- Yusing NXOpen;
7 r" Q2 A& j$ i$ m" x1 G; p# u8 h Uusing System.Collections;
) _# `2 B6 ^6 |3 P6 kusing System.Management;
8 G$ E' T. E- s0 G1 ?1 G" nusing System.Management.Instrumentation;
0 J4 _4 M' c( q1 }6 R3 C. vusing System.Text.RegularExpressions;" H6 B' d1 V# U Z* e0 z) ]# V
using System.IO;8 z" S. D4 S! Q, E; d
using System.Collections.Generic;
% Z0 T7 k6 n( B* b: b3 tusing System.ComponentModel;2 C' v) Y( p6 _- d% D0 u
using System.Data;# F. B' f) o% m4 z8 R+ n- S
using System.Drawing;
! R8 a. \* ~8 G5 e. b9 Q9 vusing System.Linq;, D7 |7 [/ ]( R$ o! H+ n
using System.Text;3 j* j, I X6 N- w
using System.Windows.Forms;" ?# o. C5 B# D& P0 o
public class NXJournal555
/ x0 }$ N) t4 B+ D6 I- X{
* e4 A' }8 c6 ^3 D' E public static void Main555(Tag[] bj, int fhsl). Q) a0 d7 G4 T5 w4 l2 I
7 b! l: q0 C$ d; Z' G) Z6 }
4 a3 c5 B5 s- s( | Session theSession = Session.GetSession();9 {+ I# z3 T" H; H2 K' I U, z
Part workPart = theSession.Parts.Work;3 c# ~/ j5 j3 D* _) c& Z/ s
Part displayPart = theSession.Parts.Display;
: o, Y0 j1 D* u/ s" l) Z // ----------------------------------------------3 T# E0 n# Q$ W. N, w( d
// 菜单:镶块->曲面->Bounded Plane...
: ~7 r& n1 n8 c& v8 w0 B. x! _ // ----------------------------------------------+ X9 W4 Y+ Y1 k' t: [4 e% p% r% \- {
NXOpen.Session.UndoMarkId markId1;
. @1 L0 j# w9 A6 i4 g4 h$ d; J markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Start");
2 E) V; u- A4 R
2 d9 Q; f: r: M o3 ~: e NXOpen.Features.BoundedPlane nullFeatures_BoundedPlane = null;
" E" f: U7 i% ~, u+ {
) Z/ F" F9 C: g H" d if ( !workPart.Preferences.Modeling.GetHistoryMode() )& l4 }1 P2 j7 ?& B
N) k+ J1 }& v2 v9 I" A; t/ r throw new Exception("Create or edit of a Feature was recorded in History Mode but playback is in History-Free Mode.");% K6 |8 C) D# Z! g9 e& a6 c& u
t5 J- J) f7 S, D3 o
/ {* r$ d- P' B$ [ NXOpen.Features.BoundedPlaneBuilder boundedPlaneBuilder1;& f- ?; m! s2 P& C( n r
boundedPlaneBuilder1 = workPart.Features.CreateBoundedPlaneBuilder(nullFeatures_BoundedPlane);9 {8 a( R3 X# F4 n1 u" a
7 f8 a' k2 H$ g% y* G0 I theSession.SetUndoMarkName(markId1, "Bounded Plane 对话框");
/ o, w$ v! d$ B8 d
* v0 e) O, x$ ~4 O& c& C; B& i3 I boundedPlaneBuilder1.BoundingCurves.SetAllowedEntityTypes(NXOpen.Section.AllowTypes.OnlyCurves);9 O+ x- t7 d( T2 Y
3 @% J& T; e6 k+ L! e4 ~0 T
NXOpen.Session.UndoMarkId markId2;4 A; G" @9 x. I/ a) U
markId2 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "section mark");3 \5 e8 k6 R/ T2 `$ a$ O' n
/ p' T+ C$ X- U0 _ e6 ?
