[二次开发源码] UG NX二次开发源码分享: NX Open C++ 创建投影曲线 project curves
2019-4-25 18:47:55 9283 3
16
发表于 2014-5-5 22:45:05 | 显示全部楼层 |阅读模式
/ x: B! \5 G4 F7 |! G9 m' [
! E( T( b$ j) o6 z' Y& a: a/ U3 R2 t  Z- ?
UG NX二次开发源码分享: NX Open C++ 创建投影曲线 project curves% J  V5 B$ [6 l, N3 j
/ h+ u8 `) s0 w  N此处使用的是 通过面的法向创建投影曲线,可以参考下!
; o$ l1 [7 _4 l6 U/ A5 B# {0 ]
! p0 n5 H3 D1 P
7 I$ c9 r, D4 j: c7 S! v" M6 s/ a& W
3 y: r" Q& r  o2 f4 e" ~( B0 j5 A
) m) d% v4 ^' e3 \' B5 |# v+ E5 U7 K+ A
  k( B! F& g" c4 B. b$ S* P
( [: F; ], Q; M$ p; U; r
" v! T8 ]) ?1 [" R- C1 j* n! F5 c: O( }! h9 t
+ W% p7 B* }2 n8 q% Z
  1. ' v  a% ~& u8 j* l! F) `; h
  2. int trimSteels::project_curves(vector<TaggedObject *>inputObjects,Plane *plane1)
    / r- @& O# |& H( Y1 g
  3. {
    4 l2 i% U) |$ n. I# H, h9 Y
  4.         int errorCode = 0;
    * s( z- w* @9 K3 m$ ?  h& U% q
  5.         try
    " V) [$ |! W9 V  ?( U( h6 L, C/ V1 k
  6.         {; m8 m) h* {# \. P& B  Y
  7.                 // createProject curves
    ) s2 [, ^& y8 G% j: Q
  8. 5 T( @5 ]* ]/ ?7 U8 o
  9.                 Features::Feature *nullFeatures_Feature(NULL);
    7 y: W6 [0 Z5 |3 Z- `! v. U% E
  10. 8 m" R0 m! ^0 k
  11.                 Features::ProjecTCurveBuilder *projectCurveBuilder1;
    7 X! `( u1 h7 c3 e! x
  12.   ?; _2 t) ^% Y0 f0 l: n+ Z
  13.                 projectCurveBuilder1 = workPart->Features()->CreateProjectCurveBuilder(nullFeatures_Feature);
    / H6 m: Y) \* \; G( Z
  14. 4 I2 ]/ c& B! K7 R! K- q8 Z
  15.                 projectCurveBuilder1->SectionToProject()->SetDistanceTolerance(DISTANCETOLERANCE);/ K, T& N" ]( d; ]8 e- o
  16. ( z6 p% s( S2 b8 A% L* N
  17.                 projectCurveBuilder1->SectionToProject()->SetChainingTolerance(CHAININGTOLERANCE);* }( Y4 w+ H, n4 W& _
  18. 0 j: N9 {4 k8 f
  19.                 projectCurveBuilder1->SectionToProject()->SetAngleTolerance(ANGLETOLERANCE);! d3 r  p* M' @4 ^5 @, l& w& }
  20. % c' C! |$ _+ J" I
  21.                 projectCurveBuilder1->SectionToProject()->SetAllowedEntityTypes(Section::AllowTypesOnlyCurves);
    4 A1 e3 {& `: \
  22. 9 w6 J0 v& j" f( q$ U, C1 ^
  23.                 projectCurveBuilder1->CurveFitData()->SetTolerance(DISTANCETOLERANCE);
    $ ~$ H% F" N; @3 ~2 ~' _
  24. ( u* R6 t' P- k$ \8 }. t. H2 b
  25.                 projectCurveBuilder1->CurveFitData()->SetAngleTolerance(ANGLETOLERANCE);
      b  D1 F: w7 u% u% X  n; U
  26. / X9 J' v# W1 Q' @& l- O: q
  27.                 int size = (int)inputObjects.size();0 H5 x$ n1 b( ?6 ^6 }0 d
  28.                 std::vector<IBaseCurve *> curves1;
    . v+ ?. u" L* o7 I5 p5 s
  29.                 for (int ii = 0 ; ii < size; ++ii)
    * x0 `- g$ V1 u# m; U9 O
  30.                 {
    : Y! Q: N. o# }. u. s& j: W9 M# D
  31.                         curves1.push_back(dynamic_cast<IBaseCurve*>(inputObjects[ii]));; a8 x0 P' U: d% P0 P
