4 H6 W- G0 P, Z6 w数据库: 禁止重复数据插入数据库的方法,没有主键和索引
4 T* O5 r6 ]; J6 r3 D- |
/ O5 V. P" V6 N, `5 _2 ^, u直接进行硬核判断,查询是否有一致的值,因为当前表中不存在主键8 t+ B1 \% B ^! q% v0 B
+ x2 [* S2 p1 X* y, c( W. T[mw_shl_code=sql,true]INSERT INTO ingate_standardsection SELECT
5 ?+ x6 m/ o+ G+ W'扁平梯形',
4 }- `$ f! s- |'FlatTrapezoidSection.bmp',1 O9 ?& R/ Y1 k1 M" |
3.75,
, l/ q. U/ \, t! D8 H8 @50,
7 u( B b( V* z) u2 D25,
9 N6 K6 [& Y7 i1 n( T7 D10," d- `& F0 ~: J8 ]) Y- S$ {
'dddddd',0 A1 U# g' D0 `1 \) Z `4 y8 }( k- e
'udf'
: C% Z k! _- s: BFROM0 ` j: I9 u. d. E3 H$ O2 O: _
DUAL D0 ]; Z+ E: u9 N0 P' k) ^
WHERE+ I& I: w( ^$ f3 I. e
NOT EXISTS (8 g3 i" |$ h# g
SELECT
! e3 q$ R- f) s; w. i0 g 1 l; f. v3 k: c% x
FROM
' ^, ~5 G# M2 u' O4 {& `' ?; a9 {/ b ingate_standardsection - v3 n$ e& y, P
WHERE/ g; D1 c; N1 V% A H% H
section_type = '扁平梯形' . d/ Z- Y4 U5 v; u6 L/ V; o- H' R
AND section_bmp = 'FlatTrapezoidSection.bmp' 9 K8 @6 f. S) B+ a+ K( p- o4 B
AND CONCAT( section_area, '' ) = '3.75'
$ Z( V: W# o; U% a! Q) w AND CONCAT( section_dima, '' ) = '50' 1 U4 ^: G8 S7 |$ Q$ D( f6 }
AND CONCAT( section_dimb, '' ) = '25' 8 |/ k( m$ o1 E9 o/ e; T
AND CONCAT( section_dimc, '' ) = '10'
7 P4 o" D. A1 L9 b7 z( U; ^* v9 [ AND section_from = 'udf' 3 w/ t9 d" m) D# `
)' s; C7 c' Y- W0 o% \0 H! c- {
$ I# z- g* ]. m/ p [/mw_shl_code]' o# @% w; L B- T: o
