本帖最后由 PLM之家NX 于 2014-5-5 22:42 编辑 1 c) v5 M, _/ p
, F: q4 o0 i4 `8 h% K
6 T+ u2 n; \% A/ J/ P# O3 c1 Z0 k/ o7 Z. [3 i' C( B
两种方法 都可以生成 ,但是是老的对话框,新的对话框参见NXOpen 代码, u% S: T& i( v
) R8 c/ D: B) o; ^) H; n
UG二次开发源码分享:ufun 生成投影曲线源码
' ^8 }1 |# N# [. _% g" m. {
?& q0 G) {# j" ~% @" X1 B; i
K6 Q' \8 _* Z0 N- int n_curve_refs = 1;
: ~$ j+ D/ J0 F7 m - tag_t curve_refs = selectedFirsTCurveTag;
$ T& h5 |6 U/ w - int n_face_refs = 1;
. `7 {1 ?4 ?8 A& O4 D - tag_t face_refs = selectedPlaneTag;
?+ _' K! o! ?# c - int copy_flag = 3;
& A a1 B( w4 v9 |2 w' A
% g- s' G9 c7 n4 c2 e* M- UF_CURVE_proj_t proj_data ;/ a/ b- }" w; N' @# B$ Y* i* `
- proj_data.proj_type = 3;
$ N5 ~$ M; y1 U5 n- x% X" u. T3 ^ - proj_data.multiplicity = 1;. J. X5 |* E* Q( ^6 W- q3 W+ t* U
- proj_data.proj_vec[0] = 0.0;8 G ^# }; a7 }% [/ f
- proj_data.proj_vec[1] = 0.0;
( P+ |+ t0 T8 F* s. S - proj_data.proj_vec[2] = 1.0;3 o7 K4 Y. g' r5 E! u
- Z' l9 r4 c' g/ `0 h) P- tag_t proj_curve_feature = NULL_TAG;* U; m j+ W& Z$ J r
- UF_CURVE_create_proj_curves(n_curve_refs,&curve_refs,n_face_refs,&face_refs,copy_flag,&proj_data,&proj_curve_feature);* x; ?. K$ W' k2 J
3 L6 ~( u$ L+ l" M* ^" ?" V* v. L! v - uf_list_t *curvelist,*datumlist;
0 G5 ]) o' j$ `* f8 G - //int curve_count,datum_count;$ {+ F- O- C% y# Y
- UF_MODL_create_list(&curvelist);: {8 E9 A* {8 _+ S \/ c( `$ q+ e( [6 j
- UF_MODL_put_list_item(curvelist,selectedFirstCurveTag);
+ M% x% Y. N4 y3 _$ [/ q/ E! E- {7 k. W - UF_MODL_create_list(&datumlist);
/ _5 y/ V! A# w+ F# { - UF_MODL_put_list_item(datumlist,selectedPlaneTag);# p' @% L$ \3 P" |/ q
- //UF_MODL_ask_list_count(curvelist,&curve_count);
2 W7 c4 Z6 L D5 e3 B0 K: R5 e - # e7 c6 |9 U+ A
- double projectVector[3] = {0.0,0.0,1.0};
( o. O3 i% O& G - tag_t projectCurveTag = NULL_TAG;0 X5 ?, p* r& F( p) @' o7 v8 }
- UF_MODL_create_proj_curves(curvelist,datumlist,0,projectVector,&projectCurveTag);
* m! V* R- x; t, Y, Z' ^6 x. g7 j - # c3 f, B i: }8 @& S, O+ E
- UF_MODL_delete_list(&curvelist);
, h' x8 a+ T- A/ ~% C+ {% u$ ` - UF_MODL_delete_list(&datumlist);
复制代码 5 M! b4 v: l: N( S1 `3 l) l
2 E' Y$ ^- u* G+ K( q0 ^
0 j: y: M3 Z r( @
