- b% j+ D5 f8 Y c8 V
" o& o2 p8 L% V/ o9 a: yNX二次开发源码分享: 报告所有的PMI显示的视图对象
) V7 t6 w( I5 r; R
$ P* n) W! D. P3 r" p. eextern "C" DllExport void ufusr(char *param, int *reTCod, int param_len)& c( u9 m* K* R4 l7 D2 e- S8 |
$ ?1 j' D! a3 m; m Session *theSession = Session::GetSession();7 Z$ j+ h( M7 s5 u) ~) o" O+ m A
UI *ui = UI::GetUI();
; }- R& c9 _9 `9 ~ Selection *sm = ui->SelectionManager();. `- A4 F4 Q9 E2 U! R% F4 ]
std::vector<Selection::MaskTriple> mask(1);! T5 ~% D$ Q. g9 k A/ l
mask[0] = Selection::MaskTriple(UF_smart_model_instance_type, 0, 0);
# E& a/ g4 Q2 u& Q5 _! e$ z std::vector<NXOpen::NXObject*> objects;3 B6 o7 E! ]8 k# ^; n) Y
unsigned int ii, jj;
% E' f) K+ C1 L Annotations::Annotation *ann;
$ t& ^; T& S9 N$ M* O: S! { std::vector<View *> views;
' n8 ?" a- @; _- m/ Y9 N NXMessageBox *mb = ui->NXMessageBox();( t9 g$ ?% T% b1 V& H
std::vector<NXString> messages;
$ H; i9 s# Z( r7 ?/ D: w/ Q( q) c) o- B$ `
d" c0 q5 P7 A Selection::Response resp = sm->SelectObjects("Select PMI notes"," o! f$ f. Y; l/ {6 P& r
"Select PMI notes", Selection::SelectionScopeWorkPart,
9 l+ P4 s2 L; W& J# l6 u Selection::SelectionActionClearAndEnableSpecific, false, false, mask,
, N# `' m0 I2 ~1 r- J objects);+ x% i [; m4 B
6 j; g, y# [' v! [0 K
1 M8 O4 R- p9 ^
if (objects.size())& g( Q& g7 n3 l8 F/ g; F
{! U Z& L1 x" o
for (ii = 0; ii < objects.size(); ii++)& e' `, l3 P3 X/ ^3 e
% F2 `1 y7 E& d, p& N) T3 n* l3 m; c4 S
, n1 r6 g+ u0 s6 v: ] /* This may fail - see PR 5872709 */
" ^) ?0 t% S# D6 P- J- r+ A0 V1 c2 e8 {7 L
! y- _( n2 e5 d6 t* C$ v2 q+ x
ann = dynamic_cast<Annotations::Annotation *>(objects[ii]);9 S6 |( j2 n. p z T# {; f+ k. F
if (ann != NULL)+ A& p6 T# e; |8 q/ y) \/ k
views = ann->GetViews();1 [: t2 V6 u2 _
else
% c$ U( S" k2 \# c: s, f9 O7 Z1 \ {
4 I* J; S# l. Z) \4 L' E mb->Show("Failure",
* a1 I( S4 y" i5 M) \9 ? NXMessageBox::DialogTypeInformation,5 x$ L& s0 i# I B# o
"dynamic_cast did not work!");' ~( O( L, q* S- z3 C" Y, K
q) B9 J% M- D( {
2 M! u7 H4 ? T3 o
/* This will work and is safe due to selection masking */
. z' r- h$ C" o6 ]$ O5 Z0 o! D
% ^( o2 i9 C, y0 o7 F1 l, a Q
. h) v" k4 S3 @5 z ann = (Annotations::Annotation *)objects[ii];
, J5 U3 F( b, h( S' x$ W views = ann->GetViews();
; a: ~! @3 M5 c- g1 Y }, L9 W9 s9 n: T3 |+ J7 c& C V
7 k0 Z- P8 v* Z! T2 r
# o# `6 d4 l$ K' g F& o if (views.size())
- d- ]8 @7 k( p; W& y# Z* P {
9 S* k% w, P% o* \, c( P for (jj = 0; jj < views.size(); jj++)+ l$ R5 I4 V- R3 b
messages.push_back(views[jj]->Name());4 T7 }+ I/ Q- x- B; m! {
0 d6 G# S# v& F9 T, |4 c- `7 d6 `, `
mb->Show("GetViews results",
7 V: |/ _+ J+ Q0 g NXMessageBox::DialogTypeInformation,3 u, J- D! c. k$ _. \
messages);
/ K# d$ C; m% r4 u4 x, w8 M) r0 D4 M, h! J
* k0 y6 N9 P+ A# N8 f3 b* B messages.clear();
# c& j9 i ]3 s' J6 V) x }' W* @) x/ |6 O. r* u0 x, n+ n0 z* W
" [0 r y5 t0 |# @$ D: K }
Y( v. U/ W# X3 K# T q' c}& @; T% e( [0 m E" p
/ v2 u' ^8 @) E; x |
