UG NX9.0 新增的ufun函数列表,可以参考使用
. |+ q. P# {2 S1 h+ P& u7 l( M- u+ R& Z' e9 Z
uc4514a: s5 q, l3 ^2 ]
UF_ASSEM_add_sequencing_view% f* A+ L( l' X; ]4 [* L
UF_ASSEM_ask_stable_id_of_instance
: M6 Z3 J8 O1 B# M# HUF_ASSEM_initialize_sequencing_keep_layout
) g9 M! O4 _. }* ~4 T5 q+ f: tUF_ASSEM_register_animation_callback
0 o1 l& ]5 z. G& ?' j" hUF_ASSEM_remove_sequencing_view
3 \# Q$ x- s9 @7 \3 f! qUF_ATTR_count_user_attributes* P1 K" z& Q3 _/ d* J6 h- m: d: w! }
UF_ATTR_delete_user_attributes
# V! G/ p* Y7 Q: YUF_ATTR_delete_user_attribute_with_title_and_type
. c1 ^+ ^! ~" C* \! z) o) xUF_ATTR_free_user_attribute_info_array
2 y% T9 I/ }5 GUF_ATTR_free_user_attribute_info_strings6 h# K! |( _, T/ a* w& X
UF_ATTR_free_user_attribute_iterator_strings
+ q1 \. h5 r6 R2 J& WUF_ATTR_get_bool_user_attribute+ @+ B4 Q4 U* e7 \$ Q5 S
UF_ATTR_get_computational_time_user_attribute% H2 H% o& ^1 ]( f$ z
UF_ATTR_get_integer_user_attribute! U9 F& `8 R, D
UF_ATTR_get_next_user_attribute
5 @% c b( [. V8 h+ ]+ T D6 HUF_ATTR_get_null_user_attribute/ v* K7 y- }0 {& U% E
UF_ATTR_get_real_user_attribute$ }& R& R5 ~( X- R1 ~
UF_ATTR_get_reference_string_of_user_attribute& {. u; n* J. X+ J( I
UF_ATTR_get_string_time_user_attribute
, m) w2 b3 P/ \: ~9 p |8 w( WUF_ATTR_get_string_user_attribute
/ \4 a4 o! S0 R, ?UF_ATTR_get_user_attribute' p* V& ?) K8 c8 w% T7 A6 k
UF_ATTR_get_user_attributes
3 W3 J4 p' A+ o7 c2 Q: KUF_ATTR_get_user_attribute_with_title_and_type- m( y* f, D! M4 q
UF_ATTR_has_user_attribute: l% J) |# V( m4 k5 O4 [% W
UF_ATTR_has_user_attribute_with_title_and_type! r; ~( Z/ h$ c9 z, b
UF_ATTR_init_user_attribute_info
^, M! Y3 G, W3 q+ ?6 AUF_ATTR_init_user_attribute_iterator$ K: @& R4 R3 f4 V- N4 X% y. ~
UF_ATTR_release_user_attribute_iterator
2 L$ [- b6 c& x8 ?7 ?+ A& s" [* MUF_ATTR_set_bool_user_attribute
' w" @7 [9 H4 g! O9 X/ q, P; AUF_ATTR_set_computational_time_user_attribute
! H# U8 R: P/ \- W4 @UF_ATTR_set_integer_user_attribute' L! M V& N: ?: k* p- |
UF_ATTR_set_null_user_attribute
4 i2 w; \) S6 x9 U9 f$ SUF_ATTR_set_real_user_attribute
& K; h* `5 N0 g# ^/ @5 x/ r, _UF_ATTR_set_reference_string_user_attribute
1 p- ^! a! I! E6 \5 O% DUF_ATTR_set_string_time_user_attribute+ j u2 J" Z9 u
UF_ATTR_set_string_user_attribute% T+ V' y; j' t: V6 C' Y4 D
UF_ATTR_set_time_string_format7 P8 c) Y" B1 n# E5 C5 m' _- \
UF_ATTR_set_user_attribute3 a& f3 P4 i4 C
UF_ATTR_set_user_attribute_locks. E: m3 w8 H# B- ?+ x* V2 O8 u
UF_ATTR_set_user_attribute_lock_with_title_and_type" n. w) r& s: `4 Z
UF_CLONE_ask_clone_related_cae( k2 k: k4 U$ R- E6 z, S
UF_CLONE_ask_clone_related_dwgs- Q, e8 I4 [/ _6 r5 f0 y
UF_CLONE_set_clone_related_cae
8 v& e1 [8 o. tUF_CLONE_set_clone_related_dwgs
6 b/ Y) \" F9 D) D2 b2 a7 aUF_DRAW_define_view_boundary1
9 ~% ~( U* d8 D' {1 @UF_FACET_ask_surface_data_for_face, R+ Q v2 ?/ J( q& \
UF_MODL_ask_feat_fail_list. J } @6 B( f; M6 Z
UF_MODL_ask_feat_warning_messages
( q' m9 s: {; o4 GUF_MODL_ask_rect_pad_parms_1
5 C" k/ m2 X4 q% {, F5 @9 VUF_MODL_create_symb_thread_2
2 C# ^" n# C1 }; r) P7 n. T4 fUF_MODL_edit_symb_thread_2! o9 Y3 ^; f+ p6 }7 x! ~
UF_MODL_record_feature_update_warnings" V* u. I. h- m: i2 F
UF_OBJ_ask_extended_type_and_subtype+ G5 s! w, o0 e W' O
UF_OBJ_cycle_by_name_and_type_extended3 ^ F- c8 @9 l8 }3 D' y
UF_OBJ_cycle_typed_objs_in_part
+ p! W( k1 r0 C, Z; g6 |/ lUF_PATH_create_level_marker" u1 ^, C6 `& K8 ?+ D. J, n
UF_SF_ask_element_type_names
$ Q- n M# w+ F; b% FUF_TABNOT_enable_automatic_update/ ?: o2 v6 b- X. b
UF_TEXT_ask_text_mode
7 n9 `# E# M' YUF_TEXT_count_characters7 X9 V" F D0 {! `6 E. \9 g2 }
UF_TEXT_truncate
& k! V9 m9 ]: ~# |; l- ^0 W+ |UF_UGMGR_validate_string: q/ K' I( x1 d! ~7 N
UF_UI_ask_ribbon_vis
3 E# G5 u6 z4 ~! ^' @$ n( |UF_UI_create_filebox_with_multiple_filters
: L7 T9 [. ~# d: {UF_UI_create_ribbon
6 ]; Q5 `8 m0 h0 W) p' y& uUF_UI_remove_ribbon
- [- e, j5 C& v9 F6 H, `6 {# L2 AUF_UI_select_TC_result_file_to_import
! f' i9 O- f3 Y! b' yUF_UI_set_ribbon_vis
/ j' h0 Z8 m9 o) lUF_UNIT_ask_measure_type_from_unit_tag
' Z8 v" g+ v! O! GUF_UNIT_ask_system_unit_tag_from_measure
* P M! F$ m7 u* z2 kUF_UNIT_ask_unit_name_from_unit_tag
* D0 l. p, U B5 BUF_UNIT_ask_unit_tag_from_unit_name8 N& ~: M/ M7 o# M2 c
UF_UNIT_convert_value
) } x* o! v# ^) F! y2 U+ D
, }: t5 S% U- ?) P& }, J) Z' P, V
8 j: C. h7 x- w& _) A* z& L u: c' d |