NXOpen.Session.UndoMarkId markId3;
. z% m7 s8 q$ c w markId3 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, null);
2 x, j4 z0 O- Q6 {, G
! H. A' f" N/ _/ T9 J; w9 F7 O Curve[] curves1 = new Curve[fhsl];4 Q7 R4 @7 _5 B' y* F. K
Line zx = null; ;
2 A' N# _5 o% x- {6 p/ D! R Arc yh = null;
/ h; u1 t, _5 {7 ]2 p; J' [ int bj001 = 0;/ {+ P0 ~6 p+ n, c8 z/ G) I1 z
for (int i = 0; i < fhsl;i++ )
0 Y& h5 L1 I$ E. T5 T {0 ?5 S) s O6 D g
try9 [8 D8 p6 v" d
{2 _( E" R3 F4 U7 x1 u ^0 I
Arc body2 = null;* J, z# O, d) W3 M- s
NXObject object0;* N* C3 j. W, V5 g
// Tag body_id = NXOpen.Tag.Null;1 a; e7 [( {. g+ X1 R$ I. p' p: {
//theUFSession.Modl.AskFeatBody(bj[0], out body_id);//把特征的tag放入到body的tag.
% b& C7 z9 {" M6 `9 ` object0 = (NXObject)NXOpen.Utilities.NXObjectManager.Get(bj[i]); //把tag转为body。+ M* C8 w5 }, E3 x9 ]
body2 = (Arc)object0;
' K- I: a4 i2 O curves1[i] = body2;
+ ^# H2 v' d. v% m if (i==0)" C9 D C* U) \) W
{7 b9 C) @+ |' A7 H$ A) a, q: n
yh = body2;. Q7 J R. B8 k6 ~: Q$ `
bj001 = 1;0 H$ k$ \, y1 {8 K' ?0 H j4 d
, p( K# D/ P. y/ i4 p; {" M9 ]: G0 J$ _* d# x r
}& ~* @" S& X5 h$ Q- d7 J
caTCh (System.Exception ex)
p j0 o4 a& ^* J9 C8 y { 4 w7 p: i+ _5 ~) p- r. k' j
4 I0 _1 Z! w+ S, r' X try: N# o# d9 z. Z; e1 N7 X
{' `9 V* {7 a: |6 ?5 f9 \
Line body2 = null;
% Q' n3 m$ C: k2 I5 { T/ n NXObject object0;
& f' n: O) p7 r* J3 @! K7 x+ Y // Tag body_id = NXOpen.Tag.Null;8 J+ K$ Q. \0 ~' Y
//theUFSession.Modl.AskFeatBody(bj[0], out body_id);//把特征的tag放入到body的tag.7 \! {% h1 H- ]- k* p
. A$ y) C2 B Z0 W8 l* Z& l* B body2 = (Line)object0;5 x9 |2 s" `8 U
curves1[i] = body2;
1 L7 d, D# t, H& G2 i if (i==0)
; q" k* N7 q) \1 ?. [! z( p {$ _4 Z! i& w5 P8 {
zx = body2;: I+ g# }7 a5 i; n6 D
bj001 = 2;
R% r$ ^7 W8 l" b4 F }" _ y6 {( p" _' t; H. a* ?$ w: X
}* X9 m6 G; u N
catch (System.Exception ex)1 ~. }; [3 p; O6 \
{/ T3 f4 _# @) E- z! c$ Y
4 Z" b( n$ h4 z9 k# F2 P, S. {4 A6 Z
6 p: Q5 Z% C! u% h* L4 A& [
0 d# X8 |6 Y* S3 ^ }2 E- M4 K& P/ {# W$ g2 c- E: M
3 H4 u/ E1 Y$ Z// Line line1 = (Line)workPart.Lines.FindObject("HANDLE R-7608");
6 l J# y# M- f3 D: v1 ]// curves1[0] = line1;
2 @8 R1 l: J3 E2 ^0 F3 x// Arc arc1 = (Arc)workPart.Arcs.FindObject("HANDLE R-7621");5 ^& t4 o5 j% m( i1 u( J6 r% Q$ j/ a
