extern DllExport void ufsta( char *param, int *returnCode, int rlen )" o+ V8 b4 t; i% x6 I
9 x6 C' w* _& }, N) f /* Initialize the API environment */
9 d, H- O% o I! k8 p" d1 j if( UF_CALL(UF_initialize()) )
' u, x) X8 i0 j# S6 ~2 [ {- G9 R- j) r" w0 P8 D
/* Failed to initialize */
# E; c: a9 ?3 Y/ k& P return;
n- E. C E# ?4 D+ H2 @ }
! s: Q! O( h3 }! p2 `* T9 f
1 d1 e+ R/ `1 @7 I' q) h /* TODO: Add your application code here */
8 D# x9 k8 y* w9 F. _ tag_t part_tag;
! Y- a4 j/ R! G* [ part_tag=UF_PART_ask_display_part() ;& c6 K( _3 h( E# [& d
int num_views;2 K5 e9 ~8 E7 p% h5 L4 |- G
char message[MAX_LINE_SIZE];
# F. c% c0 X8 @7 z' J - Q' l! J5 n z6 _8 S; @* Z8 }+ y
char drawing_name[MAX_ENTITY_NAME_SIZE]="my_drawing";
* Y( w% a d$ x/ F UF_DRAW_info_t drawing_info;
8 z( h" x/ v' s0 P& i1 O tag_t drawing_tag =NULL_TAG;3 Y0 y# ^1 N+ M$ G
tag_t view_tag=NULL_TAG;! K2 c: C& C, r" s. S+ B' r
9 ?& a# D' b# e* E. D! {" w* y tag_t front_view_tag=NULL_TAG;
. r* H+ ?" I2 ?" c4 W char *front_view_name="FRONT";
0 ]* Z, w% \8 | Q. x. ? double front_reference_point[2]={210,400};( w% q( t4 O: q$ e; k
. \7 U$ k& J4 `' t" x0 c( t' z
tag_t tri_view_tag=NULL_TAG; \( `+ k7 H i$ z" w
char *tri_view_name="TFR-TRI";
+ Z/ i6 W3 \* O8 Y: g9 F double tri_reference_point[2]={630,120};7 _0 x! ^ N) }. c3 n
( q* m; a5 }. i* d% q
UF_DRAW_proj_dir_t botton_projection_direction=UF_DRAW_project_below;4 D+ L' J; {3 ~8 G
double botton_reference_piont[2]={210,120};
( H2 N% d% M6 m tag_t botton_view_tag=NULL_TAG;1 R( @; i: ^* U3 Z% \$ o" ?$ N5 Y3 H
' e6 A. ]2 J, t: y) o9 m, U( ^ | UF_DRAW_proj_dir_t left_projection_directiom=UF_DRAW_project_left;
- C, t' O7 H9 L3 m) I double left_reference_piont[2]={630,400};
5 B- @5 g& a( `$ k: e$ q* t tag_t left_view_tag=NULL_TAG;5 I+ I9 ^* T: | G
1 y1 y* u6 \ X: c6 S; W
drawing_info.drawing_scale=1.0;
& o. x6 }2 `0 s9 E' Q" q/ y5 y drawing_info.projection_angle=UF_DRAW_THIRD_ANGLE_PROJECTION;) r& H* N3 F: G) ^# w
drawing_info.size .metric_size_code=UF_DRAW_A1;& `5 ]- E) N3 |2 P1 \
drawing_info.size_state=UF_DRAW_METRIC_SIZE;
( T, G7 j* U% ^- v* R; c" K! ]$ p drawing_info.units =UF_PART_METRIC;
9 x9 R& o* m4 `$ D: `+ V! t( e- t" }- {+ x! Q
UF_DRAW_create_drawing(drawing_name,&drawing_info,&drawing_tag);
4 ~6 S6 g5 t8 N8 Y, E UF_DRAW_open_drawing(drawing_tag);
2 r- t$ K+ E" W0 ~: O% v& z8 b4 v7 s" L& e# O+ e+ `; u8 G2 ?
UF_DRAW_view_info_t view_info;* u9 S- W2 n6 s- } I# k
UF_DRAW_initialize_view_info(&view_info);- }5 k/ T' y% j7 A; [7 \4 ?0 n
; s1 ^! ^; N' A% _ view_info.view_status=UF_DRAW_ACTIVE_VIEW;+ H2 g. b, S. _0 r+ ^
view_info.anchor_point=NULL_TAG;1 r/ v' V& p7 Q: C, o9 X8 a
view_info.view_scale=1.0;
$ Z5 I2 g, z D7 b view_info.use_ref_pt=TRUE;
' e) e( P! Y; B7 V+ v2 R4 x view_info.inherit_boundary=TRUE;
0 n- g! C. [; i- l2 J9 z5 P6 ]% F7 B9 I ~
UF_OBJ_cycle_by_name_and_type(part_tag,front_view_name,UF_view_type,TRUE,&view_tag);4 T" k" d$ O9 F) T2 x
if (view_tag!=NULL_TAG)$ |2 i6 c8 K6 w: p1 h# \
{1 {6 O/ x* ~3 x
UF_DRAW_import_view(drawing_tag,view_tag,front_reference_point,&view_info,&front_view_tag);* v2 C! Y8 W' A. X+ p
UF_DRAW_define_view_auto_rect(front_view_tag);
+ E2 |0 a, t" ?2 M/ U- O4 q }9 V; O- }9 q6 V7 I
view_tag=NULL_TAG;) t( e* |4 a+ y) z2 N- f% }8 N. N) K! }
4 N5 v9 C5 [( d. P( O, B& |( b" ^
UF_OBJ_cycle_by_name_and_type(part_tag,tri_view_name,UF_view_type,TRUE,&view_tag);" O/ ]( m R+ ~+ ^* i, ~+ N, e, m7 V
