[二次开发源码] NX二次开发源码分享: 快速获取显示部件下所有的视图
2018-8-20 08:09:12 2349 0
发表于 2018-8-20 08:09:12 | 显示全部楼层 |阅读模式
, @/ M. ^$ u- @. Q5 C. M; d. u; o0 Y1 F4 M+ v0 l1 J0 \
: _  _0 M+ g9 i5 M" C, |! O比较快的方法吧,直接找属性VWLETTER
4 @: P* @9 [: s6 h) U3 K
4 V: J9 `) r& @! P
, Q$ {1 v7 Y7 F1 ^7 M4 l        For Each dwg As Drawings.DrawingSheet In theSession.Parts.Display.DrawingSheets
+ U7 I9 r% O$ W: y$ z            Echo("Drawing: " & dwg.Name.ToString)
8 |8 i5 _) ?4 x' w; p* U            For Each draftingView As Drawings.DraftingView In dwg.GetDraftingViews()
" \) C$ C: h( t$ m                If draftingView.HasUserAttribute("VWLETTER", NXObject.AttributeType.String, -1) Then
% f, e$ B- G1 G+ _; W                    Echo("    " & draftingView.Name & " - " &
' h3 O5 k6 d9 _2 |" z* v( J7 M6 @                         draftingView.GetUserAttributeAsString("VWLETTER", NXObject.AttributeType.String, -1))& P4 D# C( Q+ ?
                Else
3 u) h, U8 |0 {6 W8 P; q                    Echo("    " & draftingView.Name)' a/ p2 z3 p' q( k8 j. s
                End If  h0 Q  Q9 t2 ~+ F# w7 Z$ ]: K
            Next9 X9 O: Q1 z* \/ K  G; t( M
        Next0 l- B. {  p* p, J2 `
4 o( W9 x8 q2 f$ W; g4 ]
; y. b! b; n. Z0 g) B0 W    End Sub
9 D4 |: p& _' _
' I& R* w' n# G: X
