[资料] 普通用户无法登陆, 而 administrator 用户组中的用户可以登
2014-8-4 09:03:36 3972 0
发表于 2014-8-4 09:03:36 | 显示全部楼层 |阅读模式
: v' x% u5 S5 S- {7 G
普通用户无法登陆, 而 administrator 用户组中的用户可以登陆 PD/PS ' N: `5 z4 U4 x$ S: T+ n0 |
9 M( \8 B+ F# t+ N2 l, @" _
症状
# ~' f" e# E8 r( H6 V0 `& k普通用户无法登陆,而 administrator 用户组中的用户可以登陆 PD/PS ! @8 T: [3 ^% P0 k: T
' x* O' ~5 u: I4 U解决方法 2 F6 ^' S7 `/ }0 U! V2 Z
请在 eMServer 和客户端做如下设置,问题就可以解决.
) W" I+ K0 s# i: U, s- I+ n7 Z0 O& X  T  l' {5 ~
eMServer
  D1 ^( w6 V( _" U- @/ V" t--------------
$ s8 x( P4 q( x8 m3 N( |& ~Control Panel - Administrative Tools - Component Services (Alternative: Start - Run: / W) k2 z2 [$ A  g6 `6 K' B) ?' B
"dcomcnfg")   O) W5 J) ~8 B1 W: s9 g
-> Console Root - Component Services - Computers - My Computer - Properties - Default & x1 O8 s4 e7 E1 y& L# c# m) [
Properties: Enable Distributed COM on this computer
9 f+ Q# n6 M1 ?6 C- v$ [6 ^& Z* ~-> Console Root - Component Services - Computers - My Computer - Properties - COM ! M+ o8 u$ J/ j: r( C7 w' ?8 j' K% K
Security - Edit Limits/Edit Defaults (all): Add "Everyone" with full access - D9 l$ I5 c. k9 A% [( q
-> Console Root - Component Services - Computers - My Computer - Stop MS DTC -> / Start 3 f( |# f8 j/ M+ K# g8 F5 O' n
MS DTC
+ j* G* I4 `1 m; S$ G. _9 U2 S-> Console Root - Component Services - Computers - My Computer - COM+
) p- C3 I7 d5 f# }8 {. iApplications                                         3 C$ w' D: d% P8 w( m/ G
-> eM-Server - Properties - Advanced: uncheck "Disable changes"   j5 G! }2 v$ M# ]+ }/ @
-> eM-Server - Properties - Identity: "This user" - Enter a (domain) user with local administration
; {4 ~4 Y: e$ ?( k$ ]. P- A# ipermissions
, [: a. D( H" u: A0 x* b; \-> Console Root - Component Services - Computers - My Computer - DCOM Config . f3 B2 I9 L% j  K: t& \0 \
-> eMSAgent - Properties - Location - Run application on this computer 6 ^% f2 K% e1 M5 K3 v+ m
-> eMSAgent - Properties - Security - Edit (3x): Add "Everyone" with full access
3 H3 N3 {! a# ^7 u: B-> eMSAgent - Properties - Identity: "This user" - Enter a (domain) user with local administration ! r& F6 H  j* _; H0 m7 S( j  Y
permissions 9 R! H' w' m7 C# z$ t. ?+ b& f
: i) ?+ P! Z/ U: z0 V
CLIENT / R( V, l' |  @: g, e+ r5 x, Y
-------------- ' @6 a, I4 P  B9 a; i1 n& L: U
-> Console Root - Component Services - Computers - My Computer - Properties % Y& o) ~+ ~8 i! E; F
--> COM Security - 2x Edit Limits, Edit Defaults - Add Everyone - All permissions for all users
% ^+ J% m; R& P-> Console Root - Component Services - Computers - My Computer - DCOM Config
' O4 T+ _9 q+ L, _" y-> eMSAgent - Properties - Location - Run application on the following computer "<eMServer>"
* U1 Y8 o2 m' i; X/ p( ^+ f-> eMSAgent - Properties - Security - 3x Customize - Edit - Add Everyone - All permissions for $ O% T, W2 J  x' G5 |6 U
all users
; u2 ?' A+ H# s  h/ m3 G) N-> eMSAgent - Properties - Identity: "This user" - Enter a (domain) user with local administration - f, a% d9 M* o1 Q2 u% {
permissions
( U' |. m* \& A/ n6 a-> eMServer - Properties - Location - Run application on the following computer "<eMServer>" & ^9 ?' {% d7 L# H! A# f
-> eMServer - Properties - Security - 3x Customize - Edit - Add Everyone - All permissions for all
  |7 S2 {3 s5 Nunsers
9 u. K" C  _% ~; W% V# u2 S-> eMServer - Properties - Identity: "This user" - Enter a (domain) user with local administration
6 b" `/ j' y3 }* |& Xpermissions (eMSAgent 和 eMServer 依赖于安装的版本. 有些版本只有一个 DCOM 服务.) & N" A9 U) ~' a* S5 z* F& x; t& c
(运行服务的用户需要是同一个用户, 包括使用同样的密码, 在服务器和客户端上。) 6 l5 |1 W% `5 _+ a
检查是否用户在 Distributed COM users 组中(Computer Management -> Local Users 0 S/ _( R  v3 C$ {$ s6 r" o
and Groups -> Distributed COM users) 1 R3 P; u8 z& y% I9 O
检查一下防火墙的设置,检查是否 Tecnomatix 应用程序 (Tune.exe) 和 eMPlanner.exe
# W. L, O. D- c" }& q0 Q被添加到防火墙的例外中去了。* @6 p; i* y- `5 w! S1 W* g
4 O. f& E3 I% i5 v  {( i  ]0 {& p
