, c' F# G& e# L8 v在VS2012上使用Rade 开发 Catia V5R26 的安装方法
% G0 K$ N3 L" L+ r# X+ C- r$ x
* I: G! t' G8 p; |6 m' V, I8 ?1. Install VS 2008 --> Make sure to select the 64 bit compiler tools which are not selected by default --> No need for Crystal Reports crapware. 2. Install VS2008 SP1 3. Install R25 CAA 4. Install R25 CAA SP4 5. Install R24 RADE --> Use a path without any spaces; for example C:\ProgramFiles\DS\B24RADE 6. navigate to the folder C:\ProgramFiles\DS\B24RADE\intel_a\code\bin and run the program CATVBTSetup.exe --> Select Visual Studio 2008 as the target application --> Check all the boxes --> Click Install --> Click Close 7. Install VS 2012 8. Install VS 2012 SP4 9. Install R25 RADE --> Use a path without any spaces; for example C:\ProgramFiles\DS\B25RADE --> For the environment, the sUGgested default path is OK but creat the directory first. It does not seem to be built automatically. 10. Run the program C:\ProgramFiles\DS\B25RADE\intel_a\code\bin\3DSOpenNativeAppExt2012.vsix --> Install the application 11. Run the program C:\ProgramFiles\DS\B25RADE\intel_a\code\bin\CATVBTSetup.exe --> Click the check box for IBM/Rational tools --> Select all the options --> Go 12. Start Visual Studio 2012 --> The options panel should be displayed --> Enter the path to TCk_init.bat which should be C:\ProgramFiles\DS\B25RADE\intel_a\code\command\tck_init.bat 13. Restart Visual Studio 2012 --> The tools should now be available. & j. x W2 Q3 n7 x+ D
