[资料] Teamcenter 中关于 经典变量的常用 词汇 详细解释
2014-10-16 10:56:23 4748 0
发表于 2014-10-16 10:56:23 | 显示全部楼层 |阅读模式
Teamcenter 中关于 变量条件 的常用 词汇 详细解释' _! b( ?% U' Z, x6 a* b; w
. F3 ~! c& g' f. u
0 [9 I- o6 ?% ]6 l
- f) m: F# l8 t2 i
" A0 q6 R; K/ T5 k
( q- [( J& M& F! B
( a- \# d8 x% p" e5 Z( Y
Constraint
An expression that sets an option value according to the values of other options, that is, derived defaults.
Derived default
A default value that depends on a certain condition (for example, radio = stereo IF car type = GLX). A derived default is attached to an item revision but applies globally to a loaded structure.
Option default
A specific default value for an option (for example, engine = 1200). A fixed default is attached to an item revision but applies globally to a loaded structure. It can be used internally to set private from public option values or to set public option values on the child module.
Option
A parameter of variability. Options have a string type and a name.
Variant (structure)
A specific structure that is configured by applying a variant rule.
Variant condition
A condition that an engineering user sets on an occurrence to specify the option values that configure the occurrence (for example, Load IF engine = 1200). More complex condition statements may also be defined.
Variant rule
A collection of option values, typically set by a marketing user, to determine the variant of the structure to configure (for example, car type = GLS, engine = 1200, gearbox = manual). A saved variant rule is a persistent database object.
Variant rule check
A condition that specifies any option values or combinations of values that are not allowed. A variant rule check is attached to an item revision. Also called an error check.
- {1 U+ x7 E+ Y2 T- d7 V+ b