// curves1[1] = arc1;, y. b2 M% {, M! ]
// Arc arc2 = (Arc)workPart.Arcs.FindObject("HANDLE R-7614");
+ l# K9 H* r8 J' E% r9 I5 v- i// curves1[2] = arc2;1 \ g( `' d3 s
// Line line2 = (Line)workPart.Lines.FindObject("HANDLE R-7611");
; X w# E0 f9 A/ k// curves1[3] = line2;
" J, T- V4 P9 z$ y% N// Arc arc3 = (Arc)workPart.Arcs.FindObject("HANDLE R-7618");2 N+ Z& N: k8 {3 _ q4 j1 g
// curves1[4] = arc3;
+ g* ^& Y9 _9 l0 v// Arc arc4 = (Arc)workPart.Arcs.FindObject("HANDLE R-7604");1 C7 m) U, _; }4 r
// curves1[5] = arc4;
: V8 A% e- r: c3 X% r" {* @ CurveDumbRule curveDumbRule1;! V i2 c4 V; h# {+ Q. }. s
curveDumbRule1 = workPart.ScRuleFactory.CreateRuleCurveDumb(curves1);
5 D; M- {- {2 x
% h8 p& q( o* v boundedPlaneBuilder1.BoundingCurves.AllowSelfIntersection(true);
7 [4 h, Q3 Z! Z) y3 m- W9 [
' l4 v% T* M9 f$ S; X: x SelectionIntentRule[] rules1 = new SelectionIntentRule[1];0 b) S2 z- P/ Z! t) T$ N8 ?2 ?
rules1[0] = curveDumbRule1;
2 N- N* j7 y0 W4 M+ ~4 _, K NXObject nullNXObject = null;
8 G; T% L% y% \# q5 `9 ` Point3d helpPoint1 = new Point3d(0.0, 0.0, 0.0);
: {, p/ W# X9 O" x if (bj001 == 1)
& F5 o6 s: X3 j9 v. {: x* S$ N7 G* i {
; R, [4 q- ?- X+ Y' r boundedPlaneBuilder1.BoundingCurves.AddToSection(rules1, yh, nullNXObject, nullNXObject, helpPoint1, NXOpen.Section.Mode.Create, false);! {/ q; u9 }$ V+ K) f
}) |. U: B2 n2 J& \. z' M1 I
if (bj001 == 2) V* C0 M+ b& D9 T1 y0 ~$ [
{6 ?) k' l5 {+ ~* ]
boundedPlaneBuilder1.BoundingCurves.AddToSection(rules1, zx, nullNXObject, nullNXObject, helpPoint1, NXOpen.Section.Mode.Create, false);
" N: n4 b5 o- G0 v z0 S0 t }
* f1 c0 m1 } \- U8 d& S [5 S+ i0 L$ r# f9 T3 t( @
theSession.DeleteUndoMark(markId3, null); o1 Z. T: G" m* t) L+ J1 F0 N2 J
$ `8 _" g' i1 L+ H: x2 H8 |
theSession.DeleteUndoMark(markId2, null);# E1 n) K* X1 T _4 X3 P
6 l) Z E5 |. ^: Y
NXOpen.Session.UndoMarkId markId4;% Q' w. P$ }. Q: g: h
markId4 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "Bounded Plane");) O: {. [6 B5 c
Q4 }8 e& ^# Q# R
NXObject nXObject1;
/ R9 e* h- [: ~! f0 P5 ^ nXObject1 = boundedPlaneBuilder1.Commit();
9 o, v1 y4 x8 Y6 u! O2 v3 p" X
5 B+ |( u. z+ [; S4 ^
" I" V& Y" W6 A$ N& F DisplayModification displayModification1;
