UG NX二次开发:从NX5到NX10 Windows平台开发软件的配置
2015-2-6 10:39| 发布者: admin| 查看: 3936| 评论: 4|原作者: admin
摘要: UG NX二次开发:从NX5到NX10 Windows平台开发软件的配置 Note:When installing the Visual Studio be sure to install the X64 Tools. In some Studio versions, this does not happen by default. NX10.0: ...
Note:  When installing the Visual Studio be sure to install the "X64 Tools".
NX10.0:
    C/C++   Visual Studio 2012 Update 1 = Version 11.0 Update 1
    .NET    Visual Studio 2012 Update 1 = Version 11.0 Update 1
            .NET Framework 4.5
    Java    JDK 1.8.0
    Python  Python 3.3.2
NX9.0:
    Java    JDK 1.7.0_5
NX8.5:
    C/C++   Visual Studio 2010 Service Pack 1 = Version 10.0 SP1
    .NET    Visual Studio 2010 Service Pack 1 = Version 10.0 SP1
    Java    JDK 1.7.0_03
NX8.0:
    C/C++   Visual Studio 2010 = Version 10.0
    .NET    Visual Studio 2010 = Version 10.0
    Java    JDK 1.6.0_14
NX7.5:
    C/C++   Visual Studio 2008 Service Pack 1 = Version 9.0 SP1
    .NET    Visual Studio 2008 Service Pack 1 = Version 9.0 SP1
    Java    JDK 1.6.0_14
NX7.0:
    C/C++   Visual Studio 2008 = Version 9.0
    .NET    Visual Studio 2008 = Version 9.0
    Java    JDK 1.6
NX6.0:
    C/C++   Visual Studio 2005 Service Pack 1 = Version 8.0 SP1
    .NET    Visual Studio 2005 Service Pack 1 = Version 8.0 SP1
    Java    JDK 1.5
NX5.0:
    C/C++   Visual Studio 2005 = Version 8.0
    .NET    Visual Studio 2005 = Version 8.0
    Java    JDK 1.5
引用 UG小朱 2015-2-6 12:59
好东西!顶一个!
引用 静远 2015-9-12 08:34
顶!d=====( ̄▽ ̄*)b
引用 qindongjun88 2015-9-18 18:40
版主,我的电脑装的是Visual Studio 2010,但现在要开发NX7.5,必须要装一个VS2008吗?如果直接用Visual Studio 2010来开发,会不会有什么不可预知的BUG发生。
我现在在VS2010上开发的程序也能在NX7.5上运行。
引用 指针先生001 2015-9-21 20:39
谢谢!PLM之家!
查看全部评论(4)
