[二次开发源码] NX二次开发源码: 报告当前视图对象所有信息
2019-9-1 11:04:13 1720 0
发表于 2019-9-1 11:04:13 | 显示全部楼层 |阅读模式
. T; f, I9 }! y- v+ t* d- C" H
" S4 s2 j* s( k5 F
7 t  l& k& h3 E
  x7 |! e' G. t* f! h4 `6 P% N0 m  ~9 j8 ]
[mw_shl_code=applescript,true]Option Strict Off
, m. D% H8 P- v% q% sImports System  s0 o! J8 o3 A# S9 f2 @6 _9 p% y
Imports NXOpen% T- r" [# ~! m1 i$ O4 i0 ]5 v
/ H0 d/ P' ?8 \  TModule report_all_objects_visible_in_the_work_view
9 S' g+ R7 [1 q: y! v. `# M: S3 h2 r6 L$ b6 S* C
    Dim s As Session = Session.GetSession()( k  H# s, [+ Z# @. R$ ~7 Z
    Dim workPart As Part = s.Parts.Work
) K2 E+ b3 c9 t! H. e5 Z5 n- \2 _% m& R2 _) G
    Sub Main()
' u, [0 }3 S' b) \, ?9 p' R: C
) B' _8 r0 S% v+ Y/ r! a) ]        Dim visibleObjects() As DisplayableObject = workPart.Views.WorkView.AskVisibleObjects()
$ f/ l7 A" h% l0 m        s.Information.DisplayObjectsDetails(visibleObjects)8 M& @( U4 Y4 o8 k$ q* x
: X7 W' z( O9 h. a7 j0 a    End Sub
8 ~! ~) N0 b/ V, [
' j# R( V4 Z! t+ u% k: J& o; @    Public Function GetUnloadOption(ByVal dummy As String) As Integer; R7 N  h4 |7 z& R6 w
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
7 O; D' q/ `1 T, a    End Function# ~. d9 D& @/ t7 Z+ F/ w1 V& v# o
5 e* E. ^  w, n. MEnd Module[/mw_shl_code]
! D. y$ ~- j  t; U8 R" K