% w- `9 n. [( R: e! `; F displayModification1 = theSession.DisplayManager.NewDisplayModification();
: M, z7 L/ T" Q- h& h r# n * d& |$ m1 S3 c/ R5 e
displayModification1.ApplyToAllFaces = false;4 t1 L/ ~: p- K3 X
5 L4 `, @" E |) K% z1 k8 a; N
displayModification1.SetNewGrid(0, 0);' k) s! V; w6 |
5 R% g/ s# o" }! F0 R: s4 @
displayModification1.PoleDisplayState = false;% K- I5 h4 B; k' r0 W
% w {0 t3 O! R& i0 j8 Y( \& z displayModification1.KnotDisplayState = false;
, A2 ?. E" @7 |+ R$ u- v& |
. u+ n5 T1 P7 D+ S+ X7 ]9 u- g0 J DisplayableObject[] objects1 = new DisplayableObject[1];
' {7 Z, V2 l# U NXOpen.Features.BoundedPlane boundedPlane1 = (NXOpen.Features.BoundedPlane)nXObject1;6 S! p* E& a2 o# R
Face face1 = (Face)boundedPlane1.FindObject("FACE 10001 {(0,0,0) BOUNDED_PLANE(20)}");
1 e9 j) M* x5 N8 o( ?9 g* j 6 I3 {9 R1 P( {
objects1[0] = face1;
! }. v; x5 p+ T displayModification1.Apply(objects1);; _1 r, X9 J. @
face1.Color = 32767;
; C! i0 _, Q5 I6 Q( I. M4 u9 ` 6 A: j) H, f2 z6 P7 Z
theSession.DeleteUndoMark(markId4, null);
: \* ~4 \2 {/ f3 D( T
1 v. G: c* s& y7 r/ a theSession.SetUndoMarkName(markId1, "Bounded Plane");
7 {' s$ I1 i/ ], `, D
O! s {/ C2 A1 d boundedPlaneBuilder1.Destroy();
. o4 p/ P: ]! q4 J0 o 1 J N+ [ O8 R& E0 @3 E3 M3 O
/* if(fhyi==1){7 [1 n' s8 V5 z6 m$ ~' U% _5 E0 n
NX8_Open_CS_Wizard1.CodeString.yfht1 = face33;}9 v6 j% j: h& _- j' K
if(fhyi==2){5 V; K" ?, A% i/ [! o
NX8_Open_CS_Wizard1.CodeString.yfht2 = face33;}
5 i1 h6 z% x1 ]* t4 ~* B+ y */
" e0 T8 o' z' z) H- d2 @, G // ----------------------------------------------2 ?+ h2 _4 E5 g
// 菜单:刀具->操作记录->Stop Recording- S6 _" {! f0 U0 j' l
7 S0 O+ o- d. s7 z 9 S& Z5 X9 ^- U, F1 f+ B1 j( ]
6 H" r* X( W0 y: ]9 C public static int GetUnloadOption(string dummy) { return (int)Session.LibraryUnloadOption.Immediately; }- r9 I( j# L4 D- Y% z
}! h) R% B- Z, f& L1 |# U, l6 \- M
这是录制有界平面点选封闭曲线产生的日志
4 ^' H7 s- l! ~我用自己算的的TAG[]转换成NXObject再转Body存入了它自己创建的curves1[i] 数组 结果画出平面了 t7 z n8 f* B) m( E' z3 w3 ~5 J
NXObject nXObject1;' K! u* ~; S, \: t
3 d/ y+ B7 l! |1 d6 j: z但在这段下面加上 Body face33;face33=(Body)nXObject1 时就出错 生成的文件不会往下走 我本意是想让它返回一个记录生成平面的Body值 用于以后缝合用 该怎么改才能让这个函数返回值3 j" A6 ]% K% [$ K% f
2 Q% L3 W8 J( P G; i# p& e$ r