1 y/ _# b8 N2 y4 F* l {4 Q( s8 N5 }- @9 U+ f* Y
UF_DRAW_import_view(drawing_tag,view_tag,tri_reference_point,&view_info,&tri_view_tag);. H( ?0 ?+ D+ d" p7 T! t! K
UF_DRAW_define_view_auto_rect(tri_view_tag); v* S$ E9 E! }0 N$ X
7 u5 @+ i& g5 ?, U) o if (front_view_tag!=NULL_TAG)7 a1 H+ j3 g4 V: l7 ^
- `$ h: S0 K+ `! e2 _ UF_DRAW_add_orthographic_view(drawing_tag,front_view_tag,botton_projection_direction,botton_reference_piont,&botton_view_tag);
" f5 j; q* F$ F+ _7 L+ ~ UF_DRAW_define_view_auto_rect(botton_view_tag);
$ R J5 q6 Z% A. F* r }# @! t H0 S S L/ ]# F$ E- ?$ c
if (front_view_tag!=NULL_TAG)/ S. U+ n: X' u" T. z9 O
5 T! O; f# d/ `( B' A+ D2 d UF_DRAW_add_orthographic_view(drawing_tag,front_view_tag,left_projection_directiom,left_reference_piont,&left_view_tag);
$ E; I8 W! n7 f, x UF_DRAW_define_view_auto_rect(left_view_tag);
9 R7 d! ]% I* C" w8 | }
$ }1 F3 j) o0 E% l! z$ k0 Y$ \6 N. F. ~8 J
3 W$ x& w! O" N2 f% ]: B M UF_DRAW_ask_num_views(NULL_TAG,&num_views);6 [. q2 C' X2 g
UF_UI_open_listing_window();
2 q- z3 x; {2 X, @% x sprintf(message,"当前图纸共有:%d个视图 ",num_views);5 k6 E5 o) j: ~9 l
UF_UI_write_listing_window(message);
1 ]3 D( ^; O/ K
. M- ]: c9 s3 K& i8 A6 T b! v% S/ E! B+ l0 l# N5 c v) S
* q$ ~0 X0 v/ [) k V J, y! z) m
tag_t object=NULL_TAG, front_objects[6];, `5 d' w5 P6 d: Z5 f3 Y9 t8 Z
int subtype, type, count=0;
% e& b9 O) h8 x% t9 S: T. f8 k UF_VIEW_cycle_objects( front_view_tag, UF_VIEW_VISIBLE_OBJECTS, &object );
% q/ \. _8 h) v1 G while(object!=NULL_TAG)0 a& |" ^) }8 c
$ s4 U1 D6 Q) x+ j3 k' a UF_OBJ_ask_type_and_subtype (object,&type, &subtype );5 c" N' z* f& g* V& C7 X. J
if(type==UF_solid_type && subtype==UF_solid_edge_subtype )
& z$ o% I H1 T# n2 L+ g% l; }) L {
2 U" v1 F( b* W7 C& N# t# [3 W front_objects[count] = object;6 y+ F4 n% Z2 j
count++;
8 Y. L; \7 ?6 _ }% v! U9 F) y2 F# q d
7 K8 K3 T3 U! b) O- Y }
7 g0 P( @- d1 H1 J' R UF_DRF_object_t object1;
- U, U& D* R5 L7 b+ g UF_DRF_object_t object2;
' k' p" ~/ n$ D9 `9 W6 L T: _ UF_DRF_init_object_structure( &object1 );/ ^! [( @5 n, I3 H4 a
UF_DRF_init_object_structure( &object2 );
, |! K: J( r8 N& X5 V- f object1.object_tag = front_objects[ 0 ];
) T- O' i$ Q) ? O! [5 _- ^ object1.object_assoc_type = UF_DRF_end_point;1 S; r2 O4 k# z: i: H' S
object1.object_assoc_modifier = UF_DRF_first_end_point;
6 M# G* g+ r& ?+ j object1.object_view_tag = front_view_tag;
4 y2 B! G+ U. M' _ object2.object_tag = front_objects[ 1 ];
3 ^( T9 e9 o( i object2.object_assoc_type = UF_DRF_end_point;
' D9 V- n6 ]. _, X% _/ l object2.object_assoc_modifier = UF_DRF_first_end_point;
5 j X' _2 n' r, R. K7 x! i( R object2.object_view_tag = front_view_tag;) m3 W- i# t$ a0 J/ ?8 y L
UF_DRF_text_t dim_text;
* G( u1 W% S9 H* y# F1 l0 D: x! [# G dim_text.lines_app_text = 0;$ G+ M( ~# F/ u" y" H) |# \
dim_text.appended_text = NULL;3 U) u) O4 L+ @
dim_text.user_dim_text = NULL;4 z& ]4 }9 V7 f. @: G& U" e) ?
double dimension_3d_origin[ 3 ] = { 360, 400, 0.0 };
! `3 h0 ?4 p- ]6 V$ v) W$ j tag_t dimension_tag=NULL_TAG;
. ^$ \7 Q0 q! M+ e6 @ N UF_DRF_create_vertical_dim( &object1, &object2,
' U# t0 l7 r# I! O# _4 t$ I &dim_text, dimension_3d_origin, &dimension_tag ); + p/ o3 ^# \! x1 }/ e K
4 }. j* T2 e& K/ h: C7 j
# l5 m. @! p% v* ]" M! p UF_DRAW_upd_out_of_date_views(drawing_tag);
+ `; w6 x1 W, H" w /* Terminate the API environment */
+ X( v' }/ i, ]+ G3 \ UF_CALL(UF_terminate());0 l" E8 u* e$ x: K# }