  32.                 }
    # _# ~5 E: W. |
  33. $ k, @3 s: ^2 C/ v
  34.                 NXOpen::CurveDumbRule *curveDumbRule1;* b* K) I4 ~' l5 v/ S8 p
  35. ; O  h& C% m- {# E. ^
  36.                 curveDumbRule1 = workPart->ScRuleFactory()->CreateRuleBaseCurveDumb(curves1);$ x- @7 W4 H7 S; b0 n5 r; k
  37. 3 L# e$ x1 e/ n4 _5 V
  38.                 projectCurveBuilder1->SectionToProject()->AllowSelfIntersection(true);
    & |: a5 E6 h. X% C4 u
  39. / Y7 G& b; A' _  T5 I9 Z
  40.                 std::vector<SelectionIntentRule *> rules1(1);
    , {! S! r% u1 I; ~+ S
  41.                 rules1[0] = curveDumbRule1;
    2 Z2 r- z, d: z
  42.                 NXObject *nullNXObject(NULL);
    6 R. C: Z* X2 \) S* U
  43.                 Point3d helpPoint1(0, 0, 0);
    ) |* f" @; v% F+ x: w
  44.                 projectCurveBuilder1->SectionToProject()->AddToSection(rules1, nullNXObject, nullNXObject, nullNXObject, helpPoint1, Section::ModeCreate, false);/ D4 D" R5 Q( q* J/ o5 e
  45. : E+ O7 l$ B$ L1 S$ |
  46.                 plane1->Evaluate();
    ( O  ^. e% b" o
  47. 3 j% z& m) ?# W4 k$ C
  48.                 projectCurveBuilder1->SetPlaneToProjectTo(plane1);
    7 e2 M3 {; }4 d. G: F& s
  49. 9 Z7 w4 z1 o4 S9 k
  50.                 projectCurveBuilder1->SetGapOption(true);8 U5 _% P8 R7 u$ h; L1 |1 p
  51. 0 ~: K3 p  O, c
  52.                 projectCurveBuilder1->CurveFitData()->SetCurveJoinMethod(GeometricUtilities::CurveFitData::JoinGeneral);
    0 T+ n* I7 O8 t; o1 _
  53. 2 ?. o0 M, x9 V* y8 x. ?. p* l
  54.                 NXObject *nXObject1;0 q0 Z- _: a3 h, B7 {, a$ i% V
  55.                 nXObject1 = projectCurveBuilder1->Commit();" c, ]" |. ~! x
  56. 7 o  C& [& k" L& M; P
  57.                 projectCurveBuilder1->SectionToProject()->CleanMappingData();
    6 O- s1 C1 Q) Z/ \: R
  58. 1 B/ X2 r" @. E) F* [
  59.                 projectCurveBuilder1->Destroy();
    ; M* K3 z9 I1 J% d7 Z
  60. 0 M$ f0 e+ `5 z# [  b* l
  61.         }
    ( T: e& x( z/ |$ P3 f8 H* B
  62.         catch(exception& ex)- n6 `% Y: S( s
  63.         {8 @9 {& _4 q6 r4 D8 Q
  64.                 //---- Enter your exception handling code here ------ I, P/ [! Z: n2 [3 N
  65.                 errorCode = 1;/ b" L$ I" ]: W, q3 |
  66.                 trimSteels::theUI->NXMessageBox()->Show("Block Styler", NXOpen::NXMessageBox::DialogTypeError, ex.what());
    1 a! \  ?, E) C, \
  67.         }9 |* D0 \7 q) G, K! g6 d
  68. 2 K; B$ P1 |, X- _' n0 x  q
  69.         return errorCode;. b2 t6 R! Q/ c8 p
  70. }$ N2 W- X! w  |7 I
- |* y; O3 e5 s$ v- T. c
" ^  O4 @% p5 K2 y6 _0 M
3 t5 e$ T; |* E$ `
发表于 2014-5-15 17:18:05 | 显示全部楼层
创建完投影之后 如何能够获取投影曲线的指针呢?
发表于 2014-5-15 17:54:14 | 显示全部楼层
版主 我找到接口了
发表于 2019-4-25 18:47:55 | 显示全部楼层
学习了,高手
