[新功能] 【官方文档】NX9.0.1的最全新功能文档,其他的弱爆鸟!
2015-1-11 00:26:53 5001 1
16
发表于 2014-2-22 13:05:55 | 显示全部楼层 |阅读模式
3 r( ^; ^0 X! `
" f% Z0 ~3 D% N( [最新的补丁包下载( V6 Q$ H- G% W7 N
1 d4 H6 ~' Z; o, r- F6 l7 E
, r+ P8 r6 g+ V* FSiemens_NX_9.0.1.3_Win64_Update_SSQ
% S; h1 B7 P! N! J0 v( f1 Chttp://www.plmhome.com/forum.php ... d=999&fromuid=10 h6 _8 F; i1 s- R6 g+ ^
(出处: UG论坛|NX论坛|Teamcenter论坛|兄弟UG网|UG视频网|PLM之家UG网|Teamcenter技术支持网|Tecnomatix学习网)
3 {, [4 V0 N" U+ R% T* @
" o+ }' d5 ?" @9 Y
0 {5 h) ?* a5 q3 c* q# x新功能官方如下
/ J: Y, m4 f8 w* R, ]$ m: h9 ]8 [# T$ _! P
NX9.0.1的最全新功能文档
NX9.0.1的最全新功能文档
' ]! U  ~# ~5 b% [8 m
( m8 g0 b+ R3 p
) t' L; r* F6 B+ W* p8 }     What's New in NX 9     iii $ d  |) X+ a( h( p5 M' _; H+ X
) C; g5 W" @# eContents
1 t. k0 ^6 b4 z8 T3 ZChapter 1:  Routing , r5 j3 p7 r3 k3 Q
Using assembly constraints for active arrangements
8 M, X/ c/ @; T( L, ?Part placement enhancements * q% l' S& l. e  X+ x
Move Part enhancements ; ~6 v+ t) p  t* K# m/ e
Chapter 2:  Fundamentals
! _: k; Y/ l. Y, ?6 i8 pNew NX look 0 j! w) r$ x; f, d6 Q. a
Chapter 3:  Modeling
3 ~% N% [+ `# V9 j0 Q( H' I: MBlend Corner 5 w! K0 o$ {. X2 Z1 s- i7 C
Fill Surface   w2 s7 }2 S" x/ X
Chapter 4:  Assemblies
0 B% y7 i; ~, T. NArrangements $ W' D% i. z6 w' u6 X1 u: Q$ ?
Arrangements that ignore constraints / n* h  ]& g9 v% I9 z
Isolated arrangements ; X. D" X. f  ~3 r, _" ^
Definition of terms for isolated arrangements
' K0 O& @! s- gIsolated positions and isolated position overrides + p; Q% i% J+ s
Position column in the Assembly Navigator
' {1 N3 S* O( F# U( H; U5 t6 NExpressions in product interfaces
* S: |* }* c+ q. `. m* H% iChapter 5:  NX Realize Shape — Subdivision Modeling 4 {! v' D: s9 s. ?' J
Realize Shape 2 e$ E6 b* k- ~% G
  Primitive Shape
6 r/ v# y; v) V1 o9 V" F  Extrude Cage
' A' S. F  G$ K6 ^2 Q  Transform Cage
% i# h, y; @; y0 U  Split Face " T% Y( g9 F/ J5 k6 ~) h
  Subdivide Face 6 l; D' j* D5 k% Q8 ?: |$ m
  Bridge Face & p, P& K$ X- a+ @0 I6 j
  Fill
; |, A4 m6 ^" H- i! b2 R8 X  Delete Face , K0 [3 c. M  u, N: K. i
  Merge Face # ?3 z# r: r8 q8 {: p/ g( v
  Project Cage
4 x0 E3 `8 U* C! p8 ^   X-Ray Cage 5 X. [$ ^. D3 g# L0 _- g
iv    What's New in NX 901     & S# L0 r4 [. `, H0 C8 b
% j; N: r9 i# `& U8 k; Q7 l' e  Set Weight 7 c! x9 T, C3 D/ T! k6 X! l7 t$ h: y
  Set Continuity % y  P) M8 a4 k2 b( m; R
  Symmetric Modeling 4 T1 y- t, p" B6 f$ a
  Realize Shape Preferences dialog box
. g: r' r& M1 \Chapter 6:  Manufacturing
' f- e* ]" a* [5 Y* F8 |+ ZSaving and retrieving simulation settings
