[二次开发源码] UG NX二次开发源码:ufun 访问电子表格的实例
2017-3-30 16:03:49 4736 4
发表于 2014-10-5 19:21:16 | 显示全部楼层 |阅读模式
) O0 R8 Y7 B0 V4 c6 e$ m5 d4 X& ?$ Q. H# m; F$ n
访问电子表格的实例:+ ~  t' Q  Q' c) {2 r# s
$ z1 t/ |" h$ {0 j( v1 Ustatic void do_UGopen_api(void)
* v9 C& Y. P" W- ?* Z$ p{
4 B* Z" u& |1 T8 e. l    int     result;
& u* s+ G% K) i/ r' L9 }- ~" O    tag_t   part_tag = NULL_TAG;
4 f4 a+ e7 h# l7 z" y    tag_t   object   = NULL_TAG;
' h4 X  t+ n2 x    char err_message[200];
# n+ |+ |( y6 S9 a/ ]" p    part_tag = UF_ASSEM_ask_work_part();
0 S( w8 [$ X$ s1 K; d5 J    result = UF_OBJ_cycle_objs_in_part(part_tag, UF_spreadsheet_type, &object);' w# i7 `: U! s0 a5 u; R1 j1 z
    while( object != NULL_TAG )  ~8 k/ c" V5 x# @
    {0 p' p( r9 A) `- ~& l0 X" I" V
        char name[UF_OBJ_NAME_LEN+1];/ X0 w! h, ~2 p5 S( h
        char spreadname[UF_OBJ_NAME_LEN+5];
/ `0 [0 T/ F$ s        char spreadname1[UF_OBJ_NAME_LEN+5];
0 L- m& x/ f+ h& H        UF_OBJ_ask_name(object, name);
* G: p5 U* M1 n: o% [" p        strcpy(spreadname,name);" m* o& U' d# U: L. w
        strcat(spreadname,".xls");
+ k6 t, O% f9 H8 s, s        strcpy(spreadname1,"d:\\");
, a" C0 W0 S4 B( a9 A- I/ e        strcat(spreadname1,spreadname);
$ R  O, H8 J+ ~5 n        if( strcmp(name,"MODELING_SHEET") == 0 || strcmp(name,"DEFAULT_SHEET") == 0 )          ) d) p' w+ O4 g9 I" Z8 _* K
            uc1601(spreadname1, 1);! D, L9 _6 g9 @; Q) ~
        else
2 F" W3 J, `1 g& m* I            uc1601("当前Part没有电子表格", 1);& v' c1 U5 C, D  ~2 v7 s6 w- G1 @
        result = UF_XS_extract_spreadsheet(name,spreadname1);" L/ C. r" c! r' X) o& S( q: O
( ]/ W/ T: N4 k; Z/ _* O* ^
        if (result) 5 H1 |. k' b0 W/ v! E: M# W
            uc1601("抽取电子表格失败" ,1);
, {' R1 j) j) Q2 X; F/ V6 C6 y: I        uc1601("请修改Excel表", 1);
! ?/ [2 m+ b( l0 x        result = UF_XS_store_spreadsheet(name,spreadname1);
( F6 }. Q6 a6 ~8 P5 k9 Z6 Q/ B$ g, \
        if (result) 5 S8 Y( ]/ j# o0 \. B* K
             uc1601("存贮电子表格失败" ,1);
; R, X8 @0 R! K        result = UF_OBJ_cycle_objs_in_part(part_tag, UF_spreadsheet_type, &object);6 f, t/ F! ]3 }: p6 y
: U4 ]+ n9 n- k0 l7 P; D}
% ^. y9 G5 `- [8 L
: P$ O1 B, O7 o, X# n5 n: g- P
发表于 2014-10-5 23:48:05 | 显示全部楼层
这是好东东,谢谢
发表于 2014-12-4 22:38:44 | 显示全部楼层
怎么样插入数据,能不能用程序写入数据,请问怎么操作?
发表于 2014-12-9 20:56:05 | 显示全部楼层
xml_ug 发表于 2014-12-4 14:38# p5 A8 ^' b6 L" N" L' l( A
9 B( d4 u1 R5 ?+ M
插入数据 要用 MFC 相关的东东- r$ V2 w/ t# m) j
/ |$ i+ z' k' `8 {2 y9 z5 c- o
ufun没有这个接口
发表于 2017-3-30 16:03:49 | 显示全部楼层
刚看到还高兴哪,结果还得用MFC的功能插入,白高兴了