# s- M9 {+ S; B8 B- aConnect tool path after editing
2 N+ _6 r; ?2 ~5 O/ M1 X; Y) CCut regions and cut order in Flowcut Single operations
! e# C" i& ^3 h5 Z+ B8 s7 KCreating the IPW in the background
. M4 o& P, H' g0 TDisplaying cutter paths
* ~9 P) z6 o0 ~" L5 KBoss milling and threading operations
9 \$ b; T5 ^% h( RMulti Blade Swarf Blade tool axis enhancement 7 _/ N2 F% T* d6 _0 C
Chapter 7:  CMM Inspection Programming
" \4 n1 J& P" Q+ o# IGeneral enhancements ) g+ Y3 P- ?/ x7 e- _8 o  G' `
Path statuses in the Inspection Navigator : A6 n9 ~! |+ S* l3 }# U! s
DMIS Equator and mirroring postprocessors 6 _3 R* ?6 Q# `& {5 H
Tip type and tool selection & r, N/ `" ^* q; m7 f) N
Sub-operation inheritance from feature methods
' B3 h/ H# p" J) F9 tCollision avoidance enhancements - H8 \, B4 S+ D0 h1 y$ N  l/ q  Z
Data analysis options 1 z7 v: [  o" g" j9 G- b! ^
Ability to save loaded analysis data
3 B9 _5 ]  k5 s/ ?Save analysis data to the Part Navigator * P9 n5 b  {$ `9 [% w' @' u& L/ S; _
Creating annotations for data analysis
2 K+ K- v( Q" X6 e! i( pCreate annotations using analysis data
! u2 T6 D6 _, x/ r9 o& iDeleting problematic analysis measurement points
9 ^, M% Z; i- v# u3 ^& C3 ADelete problematic analysis points + \3 [& q6 A* k# D7 A
Chapter 8:  Advanced Simulation
: {7 b+ V/ V% e! ?2 QSolver version support
8 u1 F$ t  p5 K4 W  H: }Materials ; U" r5 T. e0 D8 a6 M
Create material enhancements 3 m" [  ?1 c( _" ?) e  [
Durability
8 U) Y, [' Y  H9 H  YAdditional fatigue life results 4 Z  Q8 m/ ]6 d( J
NX Laminate Composites
# h: j. F- b0 c) o5 CImport and export to Fibersim enhancements + X6 Y- `" |) Y1 Q  `7 @
Global layup support with Append FEM 2 N8 Z& f2 d. ]' m
Chapter 9:  Motion Simulation & w3 x$ r% G- y8 y" o/ o) i
Support for Isolated assembly arrangements 5 b# M; c; j' ~% _0 n" M: T1 |. z
     What's New in NX 9     v 1 c9 {8 n" @- D6 V1 B" x
8 J$ f( ^: Q+ fChapter 10:  PCB Exchange
3 X9 z- r: Y6 u; |7 z+ zMCAD Primary Pin
8 H* S) u3 P- ~/ y! B7 kComponent Load Options
, h: v* ^+ {& w! O' VPCA validation enhancement
9 y8 D5 \3 ?3 [. u; gPCB Exchange user interface enhancements * h3 I; ^; b  b3 P
Chapter 11:  Data Translation
3 u( R* I$ S# k  O- V0 m, uExport NX reference sets as layer filters enhancements
" ]- n; ~$ ^) g9 k- v5 LDimension export enhancements 0 J" X" W3 ?, r+ c1 u
MText import enhancements in the DXF/DWG translator
* N' w* r4 v8 o/ }# Y3 W2 N1 }6 YCATIA V5 translator enhancements
* _4 r* v3 i3 {$ U
: {% r! I2 m$ U& R. j! U" d7 W1 B7 P) {
& t* C5 l& U! J1 P6 {4 H& {# Y2 I
NX9.0.1的最全新功能文档(2.04M)
发表于 2015-1-11 00:26:53 | 显示全部楼层
太赞了,感谢楼主
